LTP829
P-1
General Description
The LTP829 is low noise, LDO Voltage Regulators with enable function that output voltages of 3.3 V,
5 V. These characteristics, combined with low noise and good PSRR with low dropout voltage, make
this device ideal for portable consumer applications. The LTP829 can operate with up to 20 V input.
The Devices are available in SOT-223, ESOP-8, DFN2×2-6, DFN3×3-8 and SOT89-3.
Features
Wide Input Voltage Range: up to 20 V
Max Output Current: 1 A
Output Voltage Accuracy: ±2%
Adjustable Output Voltage Options: VFB = 0.64 V
Fixed Output Voltage: from 3.3 V, 5 V
Other Output Voltage Options Available on Request
Standby Current: 160 µA (Typical)
Dropout Voltage: 0.5 V at 1A when VOUT ≥ 2 V
High Ripple Rejection: 80 dB at 1 kHz
Available Packages: SOT-223, ESOP-8, SOT89-3, DFN2×2-6, DFN3×3-8
Applications
Consumer and Industrial Equipment Point of Regulation
Switching Power Supply Post Regulation
Battery Chargers
Hard Drive Controllers
Order Information
Model
LTP829
Package
Ordering Number Note1
Packing Option
SOT223
LTP829-xxXT3
Tape and Reel, 2500
DFN2×2-6
LTP829-ADJF6
Tape and Reel, 3000
DFN3×3-8
LTP829-ADJF8
Tape and Reel, 3000
ESOP-8
LTP829-ADJS8
Tape and Reel, 4000
SOT89-3
LTP829-xxXT4
Tape and Reel, 1000
Note: xx stands for output voltage, e.g. if xx = 18, the output voltage is 1.8 V; if xx = 30, the output voltage is 3.0 V. Adjustable
Output Voltage, Rang: 0.6 V to 3.6 V.
CAUTION: These devices are sensitive to electrostatic discharge; follow proper IC Handling Procedures.
Linearin and designs are registered trademarks of Linearin Technology Corporation.
©Copyright Linearin Technology Corporation. All Rights Reserved.
All other trademarks mentioned are the property of their respective owners.
FN1620-2L.3 — Data Sheet
20 V Input Voltage, 1 A, High Speed LDOs
LTP829
P-2
Pin Configuration(Top View)
1
2
3
1
2
3
GND
OUT
IN
GND
IN
OUT
SOT-223
EN
1
8
GND
IN
2
7
GND
OUT
3
6
GND
FB
4
5
GND
SOT89-3
OUT
1
FB
2
GND
3
GND
6
IN
5
NC
4
EN
ESOP-8
IN
1
IN
2
OUT
3
OUT
4
DFN2×2-6
GND
8
EN
7
GND
6
FB
5
NC
DFN3×3-8
Pin Function
Package
SOT-223 DFN2×2-6 DFN3×3-8
1
SOT89-3
3
7
1
2
1
3, 4
3
6
1, 2
4
8
2
6
5
5
Exposed
Pad
Exposed
Pad
ESOP-8
Symbol
Function
5,6,7,8
GND
3
3
OUT
2
2
IN
1
EN
Enable pin.
FB
This pin is used as an input to the control loop
error amplifier and is used to set the output
voltage of the LDO.
NC
Not connect.
4
Exposed
Pad
GND
Ground.
Output pin.
Power supply input pin.
Exposed thermal pad. Connect to GND for best
thermal performance.
LTP829
P-3
Block Diagram
VIN
VOUT
Current
Limit
MOSFET
Driver
Thermal
Shutdown
RLOW
Adaptive
Bias
VEN
Band Gap
FB
Logic
GND
Functional Description
Enable
The LTP829 delivers the output power when it is set to enable state. When it works in disable state, there is no
output power and the operation quiescent current is almost zero. The enable pin (EN) is active high.
