RS75xx-1
150mA, Low Power Consumption,
High Voltage CMOS LDO Regulator
FEATURES
Low Quiescent Current IQ:
2µA Typical at Light Loads
150mA Nominal Output Current
Low Dropout Voltage
Low Temperature Coefficient
High Input Voltage (up to 36V)
Output Voltage Accuracy: ±2%
Fixed 2.5V、3.0V、3.3V、3.6V、
DESCRIPTION
The RS75xx-1 series is a set of low power high
voltage regulators implemented in CMOS technology.
Which can provide 150mA output current. The device
allows input voltage as high as 36V.It is very suitable
for multi-cell battery systems, bus voltage power
supply systems and other high DC voltage systems.
Wide input voltage can make it well withstand the
impact of surge voltage and ensure the stability of
output voltage.
The RS75xx-1 series only 2uA (typical) current is
consumed by itself, which is especially important in
multi-battery power supply systems and can reduce
the standby power consumption of the whole system .
and 5.0V Output Voltage
Over temperature Protection
Short Circuit Protection
Micro SIZE PACKAGES: SOT23-3 and
SOT89-3L
The RS75xx-1 is available in Green SOT23-3 and
SOT89-3L packages. The over
temperature is
150°C.
Device Information (1)
APPLICATIONS
Audio/Video Equipment
Communication Equipment
Battery-Powered Equipment
Automotive Head Unit
Laptop, Palmtops, Notebook Computers
PART NUMBER
RS75xx-1
(1)
PACKAGE
BODY SIZE (NOM)
SOT23-3(3)
1.60mm×2.92mm
SOT89-3L(3)
2.45mm×4.50mm
For all available packages, see the orderable addendum at
the end of the data sheet.
Typical Application Schematic
VIN
VIN
CIN
1μF
VOUT
RS75xx-1
VOUT
COUT
1μF
GND
REV A.9
1
www.run-ic.com
RS75xx-1
Pin Configuration and Functions (Top View)
PIN DESCRIPTION
PIN
NAME
SOT23-3
SOT89-3L
(L-Type)
SOT89-3L
GND
1
1
2
VOUT
2
3
1
VIN
3
2
3
REV A.9
2
FUNCTION
Ground.
Regulator Output. Recommended
output capacitor range:1μF to 10μF.
Regulator Input. Up to 36V input
voltage. At least 1μF supply bypass
capacitor is recommended.
www.run-ic.com
RS75xx-1
PACKAGE/ORDERING INFORMATION
PRODUCT
RS7525-1
RS7530-1
RS7533-1
RS7536-1
RS7550-1
ORDERING
NUMBER
VOUT(V)
PACKAGE LEAD
PACKAGE
MARKING
PACKAGE OPTION
RS7525-1YF3
2.5
SOT23-3
7525-1
Tape and Reel,3000
RS7525-1YE3L
2.5
SOT89-3L(L-Type)
7525-1
Tape and Reel,1000
RS7530-1YF3
3.0
SOT23-3
7530-1
Tape and Reel,3000
RS7530-1YE3L
3.0
SOT89-3L(L-Type)
7530-1
Tape and Reel,1000
RS7533-1YF3
3.3
SOT23-3
7533-1
Tape and Reel,3000
RS7533-1YE3
3.3
SOT89-3L
7533-E
Tape and Reel,1000
RS7533-1YE3L
3.3
SOT89-3L(L-Type)
7533-1
Tape and Reel,1000
RS7536-1YF3
3.6
SOT23-3
7536-1
Tape and Reel,3000
RS7536-1YE3L
3.6
SOT89-3L(L-Type)
7536-1
Tape and Reel,1000
RS7550-1YF3
5.0
SOT23-3
7550-1
Tape and Reel,3000
RS7550-1YE3
5.0
SOT89-3L
7550-E
Tape and Reel,1000
RS7550-1YE3L
5.0
SOT89-3L(L-Type)
7550-1
Tape and Reel,1000
NOTE:
1.Date Code and Vendor Code also marking in package.
3
www.run-ic.com
RS75xx-1
Specifications
Absolute Maximum Ratings
over operating free-air temperature range (unless otherwise noted) (1)(2)
MIN
MAX
UNIT
VIN
Input voltage
-0.3
40
V
TJ
Junction temperature
-40
150
°C
PD
Continuous power dissipation (3)
Tstg
Storage temperature
(1)
W
Internally Limited
-65
150
°C
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are stress
ratings only, and functional operation of the device at these or any other conditions beyond those indicated under Recommended
Operating Conditions is not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device
reliability.
