SJD12X SERIES
Rev-1.1
www.elecsuper.com
SuperTVS –200W Transient Voltage Suppressor
1. Features
IEC61000-4-2 ESD 30KV Air,30KV contact
Low leakage current
compliance
Working voltage: 5V~220V
SOD-123F surface mount package
Solid-state silicon avalanche technology
Protects one I/O line
Lead Free/RoHS compliant.
Peak power dissipation of 1000W under
Solder reflow temperature: Pure
8/20 waveform
Tin-Sn,260-270℃
2. Application
Personal digital assistants (PDA)
Portable instrumentation
Cellular handsets & Accessories
Handhelds and notebooks
Portable devices
Digital cameras
3. Marking Information
BI- directional
UNI-directional
Marking
Marking
4. Maximum Ratings
Ratings at 25°ambient temperature unless otherwise specified
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000us waveform
PPP
200
W
Peak pulse current of at 10/1000us waveform
IPPM
See Table
A
PM(AV)
1.0
W
PPP
1000
W
Steady state power dissipation at TA=50℃
Peak pulse power at 8/20us waveform
ESD voltage (Contact discharge)
VESD
ESD voltage (Air discharge)
Storage & operating temperature range
Copyright© ElecSuper Incorporated
TSTG,TJ
Contact Us
±30
±30
-65 to 150
kV
1 / 6
SJD12X SERIES
Rev-1.1
www.elecsuper.com
5. Electrical Characteristics (TA=25℃)
Part Number
Part Number
Marking
Uni
Bi
Uni
Bi
SJD12A05L01-ES
SJD12C05L01-ES
AE
WE
SJD12A06L01-ES
SJD12C06L01-ES
AG
SJD12A6.5L01-ES
SJD12C6.5L01-ES
SJD12A07L01-ES
Reverse
Breakdown
Test
Stand off
Voltage VBR
Current
Voltage VR
(Volts) @ IT
IT
(Volts)
Maximum
Maximum
Maximum
Clamping
Peak Pulse
Reverse
Voltage VC @
Current Ipp
Ipp
Leakage IR @ ROHS2.0
VR
MIN
MAX
(mA)
(V)
(A)
(µA)
5
6.4
7
10
9.2
21.7
200
y
WG
6
6.67
7.37
10
10.3
19.4
200
y
AK
WK
6.5
7.22
7.98
10
11.2
17.9
150
y
SJD12C07L01-ES
AM
WM
7
7.78
8.6
10
12
16.7
75
y
SJD12A7.5L01-ES
SJD12C7.5L01-ES
AP
WP
7.5
8.33
9.21
1
12.9
15.5
50
y
SJD12A08L01-ES
SJD12C08L01-ES
AR
WR
8
8.89
9.83
1
13.6
14.7
25
y
SJD12A8.5L01-ES
SJD12C8.5L01-ES
AT
WT
8.5
9.44
10.4
1
14.4
13.9
y
SJD12A09L01-ES
SJD12C09L01-ES
AV
WV
9
10
11.1
1
15.4
13
10
y
SJD12A10L01-ES
SJD12C10L01-ES
AX
WX
10
11.1
12.3
1
17
11.8
5
y
SJD12A11L01-ES
SJD12C11L01-ES
AZ
WZ
11
12.2
13.5
1
18.2
11
1
y
SJD12A12L01-ES
SJD12C12L01-ES
BE
XE
12
13.3
14.7
1
19.9
10.1
1
y
SJD12A13L01-ES
SJD12C13L01-ES
BG
XG
13
14.4
15.9
1
21.5
9.3
1
y
SJD12A14L01-ES
SJD12C14L01-ES
BK
XK
14
15.6
17.2
1
23.2
8.62
1
y
SJD12A15L01-ES
SJD12C15L01-ES
BM
XM
15
16.7
18.5
1
24.4
8.2
1
y
SJD12A16L01-ES
SJD12C16L01-ES
