AW86502STR
July 2022 V1.3
High Sensitivity Micropower Omnipolar Hall-effect Switch
General Description
High sensitive omnipolar operation.
Micropower operation.
AW86502STR is a high-sensitivity micropower
Omnipolar Hall effect switch IC. It has open-drain
outputs that can become high impedance or drive
ground, and an external pullup resistor must be
used. AW86502STR uses a hibernating clocking
system to reduce power consumption, which the
total power consumption in normal operation is
typically 0.8A with a 1.8V power source. Mainly
designed for portable devices such as laptop
computer, smartphone and bluetooth headset etc.
The supply range of AW86502STR is 1.6V to 5.5V
to support portable equipment. To minimize PCB
space, the AW86502STR has ultra small package:
SOT23-3L .
Ultra small package: SOT23-3L.
On board voltage regulator for 1.6V to 5.5V
range.
Wide operating temperature range: -40 ℃ to
85℃.
ESD (HBM) > 6KV.
fid
en
Typ 0.8A (average: VDD=1.8V).
tia
l
Features
Applications
Smartphone.
Notebook computer.
Handheld gaming consoles.
Bluetooth headset.
DV.
Contact-less switch, Level, proximity and
position switches in consumer products.
When the magnetic field strength is greater than
Bop, then the device output is pulled low; When the
magnetic field strength is less than Brp, then the
device output is pulled high; When the magnetic
field strength is between Bop and Brp, then the
device output remains in the previous state.
cC
on
aw
ini
Typical Application Circuit
VDD=1.6-5.5V
RL
C1
100nF
10V
Output
AW86502STR
GND
Figure 1 Typical Application Circuit of AW86502STR
www.awinic.com
1
Copyright © 2021 SHANGHAI AWINIC TECHNOLOGY CO., LTD
AW86502STR
July 2022 V1.3
Pin Configuration And Top Mark
AW86502STR Marking
(Top View)
OUT
GND
fid
2
3
en
0GG6
XXXX
VDD
tia
l
1
on
0GG6 - AW86502STR
XXXX – Production Tracing Code
Pin Definition
cC
Figure 2 Pin Configuration and Top Mark
NAME
DESCRIPTION
1
VDD
Power Supply
2
OUT
3
GND
aw
ini
NO
www.awinic.com
2
Output pin
Ground
AW86502STR
July 2022 V1.3
Functional Block Diagram
Bias
en
Timing Logic
OUTPUT
fid
Hall Plate
tia
Sleep/Awake
Control
l
VDD
Comparator
on
Chopper
GND
Figure 3 Functional Block Diagram
Temperature
AW86502STR
-40℃~85℃
Package
Marking
Moisture
Sensitivity Level
Environmental
Information
Delivery Form
SOT23-3L
0GG6
MSL1
ROHS+HF
3000 units/ Tape
and Reel
aw
ini
Part Number
cC
Ordering Information
www.awinic.com
3
AW86502STR
July 2022 V1.3
Detailed Functional Description
When the magnetic field strength is greater than Bop, then the device output is pulled low; When the magnetic
field strength is less than Brp, then the device output is pulled high; When the magnetic field strength is
between Bop and Brp, then the device output remains in the previous state.
OUTPUT
VDD
(Off-state)
VOH
Brpn
Turn
on
Bhy
(On-state)
VOL
Bopn
tia
(On-state)
Turn
off
en
Turn
off
Bhy
Output Voltage
Turn
on
VOH
l
(Off-state)
Brps
VOL=VSAT
Bops
fid
Magnetic Flux Density B
Figure 4 The Working Process of AW86502STR
cC
PARAMETERS
Supply Voltage
VDD Reverse Voltage VDD
Supply Current
Output Voltage
Output Current
on
Absolute Maximum Ratings(NOTE1)
RANGE
6V
-0.3v
3mA
-0.4V to VDD+0.4V
4mA
-40℃ to 85℃
Storage Temperature TSTG
-65℃ to 150℃
Junction temperature TJ
Magnetic Flux
Lead temperature (soldering 10 seconds)
-50℃ to 165℃
aw
ini
Operating Ambient Temperature TA
No limit
260°C
ESD Rating(NOTE2 3)
Human Body Model (HMB) ESD capability
Charged-device model (CDM) ESD capability
Latch-up
6kV
1.5kV
+IT: 200mA
-IT: 200mA
Test Condition: JESD78E
NOTE1: Conditions out of those ranges listed in "absolute maximum ratings" may cause permanent damages
to the device. In spite of the limits above, functional operation conditions of the device should within the ranges
listed in "recommended operating conditions". Exposure to absolute-maximum-rated conditions for prolonged
periods may affect device reliability.
NOTE2:The human body model test method: ESDA/JEDEC JS -001-2017.
