ES8327
ES8327
    EVEREST(顺芯)
    QFN32_4X4MM
    ADCs+DAC 1.6V~3.6V QFN32
ES8327 数据手册
ES8327 FEATURES Low Power Audio CODEC System • • • • Stereo DAC High performance and low power multibit delta-sigma audio ADC and DAC I2S/PCM/TDM master or slave serial data port 256/384Fs, USB 12/24 MHz and other non standard audio system clocks I2C interface • • • • • • • Stereo DMIC • • • Support 2-ch digital microphone 24-bit, 8 to 96 kHz sampling frequency 110 dB signal to noise ratio, -100 dB THD+N APPLICATIONS • • • Mono ADC • • • • • • 24-bit, 8 to 96 kHz sampling frequency 100 dB signal to noise ratio, -85 dB THD+N Ground centered headphone driver Dynamic range compression Headset detection OMTP and CTIA auto switch Pop and click noise suppression Notebook Tablet PC ORDERING INFORMATION 24-bit, 8 to 96 kHz sampling frequency 102 dB signal to noise ratio, -90 dB THD+N Two pairs of analog input with differential input option Low noise pre-amplifier Auto level control (ALC) and noise gate Noise reduction filter ES8327 -40°C ~ +105°C QFN-32 1 Everest Semiconductor 1. 2. 3. 4. 5. 6. 7. Confidential ES8327 BLOCK DIAGRAM ................................................................................................................... 6 PIN OUT AND DESCRIPTION ................................................................................................ 7 TYPICAL APPLICATION CIRCUIT.......................................................................................... 8 CLOCK MODES AND SAMPLING FREQUENCIES ............................................................... 9 MICRO-CONTROLLER CONFIGURATION INTERFACE ...................................................... 9 DIGITAL AUDIO INTERFACE................................................................................................. 11 ELECTRICAL CHARACTERISTICS ..................................................................................... 13 ABSOLUTE MAXIMUM RATINGS................................................................................................ 13 RECOMMENDED OPERATING CONDITIONS .............................................................................. 13 ADC ANALOG AND FILTER CHARACTERISTICS AND SPECIFICATIONS ........................................ 13 DAC ANALOG AND FILTER CHARACTERISTICS AND SPECIFICATIONS ........................................ 14 DC CHARACTERISTICS ................................................................................................................ 14 SERIAL AUDIO PORT SWITCHING SPECIFICATIONS ................................................................... 15 I2C SWITCHING SPECIFICATIONS (SLOW SPEED MODE/HIGH SPEED MODE) ........................... 16 8. CONFIGURATION REGISTER DEFINITION ........................................................................ 17 REGISTER 0X00 -RESET, DEFAULT 00011111 ............................................................................. 17 REGISTER 0X01 -CLOCK MANAGER, DEFAULT 00000000 .......................................................... 17 REGISTER 0X02-CLOCK MANAGER, DEFAULT 00000000 ........................................................... 18 REGISTER 0X03-CLOCK MANAGER, DEFAULT 00000010 ........................................................... 18 REGISTER 0X04-CLOCK MANAGER, DEFAULT 0000 0000 .......................................................... 19 REGISTER 0X05-CLOCK MANAGER, DEFAULT 0000 0000 .......................................................... 19 REGISTER 0X06-CLOCK MANAGER, DEFAULT 0000 0000 .......................................................... 