GM3488E/GM3490E/GM3491E
Low-Power,RS-485/RS-422 Transceivers
1. Feature
3. General Description
Devices in the GM3485E family (GM3488E/ GM3490E/
GM3491E) are ±15kV ESD-protected, +3.3V, low-power
transceivers for RS-422 communications. Each device
contains one driver and one receiver.
The GM3488E feature slew-rate-limited drivers that
minimize EMI and reduce reflections caused by
improperly terminated cables, allowing error-free data
transmission at data rates up to 1Mbps. The GM3490E,
and GM3491E transmit at up to 12Mbps.
ESD Protection for RS-485 I/O Pins
• ±15kV—Human Body Model
• ±8kV—IEC 1000-4-2, Contact Discharge
• ±15kV—IEC 1000-4-2, Air-Gap Discharge
Operate from a Single +3.3V Supply—
No Charge Pump Required
Interoperable with +5V Logic
Guaranteed 12Mbps Data Rate
(GM3490E/GM3491E)
Slew-Rate Limited for Error less Data Transmission
(GM3488E)
-7V to +12V Common-Mode Input Voltage Range
Current-Limiting and Thermal Shutdown for Driver
Overload Protection
2. APPLICATIONS
Telecommunications
Industrial-Control Local Area Networks
Transceivers for EMI-Sensitive Applications
Integrated Services Digital Networks
Packet Switching
All devices feature enhanced electrostatic discharge
(ESD) protection. All transmitter outputs and receiver
inputs are protected to ±15kV using IEC 1000-4-2
Air-Gap Discharge, ±8kV using IEC 1000-4-2 Contact
Discharge, and ±15kV using the Human Body Model.
Drivers are short-circuit current limited and are
protected against excessive power dissipation by
thermal shutdown circuitry that places the driver
outputs into a high-impedance state. The receiver input
has a fail-safe feature that guarantees a logic-high
output if both inputs are open circuit. The GM3488E,
GM3490E, and GM3491E feature full
duplex
communication.
Figure 1 Simplified Schematic
www.gmmicro.com
Copyright © GATEMODE Corp.
-1-
Tel: (+86) 13135660803
Email: sales@gmmicro.com
4. Specifications
4.1 ABSOLUTE GMIMUM RATINGS
Parameter
VCC
Description
MIN
Supply Voltage
MAX
UNIT
+7
V
RE , DE
Control Input Voltage
-0.3
+7
V
DI
Driver Input Voltage
-0.3
+7
V
A, B,Y,Z
Driver Output Voltage
-7.5
+12.5V
V
A, B
Receiver Input Voltage
-7.5
+12.5V
V
RO
Receiver Output Voltage
0.3
VCC+0.3V
Storage Temperature Range
-65
150
°C
4.2 DC ELECTRICAL CHARACTERISTICS
(VCC = +3.3V ±0.3V, TA = TMIN to TGM, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER
Differential Driver Output
CONDITIONS
MIN
RL = 100Ω (RS-422), Figure 4
2.0
RL = 54Ω (RS-485), Figure 4
1.5
RL = 60Ω (RS-485), VCC = 3.3V, Figure 5
1.5
SYMBOL
VOD
TYP
MAX
UNIT
V
Change in Magnitude of
Driver Differential Output
Voltage for Complementary
△VOD
R = 54Ω or 100Ω, Figure 4
0.2
V
VOC
3
V
△VOC
0.2
V
Output States(Note 1)
Driver Common-Mode
Output Voltage
Change in Magnitude of Driver
Common-Mode Output
Output States
Input High Voltage
VIH
DE, DI, RE
Input Low Voltage
VIL
DE, DI, RE
0.8
V
Input Current
IIN1
DE, DI, RE VCC floating
±2
µA
