BTA12A-600SW
BTA12A-600SW
    NH(纽航)
    TO-220A
    可控硅/晶闸管/光电可控硅 1个双向可控硅 600V 12A TO-220A
BTA12A-600SW 数据手册
Guangdong Niuhang Electronic Technology Co., Ltd Specification For Approval BTA12A-600XW ✔ Pb RoHS THREE-QUADRANT TRIAC VOLTAGE: 600 Volts 12 CURRENT: Ampers Pb-Frce Package: TO-220A Marking and Polarity FEATURES · · · · COMPLIANT T2 Highly di/dt For High Reliability Low On-State Voltage For Low Power Consumption FFYWW LLWWF Ceramic Pad For Internal Insulation G BTA12A-600XW RoHS Compliant TYPICAL APPLICATIONS · · · T1 Phase Control Operation Of Light Dimmers And Motor Speed Controllers  T1     T2     G ON/OFF Control Operation Of Heating Regulation And Induction Motor Weight:App. 2.057 Grams(0.07255 Ounce) Remark: PRODUCT SUMMARY Item ①. NH=Niuhang Trademark TW SW CW BW Unit ②. FF=Product Line Code,According To Actual Changes IT(RMS) 12 A YWW=Date Code,,According To Actual Changes VDRM/VRRM Min. 600 V LLWWF=Inernal Code,,According To Actual Changes IGT(Ⅰ-Ⅱ-Ⅲ) Max. 5 10 35 50 ③. BTA12A-600XW=Model,XW=TW,SW,CW,BW mA Absolute Maximum Ratings (Ta=25℃ Unless otherwise specified) Symbol BTA12A-600XW Unit Repetitive Peak Off-State Voltage VDRM 600 V Repetitive Peak Reverse Voltage VRRM 600 V IT(RMS) 12 A ITSM 120 A 2 It 72 A di/dt 100 A/µs IGM 4.0 A PG(AV) 0.5 W TMM 1.1 N.m Symbol BTA12A-600XW Unit Parameter Test Conditions RMS On-State Current Non Repetitive Surge Peak On-State Current Tc≤ F= 2 50 ℃ Hz,Tp= Tp= I T Value For Fusing 80 10 20 ms ms IG=2*IGT, tr≤10ns Critical Rate Of Rise Of On-State Current Peak Gate Current F= 100 Hz,Tj= 125 ℃ Tp= 20 µs,Tj= 125 ℃ Average Gate Power Dissipation Tj= 125 Maximum Mounting Torque M3 srew ℃ Thermal Characteristcs (Ta=25℃ Unless otherwise specified ) Parameter Operating Junction Temperature Range Storage Temperature Range Typical Thermal Resistance Http://www.nh-semicon.com Date:2014/10/20 TJ -40 to 125 TSTD -40 to 150 ℃ R θJA 60.0 R θJC 2.3 Rev.:A/1 ℃/W Page: 1 of 6 R&D-TD-001 Guangdong Niuhang Electronic Technology Co., Ltd Specification For Approval BTA12A-600XW ✔ Pb RoHS THREE-QUADRANT TRIAC Pb-Frce COMPLIANT Electrical Characteristcs (Ta=25℃ Unless otherwise specified ) Quadrants Parameter Test Conditions Symbol Gate Trigger Current VD=12V,IT=0.1A I GT Ⅰ-Ⅱ-Ⅲ Gate Trigger Voltage VD=12V,IT=0.1A V GT Ⅰ-Ⅱ-Ⅲ Holding Current IT=100mA IH Latching Current IG=1.2*IGT IL Rise Of Off- State Voltage VD=2/3*VDRM,Gate open,Tj =150°C Peak On-State Voltage IT= 12 A, TW SW CW BW ≤5 ≤10 ≤35 ≤50 ≤ ≤35 ≤50 Ⅰ-Ⅲ ≤10 ≤25 ≤50 ≤70 Ⅱ ≤15 ≤30 ≤60 ≤90 ≥100 ≥500 ≥1000 ≥2000 VD=VDRM, Tj =25°C Peak Repetitive Forward Blocking Current I DRM VD=VDRM, Tj =125°C VR=VRRM, Tj =25°C Peak Repetitive Reverse Blocking Current I RRM VR=VRRM, Tj =125°C mA V ≤15 V TM Unit 1 ≤10 dv/dt Tj =25°C Value mA mA V/us ≤ 1.50 V ≤ 5 uA ≤ 0.4 mA ≤ 5 uA ≤ 0.4 mA Model and identification instructions BT 1 12 A 600 - xW Productor Type BT=TRIAC Insulation Spec.: A=Insulation B=No insulation IT(RMS) Spec.: 12 = 12A Package Spec.: A= TO-220A "-"=Connector constant VDRM/VRRM Spec. 600 = 600V IGT Spec. TW:IGTⅠ-Ⅲ≤5mA SW:IGTⅠ-Ⅲ≤10mA CW:IGTⅠ-Ⅲ≤35mA BW:IGTⅠ-Ⅲ≤50mA Http://www.nh-semicon.com Date:2014/10/20 Rev.:A/1 Page: 2 of 6 R&D-TD-001 Guangdong Niuhang Electronic Technology Co., Ltd Specification For Approval BTA12A-600XW ✔ Pb RoHS THREE-QUADRANT TRIAC Pb-Frce COMPLIANT IT(RMS)-RMS On-state Current(A) PD-Maximum Power Dissipation(W) Typical Characteristics Curves IT(RMS)-RMS On-state Current(A) Fig.1-RMS on-state current vs. case temperature Fig.2- Maximum Power Dissipation Vs. on-state current PD-Maximum Power Dissipation(W) IDM-Surge Peak On-state Current(A) TC-Case Temp (℃) Number Of Cycles Fig.3- Maximum Power Dissipation Vs. on-state current Fig.4- Surge Peak On-state Current Vs. Number Cycles IGT,IH,IL(Tj)/IGT,IH,IL(Tj=25℃) IT(RMS)-RMS On-state Current(A) TJ-Junction Temperature(℃) Fig.5- Relative