Shutdown
Turn off the device by forcing the EN pin to drop below VEN(LO). If shutdown capability is not required, connect EN
to IN. The LTP829 has an internal pulldown MOSFET that connects an RPULLDOWN resistor to ground when the
device is disabled. The discharge time after disabling depends on the output capacitance (COUT) and the load
resistance (RL) in parallel with the pulldown resistor (RPULLDOWN). Formula 1 calculates the time constant:
τ = (RPULLDOWN × RL) / (RPULLDOWN + RL)
(1)
Over-Temperature Protection
The over-temperature protection function will turn off the P-MOSFET when the junction temperature exceeds
150ºC (typical). Once the junction temperature cools down by approximately 20ºC the regulator will automatically
resume operation.
Current-Limit Protection
The LTP829 provides current limit function to prevent the device from damages during over-load or shortedcircuit condition. This current is detected by an internal sensing transistor.
LTP829
P-4
Recommended Operating Condition
Parameter
Symbol
Rating
Input Voltage
VIN
up to 20
V
Output Current
IOUT
0 to 1
A
TA
-40 to 85
°C
CIN
1 to 10
μF
COUT
1 to 10
μF
ESR
5 to 100
mΩ
Operating Ambient Temperature
Effective Input Ceramic Capacitor
Value(1)
Value(1)
Effective Output Ceramic Capacitor
Input and output Capacitor Equivalent Series
Resistance(ESR)
Unit
Notes: (1) The capacitor is a chip capacitor, and larger capacitance value is required if electrolytic capacitor is used.
Absolute Maximum Ratings
Parameter
IN pin to GND
Rating
pin(1)
Unit
-0.3 to 24
V
OUT pin to GND pin
0.65 to 6
V
Chip Enable Input
-0.3 to 22
V
Maximum Junction Temperature
150
°C
Storage Temperature
-65 to 150
°C
ESD (HBM mode)
Latch up Current Maximum Rating(3)
Thermal Resistance (Junction to
Ambient)(4)
HBM(2)
±2000
CDM(2)
±1500
V
mA
200
SOT223
80
SOT89-3
120
ESOP-8
60
DFN2×2-6
105
DFN3×3-8
65
°C/W
Notes:
Stresses beyond those listed under “ABSOLUTE MAXIMUM RATINGS” may cause permanent damage to the device. These are
stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated in the
operational sections of the specifications is not implied. Exposure to absolute maximum rating conditions for extended
periods may affect device reliability.
(1) Refer to ELECTRICAL CHARACTERISTIS and APPLICATION INFORMATION for Safe Operating Area.
(2) This device series incorporates ESD protection and is tested by the following methods: ESD Human Body Model tested
per EIA/JESD22-A114. CDM tested per JESD22-C101.
(3) Latch up Current Maximum Rating tested per JEDEC78.
(4)This particular frame decreases the total thermal resistance of the package and increases its ability to dissipate power
when an appropriate area of copper on the printed circuit board is available for heat-sinking.
Caution
This integrated circuit can be damaged by ESD if you don’t pay attention to ESD protection. LINEARIN
recommends that all integrated circuits be handled with appropriate precautions. Failure to observe proper
handling and installation procedures can cause damage. ESD damage can range from subtle performance
degradation to complete device failure. Precision integrated circuits may be more susceptible to damage
because very small parametric changes could cause the device not to meet its published specifications.
LINEARIN reserves the right to make any change in circuit design, specification or other related things if
necessary without notice at any time. Please contact LINEARIN sales office to get the latest datasheet.
LTP829
P-5
Electrical Characteristics
(VIN= VOUT +1 V, IOUT=10 mA, Ta= 25°C, CIN= COUT =1.0 uF, unless otherwise noted)
Parameter
Symbol
Test Conditions
Min. Typ. Max.