19 REGISTER 0X07-CLOCK MANAGER, DEFAULT 0010 1101 .......................................................... 19 REGISTER 0X08-CLOCK MANAGER, DEFAULT 0000 1010 .......................................................... 20 REGISTER 0X09-CLOCK MANAGER, DEFAULT 0000 1010 .......................................................... 20 REGISTER 0X0A-CLOCK MANAGER, DEFAULT 00011111 .......................................................... 21 REGISTER 0X0B-CLOCK MANAGER, DEFAULT 00011111........................................................... 21 REGISTER 0X0C-CLOCK MANAGER, DEFAULT 00011111 ........................................................... 21 REGISTER 0X0D-CLOCK MANAGER, DEFAULT 0000 0011 ......................................................... 22 REGISTER 0X0E-CLOCK MANAGER, DEFAULT 0000 0000 .......................................................... 22 REGISTER 0X0F-CLOCK MANAGER, DEFAULT 11111111 ........................................................... 22 REGISTER 0X10 -CLOCK MANAGER, DEFAULT 1110 0000 ......................................................... 22 REGISTER 0X11-CLOCK MANAGER, DEFAULT 1010 0000 .......................................................... 23 REGISTER 0X12-CLOCK MANAGER, DEFAULT 0100 0000 .......................................................... 24 REGISTER 0X13-SDP, DEFAULT 00000000 ................................................................................. 24 Revision 2.0 2 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 REGISTER 0X14-SDP, DEFAULT 00000000 ................................................................................. 25 REGISTER 0X15-SDP, DEFAULT 00011111 ................................................................................. 25 REGISTER 0X16-ANALOG, DEFAULT 11111011 ......................................................................... 25 REGISTER 0X17-ANALOG,DEFAULT11111000 ........................................................................... 26 REGISTER 0X18-ANALOG, DEFAULT 00000000 ......................................................................... 26 REGISTER 0X19-ANALOG,DEFAULT 00000000 .......................................................................... 26 REGISTER 0X1A-ANALOG, DEFAULT 00000000 ......................................................................... 26 REGISTER 0X1B-ANALOG, DEFAULT 01000000 ......................................................................... 27 REGISTER 0X1C-ANALOG, DEFAULT 01111100 ......................................................................... 27 REGISTER 0X1D-ANALOG, DEFAULT 00001010 ......................................................................... 27 REGISTER 0X1E-ANALOG, DEFAULT 10001000.......................................................................... 27 REGISTER 0X1F-ANALOG, DEFAULT 10001000 .......................................................................... 28 REGISTER 0X20 -ANALOG, DEFAULT 10001000......................................................................... 29 REGISTER 0X21-ANALOG, DEFAULT 10001000 ......................................................................... 30 REGISTER 0X22-ANALOG, DEFAULT 00001100 ......................................................................... 30 REGISTER 0X23-ANALOG, DEFAULT 00000000 ......................................................................... 31 REGISTER 0X24-ANALOG, DEFAULT 00001111 ......................................................................... 