All voltages are with respect to the GND pin.
Internal thermal shutdown circuitry protects the device from permanent damage.
(2)
(3)
ESD Ratings
V(ESD)
Electrostatic discharge
VALUE
UNIT
Human-body model (HBM)
±4000
V
Machine model (MM)
±100
V
MAX
UNIT
Recommended Operating Conditions
MIN
VIN
Input supply voltage
IOUT
Output current
COUT
Capacitor of Vout pin
TA
Operating temperature
2.5
36
V
mA
1
-40
22
+85 2
μF
°C
(1) All voltages are with respect to the GND pin
(2) The chip’s operating temperature is determined by the junction temperature(TJ) , the relationship between TA and TJ , Please refer to
the application note as below.
Thermal Information
RS75xx-1
THERMAL METRIC (1)
SOT89-3L
(L-Type)
SOT89-3L
SOT23-3
UNIT
3 PINS
3 PINS
3 PINS
RθJA
Junction-to-ambient thermal resistance
165
75
185.6
°C/W
RθJC(top)
Junction-to-case (top) thermal resistance
88.5
88.1
104.3
°C/W
RθJB
Junction-to-board thermal resistance
39.6
9.6
54.5
°C/W
ψJT
Junction-to-top characterization parameter
26.5
6.2
31.0
°C/W
ψJB
Junction-to-board characterization parameter
49.7
9.7
54.5
°C/W
RJC(bot)
Junction-to-case (bottom) thermal resistance
77.7
7.7
N/A
°C/W
4
www.run-ic.com
RS75xx-1
ELECTRICAL CHARACTERISTICS
(VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 3.3V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.)
PARAMETER
TEMP
MIN
TYP
VOUT = 3.3V
+25°C
36
V
IOUT = 10mA
+25°C
-2
Ground Pin Current
No load
+25°C
2
3
μA
+25°C
70
100
mA
+25°C
526
800
mV
+25°C
0.05
0.2
%/V
+25°C
25
60
mV
Input Voltage(1)
SYMBOL
VIN
CONDITIONS
Maximum Output Current (2)
Dropout Voltage (3)
Line Regulation
Load Regulation
Power Supply Rejection
Ratio
Output Voltage Temperature
Coefficient (4)
VDROP
IOUT =100mA,
△Vo=2%
ΔVOUT
VIN = VOUT + 2V to 36V, IOUT = 1mA
ΔVIN × VOUT
ΔVOUT
PSRR
VIN =VOUT+2V, IOUT = 1mA to 50mA
VOUT = 3.3V,
IOUT = 10mA
f = 217Hz
f = 1KHz
ΔVOUT
IOUT = 1mA
ΔTA × VOUT
+25°C
FULL
58
40
MAX
UNITS
dB
100
ppm/°C
150
°C
THERMAL PROTECTION
Thermal Shutdown
Temperature
TSHDN
NOTES:
1. VIN >= VOUT (NOMINAL) , whichever is greater.
2 Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal
layers, ambient temperature and the other environment factors of system. Attention should be paid to the dropout voltage
when VIN < VOUT + VDROP.
3. The dropout voltage is defined as VIN - VOUT, when VOUT is 100mV below the value of VOUT for VIN = VOUT (NOMINAL) + 2V.
4. Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature
range.
5
www.run-ic.com
RS75xx-1
(VIN = VOUT + 2V, CIN = COUT = 1μF, VOUT = 5.0V, Full = -40°C to +85°C, typical values are at TA = +25°C, unless otherwise noted.)
PARAMETER
TEMP
MIN
TYP
VOUT = 5.0V
+25°C
36
V
IOUT = 10mA
+25°C
-2
Ground Pin Current
No load
+25°C
2
3
μA
+25°C
100
150
mA
+25°C
440
700
mV
+25°C
0.05
0.2
%/V
+25°C
25
60
mV
Input Voltage(1)
SYMBOL
VIN
CONDITIONS
VIN = VOUT + 2V
Dropout Voltage (3)
Line Regulation
Load Regulation
Ratio
Coefficient (4)
VDROP
IOUT = 100mA
△Vo=2%
ΔVOUT
ΔVIN × VOUT
ΔVOUT
PSRR
VIN =VOUT+2V, IOUT = 1mA to150mA
VOUT = 5.0V,
IOUT = 10mA
f = 217Hz
f = 1KHz
ΔVOUT
IOUT = 1mA
ΔTA × VOUT
+25°C
FULL
MAX
UNITS
58
dB
40
100
ppm/°C
150
°C
THERMAL PROTECTION
Thermal Shutdown
Temperature
TSHDN
NOTES:
2. Maximum output current is affected by the PCB layout, size of metal trace, the thermal conduction path between metal
4.Output voltage temperature coefficient is defined as the worst-case voltage change divided by the total temperature
range.