Input Voltage Operation Range VIN(1)
TA=25ºC
-2%
+2%
-40ºC ≤ TA ≤ 85ºC
-3%
+3%
Output Voltage
VOUT
Reference Voltage
VFB
TA=25ºC
0.64
Line Regulation
RegLINE
2.5 V ≤ VIN ≤ 20 V, IOUT = 10 mA
0.05 0.2
Dropout Voltage
VDROP(3)
Unit
V
V
V
0.65 V ≤ VOUT < 1V
2500
-40ºC ≤ TA ≤ 125ºC 1 V ≤ VOUT < 1.5 V
VIN ≥ 2.5 V
1.5 V ≤ VOUT < 2 V
IOUT = 1 A
2 V ≤ VOUT < 2.5 V
2000
1000
%VOUT
mV
800
2.5 V ≤ VOUT < 5.5 V
450 598
Load Regulation
RegLOAD
1 mA ≤ IOUT ≤ 800 mA,
VIN = VOUT + 1 V
Current Limit
ILMT
VIN = VOUT + 1 V
1.04 1.3
Short Circuit Current Limit
ISHORT
VOUT = 0 V
350
Quiescent Current
IQ
IOUT = 0 mA
160
190
μA
Standby Current
IQ_OFF
VEN = 0 V, TA = 25ºC
0.1
1
μA
EN Pin Threshold Voltage
VENH
EN Input Voltage “H”
VENL
EN Input Voltage “L”
EN Pin Current
IEN
VEN ≤ VIN ≤ 20 V
1
f = 1 kHz
VIN = VOUT + 1 V, IOUT
f = 100 kHz
= 50 mA,
f = 1 MkHz
80
70
Power Supply Rejection Ratio PSRR
40
mV
A
mA
1.2
V
0.4
V
μA
dB
65
Active Output Discharge
Resistance (A option only)
RLOW
VIN = 4 V, VEN = 0 V
70
Ω
Thermal Shutdown
Temperature
TSD
150
ºC
Thermal Shutdown Hysteresis TSDH
Increasing from TA = +25ºC (2)
25
ºC
Output Noise Voltage
VIN = VOUT + 1 V, IOUT = 1 mA,
f = 10 Hz to 100 kHz,
VOUT = 3 V, COUT = 1 μF (2)
60
µVRMS
eN
Notes:
(1) Here VIN means internal circuit can work normal. If VIN < VOUT, Output voltage follow VIN (IOUT = 1 mA), circuit is safety.
(2) Guaranteed by design and characterization. not a FT item.
(3) VDROP FT test method: test the VOUT voltage at VSET + VDROP(MAX) with 1A output current.
P-6
LTP829
Typical Performance Characteristics
Note: Typical Characteristics are intended to be used as reference data; they are not guaranteed.
TON and TOFF
(VIN = VOUT + 1 V, IOUT = 0 mA, CIN = COUT = 10 μF)
Turn On VS. EN Voltage (VOUT = 1.8 V, IOUT = 0 mA)
Turn Off VS. EN Voltage (VOUT = 1.8 V, IOUT = 0 mA)
Turn On VS. EN Voltage (VOUT = 3.3 V, IOUT = 0 mA)
Turn Off VS. EN Voltage (VOUT = 3.3 V, IOUT = 0 mA)
Turn On VS. EN Voltage (VOUT = 5.0 V, IOUT = 0 mA)
Turn Off VS. EN Voltage (VOUT = 5.0 V, IOUT = 0 mA)
P-7
LTP829
Input Transient Response
(VIN = VOUT + 1 V, IOUT = 10 mA, COUT = 10 μF, t = 10 μs, VIN jump from 6 V to 18 V)
Input Transient Response (VOUT = 1.8 V, IOUT = 1 mA)
Input Transient Response (VOUT = 3.3 V, IOUT = 1 mA)
Input Transient Response (VOUT = 5.0 V, IOUT = 1 mA)
P-8
LTP829
Load Transient Response
(VIN = VOUT + 1 V, t = 10 μs, IOUT jump from 1 mA to 1000 mA)
Load Transient Response (VOUT = 1.8 V, IOUT = 1~1000 mA)
Load Transient Response (VOUT = 3.3 V, IOUT = 1~1000 mA)
Load Transient Response (VOUT = 5.0 V, IOUT = 1~1000 mA)
LTP829
P-9
Temperature Characteristics
Supply Current VS. Temperature
Output Voltage VS. Temperature (VOUT = 1.8V)
Shutdown Current VS. Temperature
Output Voltage VS. Temperature (VOUT = 3.3V)
Output Voltage VS. Temperature (VOUT = 5.0V)
P-10
LTP829
PSRR
(VIN = VOUT + 1 V, IOUT = 0 mA, COUT = 10 μF)
PSRR VS. IOUT (VOUT = 1.8 V, IOUT = 50 mA)
PSRR VS. IOUT (VOUT = 1.8 V, IOUT = 500 mA)
