电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
RS3005-3.0YE3
RS3005-3.0YE3
    RUNIC(润石)
    SOT89-3
RS3005-3.0YE3 数据手册
RS3007 300mA LOW POWER LDO FEATURES  DESCRIPTION Low Quiescent Current IQ: The RS3007 series is a Low Dropout Linear Regulator designed by CMOS technology. Which can provide 300mA output current. The device allows input voltage as high as 45V.It is very suitable for multi-cell battery systems, bus voltage power supply systems, Vehicle battery power supply system and other high DC voltage systems. Wide input voltage can make it well withstand the impact of surge voltage and ensure the stability of output voltage. 3uA Typical at Light Loads  300mA Nominal Output Current  Low Dropout Voltage  Low Temperature Coefficient  High Input Voltage (up to 45V)  Output Voltage Accuracy: ±1%/±2%  Fixed Output Voltage: 1.8V, 2.5V, 3.0V, 3.3V and 5.0V  Over temperature protection and overcurrent protection function  SOT23-3, SOT23-5、SOT89-3L and SOT223 Packages The RS3007 series only consume 3uA (typical), Which is particularly important in battery power system, can reduce the standby power consumption of the whole system. The RS3007 is available in Green SOT23-3, SOT235 , SOT89-3L and SOT223 a variety of packages, for the different application’s requirements. APPLICATIONS  Smart Power Network Equipment  Portable Power Tools   BMS systems  Power Meter/Instrument  White Goods  Vehicle-mounted system  Fire fighting / security equipment  Consumer products Device Information (1) PART NUMBER Motor control system/Industrial control system RS3007 (1) PACKAGE BODY SIZE (NOM) SOT23-3(3) 1.60mm×2.92mm SOT23-5(5) 1.60mm×2.92mm SOT89-3L(3) 2.45mm×4.50mm SOT223(3) 3.50mm x 7.00mm SOIC-8(8) 4.90mm x 3.90mm For all available packages, see the orderable addendum at the next page of the data sheet. Typical Application Schematic VIN VIN CIN 1μF VOUT VOUT RS3007 COUT 1μ F GND REV A.3 1 / 17 www.run-ic.com RS3007 Revision History Note: Page numbers for previous revisions may different from page numbers in the current version. VERSION Change Date A.1 2020/03/16 A.2 2020/06/03 A.3 2020/09/11 Change Item Initial version completed 1) Added part-number to ordering information table 2) Added SOT223(L Type) package 1) Added part-number to ordering information table 2) Added SOP8 package 3) Added 3.0 and 5.0 VOUT Accuracy of 1% 2 / 17 www.run-ic.com RS3007 Pin Configuration and Functions (Top View) VIN VOUT NC 3 5 4 SEXX xxxx SEXX xxxx 1 2 1 2 3 1 GND VOUT VIN GND EN VIN SOT23-3 SOT23-5 VIN GND SEXXL xxxx SEXX xxxx 1 2 GND VIN 3 1 2 VOUT VOUT SOT89-3L(L-Type) GND 2 3 GND VOUT SOT223 SEXXL xxxx 3 VIN SOT89-3L 1 2 3 GND VOUT VIN SOT223(L-Type) NOTE: XX indicate Output Voltage, xx indicate Data Code For example: SE33 (VOUT=3.3V) PIN DESCRIPTION PIN NAME SOT23-3 SOT23-5 GND 1 2 SOT89-3L (L-Type) 1 2 SOT223 (L-Type) 1 VOUT 2 5 3 1 2 3 VIN 3 1 2 3 3 1 EN / 3 / / / / NC / 4 / / / / SOT89-3L 3 / 17 SOT223 2 FUNCTION Ground Regulator Output. Recommended output capacitor range:1μF to 