NOTE3:Charge Device Model test method: ESDA/JEDEC JS-002-2018.
www.awinic.com
4
AW86502STR
July 2022 V1.3
Electrical Characteristics
Parameters Specification (VDD=3.3V supply, TA= -40 ºC to 85ºC except where otherwise specified.)
Symbol
Characteristic
Test Conditions
Min
VDD
Supply Voltage
Operating, TJ < 165°C
During awake period, TA =
Supply Current
IDD(sleep)
During sleep period, TA =
25℃,VDD=3.3V
VOL
Output low voltage(on)
IOUT =1 mA
VOH
Output high voltage(off)
IOUT = -1mA
Tawake
Awake time
(note)
Tperiod
Period
(note)
D.C.
Duty cycle
fC
Chopping Frequency
IOFF
Output Leakage Current
en
Average supply current
on
TA = 25°C, VDD = 1.8V
IDD(avg)
fid
TA = 25°C, VDD = 3.3V
VOUT = 5.5 V; Switch
state=off
cC
0.95
Max
Unit
5.5
V
1.3
mA
l
25℃,VDD=3.3V
1.6
tia
IDD(awake)
Typ
0.43
A
0.8
A
1.13
A
0.1
0.2
V
VDD0.2
VDD0.1
V
40
60
s
50
75
ms
0.08
500
kHz
0.1
A
aw
ini
Note: Maximum and minimum parameters values over operating temperature range are not tested
in production. They are guaranteed by design, characterization and process control. The magnetic
field strength (Gauss) required to cause the switch to change state (operate and release) will be
as specified in the magnetic characteristics. To test the switch against the specified magnetic
characteristics, the switch must be placed in a uniform magnetic field.
www.awinic.com
5
AW86502STR
July 2022 V1.3
Magnetic Characteristics
Magnetic Characteristics (TA=+25℃,VDD=3.3V, unless otherwise specified 1 mT=10 Gauss)
Brps (south pole to
part marking side)
Brpn (north pole to
part marking side)
Bhy (|Bopx|-|Brpx|)
Min Typ Max
VDD=1.6V to 5.5V, TA=-40℃ to +85℃
Release
30
40
18
30
42
-40
-30
-20
-42
-30
-18
10
8
-30
-20
-10
-32
-20
-8
10
l
tia
Bopn (north pole to
part marking side)
Operation
Point
Test condition
en
Bops (south pole to
part marking side)
Characteristics
Point
fid
Symbol
Hysteresis
Gauss
on
Notes: Tyoical data is at TA=+25℃, VDD=3.3V.
Unit
aw
ini
cC
Maximum and minimum parameters values over operating temperature range are not tested in production.
They are guaranteed by design, characterization and process control. The magnetic characteristics may
vary with supply voltage, operating temperature and after soldering.
www.awinic.com
6
AW86502STR
July 2022 V1.3
Typical Characteristics
AW86502STR IDD(avg) VS Temperature
2
VDD=1.6V
VDD=1.8V
l
VDD=3.3V
tia
1
en
IDD(A)
VDD=5.0V
-45
-25
-5
15
fid
55
75
95
on
Temperature(℃)
Ambient Temperature Ta[℃]
IDD vs. Ta
cC
AW86502STR IDD(avg) VS Voltage
aw
ini
IDD(A)
2
1
2
3
4
5
6
Supply Voltage(V)
Average Supply Current vs. Supply Voltage(Ta=35℃)
www.awinic.com
7
AW86502STR
July 2022 V1.3
AW86502STR Switch Point VS Temperature(VDD=1.8V)
60
40
l
Gauss(G)
BopS
tia
-60
-45
-25
-5
15
35
en
-20
55
75
BrpS
BhyS
BopN
BrpN
BhyN
95
fid
Temperature(℃)
on
Bop,Brp vs. Ta(VDD=1.8V)
AW86502STR Switch Point VS Temperature(VDD=3.3V)
cC
60
-40
-60
aw
ini
Gauss(G)
40
-45
-25
-5
BopS
BrpS
BhyS
BopN
BrpN
BhyN
15
35
55
75
95
Temperature(℃)
Bop,Brp vs. Ta(VDD=3.3V)
Figure 5 The Typical Characteristics of AW86502STR
www.awinic.com
8
AW86502STR
July 2022 V1.3
Application Information
It is recommended to connect an external capacitor of 0.1uF to VDD and GND. The noise of the injection
device can be reduced. RL is pull-up resister and the recommended value is 100KΩ.