Input Current (A, B)
IIN2
Output Leakage (Y, Z)
IO
in Shutdown Mode
Receiver Differential Threshold
Voltage
Receiver Input Hysteresis
Receiver Output High Voltage
www.gmmicro.com
IO
VTH
△VTH
VOH
2.0
V
DE = 0V;
VIN = 12V
1.0
VCC = 0V or 3.6V
VIN = -7V
-0.8
DE = 0V, RE = 0V,
VOUT = 12V
100
VCC= 0V or 3.6V, GM3491E VOUT = -7V
-100
VOUT = 12V
100
-100
DE = 0V, RE = 3.6V,
-0.2
-7V≤VCM ≤12V
0.2
50
VCM = 0V
IO = -4mA, VID = 200mV,Figure 6
-2-
VCC-0.4
mA
µA
µA
V
mV
V
DC ELECTRICAL CHARACTERISTICS(continued)
MAX
UNIT
IO = 4mA, VID = -200mV,Figure 6
0.4
V
IOZR
VCC = 3.6V, 0V ≤ VOUT ≤ VCC
±1
µA
Receiver Input Resistance
RIN
-7V ≤ VCM ≤ 12V
Supply Voltage Range
VCC
PARAMETER
SYMBOL
Receiver Output Low Voltage
VOL
Three-State (high impedance)
Output Current at Receiver
Supply Current
Supply Current in Shutdown
Mode
Driver Short-Circuit Current
Receiver Short-Circuit Output
Current
ESD Protection for Y, Z, A, B
ICC
ISHDN
IOSD
IOSR
CONDITIONS
TYP
96
kΩ
3.0
No load,
DI = 0 or VCC
3.6
DE = VCC, RE = 0 or
VCC
0.5
DE = 0V, RE = 0
0.45
0.9
1.3
2
1.0
VOUT = -7V
-250
VOUT = 12V
250
±8
0V ≤ VO ≤ VCC
±60
IEC 1000-4-2 Air Discharge
±15
IEC 1000-4-2 Contact Discharge (GM3491E)
±8
IEC 1000-4-2 Contact Discharge (GM3490E,
Human Body Model
-3-
V
mA
DE = 0, RE = VCC, DI = VCC or 0
GM3488E)
www.gmmicro.com
MIN
±8
µA
mA
mA
KV
±15
4.3 Switching Characteristics—GM3490E/GM3491E
(VCC = +3.3V, TA = +25°C.)
PARAMETER
SYMBOL
CONDITIONS
Maximum Data Rate
Delay
Transition Time
Driver Propagation Delay,
Low-to-High Level
High-to-Low Level
MIN
TYP
12
15
MAX
UNITS
Mbps
tDD
RL = 60Ω, Figure 7
1
22
35
ns
tDD
RL = 60Ω, Figure 7
3
11
25
ns
tPLH
RL = 27Ω, Figure 8
7
23
35
ns
tPHL
RL = 27Ω, Figure 8
7
23
35
ns
tPDS
RL = 27Ω, Figure 8
-1.4
±8
ns
|tPLH - tPHL| Driver
Propagation Delay Skew
(Note 2)
DRIVER-OUTPUT ENABLE/DISABLE TIMES (GM3491E only)
Driver-Output Enable Time to
Low Level
High Level
Driver-Output Disable Time
from High Level
from Low Level
from Shutdown to Low Level
from Shutdown to High Level
www.gmmicro.com
tPZL
RL = 110Ω, Figure 10
42
90
ns
tPZH
RL = 110Ω, Figure 9
42
90
ns
tPHZ
RL = 110Ω, Figure 9
35
80
ns
tPLZ
35
80
ns
tPSL
650
900
ns
tPSH
RL = 110Ω, Figure 9
650
900
ns
-4-
4.4 SWITCHING CHARACTERISTICS—GM3488E
PARAMETER
SYMBOL
CONDITIONS
MIN
Delay
Transition Time
Low-to-High Level
High-to-Low Level
MAX
1000
Maximum Data Rate
TYP
UNITS
Kbps
tDD
RL = 60Ω, Figure 7
200
300
500
ns
tDD
RL = 60Ω, Figure 7
150
240
400
ns
tPLH
RL = 27Ω, Figure 8
200
300
500
ns
tPHL
RL = 27Ω, Figure 8
200
300
500
ns
tPDS
RL = 27Ω, Figure 8
±50
tPZL
300
500
ns
tPZH
RL = 110Ω, Figure 9
150
400
ns
tPHZ
RL = 110Ω, Figure 9
50
80
ns
tPLZ
50
80
ns
tPSL
1.9
2.7
µs
tPSH
RL = 110Ω, Figure 9
2.2
3.0
µs
|tPLH - tPHL| Driver
ns
(Note 2)
Low Level
High Level
from High Level
from Low Level
4.5 NOTES FOR ELECTRICAL/SWITCHING CHARACTERISTICS
Note 1: ∆VOD and ∆VOC are the changes in VOD and VOC, respectively, when the DI input changes state.