Variation Of Gate Trigger Current , Holding Current And Latching Current Versus Junction Temperature (Typical Value) Http://www.nh-semicon.com Date:2014/10/20 Rev.:A/1 Page: 3 of 6 R&D-TD-001 Guangdong Niuhang Electronic Technology Co., Ltd Specification For Approval BTA12A-600XW ✔ Pb RoHS THREE-QUADRANT TRIAC OUTLINE DRAWINGS COMPLIANT Pb-Frce TO-220A OUTLINE DIMENSIONS Milimeters Inches Dim. Min. Typ. Max. Min. Typ. Max. A 9.25 -- 10.75 0.3642 -- 0.4232 B 1.15 -- 1.45 0.0453 -- 0.0571 C 4.20 -- 4.70 0.1654 -- 0.1850 D 0.45 -- 0.65 0.0177 -- 0.0256 E 14.70 -- 16.70 0.5787 -- 0.6575 F 8.55 -- 10.05 0.3366 -- 0.3957 G 12.50 -- 14.50 0.4921 -- 0.5709 H 3.00 -- 4.00 0.118 -- 0.157 J 1.20 -- 1.40 0.0472 -- 0.0551 K 0.70 -- 1.00 0.0276 -- 0.0394 M 2.20 -- 3.00 0.0866 -- 0.1181 O 3.45 -- 4.15 0.1358 -- 0.1634 P 2.40 -- 3.40 0.0945 -- 0.1339 PACKING INFORMATION Package Code TO-220A Http://www.nh-semicon.com Package Method Box Size L×W×H (mm) Quantity (pcs/box) Carton Size L×W×H (mm) Quantity (pcs/carton) Tube Packaging 570*153*47 1000 580*250*180 5000 Date:2014/10/20 Rev.:A/1 Page: 4 of 6 R&D-TD-001 Guangdong Niuhang Electronic Technology Co., Ltd Specification For Approval BTA12A-600XW THREE-QUADRANT TRIAC ✔ Pb RoHS Pb-Frce COMPLIANT Recommended wave soldering condition Product Peak Temperature Soldering Time Pb-free devices 260 +0/-5 °C 5 +1/-1 seconds Profile feature Sn-Pb eutectic Assembly Pb-free Assembly Average ramp-up rate (Tsmax to Tp) 3°C/second max. 3°C/second max. Preheat −Temperature Min(TS min) −Temperature Max(TS max) −Time(ts min to ts max) 100°C 150°C 60-120 seconds 150°C 200°C 60-180 seconds Time maintained above: −Temperature (TL) − Time (tL) 183°C 60-150 seconds 217°C 60-150 seconds Peak Temperature(TP) 240 +0/-5 °C 260 +0/-5 °C Time within 5°C of actual peak temperature(tp) 10-30 seconds 20-40 seconds Ramp down rate 6°C/second max. 6°C/second max. Time 25 °C to peak temperature 6 minutes max. 8 minutes max. Recommended temperature profile for IR reflow Note : All temperatures refer to topside of the package, measured on the package body surface. Http://www.nh-semicon.com Date:2014/10/20 Rev.:A/1 Page: 5 of 6 R&D-TD-001 Guangdong Niuhang Electronic Technology Co., Ltd Specification For Approval BTA12A-600XW THREE-QUADRANT TRIAC ✔ Pb RoHS Pb-Frce COMPLIANT Disclaimer ● Reproducing and modifying informatiom of the document is prohibited without permission from niuhang Electronics co., LTD ● Niuhang Electronics co., LTD. reserves the rights to make changes of the content herein the document anytime without notification. ● Niuhang Electronics co., LTD. disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. ● Niuhang Electronics co., LTD. does not assume any and all implied warranties, including warranties of fitness for particular purpose,non-infringement and merchantability. ● Applications shown on the herein document are examples of standard use and operation. Customers are responsible in comprehending the suitable use in particular applications. Niuhang Electronics co., LTD.makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. ● The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining,such as medical instruments.transportation equipment,aerospae machinery et cetera.Customers usin or selling these products for use in such applications do so at their own rish and agree to fully indemnify Niuhang Electronics co., LTD.for any damages resulting resulting from such improper use or sale. ● When the appearance of the product and chip size does not change, in order to product the customer. quality, change the internal structure and the production process Niuhang can not notify Http://www.nh-semicon.com Date:2014/10/20 Rev.:A/1 Page: 6 of 6 R&D-TD-001
BTA12A-600SW 价格&库存
很抱歉,暂时无法提供与“BTA12A-600SW”相匹配的价格&库存,您可以联系我们找货
BTA12A-600SW
  • 5+1.83910
  • 50+1.57045
库存:50