tia
l
VDD=1.6-5.5V
RL
C1
100nF
10V
en
Output
fid
AW86502STR
GND
aw
ini
cC
on
Figure 6 The Application Circuit of AW86502STR
www.awinic.com
9
AW86502STR
July 2022 V1.3
Tape And Reel Information
TAPE DIMENSIONS
REEL DIMENSIONS
P1
P2
P0
K0
W
l
B0
tia
D1
A0
Cavity
en
A0:Dimension designed to accommodate the component width
B0:Dimension designed to accommodate the component length
K0:Dimension designed to accommodate the component thickness
W:Overall width of the carrier tape
P0:Pitch between successive cavity centers and sprocket hole
P1:Pitch between successive cavity centers
P2:Pitch between sprocket hole
D1:Reel Diameter
D0:Reel Width
fid
D0
QUADRANT ASSIGNMENTS FOR PIN 1 ORIENTATION IN TAPE
Pin 1
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
on
Sprocket Holes
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
User Direction of Feed
cC
Pocket Quadrants
Note:The above picture is for reference only. Please refer to the value in the table below for the actual size
DIMENSIONS AND PIN1 ORIENTATION
D0
(mm)
A0
(mm)
B0
(mm)
K0
(mm)
P0
(mm)
P1
(mm)
P2
(mm)
178
8.4
3.15
2.77
1.22
2
4
4
W
Pin1 Quadrant
(mm)
8
Q3
aw
ini
D1
(mm)
All dimensions are nominal
www.awinic.com
10
AW86502STR
July 2022 V1.3
Package Description
2.90±0.10
SYMM
3X(0.36~0.50)
0.14~0.2
0.45±0.15
Pin1 CORNER
2
1
2X0.95TYP
fid
0.60REF
1.90TYP
0°~8°
SIDE VIEW
cC
on
TOP VIEW
0.95±0.10
2.5±0.15
en
PKG
1.30±0.10
tia
l
3
MAX1.12
0~0.10
aw
ini
BOTTOM VIEW
www.awinic.com
Unit:mm
11
AW86502STR
July 2022 V1.3
Land Pattern Data
SYMM
tia
l
0.60TYP
en
3
PKG
cC
1
on
fid
2.90REF
2
0.80TYP
aw
ini
0.95TYP
0.05 MAX
All AROUND
1.90TYP
2.50REF
SOLDER MASK
OPENING
METAL
0.05 MIN
All AROUND
SOLDER MASK
OPENING
METAL UNDER
SOLDER MASK
SOLDER MASK DEFINED
NON SOLDER MASK DEFINED
Unit:mm
www.awinic.com
12
AW86502STR
July 2022 V1.3
Revision History
Date
Change Record
V1.0
Apr. 2021
Officially initial version
V1.1
Sep.2021
Revise current value from 0.85A to 0.8A When VDD=1.8V
V1.2
Apr. 2022
Revise the description of the output form in the General Description
V1.3
July. 2022
Chart temperature changed from -20℃ to -40℃
aw
ini
cC
on
fid
en
tia
l
Version
www.awinic.com
13
AW86502STR
July 2022 V1.3
Disclaimer
All trademarks are the property of their respective owners. Information in this document is believed to be
accurate and reliable. However, Shanghai AWINIC Technology Co., Ltd (AWINIC Technology) does not give
any representations or warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such information.
tia
l
AWINIC Technology reserves the right to make changes to information published in this document, including
without limitation specifications and product descriptions, at any time and without notice. Customers shall
obtain the latest relevant information before placing orders and shall verify that such information is current and
complete. This document supersedes and replaces all information supplied prior to the publication hereof.
en
AWINIC Technology products are not designed, authorized or warranted to be suitable for use in medical,
military, aircraft, space or life support equipment, nor in applications where failure or malfunction of an AWINIC
Technology product can reasonably be expected to result in personal injury, death or severe property or
environmental damage. AWINIC Technology accepts no liability for inclusion and/or use of AWINIC Technology
products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own
risk.
fid
Applications that are described herein for any of these products are for illustrative purposes only. AWINIC
Technology makes no representation or warranty that such applications will be suitable for the specified use
without further testing or modification.
on
All products are sold subject to the general terms and conditions of commercial sale supplied at the time of
order acknowledgement.
Nothing in this document may be interpreted or construed as an offer to sell products that is open for
acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other
industrial or intellectual property rights.
cC
Reproduction of AWINIC information in AWINIC data books or data sheets is permissible only if reproduction
is without alteration and is accompanied by all associated warranties, conditions, limitations, and notices.
AWINIC is not responsible or liable for such altered documentation. Information of third parties may be subject
to additional restrictions.
aw
ini
Resale of AWINIC components or services with statements different from or beyond the parameters stated by
AWINIC for that component or service voids all express and any implied warranties for the associated AWINIC
component or service and is an unfair and deceptive business practice. AWINIC is not responsible or liable for
any such statements.
www.awinic.com
14