PSRR VS. IOUT (VOUT = 3.3 V, IOUT = 50 mA)
PSRR VS. IOUT (VOUT = 3.3 V, IOUT = 500 mA)
PSRR VS. IOUT (VOUT = 5.0 V, IOUT = 50 mA)
PSRR VS. IOUT (VOUT = 5.0 V, IOUT = 500 mA)
LTP829
P-11
Application Circuits
VIN
IN
VOUT
OUT
R1
CIN
EN
GND
FB
COUT
R2
Input and Output Capacitor Selection
The LTP829 requires an output capacitance of 1μF or larger for stability. Use X5R-type and X7R-type ceramic
capacitors because these capacitors have minimal variation in value and equivalent series resistance (ESR) over
temperature. When choosing a capacitor for a specific application, pay attention to the DC bias characteristics for
the capacitor. Higher output voltages cause a significant derating of the capacitor. Although an input capacitor is
not required for stability, good analog design practice is to connect a capacitor from IN to GND. Some input
supplies have a high impedance, thus placing the input capacitor on the input supply helps reduce the input
impedance. This capacitor counteracts reactive input sources and improves transient response, input ripple, and
PSRR. If the input supply has a high impedance over a large range of frequencies, several input capacitors can be
used in parallel to lower the impedance over frequency. Use a higher-value capacitor if large, fast, rise-time load
transients are anticipated, or if the device is located several inches from the input power source.
Application of Electrolytic Capacitor
If the electrolytic capacitor should be used as input and output capacitor, the capacitance of the capacitor must be
greater.
Enable
The LTP829 has an EN pin to turn on or turn off the regulator, When the EN pin is in logic high, the regulator will
be turned on. The shutdown current is almost 0μA typical. The EN pin may be directly tied to VIN to keep the part
on. The Enable input is CMOS logic and cannot be left floating.
Setting the Output Voltage
The LTP829 develops a 0.64 V reference voltage, VFB, between the output and the adjust terminal. This voltage is
applied across resistor R1 to generate a constant current. The current IADJ from the ADJ terminal could introduce
DC offset to the output. Because, this offset is very small (about 0.1 μA) , it can be ignored. The constant current
then flows through the output set resistor R2 and sets the output voltage to the desired level. Equation 2 is used
for calculating VOUT:
VOUT = VFB × (1 + R1/R2)
(2)
Although IADJ is very small, R1 + R2 should be limited to less than 100kΩ for optimum performance.
Dropout Voltage
The LTP829 uses a PMOS pass transistor to achieve low dropout. When (VIN - VOUT) is less than the dropout voltage
(VDO), the PMOS pass device is in the linear region of operation and the input-to-output resistance is the RDS(ON) of
the PMOS pass element. VDO scales approximately with output current because the PMOS device behaves like a
resistor in dropout mode. As with any linear regulator, PSRR and transient response degrade as (VIN - VOUT)
approaches dropout operation.
