1
www.china-amass.com
www.china-amass.com
2
3
www.china-amass.com
www.china-amass.com
4
5
www.china-amass.com
www.china-amass.com
6
P9-14
P24-26
P34-38
P15-20
P27-31
7
www.china-amass.com
P32-33
P39-41
P45-47
P21-23
P42-44
P48
www.china-amass.com
8
测试钩 ( 针、探笔 )Test Probe & Clip
20.132. *
材质
塑壳 :PA
主体 : 铜
表面:镀金
电气性能 :30Vac-60Vdc/Max.2A
1
2
3
4
5
Feature
Mini test clip with pin connection.Specially for the thin wires and
samll terminals.
Material
Insulator:PA
Body:Brass
Surface:Gold plated
Rated voltage/current:
30Vac-60Vdc/Max.2A
20.135. *
材质
塑壳 :PA
主体 : 铜
表面:镀金
电气性能 :30Vac-60Vdc/Max.10A
1
2
3
4
5
Feature
Mini test clip with solder connection.Press with the good feeling
and contact hook for wires up easily.
Material
Insulator:PA
Body:Brass
30Vac-60Vdc/Max.10A
20.155. *
材质
塑壳 :PA
主体 : 铜和不锈钢
电气性能 :CATII 600V/Max.1A
1
Feature
Safety test probe with 4mm socket connection. Sharp stainless
steel needle.
2
Material
Insulator:PA
Body:Stainless steel & Brass
CATII 600V/Max.1A
20.156. *
材质
塑壳 :PA
主体 : 铜和不锈钢
电气性能 :CATII 1000V/Max.10A
1
9
www.china-amass.com
2
3
4
5
Feature
steel tip with the perfectly protective cap.
www.china-amass.com
Material
Insulator:PA
CATII 1000V/Max.10A
10
20.157. *
材质
20.163. *
塑壳 :PA
主体 : 铜
弹片 : 铍铜
表面 : 镀镍
电气性能 :CATII 1000V/Max.32A
1
2
3
4
5
Feature
Safety test probe with 4mm socket connection. Spring-loaded tip
with the protective cap.
Material
Insulator:PA
Body:Brass
Spring:Beryllium copper
Surface:Nickel plated
CATII 1000V/Max.32A
20.160. *
材质
塑壳 :PA
主体 : 不锈钢和铜
电气性能 :CATIII 1000V/Max.10A
1
2
Feature
Safety test probe with 4mm socket connection. Stainless steel tip
can connect with the wire without cutting it.
Material
Insulator:PA
20.164. *
材质
材质
塑壳 :PA
主体 : 不锈钢和铜
电气性能 :30Vac-60Vdc/Max.1A
1
2
3
4
5
Feature
steel needle.
Material
Insulator:PA
30Vac-60Vdc/Max.1A
塑壳 :PA
主体 : 不锈钢和铜
1
2
Feature
steel tip with the protective cap.
20.168. *
20.161. *
材质
材质
1
2
3
4
5
Feature
steel needle.
塑壳 :PA
主体 : 不锈钢和铜
塑壳 :PA
主体 : 铜和不锈钢
表面 : 镀镍
Material
Insulator:PA
30Vac-60Vdc/Max.1A
Material
Insulator:PA
Body:Brass & Stainless steel
20.162. *
1
11
2
Material
Insulator:PA
1
2
Feature
Safety test probe with 4mm socket connection.Stainless steel tip
20.169. *
3
Feature
Safety test clip with 4mm socket connection. Long sharp stainless
steel tip and flexible spring with the silicone tube can meet kinds
of your request.
www.china-amass.com
材质
材质
塑壳 :PA
主体 : 不锈钢和铜
塑壳 :PA
主体 : 铜和不锈钢
Material
Insulator:PA
30Vac-60Vdc/Max.10A
1
2
Feature
Safety test clip with 4mm socket connection.Flexible spring with
the tube can contact the wires and terminals even at the corner.
www.china-amass.com
Material
Insulator:PA
12
20.170. *
材质
20.601. *
塑壳 :PA
主体 : 铜和不锈钢
电气性能 :CATIII 1000V/Max.20A
1
2
3
4
Feature
The clip can connect the terminals easily.
5
Material
Insulator:PA
Feature
Safety test lead one end with the insulated 4mm spring loaded test probe and the other
end with the insulated 4mm angled plug.Nickel plated plugs with the protective cap.