6
www.run-ic.com
RS75xx-1
TYPICAL CHARACTERISTICS
VIN = 5.3V, VOUT = 3.0V, CIN = COUT = 1μF, TA = 25°C unless otherwise noted.
Load-Transient Response
Line-Transient Response
IOUT=10mA to 100mA
VIN=5.3V to 6.3V,IOUT=50mA
VOUT
50mV/div
VOUT
Time(1ms/div)
100mV/div
1V/div
IOUT
100mA/div
VIN
Time(2ms/div)
Output Short Waveform
Power-Up/Power-Down Output Waveform
VIN=0 to 3.4V,IOUT=50mA
VOUT
2V/div
2V/div
VIN
100mA/div
2V/div
VOUT
IOUT
VIN=0 to 5.3V,IOUT=50mA
Time(2ms/div)
Time(1ms/div)
IOUT=50mA
7
www.run-ic.com
RS75xx-1
8
www.run-ic.com
RS75xx-1
DETAILED DESCRIPTION
Overview
The RS75xx-1 low-dropout regulators (LDO) consumes only 2µA of quiescent current at light load and
delivers excellent line and load transient performance. These characteristics, combined with low noise and
good PSRR with low dropout voltage, make this device ideal for portable consumer applications.
Functional Block Diagram
Thermal Considerations
When the junction temperature is too high, the thermal protection circuitry sends a signal to the control logic
that will shut down the IC. The IC will restart when the temperature has sufficiently cooled down. The
maximum power dissipation is dependent on the thermal resistance of the case and the circuit board, the
temperature difference between the die junction and the ambient air, and the rate of air flow. The GND pin
must be connected to the ground plane for proper dissipation.
Applications Note:
1)The phase compensation circuit and ESR of the output capacitor are used inside the circuit to
compensate, so a capacitor larger than 1.0uF must be connected to the ground.
2)It is recommended to use 1uF polar capacitors for input and output, and to keep the capacitors as
close to the VIN and VOUT pins of LDO as possible.
3)Pay attention to the use conditions of input and output voltages and load currents to avoid the
power consumption (PD) inside the IC exceeding the maximum power consumption allowed by the
package.
PD=(VIN-VOUT)×IOUT
TPN = PD×RθJA+T
TPN is junction temperature
T is ambient temperature。
4)When the input voltage VIN is greater than 2.5V, if VIN is also higher than the output set value plus the
device dropout voltage, VOUT is equal to the set value. Otherwise, VOUT is equal to VIN minus the
dropout voltage. If VIN lower than 2.5V, the VOUT is:
VOUT = VIN - VDropout
9
www.run-ic.com
RS75xx-1
PACKAGE OUTLINE DIMENSIONS
SOT23-3
D
1.90
b
2.59
E1
E
0.99
0.95
0.69
e
e1
RECOMMENDED LAND PATTERN (Unit: mm)
0.2
A A2
L
A1
Symbol
c
θ
Dimensions In Millimeters
Dimensions In Inches
Min
Max
Min
Max
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950(BSC)
0.037(BSC)
e1
1.800
2.000
0.071
0.079
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
10
www.run-ic.com
RS75xx-1
SOT89-3L
D
2.0
A
D1
3.0
E
E1
0.7
45°
b1
L
e
1.5
b
c
1.5
e1
1.0
Symbol
Min
Max
Min
Max
A
1.400
1.600
0.055
0.063
b
0.320
0.520
0.013
0.020
b1
0.400
0.580
0.016
0.023
c
0.350
0.440
0.014
0.017
D
4.400
4.600
0.173
0.181
D1
1.550 REF
0.061 REF
E
2.300
2.600
0.091
0.102
E1
3.940
4.250
0.155
0.167
e
1.500 BSC
0.060 BSC
e1
3.000 BSC
0.118 BSC
L
0.900
1.200
11
0.035
0.047
www.run-ic.com