31 REGISTER 0X25-ANALOG, DEFAULT 00010001 ......................................................................... 31 REGISTER 0X26-ANALOG, DEFAULT 00000000 ......................................................................... 32 REGISTER 0X27-ANALOG, DEFAULT 00000000 ......................................................................... 32 REGISTER 0X28-ANALOG, DEFAULT 10000111 ......................................................................... 33 REGISTER 0X29-ADC CONTROL, DEFAULT 00000000 ................................................................ 33 REGISTER 0X2A-ADC CONTROL, DEFAULT 00000000 ................................................................ 33 REGISTER 0X2B-ADC CONTROL, DEFAULT 00000000 ................................................................ 34 REGISTER 0X2C-ADC CONTROL, DEFAULT 10111111 ................................................................ 34 REGISTER 0X2D-ADC CONTROL, DEFAULT 1011 1111 ............................................................... 34 REGISTER 0X2E-ADC CONTROL, DEFAULT 00000000 ................................................................ 35 REGISTER 0X2F –NOT USED, DEFAULT 00000000 ..................................................................... 35 REGISTER 0X30 - NOT USED, DEFAULT 00000000 ..................................................................... 35 REGISTER 0X31- NOT USED, DEFAULT 00000000 ...................................................................... 35 REGISTER 0X32-ADC CONTROL, DEFAULT 00000000 ................................................................ 35 REGISTER 0X33-ADC CONTROL, DEFAULT 00000000 ................................................................ 36 Revision 2.0 3 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 REGISTER 0X34-ADC CONTROL, DEFAULT 00101100 ................................................................ 36 REGISTER 0X35-ADC CONTROL, DEFAULT 00001100 ................................................................ 36 REGISTER 0X36-ADC CONTROL, DEFAULT 00000000 ................................................................ 36 REGISTER 0X37-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X38-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X39-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X3A-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X3B-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X3C-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X3D-ADC CONTROL, DEFAULT 00000000................................................................ 37 REGISTER 0X3E-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X3F-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X40 -ADC CONTROL, DEFAULT 00000000 ............................................................... 37 REGISTER 0X41-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X42-ADC CONTROL, DEFAULT 00000000 ................................................................ 37 REGISTER 0X43-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X44-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X45-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X46-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X47-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X48-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X49-ADC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X4A-DAC CONTROL, DEFAULT 00000000 ................................................................ 38 REGISTER 0X4B-DAC CONTROL, DEFAULT 00000000 ................................................................ 