Note 2: Measured on |tPLH (Y) - tPHL (Y)| and |tPLH (Z) - tPHL (Z)|.
Note 3: The transceivers are put into shutdown by bringing high RE and DE low. If the inputs are in this state for less than 80ns,
the parts are guaranteed not to enter shutdown. If the inputs are in this state for at least 300ns, the parts are
guaranteed to have entered shutdown. See Low-Power Shutdown Mode section.
www.gmmicro.com
-5-
4.6 Pin Description
PIN
GM3488E
GM3490E
GM3491E
SOP8
SOP14
2
2
RO
3
RE
NAME
FUNCTION
Receiver Output: If A > B by 200mV, RO will be high; If A < B
by 200mV, RO will be low.
Receiver Output Enable. RO is enabled when RE is low; RO is
high impedance when RE is high.
Driver Output Enable. The driver outputs, Y and Z, are
enabled by bringing DE high. They are high impedance when
4
DE
DE is low. If the driver outputs are enabled, the parts
function as line drivers. While they are high impedance,
they function as line receivers if RE is low.
Driver Input. A low on DI forces output Y low and output Z
3
5
DI
high. Similarly, a high on DI forces output Y high and output
Z low.
4
6, 7
GND
5
9
Y
Non-inverting Driver Output
6
10
Z
Inverting Driver Output
A
8
12
A
Non-inverting Receiver Input
B
Inverting Receiver Input and Inverting Driver Output
7
11
B
1
14
VCC
1, 8, 13
N.C.
www.gmmicro.com
Ground
Non-inverting Receiver Input and Non-inverting Driver
Output
Positive Supply: 3.0V ≤ VCC ≤ 5.5V. Do not operate device
with VCC > 5.5V
No Connect—not internally connected
-6-
Figure 2. GM3488E/GM3490E Pin Configuration and Typical Operating Circuit
Figure 3. GM3491E Pin Configuration and Typical Operating Circuit
www.gmmicro.com
-7-
Figure 4. Driver VOD and VOC
Figure 5. Driver VOD with Varying Common-Mode Voltage
Figure 6. Receiver VOH and VOL
Figure 7. Driver Differential Output Delay and Transition Times
www.gmmicro.com
-8-
Figure 8. Driver Propagation Times
Figure 9. Driver Enable and Disable Times (tPZH, tPSH, tPHZ)
Figure 10. Driver Enable and Disable Times (tPZL, tPSL, tPLZ)
www.gmmicro.com
-9-
Figure 11. Receiver Propagation Delay
Figure 12. Receiver Enable and Disable Times
Note 4: The input pulse is supplied by a generator with the following characteristics: f = 250kHz, 50% duty cycle, tr ≤ 6.0ns,
ZO = 50Ω.
Note 5: CL includes probe and stray capacitance.
www.gmmicro.com
- 10 -
5. Function Tables
5.1 Devices with Receiver/Driver Enable (GM3491E)
Table 1. Transmitting
INPUTS
OUTPUTS
RE
DE
DI
B*
A*
1
1
High-Z
High-Z
1
High-Z
High-Z
MODE
Normal
Normal
Normal
Shutdown
* B and A outputs are Z and Y, respectively, for full-duplex part (GM3491E).
X = Don’t care; High-Z = High impedance
Table 2. Receiving
INPUTS
OUTPUTS
MODE
RE
DE
A,B
RO
1
≧ +0.2V
1
Normal
1
Normal
≦ -0.2V
Inputs Open
1
High-Z
Normal
Shutdown
* DE is a “don’t care” (x) for the full-duplex part (GM3491E).
5.2 Devices without Receiver/Driver Enable(GM3488E/GM3490E)
Table 3. Transmitting
INPUT
DI
1
www.gmmicro.com
Table 4. Receiving
OUTPUTS
Z
Y
1
INPUT
A,B
≧ +0.2V
≦ -0.2V
Inputs Open
- 11 -
OUTPUT
RO
1
6. Applications Information
TheGM3488E/GM3490E/GM3491E are low-power transceivers for RS-485 and RS-422 communications. The GM3488E can transmit
and receive at data rates up to 1Mbps, and the GM3490E/GM3491E at up to 12Mbps. The GM3488E/GM3490E/GM3491E are
full-duplex transceivers, Driver Enable (DE) and Receiver Enable (RE) pins are included on the GM3491E. When disabled, the driver
and receiver outputs are high impedance.