Red+Black as a set.
Rated voltage/current: CATIII 1000V/10A
1
0.75mm2
PVC
100
2
20.602. *
20.171. *
材质
塑壳 :PA
主体 : 铜和不锈钢
1
Feature
2
Material
Insulator:PA
Feature
Safety test lead one end with the insulated test probe and the other end with the insulated
4mm angled plug.Nickel plated plugs with the protective cap. Red+Black as a set.
1
2
0.75mm2
PVC
100
20.211. *
材质
塑壳 :PA
主体 : 铜
表面 : 镀镍
090.0058
1
2
3
4
5
Feature
Safety test probe with 4mm socket connection on both end.Fuse
inside.
Material
Insulator:PA
Body:Brass
20.212. *
材质
塑壳 :PA
主体 : 铜
090.0058
1
13
2
3
4
5
Material
Insulator:PA
Feature
Body:Brass
Safety test probe with 4mm socket connection. Spring loaded Rated voltage/current:
side with the shrinkable tube.Fuse inside.
www.china-amass.com
www.china-amass.com
14
香蕉插头 Banana Plug
25.205. *
25.201. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
弹片 Spring: 铍铜 Beryllium copper
表面 Surface: 镀金 Gold plated
* 焊接 Solder connection
电气性能 Rated voltage/current
30Vac-60Vdc/Max.10A
1
2
4
5
3
25.202. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
2
4
5
3
25.206. *
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.12A
1
2
4
5
3
25.203. *
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
2
4
5
3
25.207. *
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
2
4
5
3
1
2
4
5
3
25.208. *
25.204. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
表面 Surface: 镀镍 Nickel plated
CATII 600V/Max.10A
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
15
www.china-amass.com
1
2
4
5
3
1
2
4
5
www.china-amass.com
3
16
香蕉插头 Banana Plug
25.401. *
4
2
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
弹片 Spring: 锰钢 Steel
30Vac-60Vdc/Max.24A
3
1
5
25.402. *
2
25.410. *
2
4
5
3
25.403. *
2
4
5
25.404. *
4
17
2
5
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
弹片 Spring: 锰钢 Steel
30Vac-60Vdc/Max.32A
1
2
25.419. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
弹片 Spring: 锰钢 Steel
30Vac-60Vdc/Max.32A
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
* 螺丝压接 Screw connection
30Vac-60Vdc/Max.32A
3
1
2
3
4
5
6
4
5
6
1
25.415. *
2
25.420. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
1
2
3
1
2
3
1
2
4
5
6
4
5
6
4
5
25.416. *
25.412. *
3
3
6
2
1
2
3
4
5
6
www.china-amass.com
3
25.422. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
弹片 Spring: 锰钢 Steel
30Vac-60Vdc/Max.32A
1
2
5
1
25.411. *
3
1
4
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
弹片 Spring: 钢 Steel
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
弹片 Spring: 磷铜 Phosphorus copper
30Vac-60Vdc/Max.32A
25.414. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.19A
1
25.418. *
25.413. *
25.405. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
1
香蕉插头 Banana Plug
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
2
3
1
2
4
5
6
4
5
www.china-amass.com
3
18
香蕉插头 Banana Plug
香蕉插头 Banana Plug
25.425. *
25.431. *
25.451. *
2
4
5
3
25.426. *
1
2
4
5
3
25.432. *
2
4
5
3
25.427. *
1
2
4
5
3
25.433. *
4
2
19
2
4
5
3
1000V
1
2
4
5
3
2
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
2
25.501. *
4
5
www.china-amass.com
3
2
3
4
5
6
7
8
9
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 1000V/Max.32A
1
2
4
5
3
25.504. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 1000V/Max.32A
1
2
4
5
3
25.505. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 600V/Max.32A
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 600V/Max.32A
1
1
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
5
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 600V/Max.32A
25.503. *
3
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
1
5
25.454. *
25.450. *
25.430. *
4
3
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
2
2
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
1
25.452. *
材质 Material
塑壳 Insulator: PE
主体 Body:
铜 Brass
弹片 Spring: 钢 Steel
30Vac-60Vdc/Max.19A
1
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
* 按压 Press connection
CATII 600V/Max.32A
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
材质 Material
塑壳 Insulator: PE
主体 Body:
铍铜 Beryllium copper
30Vac-60Vdc/Max.19A
1
25.502. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 600V/Max.19A
1
2
3
1
2
4
5
5
www.china-amass.com
3
短路插及转换插 Connecting Plug
26.121. *
2
4
5
3
2
5
6
2
2
2
26.222. *
26.203. *
26.123. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
7
2
2
4
5
3
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
1
2
4
5
3
26.460. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CAT II 1000V/Max.32A
材质 Material
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
材质 Material
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
材质 Material
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
2
2
26.124. *
1
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
30Vac-60Vdc/Max.19A
26.420. *
26.221. *
26.202. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
材质 Material
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
1
26.122. *
26.410. *
26.220
26.201. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
26.223. *
26.205. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.32A
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
26.480
1
21
2
2
www.china-amass.com
7
1
26.481
2
www.china-amass.com
22
28.110
26.456. *
26.450. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.36A
1
2
4
5
3
非绝缘插头、插座 Uninsulated Banana plug & Socket
材质 Material
主体 Body: 铜 Brass
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
2
4
5
3
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.36A
2
4
5
3
2
4
5
L
M2.0
6.5
28.331
M2.5
6.5
Item No.