10μF. Regulator Input. At least 1μF supply bypass capacitor is recommended. Enable pin. EN pin voltage is higher than VEN(H) enable output and lower than VEN (L) close output. No internal connection www.run-ic.com RS3007 Pin Configuration and Functions (Top View) EN 1 8 GND VI N 2 7 GND VO UT 3 6 GND NC 4 5 GND SOIC-8(SO P8) PIN DESCRIPTION NAME PIN SOIC-8(SOP8) EN 1 VIN 2 VOUT 3 NC 4 GND 5,6,7,8 FUNCTION Enable pin. EN pin voltage is higher than VEN(H) enable output and lower than VEN (L) close output. Regulator Input. At least 1μF supply bypass capacitor is recommended. Regulator Output. Recommended output capacitor range:1μF to 10μF. No internal connection Ground 4 / 17 www.run-ic.com RS3007 PACKAGE/ORDERING INFORMATION PRODUCT RS3007-1.8 RS3007-2.5 RS3007-3.0 RS3007-3.3 RS3007-5.0 ORDERING NUMBER VOUT(V) VOUT Accuracy PACKAGE LEAD PACKAGE MARKING(1) RS3007-1.8YF3 1.8 ±2% SOT23-3 SE18 Tape and Reel,3000 RS3007-1.8SYF5 1.8 ±2% SOT23-5 SE18 Tape and Reel,3000 RS3007-1.8YE3L 1.8 ±2% SOT89-3L L-Type SE18L Tape and Reel,1000 RS3007-1.8YE3 1.8 ±2% SOT89-3L SE18 Tape and Reel,1000 RS3007-2.5YF3 2.5 ±2% SOT23-3 SE25 Tape and Reel,3000 RS3007-2.5SYF5 2.5 ±2% SOT23-5 SE25 Tape and Reel,3000 SE25L Tape and Reel,1000 PACKAGE OPTION RS3007-2.5YE3L 2.5 ±2% SOT89-3L L-Type RS3007-2.5YE3 2.5 ±2% SOT89-3L SE25 Tape and Reel,3000 RS3007-3.0YF3 3.0 ±2% SOT23-3 SE30 Tape and Reel,3000 RS3007-3.0SYF5 3.0 ±2% SOT23-5 SE30 Tape and Reel,3000 RS3007-3.0YE3L 3.0 ±2% SOT89-3L L-Type SE30L Tape and Reel,1000 RS3007-3.0YE3 3.0 ±2% SOT89-3L SE30 Tape and Reel,1000 RS3007-3.0YD3 3.0 ±2% SOT223 SE30 Tape and Reel,2500 SE30L Tape and Reel,2500 RS3007-3.0YD3L 3.0 ±2% SOT223 L-Type RS3007-3.3YF3 3.3 ±2% SOT23-3 SE33 Tape and Reel,3000 RS3007-3.3SYF5 3.3 ±2% SOT23-5 SE33 Tape and Reel,3000 RS3007-3.3YE3L 3.3 ±2% SOT89-3L L-Type SE33L Tape and Reel,1000 RS3007-3.3YE3 3.3 ±2% SOT89-3L SE33 Tape and Reel,1000 RS3007-3.3YD3 3.3 ±2% SOT223 SE33 Tape and Reel,2500 RS3007-3.3YD3L 3.3 ±2% SOT223 L-Type SE33L Tape and Reel,2500 RS3007-5.0YF3 5.0 ±2% SOT23-3 SE50 Tape and Reel,3000 RS3007-5.0SYF5 5.0 ±2% SOT23-5 SE50 Tape and Reel,3000 SE50L Tape and Reel,1000 RS3007-5.0YE3L 5.0 ±2% SOT89-3L L-Type RS3007-5.0YE3 5.0 ±2% SOT89-3L SE50 Tape and Reel,1000 RS3007-5.0YD3 5.0 ±2% SOT223 SE50 Tape and Reel,2500 RS3007-5.0YD3L 5.0 ±2% SOT223 L-Type SE50L Tape and Reel,2500 5 / 17 www.run-ic.com RS3007 PRODUCT RS3007-3.0 RS3007-3.3 RS3007-5.0 ORDERING NUMBER VOUT(V) VOUT Accuracy PACKAGE LEAD PACKAGE MARKING(1) PACKAGE OPTION RS3007-3.0AYF3 3.0 ±1% SOT23-3 SE30 Tape and Reel,3000 RS3007-3.0ASYF5 3.0 ±1% SOT23-5 SE30 Tape and Reel,3000 RS3007-3.0AYK 3.0 ±1% SOIC-8 SE30 Tape and Reel,4000 RS3007-3.3AYF3 3.3 ±1% SOT23-3 SE33 Tape and Reel,3000 RS3007-3.3ASYF5 3.3 ±1% SOT23-5 SE33 Tape and Reel,3000 RS3007-3.3AYK 3.3 ±1% SOIC-8 SE33L Tape and Reel,4000 RS3007-3.3AYD3 3.3 ±1% SOT223 SE33 Tape and Reel,2500 RS3007-5.0AYF3 5.0 ±1% SOT23-3 SE50 Tape and Reel,3000 RS3007-5.0ASYF5 5.0 ±1% SOT23-5 SE50 Tape and Reel,3000 RS3007-5.0AYK 5.0 ±1% SOIC-8 SE50 Tape and Reel,4000 NOTE: 1.XXXX=Date Code and Vendor Code. 2.There may be additional marking, which relates to the lot trace code information(data code and vendor code) , the logo or the environmental category on the device. 