WL9100
36V;1.5μA IQ,150mA LDO
Features
• Low Power Consumption: 1.5µA (Typ)
• Maximum Output Current: 150mA
• Small Dropout Voltage
300mV@100mA (Vout=3.3V)
• High Input Voltage: Up to 36V
• High Accurate:
Good Transient Response
Integrated Short-Circuit Protection
Over-Temperature Protection
Output Current Limit
Stable with Ceramic Capacitor
Support Fixed Output Voltage:
1.8,2.5,2.8.3.0,3.3,3.6,4.0,4.2,4.4and 5.0V
• Available Package:
• RoHS Compliant and Lead (Pb) Free
SOT23-3L\SOT89-3L\DFN4\DFN3\SOT23-5L
Application
• Portable, Battery Powered Equipment
• Battery-powered equipment
• Weighting Scales
• Smoke detector and sensor
• Audio/Video Equipmen
• Home Automation
Description
The WL9100 series is a high voltage,ultralow-power,low dropout voltage regulator. The device
can deliver 150mA output current with a dropout voltage of 300mV and allows an input voltage as
high as 36V. The typical quiescent current is only 1.5µA. The device is available in fixed output
voltages of 1.8,2.5,2.8,3.0,3.3,3.6,4.0,4.2,4.4 and 5.0V.The device features integrated shortcircuit and thermal shutdown protection.Although designed primarily as fixed voltage regulators,
the device can be used with external components to obtain variable voltages.
Application Circuits
VIN
VIN
VOUT
VOUT
GND
10uF
10uF
CIN
COUT
-1-
www.wpmtek.com
WL9100
Pin Configuration
SOT23-3L:
VIN
VIN
GND
GND
2
2
2
2
1
3
GND
1
VOUT
1
3
VOUT GND
WL9100S3-XX
3
VIN
WL9100SA-XX
1
3
VOUT
GND
VIN
WL9100SC-XX
WL9100SB-XX
SOT89-3L:
1
2
3
GND
VIN
VOUT
1
VOUT
WL9100P3-XX
2
3
1
VIN
GND
VIN
WL9100PA-XX
2
GND VOUT
1
2
3
VOUT
GND
VIN
WL9100PC-XX
WL9100PB-XX
DFN2x2-3L:
DFN1x1-4L:
3
SOT23-5L:
VOUT
GND
NC
VIN
VOUT
5
NC
GND
VOUT
WL9100D4-XX
VIN
WL9100D3-XX
4
1
2
3
VIN
GND
NC
WL9100S5-XX
Pin Description
SOT23-3L
3L Pin No.
Pin Name
Pin Function
WL9100S3-XX
WL9100SA-XX*
WL9100SB-XX
WL9100SC-XX
1
3
2
2
GND
Ground.
2
2
1
3
VIN
Supply voltage input
3
1
3
1
VOUT
Voltage Output
Pin Name
Pin Function
SOT89-3L Pin No.
WL9100P3-XX
WL9100PA-XX*
WL9100PB-XX
WL9100PC-XX
1
3
2
2
GND
Ground.
2
2
1
3
VIN
3
1
3
1
VOUT
Voltage Output
-2-
www.wpmtek.com
WL9100
Pin No.