7. Reduced EMI and Reflections(GM3488E)
The GM3488E are slew-rate limited, minimizing EMI and reducing reflections caused by improperly terminated cables. Figure 13
shows the driver output waveform of a GM3490E/GM3491E transmitting a 125kHz signal, as well as the Fourier analysis of that
waveform. High-frequency harmonics with large amplitudes are evident. Figure 14 shows the same information, but for the
slew-rate-limited GM3488E transmitting the same signal. The high-frequency harmonics have much lower amplitudes, and the
potential for EMI is significantly reduced.
8. Low-Power Shutdown Mode(GM3491E)
A low-power shutdown mode is initiated by bringing both RE high and DE low. The devices will not shut down unless
both the driver and receiver are disabled (high impedance). In shutdown, the devices typically draw only 1.3uA of
supply current.For these devices, the tPSH and tPSL enable times assume the part was in the low-power shutdown mode;
the tPZH and tPZL enable times assume the receiver or driver was disabled, but the part was not shut down.
Figure 13. Driver Output Waveform and FFT Plot of
Figure 14. Driver Output Waveform and FFT Plot of GM3488E
GM3490E/GM3491E Transmitting a 125kHz Signal
Figure 15. GM3490E/GM3491E Driver Propagation Delay
Figure 16. GM3490E/GM3491E Receiver Propagation Delay
Driven by External RS-485 Device
www.gmmicro.com
- 12 -
Figure 17. GM3488E Driver Propagation Delay
Figure 18. GM3488E Receiver Propagation Delay
Figure 19. GM3488E System Differential Voltage at 125kHz
Figure 20. GM3490E/GM3491E System Differential Voltage at
Driving 4000 Feet of Cable
125kHz Driving 4000 Feet of Cable
9. Driver Output Protection
Excessive output current and power dissipation caused by faults or by bus contention are prevented by two
mechanisms. A fold-back current limit on the output stage provides immediate protection against short circuits over
the whole common-mode voltage range. In addition, a thermal shutdown circuit forces the driver outputs into a
high-impedance state if the die temperature rises excessively.
10. Propagation Delay
Figures 15–18 show the typical propagation delays. Skew time is simply the difference between the low-to-high and
high-to-low propagation delay. Small driver/receiver skew times help maintain a symmetrical mark-space ratio (50%
duty cycle). The receiver skew time, |tPRLH - tPRHL|, is under 10ns 20ns for the GM3488E). The driver skew times are 8ns
for the GM3490E/GM3491E.
11. Line Length vs. Data Rate
The RS-485/RS-422 standard covers line lengths up to 4000 feet. For line lengths greater than 4000 feet, see Figure 21
for an example of a line repeater. Figures 19 and 20 show the system differential voltage for parts driving 4000 feet of
26AWG twisted-pair wire at 125kHz into 120Ω loads. For faster data rate transmission, please consult the factory.
www.gmmicro.com
- 13 -
Figure 21. Line Repeater for GM3488E/GM3490E/GM3491E
12. ±15kV ESD Protection
ESD-protection structures are incorporated on all pins to protect against electrostatic discharges encountered during
handling and assembly. The driver outputs and receiver inputs of the GM3485E family of devices have extra protection
against static electricity. Engineers have developed state-of
the-art structures to protect these pins against ESD of
±15kV without damage. The ESD structures withstand high ESD in all states: normal operation, shutdown, and
powered down.
ESD protection can be tested in various ways; the transmitter outputs and receiver inputs of this product family are
characterized for protection to the following limits:
1) ±15kV using the Human Body Model
2) ±8kV using the Contact-Discharge method specified in IEC 1000-4-2
3) ±15kV using IEC 1000-4-2’s Air-Gap method.
13. ESD Test Conditions
ESD performance depends on a variety of conditions. Contact us for a reliability report that documents test setup, test
methodology, and test results.
14. Human Body Model
Figure 22a shows the Human Body Model and Figure 22b shows the current waveform it generates when discharged
into a low impedance. This model consists of a 100pF capacitor charged to the ESD voltage of interest, which is then
discharged into the test device through a 1.5kΩ resistor.
www.gmmicro.com
- 14 -
15. IEC 1000-4-2
The IEC 1000-4-2 standard covers ESD testing and performance of finished equipment; it does not specifically refer to
integrated circuits. The GM3485E family of devices helps you design equipment that meets Level 4 (the highest level)
of IEC 1000-4-2, without the need for additional ESD-protection components.