6 / 17 www.run-ic.com RS3007 Specifications Absolute Maximum Ratings over operating free-air temperature range (unless otherwise noted) (1)(2) MIN MAX UNIT V VIN Input voltage -0.3 55 VEN VEN voltage range -0.3 VIN TJ PN Junction temperature PD Continuous power dissipation (3) -40 175 Internal thermal protection temperature limit -55 150 Tstg (1) (2) (3) Storage temperature range V °C W °C Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. All voltages are with respect to the GND pin. Internal thermal shutdown circuitry protects the device from permanent damage. The actual chip output current is subject to the input-output voltage difference, ambient temperature and PCB heat dissipation design. ESD Ratings V(ESD) Electrostatic discharge VALUE UNIT Human-body model (HBM) ±4000 V Charge device model (CDM) ±1500 V Recommended Operating Conditions over operating free-air temperature range (unless otherwise noted) (1) MIN MAX UNIT VIN Input supply voltage 2.5 45 V IOUT Output current 0 300 mA CIN Capacitor of Vin pin 1 10 uF COUT Capacitor of Vout pin 1 10 uF ESR Equivalent series resistance 5 100 TA Operating temperature -40 (2) +125 mΩ °C (1) All voltages are with respect to the GND pin. (2) The chip’s operating temperature is determined by the junction temperature (TJ), the relationship between TA and TJ, please refer to the application note as below. The larger the TA, the smaller the space left for the chip temperature rise. 7 / 17 www.run-ic.com RS3007 Thermal Information RS3007 THERMAL METRIC RθJA RθJC(top) RθJB ψJT ψJB RJC(bot) Junction-to-ambient thermal resistance Junction-to-case (top) thermal resistance Junction-to-board thermal resistance Junction-to-top characterization parameter Junction-to-board characterization parameter Junction-to-case (bottom) thermal resistance SOT23-3 SOT23-5 3 PINS/ 5 PINS SOT89-3L 3 PINS SOT89-3L (L-Type) 3 PINS SOT223 (L-Type) SOT223 SOIC-8 3 PINS 3 PINS 8 PIN UNIT 185.6 75 165 120 95 116 °C/W 104.3 88.1 88.5 25 15 60 °C/W 54.5 9.6 39.6 — — 56 °C/W 31.0 6.2 26.5 — — 12.8 °C/W 54.5 9.7 49.7 — — 98.3 °C/W N/A 7.7 77.7 — — N/A °C/W 8 / 17 www.run-ic.com RS3007 ELECTRICAL CHARACTERISTICS (VIN = VOUT + 2V, CIN = COUT = 1μF, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) PARAMETER Input Voltage SYMBOL Static power consumption Shutdown Current Dropout Voltage TYP MAX UNITS V IOUT = 10mA +25°C -2.0 2.0 % IOUT = 10mA, A Type +25°C -1.0 1.0 % IOUT = 0mA +25°C 3.0 4.0 uA VEN =0V +25°C 0.1 1.0 uA 300 350 - mA VOUT =1.8V - 450 550 VOUT =2.5V VDROP VOUT =3.0V IOUT= 100mA VOUT =3.3V - 385 485 - 350 450 - 335 435 - 300 400 +25°C - 0.05 0.2 %/V IQ IQ-OFF +25°C +25°C VOUT =5.0V Line Regulation MIN 45 (3) (4) TEMP +25°C 2.5(1) VIN Output Voltage Accuracy (2) Output Current CONDITIONS ΔVOUT