BZY55C3V0 RBG
BZY55C3V0 RBG
    TAIWANSEMICONDUCTOR(台湾半导体)
    500MW 5%齐纳二极管
BZY55C3V0 RBG 数据手册
BZY55C2V4 - BZY55C36 Taiwan Semiconductor 500mW 5% Zener Diodes FEATURES KEY PARAMETERS ● ● ● ● Wide zener voltage range selection: 2.4V to 36V VZ Tolerance Selection of ± 5% Surface device type mountin Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 2.4-36 V Test current IZT 5 mA Ptot 500 mW VF at IF=10mA 1.5 V TJ Max. 150 °C APPLICATIONS ● ● ● ● Low voltage stabilzers or voltage references Adapters Lighting application On-board DC/DC converter Package 0805 Configuration Single dice MECHANICAL DATA ● Case: 0805 ● Molding compound: UL flammability classification rating 94HB ● Moisture sensitivity level: level 1, per J-STD-020 ● Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 1A whisker test ● Polarity: Indicated by cathode band ● Weight: 0.006grams (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage @ IF=10mA SYMBOL PART NUMBER UNIT VF 1.5 V Total power dissipation Ptot 500 mW Junction temperature range TJ -55 to +150 °C Storage temperature range TSTG -55 to +150 °C SYMBOL LIMIT UNIT RӨJA 300 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version:D1612 BZY55C2V4 - BZY55C36 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE PART MARKING NUMBER CODE Min. TEST REGULAR TEST LEAKAGE CURRENT IMPEDANCE CURRENT CURRENT VZ @ IZT IZT ZZT @ IZT ZZK @ IZK IZK V mA Ω Ω mA VZ @ IZT µA V Nom. Max. Max. Max. BZY55C2V4 2V4 2.28 2.40 2.52 5 85 600 1 Max. 50 1.0 BZY55C2V7 2V7 2.57 2.70 2.84 5 85 600 1 10 1.0 BZY55C3V0 3.0 2.85 3.00 3.15 5 85 600 1 4 1.0 BZY55C3V3 3V3 3.14 3.30 3.47 5 85 600 1 2 1.0 BZY55C3V6 3V6 3.42 3.60 3.78 5 85 600 1 2 1.0 BZY55C3V9 3V9 3.71 3.90 4.10 5 85 600 1 2 1.0 BZY55C4V3 4V3 4.09 4.30 4.52 5 80 600 1 1 1.0 BZY55C4V7 4V7 4.47 4.70 4.94 5 70 600 1 0.5 1.0 BZY55C5V1 5V1 4.85 5.10 5.36 5 50 550 1 0.1 1.0 BZY55C5V6 5V6 5.32 5.60 5.88 5 30 450 1 0.1 1.0 BZY55C6V2 6V2 5.89 6.20 6.51 5 10 200 1 0.1 2.0 BZY55C6V8 6V8 6.46 6.80 7.14 5 8 150 1 0.1 3.0 BZY55C7V5 7V5 7.13 7.50 7.88 5 7 50 1 0.1 5.0 BZY55C8V2 8V2 7.79 8.20 8.61 5 7 50 1 0.1 6.2 BZY55C9V1 9V1 8.65 9.10 9.56 5 10 50 1 0.1 6.8 BZY55C10 10 9.50 10.00 10.50 5 15 70 1 0.1 7.5 BZY55C11 11 10.45 11.00 11.55 5 20 70 1 0.1 8.2 BZY55C12 12 11.40 12.00 12.60 5 20 90 1 0.1 9.1 BZY55C13 13 12.35 13.00 13.65 5 26 110 1 0.1 10 BZY55C15 15 14.25 15.00 15.75 5 30 110 1 0.1 11 BZY55C16 16 15.20 16.00 16.80 5 40 170 1 0.1 12 BZY55C18 18 17.10 18.00 18.90 5 50 170 1 0.1 13 BZY55C20 20 19.00 20.00 21.00 5 55 220 1 0.1 15 BZY55C22 22 20.90 22.00 23.10 5 55 220 1 0.1 16 BZY55C24 24 22.80 24.00 25.20 5 80 220 1 0.1 18 BZY55C27 27 25.65 27.00 28.35 5 80 220 1 0.1 20 BZY55C30 30 28.50 30.00 31.50 5 80 220 1 0.1 22 BZY55C33 33 31.35 33.00 34.65 5 80 220 1 0.1 24 BZY55C36 36 34.20 36.00 37.80 5 80 220 1 0.1 27 Notes: 1. The Zener Voltage (VZ) is tested under pulse condition of 10ms 2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±2% 3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative 4. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS value equal to 10% of the dc zener current(IZT or IZK) is superimposed to IZT or IZK 2 Version:D1612 BZY55C2V4 - BZY55C36 Taiwan Semiconductor ORDERING INFORMATION PART NO. PACKING PACKING CODE CODE SUFFIX BZY55CXXX RY (Note 1&2) RB PACKAGE PACKING 5K / 7" Reel G 0805 10K / 13" Reel Notes: 1. "xxx" defines voltage from 2.4V (BZY55C2V4) to 36V (BZY55C36) 2. Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BZY55C36 RYG BZY55C36 RY PACKING CODE SUFFIX G 3 DESCRIPTION Green compound Version:D1612 BZY55C2V4 - BZY55C36 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Zener Breakdown Characteristics 100 10 80 Zener Current (mA) Forward Current (mA) Typical Forward Characteristics 100 1 0.1 0.01 TA=25oC 60 40 20 TA=25oC 0 0.001 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0 0.9 4 12 16 20 Zener Voltage (V) Forward Voltage (V) Zener Breakdown Admissible Power Dissipation Curve 50 600 500 Power Dissipation (mW) 40 Zener Current (mA) 8 30 20 10 400 300 200 100 0 0 15 20 25 30 Zener Voltage (V) 35 0 4 30 60 90 120 150 Ambient Temperature (oC) 180 Version:D1612 BZY55C2V4 - BZY55C36 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Typical Capacitance 200 Capacitance (pF) 160 120 80 40 0 0 5 10 15 20 25 Zener Voltage (V) 5 Version:D1612 BZY55C2V4 - BZY55C36 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION 0805 DIM. Unit(mm) Unit(inch) Min Max Min Max A 1.80 2.20 0.071 0.087 B 1.05 1.45 0.041 0.057 C 0.25 0.65 0.010 0.026 D 0.65 0.85 0.026 0.033 SUGGEST PAD LAYOUT Unit(mm) Unit(inch) Typ Typ A 1.10 0.043 B 1.40 0.055 C 1.20 0.047 D 3.40 0.134 DIM. 6 Version:D1612 BZY55C2V4 - BZY55C36 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version:D1612
BZY55C3V0 RBG 价格&库存
很抱歉,暂时无法提供与“BZY55C3V0 RBG”相匹配的价格&库存,您可以联系我们找货