39 REGISTER 0X4C-DAC CONTROL, DEFAULT 00000000 ................................................................ 39 REGISTER 0X4D-DAC CONTROL, DEFAULT 00001000................................................................ 39 REGISTER 0X4E-DAC CONTROL, DEFAULT 00100000 ................................................................ 39 REGISTER 0X4F-DAC CONTROL, DEFAULT 00010101 ................................................................ 40 REGISTER 0X50 -DAC CONTROL,DEFAULT10111111 ................................................................. 41 REGISTER 0X53-DAC CONTROL, DEFAULT 00000000 ................................................................ 41 REGISTER 0X54-DAC CONTROL, DEFAULT 00000000 ................................................................ 41 REGISTER 0X56-GPIO, DEFAULT 00000000 ............................................................................... 42 Revision 2.0 4 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 REGISTER 0X57-GPIO, DEFAULT 01010100 ............................................................................... 42 REGISTER 0X58-GPIO, DEFAULT 00000000 ............................................................................... 43 REGISTER 0X59-GPIO, DEFAULT 01000000 ............................................................................... 43 REGISTER 0X5A-GPIO, DEFAULT 10010000 ............................................................................... 43 REGISTER 0X5B-N/A, DEFAULT 00000000 ................................................................................. 44 REGISTER 0X5C-GPIO, DEFAULT 00000000 ............................................................................... 44 REGISTER 0XF9-TEST MODE, DEFAULT 11111010 ..................................................................... 45 REGISTER 0XFD-CHIP ID, DEFAULT 10000011 ........................................................................... 45 REGISTER 0XFE-CHIP ID, DEFAULT 00100110 ............................................................................ 45 REGISTER 0XFF-CHIP ID, DEFAULT 00000000 ............................................................................ 45 9. PACKAGE (UNIT: MM) .......................................................................................................... 46 10. CORPORATE INFORMATION .......................................................................................... 47 11. IMPORTANT NOTICE AND DISCLAIMER........................................................................ 47 Revision 2.0 5 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 1. BLOCK DIAGRAM Headset INTOUT GMS0 GMS1 CDATA CCLK CE MCLK 2 IC Clock Mgr Headset Detect/OMTP CTIA Auto Switch MIC1P PGA MIC1N Mono ADC ALC EQ I2S PCM TDM Interface MIC2P MIC2N LOUT ROUT HP Driver Analog Reference Power Supply DVDD PVDD DGND AVDD AGND CPVDD CPGND CPTOP CPBOT CPVSSP Revision 2.0 DRC ADCVREF DACVREF VMID Mic Bias Charge Pump Stereo DAC SDOUT SCLK LRCK SDIN 6 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 2. PIN OUT AND DESCRIPTION MIC1N MIC1P MIC2N MIC2P SDINOUT1/DMIC_SCL CE CDATA CCLK 25 26 27 28 29 30 31 32 MCLK/DMIC_SDA DVDD PVDD DGND SCLK SDIN LRCK SDOUT 1 2 3 4 5 6 7 8 24 23 22 21 20 19 18 17 ES8327 VMID ADCVREF AGND AVDD DACVREF LOUT ROUT CPVSSP 16 15 14 13 12 11 10 9 CPBOT GMS1 CPGND GMS0 CPTOP CPVDD INTOUT HEADSET Pin Name CCLK, CDATA, CE MCLK/DMIC_SDA SCLK SDIN LRCK SDOUT SDINOUT1/DMIC_SCL MIC2P MIC2N MIC1P MIC1N HEADSET, INTOUT GMS0, GMS1 LOUT, ROUT PVDD DVDD, DGND AVDD, AGND CPVDD, CPGND CPTOP, CPBOT CPVSSP VMID ADCVREF, DACVREF Revision 2.0 Pin number 