BP
XP
16
17.8
19.7
1
26
7.69
1
y
SJD12A17L01-ES
SJD12C17L01-ES
BR
XR
17
18.9
20.9
1
27.6
7.25
1
y
SJD12A18L01-ES
SJD12C18L01-ES
BT
XT
18
1
29.2
6.85
1
y
SJD12A20L01-ES
SJD12C20L01-ES
BV
XV
24.5
1
32.4
6.17
1
y
SJD12A22L01-ES
SJD12C22L01-ES
BX
XX
22
24.4
26.9
1
35.5
5.63
1
y
SJD12A24L01-ES
SJD12C24L01-ES
BZ
XZ
24
26.7
29.5
1
38.9
5.14
1
y
SJD12A26L01-ES
SJD12C26L01-ES
CE
YE
26
28.9
31.9
1
42.1
4.75
1
y
SJD12A28L01-ES
SJD12C28L01-ES
CG
YG
28
31.1
34.4
1
45.4
4.41
1
y
SJD12A30L01-ES
SJD12C30L01-ES
CK
YK
30
33.3
36.8
1
48.4
4.13
1
y
SJD12A33L01-ES
SJD12C33L01-ES
CM
YM
33
36.7
40.6
1
53.3
3.75
1
y
SJD12A36L01-ES
SJD12C36L01-ES
CP
YP
36
40
44.2
1
58.1
3.44
1
y
SJD12A40L01-ES
SJD12C40L01-ES
CR
YR
40
44.4
49.1
1
64.5
3.1
1
y
SJD12A43L01-ES
SJD12C43L01-ES
CT
YT
43
47.8
52.8
1
69.4
2.88
1
y
SJD12A45L01-ES
SJD12C45L01-ES
CV
YV
45
50
55.3
1
72.7
2.75
1
y
SJD12A48L01-ES
SJD12C48L01-ES
CX
YX
48
53.3
58.9
1
77.4
2.58
1
y
SJD12A51L01-ES
SJD12C51L01-ES
CZ
YZ
51
56.7
62.7
1
82.4
2.43
1
y
Contact Us
2 / 6
SJD12X SERIES
Part Number
Part Number
Rev-1.1
Marking
Uni
Bi
Uni
Bi
SJD12A54L01-ES
SJD12C54L01-ES
RE
ZE
SJD12A58L01-ES
SJD12C58L01-ES
RG
SJD12A60L01-ES
SJD12C60L01-ES
RK
SJD12A64L01-ES
www.elecsuper.com
Reverse
Breakdown
Test
Stand off
Voltage VBR
Current
Voltage VR
(Volts) @ IT
IT
(Volts)
Maximum
Maximum
Maximum
Clamping
Peak Pulse
Reverse
Voltage VC @
Current Ipp
Leakage IR @
Ipp
ROHS2.0
VR
MIN
MAX
(mA)
(V)
(A)
(µA)
54
60
66.3
1
87.1
2.3
1
y
ZG
58
64.4
71.2
1
93.6
2.14
1
y
ZK
60
66.7
73.7
1
96.8
2.07
1
y
SJD12C64L01-ES
RM ZM
64
71.1
78.6
1
103
1.94
1
y
SJD12A70L01-ES
SJD12C70L01-ES
RP
ZP
70
77.8
86
1
113
1.77
1
y
SJD12A75L01-ES
SJD12C75L01-ES
RR
ZR
75
83.3
92.1
1
121
1.65
1
y
SJD12A78L01-ES
SJD12C78L01-ES
RT
ZT
78
86.7
95.8
1
126
1.59
1
y
SJD12A85L01-ES
SJD12C85L01-ES
RV
ZV
85
94.4
104
1
137
1.46
1
y
SJD12A90L01-ES
SJD12C90L01-ES
RX
ZX
90
100
111
1
146
1.37
1
y
SJD12A100L01-ES SJD12C100L01-ES
RZ
ZZ
100
111
123
1
162
1.23
1
y
SJD12A110L01-ES SJD12C110L01-ES
SE
VE
110
122
135
1
177
1.13
1
y
SJD12A120L01-ES SJD12C120L01-ES
SG
VG
120
133
147
1
193
1.04
1
y
SJD12A130L01-ES SJD12C130L01-ES
SK
VK
130
144
159
1
209
0.96
1
y
SJD12A150L01-ES SJD12C150L01-ES SM VM
150
167
185
1
243
0.82
1
y
SJD12A160L01-ES SJD12C160L01-ES
SP
VP
160
178
197
1
259
0.77
1
y
SJD12A170L01-ES SJD12C170L01-ES
SR
VR
170
189
209
1
275
0.73
1
y
Notes: For bi-directional type having VR of 10 volts and less, the IR limit is double.
