GM7350
40V 250mA Ultralow-Quiescent-Current LDO
General Description
The GM7350 ultra-low quiescent current
regulator features low dropout voltage and low
current in the standby mode. With less than 1.5μA
quiescent current at no load, the GM7350 is ideally
suited for standby micro-control-unit systems,
especially for always-on applications like E-meters,
fire alarms, smoke detectors and other battery
operated systems. The GM7350 retains all of the
features that are common to low dropout
regulators including a low dropout PMOS pass
device, short circuit protection, and thermal
shutdown.
The GM7350 has a 40-V maximum operating
voltage limit, a -40°C to 125°C operating
temperature range, and ±2% output voltage
tolerance over the entire output current, input
voltage, and temperature range. The GM7350 is
available in a SOT893 through-hole and SOT235,
surface mount packages.
Ordering Information
Part Number
GM7350
Package
SOT893
Ordering Number
GM7350
SOT235
GM7350K
Dropout Voltage Typically 1200 mV
at IOUT = 250 mA
Internal Thermal Overload Protection
Internal Short-Circuit Current Limit
Ceramic Capacitor Stable
Applications
E-meters, Water Meters and Gas Meters
Fire Alarm, Smoke Detector
Appliances and White Goods
Pin Configuration
SOT235
SOT893
Typical Application Circuit
Features
VIN Range up to 40V
Output Voltage Tolerances of ±2% Over the
Temperature Range
Output Current of 250 mA
Ultra Low Quiescent Current (IQ = 1.5 μA)
www.gmmicro.com
Hang Zhou Gatemode Microelectronics Ltd
1
GM7350
Pin Assignment
Pin Name
Pin No.
SOT235
Pin No.
SOT893
VOUT
GND
VIN
EN
5
2
1
3
3
1
2,4
Pin Function
Output Voltage Pin
Ground
Input Voltage pin.
Enable
Function Block Diagram
www.gmmicro.com
2
GM7350
Absolute Maximum Ratings (Note1)
VIN --------------------------------------------------------------------------------------------------
-0.3V to +45V
Junction Temperature------------------------------------------------------------------------------------------
125C
Lead Temperature (Soldering, 10 sec.)--------------------------------------------------------------------
300C
Storage Temperature ----------------------------------------------------------------------------
65C to 150C
Recommended Operating Conditions
Input Voltage, V IN ------------------------------------------------------------------------------
+2.7V to +40V
Junction Temperature ----------------------------------------------------------------------------- -40C to 125C
Electrical Characteristics
VIN=12V, IOUT=1mA, CIN=COUT=2.2uF, TJ=25℃, unless otherwise specified
Parameter
Symbol
Output Voltage
VOUT
Line Regulation
△VLINE
Load Regulation
△VLOAD
Dropout Voltage
Quiescent Current
VDROP
IQ
Test Conditions
Min
Typ
Max
Units
-2%
5.0
2%
V
VIN=VOUT + 1V to 40V
2
12
mV
IOUT= 1mA to 100mA
10
IOUT= 1mA to 250mA
IOUT=50mA
200
mV
IOUT=100mA
400
mV
IOUT=180mA
700
mV
IOUT=250mA
1200
mV
1.5
TJ= 25℃
Output Current
IOUT
Current Limit
ICL
270
Enable high level
VENHI
0.9
Enable low level
VENLO
mV
4.0
uA
250
mA
340
mA
V
0.4
V
Enable pin pull high current
IEN
0.3
uA
Thermal Shutdown
TSD
140
Thermal Shutdown
Hysteresis
THY
www.gmmicro.com
3
GM7350
Typical Characteristics
VIN=12V, IOUT=1mA, VOUT=3.3V, CIN=COUT=1uF, TJ=25℃, unless otherwise specified
Fig 1 Vout vs Vin
Fig 2 Iq vs Vin
Fig 3 Vout vs Load
Fig 4 Dropout vs Load
Fig 5 Vout Load Transient (0 to 50mA)
Fig 6 Vout Load Transient (1 to 250mA)
www.gmmicro.com
4
GM7350
Fig 7 Vout Load Transient (50 to 250mA)
Fig 8 Vout Short to GND
Fig 9 Vin Start up
www.gmmicro.com
5
GM7350
Package Information
SOT89-3
符号
毫米
英寸
最小值
典型值
最大值
最小值
典型值
最大值
A
1.4
1.5
1.6
B
2.8
3
3.2
B1
1.4
1.5
1.6
C
0.3
0.4
0.5
C1
0.3
0.4
0.5
D
4.4
4.5
4.6
D1
1.4
1.6
1.8
E
2.4
2.5
2.6
e
0.37
0.47
0.57
e1
0.22
0.42
0.62
H
4.25
L
0.8
www.gmmicro.com
6
GM7350
SOT23-5
符号
毫米
英寸
最小值
典型值
最大值
最小值
典型值
最大值
A
1.05
1.15
1.25
A1
0.0
0.05
0.1
A2
1.05
1.1
1.15
b
0.3
0.4
0.5
c
0.1
0.15
0.2
D
2.82
2.92
3.02
E
1.5
1.6
1.7
E1
2.65
2.8
2.95
e
0.95
e1
1.9
L
0.3
0.6
Ɵ
0°
8°
www.gmmicro.com
7
很抱歉,暂时无法提供与“GM7350”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.39677
- 100+0.32364
- 200+0.31879
- 400+0.28708
- 1000+0.22410