32, 31, 30 1 5 6 7 8 29 28 27 26 25 9, 10 13, 15 19, 18 3 2, 4 21, 22 11, 14 12, 16 17 24 23, 20 Input or Output I, I/O, I I I/O I I/O O O I I I/O O Analog Analog Analog Analog Analog Analog Analog Analog Pin Description I2C clock, data, address Master clock or DMIC input Serial data bit clock DAC serial data input Serial data left and right channel frame clock ADC serial data output SDOUT1 from SDIN (TDM) or DMIC bit clock Analog mic 2 input P Analog mic 2 input N Analog mic 1 input P Analog mic 1 input N Headset detect and interrupt OMTP and CTIA auto switch DAC stereo analog output Power supply for the digital input and output Digital power supply Analog power supply Charge pump power supply Charge pump capacitor top and bottom Charge pump filtering capacitor connection Filtering capacitor connection Filtering capacitor connection 7 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 3. TYPICAL APPLICATION CIRCUIT AVDD(1.8V TO 3.3V) DVDD(1.8V TO 3.3V) 1 FB6 2 C39 0.1uF C38 0.1uF AGND DGND ADCVREF R29 220R CPVDD(1.8V) 1 IOVDD C41 0.1uF R59 NC FB4 R58 2K C24 4.7uF IOVDD(1.8V TO 3.3V) 2 AGND 1 C40 0.1uF P 2 N 2K R32 2K 21 11 AVDD MIC2P MIC2N 30 32 31 DGND I2C_SCL I2C_SDA MIC1P MIC1N CE CCLK CDATA LO UT 1 5 6 7 8 I2S MCLK I2S SCLK I2S DACDAT I2S LRCK I2S ADCDAT 29 I2S TDMO UT ROUT U11 MCLK SCLK SDIN LRCK SDOUT ES8327 HEADSET GMS0 GMS1 INTOUT SDINOUT1 CPVSSP 28 27 C18 C19 1uF 1uF 26 25 C15 C16 1uF 1uF R27 10K AGND 19 18 9 13 15 10 R28 17 C25 1uF 12 C26 1uF 16 C17 4.7uF R16 33R R26 33R 220R VSPK C34 1uF C35 1uF 2 DGND DGND AGND INP HEADSET_EVT_INTERRUPT VDD GND INN 1 2 OUTP SHUTDOWN ADCVREF FB7 J2 HeadSet U14 R30 10K AGND 1 5 L/TIP 4 4 3 R 6 6 2 GND 7 7 1 M 8 8 IOVDD AGND AGND VMID ADCVREF DACVREF CPBOT R66 2K IOVDD 24 AGND CPGND PAD 23 20 4 33 22 14 DGND CPTOP AGND MICRO PHO NE AGND CPVDD PVDD R31 DVDD IOVDD R60 10K 2 3 DGND P N SPEAKER OUTN Analog Audio PA U15 C28 1uF C27 1uF C33 1uF C36 1uF C37 1uF INP VDD GND INN 1 2 OUTP SHUTDOWN AGND AGND P N OUTN SPEAKER Analog Audio PA AGND PA_SHUTDOWN VSPK IOVDD GND MCLK SCLK LRCK DAT VCC U16 I2S MCLK I2S SCLK I2S LRCK I2S TDMO UT DVDD OUTP 1 2 OUTN Digital Audio PA P N SPEAKER AVDD CPVDD AGND ES8327 PIN29 (SDINOUT1) can be used to connect digital audio PA with I2S interface. IO Power Supply, 1.8V to 3.3V. Please refer to ES8327 Datasheet Digital Power Supply, 1.8V to 3.3V. Please refer to ES8327 Datasheet Analog Power Supply, 1.8V to 3.3V. Please refer to ES8327 Datasheet Charge Pump Power Supply, must be 1.8V. One 1.8V LDO is recommended for CPVDD power supply Please refer to ES8327 Datasheet pulled up to PVDD, I2C Chip Address = 0x19 CE I2C Chip Address. pulled down to GND, I2C Chip Address = 0x18 HEADSET_EVT_INTERRUPT ADCVREF Revision 2.0 An Interrupt Signal to Host SOC / CPU ADCVREF can be used as Microphone Power Supply. 8 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 4. CLOCK MODES AND SAMPLING FREQUENCIES The device supports standard audio clocks (32Fs, 64Fs, 128Fs, 256Fs, 384Fs, 512Fs, etc), USB clocks (12/24 MHz), and some common non standard audio clocks (16 MHz, 25 MHz, 26 MHz, etc). The device can work either in master clock mode or slave clock mode. In slave mode, LRCK and SCLK are supplied externally, and LRCK and SCLK must be synchronously derived from the system clock with specific rates. In master mode, LRCK and SCLK are derived internally from device master clock. 