The major difference between tests done using the Human Body Model and IEC 1000-4-2 is higher peak current in IEC
1000-4-2, because series resistance is lower in the IEC 1000-4-2 model. Hence, the ESD withstand voltage measured to
IEC 1000-4-2 is generally lower than that measured using the Human Body Model. Figure 23a shows the IEC 1000-4-2
model, and Figure 23b shows the current waveform for the ±8kV IEC 1000-4-2, Level 4 ESD contact-discharge test.
The air-gap test involves approaching the device with a charged probe. The contact-discharge method connects the
probe to the device before the probe is energized.
Figure 22a. Human Body ESD Test Model
Figure 22b. Human Body Current Waveform
Figure 23a. IEC 1000-4-2 ESD Test Model
Figure 23b. IEC 1000-4-2 ESD Generator Current Waveform
16. Machine Model
The Machine Model for ESD tests all pins using a 200pF storage capacitor and zero discharge resistance. Its objective is
to emulate the stress caused when I/O pins are contacted by handling equipment during test and assembly. of course,
all pins require this protection, not just RS-485 inputs and outputs.
www.gmmicro.com
- 15 -
17. Typical Applications
The GM3488E/GM3490E/GM3491E transceivers are designed for bidirectional data communications on multi point
bus transmission lines. Figures 24 show typical net
work applications circuits. These parts can also be used as line
repeaters, with cable lengths longer than 4000 feet, as shown in Figure 21.
To minimize reflections, the line should be terminated at both ends in its characteristic impedance, and stub lengths
off the main line should be kept as short as possible. The slew-rate-limited GM3488E is more tolerant of imperfect
termination.
Figure 24. GM3488E/GM3490E/GM3491E Full-Duplex RS-485 Network
www.gmmicro.com
- 16 -
SOP-8L
MILLIMETER
SYMBOLS
MIN
NOM
MAX
A
1.5
1.7
A1
0.1
0.25
A2
1.3
1.4
1.5
b
0.33
0.4
0.47
C
0.2
0.25
D
4.7
4.9
5.1
E
5.9
6
6.1
E1
3.8
3.9
4
e
1.27(BSC)
L
0.55
0.6
0.75
L1
1.05(BSC)
θ
0°
4°
8°
www.gmmicro.com
- 17 -
SOP-14
MILLIMETER
SYMBOLS
MIN
NOM
MAX
A
1.75
A1
0.05
0.225
A2
1.30
1.40
1.50
A3
0.60
0.65
0.70
b
0.39
0.47
b1
0.38
0.41
0.44
c
0.20
0.24
c1
0.19
0.20
0.21
D
8.55
8.65
8.75
E
5.80
6.00
6.20
E1
3.80
3.90
4.00
e
1.24BSC
h
0.25
0.50
L
0.50
0.80
L1
θ
www.gmmicro.com
1.05REF
0°
- 18 -
8°
Order Information
Order number Package
Marking information
Operation Temperature
Range
MSL Grade
Ship, Quantity Green
GM3488ESA
SOP8
GM3488E
-40 to 85°C
3
T&R, 2500
Rohs
GM3490ESA
SOP8
GM3490E
-40 to 85°C
3
T&R, 2500
Rohs
GM3491ESA
SOP14
GM3491E
-40 to 85°C
3
T&R, 2500
Rohs
www.gmmicro.com
- 19 -
Version modification record
version
Modify the description
page
time
Modify personnel
On June 21,2024
Fan
1.Original:GM3490_GM3491_1.0 →
GM3490_GM3491_1.1
2.Input Current testing environment.Increase the VCC
Floating
3.Output Leakage (Y, Z)
1.1
VOUT = 12V environment MAX=20uA → MAX=100uA.
VOUT = -7V environment MAX=-20uA → MAX=-100uA.
2
4.Output Leakage (Y, Z) in Shutdown Mode,
testing environment RE =0V → RE =5V,
VOUT = 12V environment. MAX=1uA → MAX=100uA.
VOUT = -7V environment MAX=-1uA → MAX=-100uA.
www.gmmicro.com
- 20 -