材质 Material
主体 Body: 铜 Brass
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
T
28.330
A-1.005
28.36*
28.111
T
L
28.360
M2.0
6.5
28.361
M2.0
10.0
材质 Material
主体 Body: 铜 Brass
28.112
1
Item No.
材质 Material
主体 Body: 铜 Brass
26.470. *
26.451. *
A-1.005
28.33*
28.370
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
3
26.452. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.36A
1
2
4
5
28.41*
28.220
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
3
26.455. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
2
4
5
23
3
www.china-amass.com
28.230
材质 Material
主体 Body: 铜 Brass
Item No.
T
L
28.410
M3.0
6.0
28.411
M3.0
10.0
28.412
M4.0
4.5
28.413
M4.0
6.0
28.414
M4.0
9.0
28.415
M4.0
18.0
www.china-amass.com
24
28.420
28.461
28.910
28.710
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
T
L
28.430
28.510
材质 Material
主体 Body: 铜 Brass
28.440
28.520
A-1.005
28.441
材质 Material
主体 Body: 铜 Brass
弹片 Spring: 锰钢 Steel
材质 Material
主体 Body: 铜 Brass
弹片 Spring: 锰钢 Steel
28.803
材质 Material
主体 Body: 铜 Brass
28.620
材质 Material
主体 Body: 铜 Brass
www.china-amass.com
A-1.005
28.712
28.610
28.450
材质 Material
主体 Body: 铜 Brass
弹片 Spring: 锰钢 Steel
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
25
28.711
材质 Material
主体 Body: 铜 Brass
材质 Material
主体 Body: 铜 Brass
表面 Surface: 镀银 Silver plated
材质 Material
主体 Body: 铜 Brass
28.804
材质 Material
主体 Body: 铜 Brass
www.china-amass.com
26
面板插座 Panel Socket
24.101. *
24.106. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
2
4
5
面板插座 Panel Socket
3
24.102. *
1
2
3
4
5
6
24.107. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.6A
24.131. *
型号 Model.
24.131. *
24.132. *
1
2
4
5
24.133. *
3
1
2
3
4
5
6
24.110. *
24.103. *
2
4
5
3
2
4
5
3
24.111. *
24.104. *
1
2
4
5
27
3
2
2
4
5
www.china-amass.com
CATIII 600V/Max.10A
Nickel or Gold plated
3
1
4
5
1
2
2
4
5
3
4
5
4
5
3
24.244. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
1
2
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
3
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
塑壳 Insulator:PA
主体 Body: 铜 Brass
表面 Surface: 镀镍或镀金
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
1
24.134. *
24.242. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
24.133. *
24.243. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
材质 Material
24.241. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
1
24.134. *
24.132. *
3
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
表面 Surface: 镀锌 Zinc plated
30Vac-60Vdc/Max.24A
1
2
3
4
5
6
www.china-amass.com
28
面板插座 Panel Socket
面板插座 Panel Socket
24.331. *
24.332. *
24.333. *
24.334. *
24.335. *
24.341. *
24.342. *
24.343. *
24.344. *
24.345. *
24.321. *
型号 Model.
型号 Model.