5. MICRO-CONTROLLER CONFIGURATION INTERFACE The device supports standard I2C micro-controller configuration interface. External microcontroller can completely configure the device through writing to internal configuration registers. I2C interface is a bi-directional serial bus that uses a serial data line (CDATA) and a serial clock line (CCLK) for data transfer. The timing diagram for data transfer of this interface is given in Figure 1a and Figure 1b. Data are transmitted synchronously to CCLK clock on the CDATA line on a byte-by-byte basis. Each bit in a byte is sampled during CCLK high with MSB bit being transmitted firstly. Each transferred byte is followed by an acknowledge bit from receiver to pull the CDATA low. The transfer rate of this interface can be up to 400 kbps. A master controller initiates the transmission by sending a “start” signal, which is defined as a high-to-low transition at CDATA while CCLK is high. The first byte transferred is the slave address. It is a seven-bit chip address followed by a RW bit. The chip address must be 0011 00x, where x equals CE. The RW bit indicates the slave data transfer direction. Once an acknowledge bit is received, the data transfer starts to proceed on a byte-by-byte basis in the direction specified by the RW bit. The master can terminate the communication by generating a “stop” signal, which is defined as a low-to-high transition at CDATA while CCLK is high. In I2C interface mode, the registers can be written and read. The formats of “write” and “read” instructions are shown in Table 1 and Table 2. Please note that, to read data from a register, you must set R/W bit to 0 to access the register address and then set R/W to 1 to read data from the register. Revision 2.0 9 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 Table 1 Write Data to Register in I2C Interface Mode start Chip Address 0011 00 CE R/W 0 ACK Chip Addr CDATA Register Address RAM Write ACK bit 1 to 7 Reg Addr ACK ACK bit 1 to 8 Data to be written DATA Write Data ACK ACK bit 1 to 8 CCLK START STOP Figure 1a I2C Write Timing Table 2 Read Data from Register in I2C Interface Mode Start Start Chip Address 0011 00 CE Chip Address 0011 00 CE R/W 0 R/W 1 Chip Addr Reg Addr CDATA bit 1 to 7 Write ACK ACK ACK ACK bit 1 to 8 Register Address RAM Data to be read Data Chip Addr bit 1 to 7 Read ACK ACK NACK Stop Read Data NO ACK bit 1 to 8 CCLK START START STOP Figure 1b I2C Read Timing Revision 2.0 10 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Stop Everest Semiconductor Confidential ES8327 6. DIGITAL AUDIO INTERFACE The device provides many formats of serial audio data interface to the input of the DAC or output from the ADC through LRCK, SCLK and SDIN or SDOUT pins. These formats are I2S, left justified, DSP/PCM and TDM. DAC input SDIN is sampled by the device on the rising edge of SCLK. ADC data is out at SDOUT on the falling edge of SCLK. The relationship of SDATA (SDIN/SDOUT), SCLK and LRCK with these formats are shown through Figure 2a to Figure 2h. SDIN 6-ch TDM data can directly output to 2-ch SDINOUT1, 2-ch SDINOUT2 and 2-ch SDINOUT3. 1 SCLK 1 SCLK L Channel LRCK R Channel SCLK SDATA MSB LSB LSB MSB Figure 2a I2S Serial Audio Data Format LRCK L Channel R Channel SCLK SDATA LSB MSB MSB LSB Figure 2b Left Justified Serial Audio Data Format 1 SCLK LRCK R Channel L Channel SCLK SDATA MSB LSB MSB LSB Figure 2c DSP/PCM Mode A Serial Audio Data Format LRCK R Channel L Channel SCLK SDATA MSB LSB MSB LSB Figure 2d DSP/PCM Mode B Serial Audio Data Format Revision 2.0 11 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential 1 SCLK ES8327 1 SCLK Channel 3 Channel 1 LRCK Channel 4 Channel 2 SCLK SDATA MSB LSB LSB MSB MSB LSB LSB MSB Figure 2e TDM