SURFACE MOUNT ALUMINUM ELECTROLYTIC CAPACITORS
MVY
@Endurance : 105C 1000 to 2000 hours
@Suitable to fit for downsized equipment
@Solvent-proof type (see PRECAUTIONS AND GUIDELINES)
@Pb-free design
low Z
Standard, 105C
MVH
125C
MVK
MVL
MVJ
longer life
?SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
-40 to +105C
Rated Voltage Range
Capacitance Tolerance
Leakage Current
6.3 to 50Vdc
P20% (M)
(at 20C, 120Hz)
I=0.01CV or 3MA, whichever is greater.
Where, I : Max. leakage current (MA), C : Nominal capacitance (MF), V : Rated voltage (V)
(at 20C after 2 minutes)
6.3V 10V 16V 25V 35V 50V
Rated voltage (Vdc)
D55 to F55 0.30 0.24 0.20 0.16 0.14 0.12
tanE (Max.)
H63 to JA0 0.40 0.30 0.26 0.16 0.14 0.12
(at 20C,120Hz)
Rated voltage (Vdc)
2
2
2
3
2
4
Z(-25C)/Z(+20C)
3
10
8
6
4
3
Z(-40C)/Z(+20C)
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20C after the rated voltage is applied for the specified
period of time at 105C.
Case code
D55 to F55
H63 to JA0
Time
1000hours
2000hours
Capacitance change
[P30% of the initial value
[P20% of the initial value
D.F. (tanE)
[300% of the initial specified value [200% of the initial specified value
Leakage current
[The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20C after exposing them for the specified time at 105C
without voltage applied.
Case code
D55 to F55
H63 to JA0
Time
500hours
1000hours
Capacitance change
[P25% of the initial value
D.F. (tanE)
[200% of the initial specified value [200% of the initial specified value
Leakage current
Dissipation Factor
(tane)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
?DIMENSIONS [mm]
?MARKING
W
Size code
D55
E55
F55
H63
HA0
JA0
P
CP0.2
BP0.2
FDP0.5
@Terminal Code : A
0.3max.
LP0.3 (Note)
Note : LP0.5 for H63 to JA0
AP0.2
D
4
5
6.3
8
8
10
L
A
B
C
5.2 4.3 4.3 5.1
5.2 5.3 5.3 5.9
5.2 6.6 6.6 7.2
6.3 8.3 8.3 9.0
10.0 8.3 8.3 9.0
10.0 10.3 10.3 11.0
W
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.5 to 0.8
0.7 to 1.1
0.7 to 1.1
P
1.0
1.4
1.9
2.3
3.1
4.5
EX) 6.3V100MF
7hK
100
6.3V
?PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E MV K AAA A DA AAA M AAA G
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7MF:4R7,10MF:100)
Taping code
Terminal code
Voltage code (ex. 6.3V:6R3,10V:100,50V:500)
Series code
Category
Please refer to "A guide to global code (surface mount type)"
(1/2)
CAT. No. E1001E
Standard, 105C
?STANDARD RATINGS
WV
(Vdc)
6.3
10
16
25
35
Cap
(mF)
Case code
tane
Rated ripple
current
(mArms/
105c,120Hz)
22
47
100
330
1000
33
100
220
10
22
47
470
33
47
100
330
4.7
D55
E55
F55
HA0
JA0
E55
H63
HA0
D55
E55
F55
JA0
F55
H63
HA0
JA0
D55
0.30
0.30
0.30
0.40
0.40
0.24
0.30
0.30
0.20
0.20
0.20
0.26
0.16
0.16
0.16
0.16
0.14
21
36
56
290
410
34
90
180
16
30
48
460
45
80
180
450
15
Part No.
EMVK6R3ADA220MD55G
EMVK6R3ADA470ME55G
EMVK6R3ADA101MF55G
EMVK6R3ADA331MHA0G
EMVK6R3ADA102MJA0G
EMVK100ADA330ME55G
EMVK100ADA101MH63G
EMVK100ADA221MHA0G
EMVK160ADA100MD55G
EMVK160ADA220ME55G
EMVK160ADA470MF55G
EMVK160ADA471MJA0G
EMVK250ADA330MF55G
EMVK250ADA470MH63G
EMVK250ADA101MHA0G
EMVK250ADA331MJA0G
EMVK350ADA4R7MD55G
WV
(Vdc)
35
50
(2/2)
Cap
(mF)
Case code
tane
Rated ripple
current
(mArms/
105c,120Hz)
10
22
33
220
0.10
0.22
0.33
0.47
1.0
2.2
3.3
4.7
10
22
33
47
100
E55
F55
H63
JA0
D55
D55
D55
D55
D55
D55
D55
E55
F55
H63
HA0
HA0
JA0
0.14
0.14
0.14
0.14
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
0.12
25
40
80
375
1.3
2.6
3.2
3.8
5.6
10
14
19
29
70
140
170
310
Part No.
EMVK350ADA100ME55G
EMVK350ADA220MF55G
EMVK350ADA330MH63G
EMVK350ADA221MJA0G
EMVK500ADAR10MD55G
EMVK500ADAR22MD55G
EMVK500ADAR33MD55G
EMVK500ADAR47MD55G
EMVK500ADA1R0MD55G
EMVK500ADA2R2MD55G
EMVK500ADA3R3MD55G
EMVK500ADA4R7ME55G
EMVK500ADA100MF55G
EMVK500ADA220MH63G
EMVK500ADA330MHA0G
EMVK500ADA470MHA0G
EMVK500ADA101MJA0G
CAT. No. E1001E
很抱歉,暂时无法提供与“EMVK500ADA101MJA0F”相匹配的价格&库存,您可以联系我们找货