24.341. *
24.332. *
24.342. *
24.333. *
24.343. *
24.334. *
24.344. *
24.335. *
24.345. *
24.322. *
24.323. *
24.324. *
CATII 600V/Max.24A
CATII 600V/Max.32A
1
2
6
4
5
24.324. *
24.325. *
24.326. *
24.321. *
CATII 600V/Max.32A
塑壳 Insulator:ABS
主体 Body: 铜 Brass
材质 Material
24.323. *
CATIII 1000V/Max.32A
塑壳 Insulator:PA
主体 Body: 铜 Brass
CATIII 1000V/Max.24A
24.325. *
24.326. *
1
2
3
4
6
7
8
9
5
Ep:0.8
24.331. *
材质 Material
24.322. *
型号 Model.
24.301. *
24.311. *
24.302. *
24.312. *
24.303. *
24.313. *
24.304. *
24.314. *
24.305. *
24.315. *
24.306. *
24.316. *
29
24.301. *
24.302. *
24.303. *
24.304. *
24.305. *
24.306. *
24.311. *
24.312. *
24.313. *
24.314. *
24.315. *
24.316. *
材质 Material
24.381. *
24.382. *
24.383. *
24.384. *
24.391. *
24.392. *
24.393. *
24.394. *
塑壳 Insulator:PA
主体 Body: 铜 Brass
www.china-amass.com
材质 Material
型号 Model.
1
2
3
4
5
6
7
8
9
24.381. *
24.391. *
24.382. *
24.392. *
24.383. *
24.393. *
24.384. *
24.394. *
塑壳 Insulator:PA
主体 Body: 铜 Brass
www.china-amass.com
面板插座 Panel Socket
24.245. *
24.824. *
24.247. *
1
2
4
5
24.260. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
24.825. *
2
4
5
3
1
2
4
5
3
1
2
4
5
3
24.829.*
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
1
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
3
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.19A
24.828. *
30Vac-60Vdc/Max.24A
30Vac-60Vdc/Max.24A
2
24.246. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
1
接线柱 Binding Post
30Vac-60Vdc/Max.24A
30Vac-60Vdc/Max.24A
1
2
4
5
3
24.826. *
1
2
4
5
1
2
4
5
3
24.830.*
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.19A
30Vac-60Vdc/Max.24A
3
1
2
4
5
3
24.831.*
24.827. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
30Vac-60Vdc/Max.24A
31
www.china-amass.com
1
2
4
5
3
30Vac-60Vdc/Max.24A
1
2
4
5
www.china-amass.com
3
32
接线柱 Binding Post
线规 Cable Specification
24.935. *
24.832. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
1
2
3
4
5
30Vac-60Vdc/Max.24A
1
2
4
5
Material
Insulator:ABS
Body:Brass
30Vac-60Vdc/Max.80A
3
24.932. *
24.936. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
1
2
3
4
5
30Vac-60Vdc/Max.50A
PVC
Item No.
( 型号 )
2
4
5
24.937. *
24.933. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
1
30Vac-60Vdc/Max.60A
1
2
4
5
2
3
4
5
Material
Insulator:ABS
Body:Brass
30Vac-60Vdc/Max.150A
额定电压、电流
(Rated Volatge&Current)V/A
0.5/20
2.3
1500/10
1
2
3
4
5
6
011.0137
0.75/18
2.8
1500/15
1
2
3
4
5
6
011.0026
0.75/18
3.5
1500/15
1
2
3
4
5
6
011.0044
1.00/17
3.9
1500/19
1
2
3
4
5
6
7
011.0043
2.50/13
3.9
1500/32
1
2
3
4
5
6
7
Material
Insulator:ABS
Body:Brass
30Vac-60Vdc/Max.100A
3
Outer diameter.
外径 mm
011.0046
SIL
Item No.
( 型号 )
1
Cross Section
( 线规 ) mm2/AWG
Cross Section
( 线规 ) mm2/AWG
额定电压、电流
Outer diameter.
外径 mm
011.0078
0.5/20
1.8
1500/10
1
2
3
4
5
6
011.0066
0.75/18
3.5
1500/15
1
2
3
4
5
6
011.0063
1.00/17
3.9
1500/19
1
2
3
4
5
6
7
011.0136
2.50/13
3.9
1500/32
1
2
3
4
5
6
7
3
24.934. *
1
33
2
3
4
5
Material
Insulator:ABS
Body:Brass
30Vac-60Vdc/Max.60A
www.china-amass.com
www.china-amass.com
34
测试导线 Test Lead
测试导线 Test Lead
4mm Test Lead
2mm Test Lead
Test lead with the 2mm gold
plated plug on both ends.