P-12
LTP829
Thermal Shutdown
Thermal shutdown protection disables the output when the junction temperature rises to approximately 150ºC
Disabling the device eliminates the power dissipated by the device, allowing the device to cool. When the
junction temperature cools to approximately 125ºC, the output circuitry is again enabled. Depending on power
dissipation, thermal resistance, and ambient temperature, the thermal protection circuit may cycle on and off.
This cycling limits regulator dissipation, protecting the LDO from damage as a result of overheating. Activating
the thermal shutdown feature usually indicates excessive power dissipation as a result of the product of the
(VIN - VOUT) voltage and the load current. For reliable operation, limit junction temperature to 125ºC maximum.
Thermal Considerations
For continuous operation, do not exceed absolute maximum junction temperature. The maximum power
dissipation depends on the thermal resistance of the IC package, PCB layout, rate of surrounding airflow, and
difference between junction and ambient temperature. The maximum power dissipation can be calculated by
the following formula :
PD(MAX) = (TJ(MAX) - TA) / θJA
where TJ(MAX) is the maximum junction temperature, TA is the ambient temperature, and θJA is the junction to
ambient thermal resistance. For recommended operating condition specifications the maximum junction
temperature is 125ºC and TA is the ambient temperature. The junction to ambient thermal resistance, θJA, is
layout dependent. The maximum power dissipation depends on the operating ambient temperature for fixed
TJ(MAX) and thermal resistance, θJA.
LTP829
P-13
Package Dimension
SOT-223
θ
D
L
E
E1
L
D1
c
e
b
A
A2
A1
e1
Unit: mm
Symbol
A
A1
A2
b
c
D
D1
E
E1
e
e1
L
θ
Dimensions In Millimeters
Max
1.800
0.100
1.700
0.820
0.350
6.400
3.100
7.070
3.700
2.300BSC
4.500
4.700
0.900
1.150
0°
10°
Min
1.520
0.000
1.500
0.660
0.250
6.200
2.900
6.830
3.300
LTP829
P-14
Package Dimension
ESOP-8
D
b
E1
E
E2
L
D1
θ
c
Symbol
A
A2
A1
e
Unit: mm
Min
Max
A
1.750
A1
0.100
0.225
A2
1.300
1.500
b
0.390
0.480
c
0.210
0.260
D
4.700
5.100
D1
3.200
3.400
E
5.800
6.200
E1
3.700
4.100
E2
2.300
2.500
e
1.270BSC
L
0.500
0.800
θ
0°
8°
LTP829
Package Dimension
SOT-89
D
A
L
E
E1
D1
e
c
b
e1
Unit: mm
Symbol
Min
Max
A
1.400
1.600
b
0.320
0.520
c
0.350
0.440
D
4.400
4.600
D1
1.550REF
E
3.940
4.250
E1
2.300
2.600
e
1.500BSC
e1
3.000BSC
L
0.900
1.200
P-15
LTP829
P-16
Package Dimension
DFN3×3-8
D
e
N8
L
b
k
E
E1
D1
N1
A
A1
A2
N4
Unit: mm
Symbol
Min
Max
A
0.700
0.800
A1
0.000
0.050
A2
0.203REF
b
0.180
0.300
D
2.900
3.100
D1
2.200
2.400
E
2.900
3.100
E1
1.400
1.600
e
0.650BSC
L
0.375
k
0.200
Procedures. Linearin and designs are registered trademarks of Linearin Technology Corporation.
© Copyright Linearin Technology Corporation. All Rights Reserved.
0.575
LTP829
P-17
Package Dimension
DFN2×2-6
D
b
L
e
k
E
E1
D1
A
A1
A2
N1
Unit: mm
Symbol
Min
Max
A
0.700
0.900
A1
0.000
0.050
A2
0.203REF
b
0.180
0.300
D
1.900
2.100
D1
1.100
1.300
E
1.900
2.100
E1
0.600
0.800
e
0.650BSC
L
0.250
k
0.200
0.450
