DW01
BATTERY PROTECTION IC FOR 1-CELL PACK
■ Features
(1) High-accuracy voltage detection circuit
‧Overcharge detection voltage
3.6 to 4.4V
Accuracy
±50 mV
‧Overcharge release voltage
3.6 to 4.4V
Accuracy
±50 mV
‧Overdischarge detection voltage
2.0 to 3.0 V
Accuracy
±100 mV
‧Overdischarge release voltage
2.0 to 3.4V
Accuracy
±100 mV
‧Discharge overcurrent detection voltage
0.05 to 0.30 V
Accuracy
±30 mV
‧Load short-circuiting detection voltage
0.6V
Accuracy
±200 mV
(2) Detection delay times are generated by an internal circuit (external capacitors are unnecessary).
‧Overcharge detection delay time
Typical
100ms
‧Overdischarge detection delay time
Typical
120ms
‧Discharge overcurrent detection delay time
Typical
16ms
‧Load short-circuiting detection delay time
Typical
750s
(3)
(4)
(5)
(6)
High voltage tolerance is used for charger connection pins, VM and CO pins are absolute maximum rating=28V)
0V battery charge function available /unavailable are selectable.
Wide operating temperature range
-40 to +85℃
Low current consumption
Operation mode
Typ. 2.4 A
Standby mode
Green-mode
Max. 0.1 A
25℃
Self-recovery function
Max. 3.0 A
25℃
■ Applications
‧ Lithium-ion rechargeable battery packs
‧ Lithium polymer rechargeable battery packs
Max. 6.0 A (25℃ )
DW01
■ Block Diagram
CO
Level shift
Divider
Oscillator
VDD
DO
VCHA
VDET1
Charger Detection
Overcharge
VDET3
VDET4
Charge overcurrent
Control
Logic
VDET2
Overdischarge
VM
Short circuiting
VSS
DW01
■ Absolute Maximum Rating
Item
Symbol
Rating
Unit
Supply voltage
VDD
-0.3~10
V
VM termial input voltage
VM
VDD-28~VDD+0.3
V
CO terminal Output voltage
VCO
VDD-28~VDD+0.3
V
DO terminal Output voltage
VDO
VDD-0.3~VDD+0.3
V
Operation temperature
Topr
-40~+85
Storage temperature
Tstg
-55~+125
DW01
Operation Temperature=25℃
■ Electrical Characteristics
Parameter
Operating voltage between VDD & VSS
Symbol
Conditions
Min.
Typ.
Max.
Unit
1.5
9.0
V
1.5
25.0
V
VDD-VM,
VDD-VSS=0V
1.2
V
VDD=3.6,VM=1.0V
30
50
100
K
VDD
Operating voltage between CO & VM
Minimum operating voltage
for 0V charging
Discharging overcurrent
release resistance
Vst
Rshort
CO pin Nch ON voltage
VCOL
0.4
0.5
V
CO pin Pch ON voltage
VCOH
VDD-0.1
VDD-0.02
V
DO pin Nch ON voltage
VDOL
0.2
0.5
V
DO pin Pch ON voltage
VDOH
VDD-0.1
VDD-0.02
V
VDD=3.5V,VM=0V
1.2
2.4
6.0
uA
Ist
VDD=VM=2.0V
0.1
uA
IDOX
VDD=VM=2.0V
1.8
3.0
uA
Min.
Typ.
Max.
Unit
Current consumption
Current consumption at stand-by(Green)
Overdischarge current consumption
(Self-recovery)
Parameter
IDD
Symbol
Conditions
Vdet1
R1=100
4.240
4.2800
4.330
V
Vrel1
R1=100
4.030
4.080
4.130
V
Overcharge hysteresis voltage
Vhys1
R1=100
Vhys1=Vdet1-Vrel1
0.200
V
Vdet2
VM=0V,R1=100
2.300
2.400
2.500
V
Vrel2
R1=100
2.900
3.000
3.100
V
Overdischarge release voltage2
Vrel2'
2.300
2.400
2.500
V
Discharging overcurrent detection voltage
Vdet3
R1=100,
R2=1.0k, VM=Vchg
VDD=3.0V,
R2=1.0k
0.110
0.140
0.170
V
Short detection voltage
Vshort
VDD=3.0V
0.40
0.60
0.80
V
TVdet1
VDD=3.8V→4.5V
50
100
150
ms
TVdet2
VDD=3.2V→2.2V
60
120
180
ms
Discharging overcurrent detection delay
time
TVdet3
8
16
24
ms
Short detection delay time
Tshort
350
750
1100
us
Charger detection voltage
Vchg
VDD=3.0V,
VM=0V→0.2V
VDD=3.5V,
VM=0V→1.0V
VDD=3.6V,
R2=1.0k
0.3
0.7
1.1
V
DW01
Application Circuits
Discrete
Components
R1
Resistor
R2
Resistor
R3
Thermistor
C1
Function
Min.
Typ.
Max.
Unit
Remarks
100
1K
*1
300
1K
2K
*4
Temp. protection
k
Capacitor
Noise filtering
0.022
0.1
1.0
F
M1
N-MOSFET
Discharge switch
*2
M2
N-MOSFET
Charge switch
*2
Current limit
Noise filtering
Current limit
*1
ESD protection
R1 is a single-stage RC filter
the higher resistance of R1
*3
the better the filtering effect
If the R1
resistance higher than the recommended value it will affect the internal detection circuit and the
voltage detection accuracy will out of specification. We suggest using the recommended resistance in
application.
*2
The absolute maximum rating of CO and VM is 28V, customer could choose 20V or
N-MOSFET switches for different application.
*3
Add a C1 capacitor between VDD and VSS could filter conduction and radiation noise.
*4
R2 resistor could have a current limit function and limit charger current surge.
30V dual
DW01
DW01
Package Outline(Unit:mm)
很抱歉,暂时无法提供与“DW01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33070
- 100+0.26331
- 300+0.22961
- 3000+0.19538
- 6000+0.17518
- 9000+0.16503