Pin Name
Pin Function
DFN1x1-4L
DFN2x2-3L
SOT23-5L
1
1
5
VOUT
Voltage Output
2
2
2
GND
Ground
3
3、4
NC
No Internal Connection
4
3
1
VIN
NOTE: (*) It needs to be customized
Order Information
WL9100①②-③④⑤
Designator
Symbol
Description
①②
S3/P3/D4/D3/S5
SOT23-3L / SOT89-3L / DFN4L / DFN3L / SOT23-5L
③④
Integer
⑤
Model
Output Voltage 1.8,2.5,2.8.3.0,3.3,3.6,4.0,4.2,4.4 and 5.0V
A
Accurate ±1%
B
Accurate ±2%
Marking
Description
Package
T/R Qty
SOT23-3L
3,000 PCS
SOT89-3L
1,000 PCS
SOT23-5L
3,000 PCS
WL9100S3-XX*
AFXXA(B)
WL9100P3-XX*
AFXXA(B)
WL9100S5-XX*
AFXXA(B)
WL9100D4-XX*
DFN1X1-4L 10,000 PCS
WL9100D3-XX*
DFN2X2-3L
WL9100 36V;1.5µA IQ,
150mA Low-Dropout LDO
1,000 PCS
Note:(*) XX Represents the Output Voltage
(**) Please Page 4 . Only Off DFN1x1-4L and DFN2x2-3L (customized)
-3-
www.wpmtek.com
WL9100
Marking Information
SOT23-3L 、SOT23-5L and SOT89-3L Marking: ①②③④⑤
①②Represents the product name
Mark ①②
AF
Product Series
WL9100 S3 / S5 / P3
③④Represents the Output Voltage
Mark
Output Voltage (V)
Mark
Output Voltage (V)
36
3.6
40
42
4.0
4.2
30
3.0
33
3.3
⑤Represents the Output Voltage Accurate
44
50
4.4
5.0
18
25
28
1.8
2.5
2.8
Mark⑤
Product Series
±1% Output Voltage
±2% Output Voltage
A
B
WL9100 (A or B)
DFN1X1-4L and DFN2X2-3L Marking:
Mark
Output Voltage (V) Accurate ±1%
Mark
Output Voltage (V) Accurate ±2%
AF
1.8
AF
1.8
BF
2.5
BF
2.5
CF
DF
EF
2.8
3.0
3.3
CF
DF
EF
2.8
3.0
3.3
GF
HF
KF
MF
4.6
4.0
4.2
4.4
GF
HF
KF
MF
4.6
4.0
4.2
4.4
LF
5.0
LF
5.0
-4-
www.wpmtek.com
WL9100
Absolute Maximum Ratings
(1) (2)
Parameter
Symbol
Maximum Rating
Unit
Input Voltage
VIN
VOUT
VSS -0.3~VSS+42.0
VSS -0.3~VSS+6.0
V
V
Output Current
IOUT
150
mA
SOT23-3L/5L
Power Dissipation
Thermal Resistance
400
SOT89-3L
DFN1x1-4L
500
400
Pd
mW
DFN2x2-3L
500
SOT23-3L/5L
250
℃/W
200
250
℃/W
SOT89-3L
DFN1x1-4L
RθJA
(3)
DFN2x2-3L
200
Operating Temperature
Topr
-40~85
Storage Temperature
Tstg
-40~125
Soldering Temperature & Time
Tsolder
260℃, 10s
Note (1): Exceeding these ratings may damage the device.
Note (2): The device is not guaranteed to function outside of its operating conditions
Note (3): The package thermal impedance is calculated in accordance to JESD 51-7.
ESD Ratings
Item
V(ESD-HBM)
V(ESD-CDM)
ILATCH-UP
Description
Human Body Model (HBM)
ANSI/ESDA/JEDEC JS-001-2014
Classification, Class: 2
Charged Device Mode (CDM)
ANSI/ESDA/JEDEC JS-002-2014
Classification, Class: C0b
JEDEC STANDARD NO.78E APRIL 2016
Temperature Classification, Class: I
Value
Unit
±4000
V
±100
V
±150
mA
ESD testing is performed according to the respective JESD22 JEDEC standard.The human body model is a 100 pF capacitor discharged
through a 1.5kΩ resistor into each pin. The machine model is a 200pF capacitor discharged directly into each pin.
Recommended Operating Conditions
Parameter
MIN.
MAX.
Units
Supply voltage at VIN
3.0
24
V
Operating junction temperature range, Tj
-40
125
°C
Operating free air temperature range, TA
-40
85
°C
Note : All limits specified at room temperature (TA = 25°C) unless otherwise specified. All room temperature limits are 100% production
tested. All limits at temperature extremes are ensured through correlation using standard Statistical Quality Control (SQC) methods. All
limits are used to calculate Average Outgoing Quality Level (AOQL).
-5-
www.wpmtek.com
WL9100
Electrical Characteristics
(Test Conditions:VIN=12V, VOUT=Vset,CIN=10uF, COUT=10uF,TA=25℃, unless otherwise specified.)