36
11
Test lead with the injected 4mm satckable
nickel plated plug on both ends.
φ4
1
2
3
4
5
L
φ2
1
2
3
22.030.
22.040.
4
22.162.
22.171.
22.172.
22.170.
5
Rated voltage/current: 30Vac-60Vdc/Max.10A
0.50mm2 PVC 025 050
0.50mm2 SIL 025 050 100
Test lead with the 2mm stackable
gold plated plug on both ends.
11
26.5
3
22.050.
22.060.
4
1
5
18
59
18
025 050 100
L
2
3
4
5
22.190.
22.201.
Rated voltage/current: 30Vac-60Vdc/Max.15A
straight plug and the other end with the insulated 4mm 30
cap. Injected type.
L
φ4
φ4
3
4
22.090.
22.091.
5
1
0.75mm2 PVC
0.75mm2 SIL
025 050 100
025 050 100
0.75mm2 PVC
0.75mm2 SIL
025 050 100
025 050 100
φ4
42
2
3
4
5
22.210.
Rated voltage/current: CATIII 1000V/15A
L
70
0.75mm2 PVC 025 050 100
CE
4mm Safety Test Lead
4mm Test Lead
Test lead with the 4mm stackable
nickel plated plug on both ends. φ4
18
44.5
L
Safety test lead with the insulated 4mm
angled plug on both ends.Nickel plated
plugs with the protective cap. Injected type.
φ4
2
3
4
22.100.
22.111.
22.110.
Rated voltage/current: 30Vac-60Vdc/Max.19A
φ4
70
L
5
0.75mm2 PVC
0.75mm2 SIL
1.0mm2 JBF
1
025 050 100
025 050 100
025 050 100
2
22.241.
3
4
5
CE
4mm Test Lead
16
33
L
φ4
φ4
stackable plug on both ends. Nickel plated φ4
plugs with the red cap.
1
2
3
4
22.120.
22.121.
35
025 050 100
025 050 100
025 050 100
0.50mm2 PVC 025 050 100
47.5
2
1
30Vac-60Vdc/Max.15A
30Vac-60Vdc/Max.19A
30Vac-60Vdc/Max.32A
1
2.5mm2 SIL
0.75mm2 PVC
0.75mm2 PVC
2.5mm2 PVC
30Vac-60Vdc/Max.32A
φ4
φ2
4mm Test Lead
1
L
φ4
Test lead with the 4mm nickel
L
φ2
2
48.5
4mm Test Lead
2mm Test Lead
1
18
5
0.75mm2 PVC
1.0mm2 JBF
www.china-amass.com
025 050 100
025 050 100
2
22.390.
22.391.
22.401.
3
4
5
φ4
18.5
50
Rated voltage/current: CATIII 600V/19A
Rated voltage/current: CATIII 600V/32A
L
1.0mm2 JBF
2.5mm2 JBF
2.5mm2 SIL
www.china-amass.com
025 050 100
025 050 100
025 050 100
CE
CE
CE
36
测试导线 Test Lead
测试导线 Test Lead
4mm Test Lead
4mm straight plug and the other end with the
40
with the protective cap. Assembled type.
Safety test lead with 4mm stackable plug
on both ends. Nickel plated plugs with the
shrinkable tube and red cap.
φ4
1
2
22.270.
22.280.
22.281.
22.291.
22.290.
3
4
5
41
CATIII 1000V/15A
CATIII 1000V/19A
CATIII 1000V/32A
CATIII 1000V/19A
CATIII 1000V/32A
L
0.75mm2 PVC
1.0mm2 PVC
2.5mm2 PVC
1.0mm2 SIL
2.5mm2 SIL
54
025 050 100
025 050 100
025 050 100
CE
CE
CE
025 050 100
025 050 100
CE
CE
4
1
5
54
L
0.75mm2 PVC
1.0mm2 PVC
2.5mm2 PVC
1.0mm2 SIL
2.5mm2 SIL
CATIII 1000V/15A
CATIII 1000V/19A
CATIII 1000V/32A
CATIII 1000V/19A
CATIII 1000V/32A
025
025
025
025
025
050
050
050
050
050
100
100
100
100
100
68.5
L
CATIII 1000V/19A
1.0mm2
CATIII 1000V/32A
CATIII 1000V/19A
CATIII 1000V/32A
2.5mm2
1.0mm2
2.5mm2
PVC
PVC
SIL
SIL
025 050 100
025 050 100
025 050 100
CE
CE
CE
025 050 100
CE
CE
CE
CE
CE
CE
2
3
22.480.