Contact Us
3 / 6
SJD12X SERIES
Rev-1.1
www.elecsuper.com
6. Ratings and Characteristic Curves (TA =25℃ unless otherwise noted)
Figure 1. Peak Pulse Power Rating Curve
Figure 2. 10/1000 us Pulse Waveform
Figure 3. Capacitance vs. Reverse Voltage
Figure 4. Power Derating curve
Contact Us
4 / 6
SJD12X SERIES
Rev-1.1
www.elecsuper.com
7. Dimension (SOD-123F)
Millimeters
Inches
Dimensions
Min
Max
Min
Max
A
2.5
3.05
0.0984
0.1201
B
3.35
4.05
0.1319
0.1594
C
0.7
1.2
0.0275
0.0472
D
1.5
2
0.0591
0.0787
E
0.35
0.95
0.0138
0.0374
F
0.05
0.26
0.002
0.0102
G
H
0.70
1.35
0.0276
0.0531
8. Packaging
Part number
Component Package
Quantity
Packaging Option
Packaging Specification
SJD12XXXX
SOD-123F
3000
Tape & Reel – 8mm tape/7” reel
EIA RS-481
Contact Us
5 / 6
SJD12X SERIES
Rev-1.1
www.elecsuper.com
DISCLAIMER
ELECSUPER SUPERTVS PROVIDES TECHNICAL AND RELIABILITY DATA (INCLUDING DATASHEETS), DESIGN
RESOURCES
(INCLUDING
REFERENCE
DESIGNS),
APPLICATION
OR
OTHER
DESIGN
ADVICE,
SAFETY
INFORMATION, AND OTHER RESOURCES “AS IS” AND WITH ALL FAULTS, AND DISCLAIMS ALL WARRANTIES,
EXPRESS AND IMPLIED, INCLUDING WITHOUT LIMITATION ANY IMPLIED WARRANTIES OF MERCHANTABILITY,
FITNESS FOR A PARTICULAR PURPOSE OR NON-INFRINGEMENT OF THIRD PARTY INTELLECTUAL PROPERTY
RIGHTS.
These resources are intended for skilled developers designing with ElecSuper products. You are solely responsible for
(1) selecting the appropriate ElecSuper products for your application;
(2) designing, validating and testing your application;
(3) ensuring your application meets applicable standards, and any other safety, security, or other requirements.
These resources are subject to change without notice. ElecSuper grants you permission to use these resources only for
development of an application that uses the ElecSuper products described in the resource. Other reproduction and display of
these resources are prohibited. No license is granted to any other ElecSuper intellectual property right or to any third party
intellectual property right. ElecSuper disclaims responsibility for, and you will fully indemnify ElecSuper and its representatives
against, any claims, damages, costs, losses, and liabilities arising out of your use of these resources. ElecSuper’s products are
provided subject to ElecSuper’s Terms of Sale or other applicable terms available either on www.elecsuper.com or provided in
conjunction with such ElecSuper products. ElecSuper’s provision of these resources does not expand or otherwise alter
ElecSuper’s applicable warranties or warranty disclaimers for ElecSuper products.
Contact Us
6 / 6
很抱歉,暂时无法提供与“SJD12C15L01-ES”相匹配的价格&库存,您可以联系我们找货
免费人工找货 - 国内价格
- 10+ 0.7854 10+ 0
- 100+ 0.6204 100+ 0
- 500+ 0.4554 500+ 0
- 4000+ 0.33 4000+ 0
- 8000+ 0.297 8000+ 0
- 20000+ 0.264 20000+ 0
