电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
1N4001WS
1N4001WS
    DIOS(迪恩思)
    SOD-323(SC-76)
    整流二极管 50V 1A SOD-323(SC-76)
1N4001WS 数据手册
1N4001WS THRU 1N4007WS Surface Mount Standard Rectifiers Features SOD-323 ● Low profile space ● Ideal for automated placement ● Glass passivated chip junctions ● Low forward voltage drop ● Low leakage current ● High forward surge capability ● High temperature soldering: 260℃/10 seconds at terminals Major Ratings and Characteristics IF(AV) 1A VRRM 50 V to 1000 V IFSM 10A IR 5 μA VF 1.15V Tj max. 125 °C Mechanical Data ● Case: SOD-323 molded plastic body over glass passivated chip ● Terminals: Solder plated, solderable per JESD22-B102 ● y Laser band denotes cathode end Polarity: Maximum Ratings & Thermal Characteristics (TA = 25 °C unless otherwise noted) Items Symbol 1N4001W 1N4002W 1N4003W 1N4004W 1N4005W 1N4006W 1N4007W A1 A7 A3 A6 A2 A4 A5 UNIT Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current at TL =90 ℃ IF(AV) 1 A Peak forward surge current 8.3 ms single half sine-wave superimposed on rated load IFSM 10 A RθJL 35 ℃/ W TJ –55 to +125 ℃ TSTG –55 to +125 ℃ (1) Thermal resistance from junction to lead Operating junction range storage temperature range Note 1: Mounted on PCB with 0.2 x 0.2” (5.0 x 5.0mm) copper pad areas. Electrical Characteristics Items (TA = 25 °C unless otherwise noted) Test conditions IF=0.5A Instantaneous forward voltage Reverse current IF=1A (2) VR=VDC TA=25℃ TA=125℃ Symbol Min VF - IR - Type Max 0.95 - 1 1.15 - 5 50 UNIT V μA Note 2: Pulse test:300μs pulse width,1% duty cycle. 1 1N4001WS THRU 1N4007WS Characteristic Curves (TA=25 ℃ unless otherwise noted) Fig.2 Maximum Non-Repetitive Peak Forward Surge Current Fig.1 Forward Current Derating Curve 1.6 10 peak Forward Surge current(A) c Average Forward Current(A) C 1.4 1.2 1.0 0.8 0.6 0.4 0.2 0.0 8 6 4 2 0 0 30 60 90 120 150 10 1 Number of Cycles 60 HZ Lead Temperature(℃) Fig.3 Typical Instantaneous Forward Characteristics Fig.4 Typicl Reverse Leakage Characteristics 10 10 Instantaneous Reverse Leakage Current(μA) Instantaneous Forward Current(A) 100 1 0.1 TJ = 100 °C 1 0.1 TJ = 25 °C 0.01 0.01 0.6 0.8 1 1.2 1.4 1.6 1.8 2 Instantaneous Forward Voltage(V) 2.2 0 20 40 60 80 100 Percent Reted Peak Reverse Voltage(%) 2 1N4001WS THRU 1N4007WS Package Outline SOD-323 0.15(0.006) 0.10(0.004) 0.6(0.024) 0.6(0.024) 0.2(0.008) 1.6(0.063) 0.6(0.024) to 0.1(0.004)max 0° 0.40(0.016) 0.25(0.010) 8° 1.15(0.045) 0.8(0.031) Cathode bar Foot print recommendation 0.45(0.018) 1.5(0.059) 1.1(0.043) 0.25(0.01) 1.95(0.077) 1.60(0.063) 2.85(0.112) 2.50(0.095) Dimensions in millimeters and (inches) 3
1N4001WS 价格&库存
很抱歉,暂时无法提供与“1N4001WS”相匹配的价格&库存,您可以联系我们找货