I2S Serial Audio Data Format LRCK Channel 3 Channel 1 Channel 4 Channel 2 SCLK SDATA MSB LSB LSB MSB MSB LSB LSB MSB Figure 2f TDM Left Justified Serial Audio Data Format 1 SCLK LRCK Channel 4 Channel 3 Channel 2 Channel 1 SCLK SDATA MSB LSB MSB LSB MSB LSB LSB MSB Figure 2g TDM DSP/PCM Mode A Serial Audio Data Format LRCK Channel 4 Channel 3 Channel 2 Channel 1 SCLK SDATA MSB LSB MSB LSB MSB LSB MSB LSB Figure 2h TDM DSP/PCM Mode B Serial Audio Data Format Revision 2.0 12 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 7. ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS Continuous operation at or beyond these conditions may permanently damage the device. PARAMETER Analog Supply Voltage Level Digital Supply Voltage Level Analog Input Voltage Range Digital Input Voltage Range Operating Temperature Range Storage Temperature MIN -0.3V -0.3V AGND-0.3V DGND-0.3V -40°C -65°C MAX +3.6V +3.6V AVDD+0.3V PVDD+0.3V +105°C +150°C RECOMMENDED OPERATING CONDITIONS PARAMETER MIN TYP MAX UNIT AVDD 1.7 1.8/3.3 3.6 V CPVDD (Note 1) 1.6 1.8 2.0 V DVDD (Note 2) 1.6 1.8/3.3 3.6 V PVDD 1.6 1.8/3.3 3.6 V Note 1: recommend an option to add a LDO in PCB for CPVDD, in case CPVDD supply is noisy. Note 2: for 96 kHz sampling frequency, DVDD must be 3.3V (±10%). ADC ANALOG AND FILTER CHARACTERISTICS AND SPECIFICATIONS Test conditions are as the following unless otherwise specify: AVDD=3.3V, DVDD=3.3V, AGND=0V, DGND=0V, Ambient temperature=25°C, Fs=48 KHz, MCLK/LRCK=256. PARAMETER ADC Performance Signal to Noise ratio (A-weigh) THD+N Gain Error Filter Frequency Response Passband Stopband Passband Ripple Stopband Attenuation Analog Input Full Scale Input Level (±: differential P/N) Input Impedance Revision 2.0 MIN TYP MAX UNIT 97 -93 102 -90 104 -87 ±5 dB dB % 0.4535 Fs Fs dB dB 0 0.5465 ±0.05 70 ±AVDD/3.3 6 ±Vrms KΩ 13 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 DAC ANALOG AND FILTER CHARACTERISTICS AND SPECIFICATIONS Test conditions are as the following unless otherwise specify: AVDD=3.3V, DVDD=3.3V, AGND=0V, DGND=0V, Ambient temperature=25°C, Fs=48 KHz, MCLK/LRCK=256. PARAMETER DAC Performance Signal to Noise ratio (A-weigh) THD+N Gain Error Filter Frequency Response Passband Stopband Passband Ripple Stopband Attenuation Analog Output Full Scale Output Level MIN TYP MAX UNIT 95 -88 100 -85 102 -82 ±5 dB dB % 0.4535 Fs Fs dB dB 0 0.5465 ±0.05 53 AVDD/3.3 Vrms DC CHARACTERISTICS PARAMETER MIN TYP MAX UNIT Normal Operation Mode DVDD=1.8V, PVDD=1.8V, AVDD=3.3V TBD mW DVDD=1.8V, PVDD=1.8V, AVDD=1.8V Power Down Mode (Note 3) DVDD=1.8V, PVDD=1.8V, AVDD=3.3V 0 uA DVDD=1.8V, PVDD=1.8V, AVDD=1.8V Digital Voltage Level Input High-level Voltage 0.7*PVDD V Input Low-level Voltage 0.5 V Output High-level Voltage PVDD V Output Low-level Voltage 0 V Note 3: recommend all power supply on, entering low power through control register setting, then stopping input clock. Revision 2.0 14 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 SERIAL AUDIO PORT SWITCHING SPECIFICATIONS PARAMETER Symbol MCLK frequency MCLK duty cycle LRCK frequency LRCK duty cycle (Note 4) SCLK frequency SCLK pulse width low TSLKL SCLK Pulse width high TSCLKH SCLK falling to LRCK edge (master mode only) TSLR LRCK edge to SCLK rising (slave mode only) TLSR SCLK falling to SDOUT valid VDDD=3.3V T VDDD=1.8V SDO LRCK edge to SDOUT valid (Note 5) VDDD=3.3V T VDDD=1.8V LDO SDIN valid to SCLK rising setup time TSDIS SCLK rising to SDIN hold time TSDIH Note 4: one SCLK period of high time in DSP/PCM modes. MIN 40 40 16 16 10 10 10 MAX 49.2 60 100 60 26 10 