22.481.
22.282.
22.500.
4
φ4
φ4
18
5
56
L
Rated voltage/current: 30Vac-60Vdc/Max.32A
2
1.0mm PVC
2.5mm2 PVC
2.5mm2 SIL
025 050 100
025 050 100
025 050 100
4mm Test Lead
Test lead one end with the 4mm stackable
nickel plated plug and the other end with
55mm length nickel plated crocodile clip.
55
22.300.
22.310.
22.311.
22.321.
22.320.
3
4
straight plug on both ends. Nickel plated plugs
φ4
2
22.460.
22.461.
22.490.
22.491.
3
4mm Test Lead
1
2
φ4
φ4
1
φ4
φ4
2
22.510.
22.520.
3
4
18
5
59
L
0.75mm2 PVC
0.75mm2 SIL
025 050 100
025 050 100
1
2
3
22.420.
22.421.
22.440.
4
5
L
4mm Test Lead
Rated voltage/current: CATIII 600V-CATII 1000V/19A 1.0mm2 PVC 025 050 100
Rated voltage/current: CATIII 600V-CATII 1000V/32A 2.5mm2 PVC 025 050 100
Rated voltage/current: CATIII 600V-CATII 1000V/32A 2.5mm2 SIL 025 050 100
CE
CE
CE
1
4mm Test Lead
φ4
1
2
22.450.
22.451.
22.470.
37
3
4
2
22.570.
22.580.
φ4
L
φ4
55mm length nickel plated crocodile clip. φ4
3
4
18
5
44.5
L
2
0.75mm PVC
0.75mm2 SIL
39.7
025 050 100
025 050 100
5
φ4
φ4
18.5
Rated voltage/current: CATII 600V/19A
Rated voltage/current: CATII 600V/32A
025 050 100
2.5mm2 SIL
www.china-amass.com
CE
CE
CE
22.900.
22.901.
50
L
0.75mm2 PVC
1.0mm2 PVC
www.china-amass.com
100
100
CE
CE
38
BNC 转接 BNC Adapter & Breakouts
21.010
21.050
Feture:Insulated BNC Male to 2*4mm straight safety plugs,connected with
the flexible RG58/50Ω wire.L:1.2M
Rating:CATI 500V、CATII 150V/3A
Feture:Insulated BNC Male to two crocodile clips,connected with the
21.060
Feture:Insulated BNC Male at the each end,connected with the flexible
RG58/50Ω wire.L:1.0M
21.020
Feture:Insulated BNC Male to 2*4mm stackable safety plugs,connected
with the flexible RG58/50Ω wire.L:1.2M
21.131
21.132
21.030
Feture:Insulated BNC Male to 2*4mm stackable plugs,connected with the
Feture:BNC Male with 2*4mm Stackable Plug
Material:
Body:Brass; Spring:Beryllium copper; Surface:Nickel plated
Rating:Maxium voltage for hands free use:500Vrms
21.133
21.040
Feture:Insulated BNC Male to 2*Mini test clips,connected with the flexible
Feture:BNC Male with 2*4mm Stackable Binding Post
Material:
Body:Brass; Surface:Nickel plated
Feture:BNC Female with 2*4mm Stackable Plug
Material:
21.134
Feture:BNC Female with 2*4mm Stackable Binding Post
Material:
21.135
Feture:Feture:BNC Male with the Binding Post
39
www.china-amass.com
www.china-amass.com
40
鳄鱼夹 Crocodile clip
21.151
27.187. *
27.260. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
30Vac-60Vdc/Max.10A
Feture: Safety BNC Male with 2x4mm Male Safety Socket
Material:
Body: Brass; Surface:Nickel plated
1
2
3
4
5
6
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 300V/Max.15A
1
27.257. *
2
27.262. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 300V/Max.15A
21.152
Feture: Safety BNC Male with 2x4mm Female Safety Socket
Material:
1
2
27.258. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
1
2
3
4
5
6
27.263. *
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
CATII 300V/Max.15A
1
2
4
5
3
27.259. *
1
2
4
5
27.264. *
材质 Material
塑壳 Insulator: ABS
主体 Body:
钢 Steel
30Vac-60Vdc/Max.19A