VIN = VOUT + 2V to 36V, IOUT = 1mA ΔVIN × VOUT mV Load Regulation ΔVOUT VIN =VOUT+1V, IOUT = 1mA to 50mA +25°C - 5 20 mV Output limiting current I_LMT VIN =VOUT+1V +25°C 300 450 - mA VOUT = 0 +25°C - 100 - mA - 72 - - 77 - - 60 - 1.2 - - V - - 0.4 V - 100 - ppm/°C - 100 - uVrms TSHDN - 170 - °C TSDH - 20 - °C short-circuit Current Ishort f = 217Hz Power Supply Rejection Ratio PSRR VOUT = 3.3V, IOUT = 10mA f = 1KHz +25°C f = 10KHz VENH Enable pin Threshold Output Voltage Temperature Coefficient (5) Output Noise Voltage Thermal Shutdown Temperature Thermal Shutdown Hysteresis Temperature VENL ΔVOUT IOUT = 1mA ΔTA × VOUT eN +25°C FULL VIN =VOUT+1V, IOUT = 1mA, VOUT=3.0V f = 10Hz~100KHz dB NOTES: 1. VIN >= VOUT (NOMINAL) or 2.5V, or higher voltage. 2. Model A provides ± 1% precision output voltage. 3. The maximum output current of the actual chip is subject to PCB heat dissipation design, input voltage, output voltage difference and ambient temperature. 4. Under the condition of VIN = Vout + 2V and a fixed load, the output voltage decreases by 2%. At this time, the input voltage minus the output voltage is the dropout voltage. 5. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature range. 9 / 17 www.run-ic.com RS3007 TYPICAL CHARACTERISTICS (VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) Line Transient Response Power-Up/Power-Down Output Waveform VIN=0V to 5.3V,IOUT=50mA VIN=5.3V to 6.3V,IOUT=50mA 2V/div VOUT 2V/div VIN 50mV/div VOUT 1V/div VIN Time(100us/div) Time(1ms/div) Load Transient Response Load Transient Response VOUT=3.3V VOUT=3.3V IOUT IOUT=10mA to 50mA Time(500us/div) 50mA/div IOUT=1mA to 100mA VOUT 100mA/div IOUT 20mV/div 50mV/div VOUT Time(500us/div) 10 / 17 www.run-ic.com RS3007 TYPICAL CHARACTERISTICS (VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.) 11 / 17 www.run-ic.com RS3007 Function introduction RS3007 series low dropout linear regulator (LDO) consumes only 3.0uA of current and has excellent linear adjustment and load characteristics to meet the requirements of lower output noise and higher PSRR, making it more suitable for applications requiring ultra-low standby power consumption of the whole machine. Functional Block Diagram Precautions for heat dissipation design When the junction temperature of PN junction is too high and reaches the set temperature value, it will trigger the thermal protection circuit to send a signal to the control logic to turn off the chip output. When the PN junction temperature is lower than the set protection temperature, the chip will restart automatically. The maximum output power actually provided by the chip depends on the heat dissipation design of the system, including ambient temperature, wiring thickness and layout, and cooling design, such as adding heat sink and air cooling. Increasing the PCB area of GND pin can also obtain better heat dissipation performance. Other application considerations 1 ) The phase compensation circuit and ESR of the output capacitor are used inside the circuit to compensate, so a capacitor larger than 1.0uF must be connected to the ground. 