16 39 11 25 UNIT MHz % KHz % MHz ns ns ns ns ns ns ns ns Note 5: only apply to MSB of Left Justified or DSP/PCM mode B. LRCK TSLR TSCLKH TLSR TSCLKL SCLK TSDO TLDO SDOUT TSDIS TSDIH SDIN Figure 3 Serial Audio Port Timing Revision 2.0 15 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 I2C SWITCHING SPECIFICATIONS (SLOW SPEED MODE/HIGH SPEED MODE) PARAMETER CCLK Clock Frequency Bus Free Time Between Transmissions Start Condition Hold Time Clock Low time Clock High Time Setup Time for Repeated Start Condition CDATA Hold Time from CCLK Falling CDATA Setup time to CCLK Rising Rise Time of CCLK Fall Time CCLK Symbol FCCLK TTWID TTWSTH TTWCL TTWCH TTWSTS TTWDH TTWDS TTWR TTWF MIN 4.7/1.3 4.0/0.6 4.7/1.3 4.0/0.6 4.7/0.6 0.25/0.1 MAX 100/400 3.45/0.9 1.0/0.3 1.0/0.3 UNIT KHz us us us us us us us us us Figure 4 I2C Timing Revision 2.0 16 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 8. CONFIGURATION REGISTER DEFINITION REGISTER 0X00 -RESET, DEFAULT 00011111 Bit Name CSM_ON Bit 7 MSC 6 SEQ_DIS 5 RST_DIG 4 RST_CMG 3 RST_MST 2 RST_ADCDIG 1 RST_DACDIG 0 Description Chip Current State Machine ON/OFF control 0 - CSM power down(default) 1 - CSM power up Master/Slave select for SDP 0 - Slave mode(default) 1 - Master mode Power up sequence enable control 0 - Power up sequence enable(default) 1 - Power up sequence disable Digital circuits reset (except control port) 0 - Not reset 1 - Reset(default) Clock manager circuit reset 0 - Not reset 1 - Reset(default) Master circuit reset 0 - Not reset 1 - Reset(default) ADC digital circuit reset 0 - Not reset 1 - Reset(default) DAC digital circuit reset 0 - Not reset 1 - Reset(default) REGISTER 0X01 -CLOCK MANAGER, DEFAULT 00000000 Bit Name CPCLK_ON Bit 6 MCLK_ON 5 BCLK_ON 4 CLK1_ON 3 CLK3_ON 2 CLK8_ON 1 CLK9_ON 0 Revision 2.0 Description Charge Pump clock CPCLK control 0 - CPCLK off(default) 1 - CPCLK on MCLK in ON/OFF control 0 - MCLK off (default) 1 - MCLK on BCLK in ON/OFF control 0 - BCLK off (default) 1 - BCLK on clk1 ON/OFF control 0 - clk1 off (default) 1 - clk1 on clk3 ON/OFF control 0 - clk3 off (default) 1 - clk3 on clk8 ON/OFF control 0 - clk8 off (default) 1 - clk8 on clk9 ON/OFF control 17 October 2021 Latest datasheet: www.everest-semi.com or info@everest-semi.com Everest Semiconductor Confidential ES8327 0 - clk9 off (default) 1 - clk9 on REGISTER 0X02-CLOCK MANAGER, DEFAULT 00000000 Bit Name MSTCLK_SEL Bit 7:6 DMIC_SCL_SEL 4 MAINCLK_SEL 3 BITCLK_SEL 2 MAINCLK_INV 1 BITCLK_INV 0 Description Master BCLK/LRCK divider source clock selection 0 - from main_clk(main_clk refer to MAINCLK_SEL)(default) 1 - from adc_cfclk(adc_cfclk refer to ADC_CFCLK_SEL) 2 - from adc_mclk(adc_mclk refer to ADC_MCLK_SEL) 3 - from dac_mclk (dac_mclk refer to DAC_MCLK_SEL) DMIC clock select 0 - from ADC OSR clock,ES8327 provides DMIC_SCL to DMIC. (default) 1 - from MCLK in, system provides DMIC clock from DMIC_SCL to ES8327, and ES8327 synchronize with DMIC_SCL as ADC OSR clock. “adc_mclk” should be 4 times frequency of DMIC_SCL. Internalclock “main_clk”select 0 - from MCLK PAD(default) 1 - from BCLK PAD Slave bit clock “bit_clk”select 0 - from BCLK PAD(default) 1 - from MCLK PAD Main clock“main_clk”invert 0 - normal(default) 1 - invert Bit clock “bit_clk”invert 0 - normal(default) 1 - invert REGISTER 0X03-CLOCK MANAGER, DEFAULT 00000010 Bit Name RATIO_RESAMPLE Bit 6:4 INTCLK_SEL 3:2 OSC_EN 1:0 Revision 2.0 Description Clock cycles justify for ratio sync. 0 -no sync(default) 1 - 1/512,sync 1 cycle per 512 cycles for adc_ratio
ES8327 价格&库存
很抱歉,暂时无法提供与“ES8327”相匹配的价格&库存,您可以联系我们找货