Parameter
Symbol
Input Voltage
VIN
Supply Current
IQ
Output Voltage
WL9100 (A)
VOUT1
Output Voltage
WL9100 (B)
Maximum Output
Current
Dropout Voltage
Conditions
VIN=12V
ILOAD=0mA
VIN=12V
IOUT=10mA
Min
Typ
Max
Units
3.0
36
V
1.5
3.0
uA
Vset*0.99
Vset
Vset*1.01
V
VOUT2
VIN=12V
IOUT=10mA
Vset*0.98
Vset
Vset*1.02
V
IOUT(Max)
150
mA
VDROP
IOUT=150mA
550
VOUT=3.0V
IOUT=100mA
IOUT=150mA
IOUT=100mA
330
500
300
IOUT=150mA
IOUT=100mA
IOUT=10mA
(Vset+2.0v)≦VIN≦24V
520
300
0.15
%/V
VDROP
VOUT=3.3V
VDROP
VOUT=5.0V
mV
Line Regulation
ΔVOUT/
ΔVIN•VOUT
Load Regulation
ΔVOUT
VIN=10V
1mA≦IOUT≦150mA
45
mV
Short Current
ISHORT
RL=1Ω
80
mA
eNO
IOUT=50mA
BW = 300Hz~50kHz
50
uVRMS
IOUT=10mA
100
ppm/℃
Output Noise
Voltage
Output Voltage
Temperature
Coefficient
ΔVOUT/
ΔT•VOUT
-6-
www.wpmtek.com
WL9100
Function Block Diagram
Application Guideline
Input Capacitor
A 10μF ceramic capacitor is recommended to connect between VDD and GND pins to decouple input
power supply glitch and noise. The amount of the capacitance may be increased without limit. This
input capacitor must be located as close as possible to the device to assure input stability and less
noise. For PCB layout, a wide copper trace is required for both VIN and GND.
Output Capacitor
An output capacitor is required for the stability of the LDO. The recommended output capacitance is
10μF, ceramic capacitor is recommended, and temperature characteristics are X7R or X5R. Higher
capacitance values help to improve load/line transient response. The output capacitance may be
increased to keep low undershoot/overshoot. Place output capacitor as close as possible to VOUT
and GND pins.
Dropout Voltage
The dropout voltage refers to the voltage difference between the VIN and VOUT pins while operating
at specific output current. The dropout voltage VDROP also can be expressed as the voltage drop on
the pass-FET at specific output current (IRATED) while the pass-FET is fully operating at ohmic
region and the pass-FET can be characterized asan resistance RDS(ON). Thus the dropout voltage
can bedefined as (VDROP = VIN − VOUT = RDS(ON) x IRATED). Fornormal operation, the
-7-
www.wpmtek.com
WL9100
suggested LDO operating range is (VIN > VOUT + VDROP) for good transient response and PSRR
ability. Vice versa, while operating at the ohmic region will degrade the performance severely.
Thermal Application
For continuous operation, do not exceed the absolute maximum junction temperature. The maximum
power dissipation depends on the thermal resistance of the IC package, PCB layout, rate of
surrounding airflow, and difference between junction and ambient temperature. The maximum power
dissipation can be calculated as below: TA=25°C, PCB,
The max PD= (125°C − 25°C) / (Thermal Resistance °C/W)
Power dissipation (PD) is equal to the product of the output current and the voltage drop across the
output pass element, as shown in the equation below:
PD = (VIN – VOUT) × IOUT
Layout Consideration
By placing input and output capacitors on the same side of the PCB as the LDO, and placing them as
close as is practical to the package can achieve the best performance. The ground connections for
input and output capacitors must be back to the WL9100 ground pin using as wide and as short of a
copper trace as is practical.Connections using long trace lengths, narrow trace widths, and/or
connections through via must be avoided. These add parasitic inductances and resistance that
results in worse performance especially during transient conditions.
-8-
www.wpmtek.com
WL9100
Packaging Information
SOT23-3L
-9-
www.wpmtek.com
WL9100
SOT89-3L
- 10 -
www.wpmtek.com
WL9100
DFN1x1-4L
- 11 -
www.wpmtek.com
WL9100
DFN2x2-3L
- 12 -
www.wpmtek.com
WL9100
SOT23-5L
- 13 -
www.wpmtek.com
