FLD0503-3.3YSOT893G/TR 数据手册
FLD0503
500nA IQ, 300mA Low-Dropout Linear Regulator
Description
Features
The FLD0503 ultra-low quiescent
current regulator features low dropout
voltage and low current in the standby
mode. With less than 500nA quiescent
current at no load, the FLD0503 is
ideally suited for standby microcontrol-unit systems, especially for
always-on applications like portable,
and other battery operated systems.
The FLD0503 retains all of the
features that are common to low
dropout regulators including a low
dropout PMOS pass device, short
circuit
protection,
and
thermal
shutdown.
The FLD0503 has a 6V maximum
operating voltage limit, a 0°C to 100°
C operating temperature range, and
± 2% output voltage tolerance over
the entire output current, input voltage,
and temperature range. The FLD0503
is available in SOT89-3, SOT23-5,
and DFN1X1 surface mount packages.
VIN Range up to 6V
Output Voltage Tolerances of ±2% Over
the Temperature Range
Output Current of 300mA, Supports
Ultar Low Quiescent Current (IQ =
450mA peak Output
500nA)
Dropout Voltage Typically 400mV at
IOUT =300mA
Internal Thermal Overload Protection
Internal Short-Circuit Current Limit
Ceramic Capacitor Stable
APPLICATIONS
Portable,
Battery
Powered
Equipment
Ultra Low Power Microcontroller
Notebook computers
TYPICAL APPLICATION
Figure 1.Typicla Application for FLD0503
http://www.full-way.com/
1
IC your Idea, we see the Future
FLD0503
Figure 2.Typicla Application for FLD0503
PIN CONFIGURATION
Figure 3. Pin Assignment of FLD0503
Package SOT89-3
Figure 5. Pin Assignment of FLD0503 Package
DFN1X1
Absolute Maximum Ratings
● VIN-----------------------------0.3V to +6.5V
● Junction Temperature -----------------125℃
● Lead Temperature (Soldering, 10 sec.) -----------------------------------------------------300 ℃
● Storage Temperature-------------------------------------------------------------65℃ to 150℃
Figure 4. Pin Assignment of FLD0503
Package SOT23-5
2
FLD0503
PIN DESCRIPTION
Pin
Pin
Pin
Pin
Name
No.SOT89-3
No.SOT23-5
No.DFN1X1
VOUT
3
5
1
Output Voltage Pin
GND
2,4
2
2
Ground
VIN
1
1
4
Input Voltage pin
EN
3
3
Enable
Pin Function
FUNCTIONAL Block Diagram
ELECTRICAL CHARACTERISTICS
(VIN = VOUT + 1V, IOUT = 1mA, CIN = COUT = 1uF, TJ = 25℃, unless otherwise specified)
Paramter
Symbol
Output Voltage Accuracy
△VOUT
Line Regulation
△VLINE
Load Regulation
△VLOAD
Dropout Voltage
VDROP
Conditions
Min
-2%
mV
13
25
IOUT = 1mA to 300mA
25
40
IOUT = 100mA, VOUT = 3.3V
130
mV
IOUT = 300mA, VOUT = 3.3V
400
mV
TJ= 25℃
0.5
360
Enable high level
VENHI
0.6
Enable low level
VENLO
V
IOUT = 1mA to 150mA
ICL
Thermal Shutdown
2%
50
Current Limit
PSRR
Unit
IQ
ratio
Max
VIN = VOUT + 1V to 5.5V
Quiescent Current
Power-supply rejection
Typ
1
560
TSD
3
uA
mA
V
0.2
f = 1kHz
mV
V
60
dB
150
FLD0503
Thermal Shutdown Hy
TSDHY
TYPICAL CHARACTERISTICS
VIN = VOUT + 1V, IOUT = 1mA, VOUT = 3.3V, CIN = COUT = 1uF, TJ = 25℃, unless otherwise
specified
Fig 1. IQ vs VIN (IOUT = 0mA)
Fig 2. VOUT vs VIN (IOUT = 1mA)
Fig 3. VOUT vs Load
Fig 4. VDROP vs Load
4
FLD0503
Fig 5. VOUT vs Temperature (IOUT = 1mA)
Operating Waveforms
VIN=5V,VOUT=3.3V,TA=25°C,IOUT=300mA, unless otherwise specified
Fig 1. VIN Power ON(IOUT=0mA)
Fig 2. VIN Power ON(IOUT=300mA)
CH1:VIN,2V/Div,DC; CH2:VOUT,2V/Div,DC
CH3:IOUT,200mA/Div,DC; TIME:1ms/Div
CH3:IOUT,200mA/Div,DC; TIME:2ms/Div
5
FLD0503
Fig 3. VIN Power OFF(IOUT=0mA)
Fig 4. VIN Power OFF(IOUT=300mA)
CH3:IOUT, 200mA/Div,DC; TIME:5ms/Div
Fig 5. EN Power ON(IOUT=0mA)
Fig 6. EN Power ON(IOUT=300mA)
CH3:IOUT,200mA/Div,DC; CH4:EN,2V/Div,DC
TIME:1ms/Div
TIME:1ms/Div
Fig 7. EN Power OFF(IOUT=0mA)
Fig 8. EN Power OFF(IOUT=300mA)
6
FLD0503
TIME:5ms/Div
TIME:3ms/Div
Fig 9. Load Transient (1mA to 300mA)
Package Outline Dimensions(All dimensions in mm.)
(1) Package Type: SOT89-3
7
FLD0503
(2)Package Type: SOT23-5
(3)Package Type: DFN1X1
8
FLD0503
9