2 ) It is recommended to use 1uF polar capacitors for input and output, and to keep the capacitors as close to the VIN and VOUT pins of LDO as possible. 3 ) Pay attention to the service conditions of input and output voltage and load current to make the junction temperature lower than the overheat protection temperature(TSHDN). Approximate estimation method of the junction temperature(TJ ): TJ =(VIN-VOUT) × IOUT×RθJA+TA IOUT is the Load current RθJA is the Junction-to-ambient thermal resistance TA is the ambient temperature. Only when the TJ < TSHDN , the chip will not trigger the over-temperature protection function. 4) When the input voltage VIN is greater than 2.5V, if VIN is also higher than the output set value plus the device dropout voltage, VOUT is equal to the set value. Otherwise, VOUT is equal to VIN minus the dropout voltage. If VIN lower than 2.5V, the VOUT is: VOUT = VIN - VDropout VDropout is converted according to the actual load current and basically maintains a linear relationship. 12 / 17 www.run-ic.com RS3007 PACKAGE OUTLINE DIMENSIONS SOT23-3 D 1.90 b 2.59 E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 13 / 17 www.run-ic.com RS3007 SOT23-5 D 1.90 b E1 E 0.99 0.95 0.69 e e1 RECOMMENDED LAND PATTERN (Unit: mm) 0.2 A A2 L A1 Symbol c θ Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.050 1.250 0.041 0.049 A1 0.000 0.100 0.000 0.004 A2 1.050 1.150 0.041 0.045 b 0.300 0.500 0.012 0.020 c 0.100 0.200 0.004 0.008 D 2.820 3.020 0.111 0.119 E 1.500 1.700 0.059 0.067 E1 2.650 2.950 0.104 0.116 e 0.950(BSC) 0.037(BSC) e1 1.800 2.000 0.071 0.079 L 0.300 0.600 0.012 0.024 θ 0° 8° 0° 8° 14 / 17 www.run-ic.com RS3007 SOT89-3L Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A 1.400 1.600 0.055 0.063 b 0.320 0.520 0.013 0.020 b1 0.400 0.580 0.016 0.023 c 0.350 0.440 0.014 0.017 D 4.400 4.600 0.173 0.181 D1 1.550 REF 0.061 REF E 2.300 2.600 0.091 0.102 E1 3.940 4.250 0.155 0.167 e 1.500 BSC 0.060 BSC e1 3.000 BSC 0.118 BSC L 0.900 1.200 15 / 17 0.035 0.047 www.run-ic.com RS3007 SOT223 Symbol Dimensions In Millimeters Dimensions In Inches Min Max Min Max A - 1.800 - 0.071 A1 0.02 0.10 0.001 0.004 A2 1.55 1.65 0.061 0.065 b 0.66 0.84 0.026 0.033 b2 2.90 3.10 0.114 0.122 c 0.23 0.33 0.009 0.013 D 6.30 6.70 0.248 0.263 E 6.70 7.30 0.263 0.287 E1 3.30 3.70 0.130 0.145 e 2.30 BSC 0.090 BSC e1 4.60 BSC 0.181 BSC L 0.90 - 16 / 17 0.035 - www.run-ic.com RS3007 SOIC-8(SOP8) b e 5.2 E E1 2.2 D 1.27 0.6 RECOMMENDED LAND PATTERN (Unit: mm) A2 c A A1 L Symbol Dimensions In Millimeters θ Dimensions In Inches Min Max Min Max A 1.350 1.750 0.053 0.069 A1 0.100 0.250 0.004 0.010 A2 1.350 1.550 0.053 0.061 b 0.330 0.510 0.013 0.020 c 0.170 0.250 0.007 0.010 D 4.800 5.000 0.189 0.197 e 1.270(BSC) 0.050(BSC) E 5.800 6.200 0.228 0.244 E1 3.800 4.000 0.150 0.157 L 0.400 1.270 0.016 0.050 θ 0° 8° 0° 8° 17 / 17 www.run-ic.com
RS3005-3.0YE3 价格&库存
很抱歉,暂时无法提供与“RS3005-3.0YE3”相匹配的价格&库存,您可以联系我们找货