41
www.china-amass.com
1
2
4
5
3
材质 Material
塑壳 Insulator: PA
主体 Body:
铜 Brass
3
1
www.china-amass.com
2
42
鳄鱼夹 Crocodile clip
材质 Material
塑壳 Insulator: ABS
主体 Body:
钢 Steel
材质 Material
塑壳 Insulator: ABS
主体 Body:
铜 Brass
2
7
1
27.330. *
2
1
2
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
材质 Material
主体 Body:
钢 Steel
3Max.10A
1
27.710
1
2
27.720. *
2
27.710/711/712. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
Max.50A
材质 Material
塑壳 Insulator: ABS
主体 Body:
钢 Steel
1
27.716. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
铜 Brass
27.211. *
27.719. *
27.715. *
27.320. *
1
鳄鱼夹 Crocodile clip
27.722. *
27.717. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
2
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
Max.30A
材质 Material
塑壳 Insulator: ABS
主体 Body:
钢 Steel
27.711
27.712
1
27.714. *
43
2
2
27.723. *
27.718. *
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
1
1
2
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
1
www.china-amass.com
2
材质 Material
塑壳 Insulator: PVC
主体 Body:
钢 Steel
Max.30A
1
2
www.china-amass.com
44
测试组套 Test Kits
33.110
测试组套 Test Kits
33.150
2 x 4mm safety test lead:22.420(1mm2 JBF wire,L:100cm)
2 x test probe:20.164
2 x safety crocodile clips:27.262
2 x test clip:20.169
2 x 4mm safety test lead:22.280(1mm2 JBF wire,L:100cm)
2 x 4mm test lead:22.530(0.75mm2 PVC wire,L:25cm)
2 x test probe:20.157
33.120
2 x test probe:20.168
33.310
2 x 4mm test lead:22.370(1mm2 JBF wire,L:100cm)
33.130
2 x 4mm safety test lead:22.310(1mm2 JBF wire,L:100cm)
Packed in the tool bag
33.320
33.140
2 x connecting plug:26.451
2 x connecting plug:26.456
45
www.china-amass.com
www.china-amass.com
46
测试组套 -DIY 区 Test kits-DIY Zone
35.900
配件 Accessories
六角螺母 Hex nut
圆螺母 Round nut
Choose the products from our catalogue and we will pack them into
the tool bag as you want.Suitable for the small test kits with the test
lead within 100CM.
Feature:1.Five independent space of each bag
2.Tool bag can hang on the wall or your belt
3.Free logo space
35.910
the magic tool box as you want.Suitable for the medium test kits with
the test lead within 200CM.
Feature:1.Tool box can be devided into the different space with the
plastic insert
3.Free logo space
Item No.
T
e
sw
035.0005
M4
3
6
035.0010
M6
2
8
035.0014
M8
3
10
035.0023
M12
2.5
14
Item No.
T
e
035.0039
M6
2.5
8
035.0029
M8
3
10
035.0030
M12
5
14
φ
端子 Terminals
35.911
the magic tool box as you want.Suitable for the big test kits with the
test lead within 500CM.
plastic insert
3.Free logo space
Item No.
W
L
023.0083
2.8
14
023.0084
4.8
15
023.0085
3.8
19
六角管 Hex spacers
35.920
33.140
the tool box as you want.Suitable for the professional test kits.
Feature:1.Special material to make the box that insure it can save in
different working enviroment
2.Foam-rubber cushion protect the inside products
3.Free logo space
47
www.china-amass.com
Item No.
φ
sw
L
023.0086
3
6
8
023.0087
3
6
www.china-amass.com
48
很抱歉,暂时无法提供与“25.413.1.N”相匹配的价格&库存,您可以联系我们找货
免费人工找货 - 国内价格
- 1+ 3.348 1+ 0
- 10+ 2.6136 10+ 0
- 30+ 2.3004 30+ 0
- 250+ 1.836 250+ 0
- 500+ 1.6524 500+ 0
