LP5308B6F
LP5308B6F
    LPSEMI(微源)
    SOT23-6
    电源开关/负载开关 3V~36V SOT23-6 -40℃~+85℃
LP5308B6F 数据手册
LP5308 36V Over-Voltage Protection Switch with Programmable Over-Current Protection Features General Description ⚫ Input voltage tolerance up to 36V ⚫ Low on-state resistance to 135mΩ ⚫ 90μA low current consumption ⚫ Adjustable OCP: 0.2A to 2.5A ⚫ Under-voltage lockout: 2.7V ⚫ Over-voltage protection: 5.85V ⚫ Output discharge integrated ⚫ Thermal shutdown protection ⚫ ESD Protection: - ⚫ Human Body Model: 4kV Charged Device Model: 0.5kV Package: SOT23-6 and DFN-8 The LP5308 is a power switch device provides full protection to systems and loads which may encounter large current and input over-voltage conditions. The device contains a 135mΩ MOSFET which can operate over an input voltage range from 3.0V to 36V. The OVP will disconnect VIN and VOUT when the voltage on VIN is higher than over voltage threshold. The over-current protection could be settable using an external resistor. When the current reaches the threshold, the device will turn off the power FET to prohibit excessive currents from causing damage. Switch is controlled by an active-low logic pin. Thermal shutdown protection is integrated which shuts off the switch to prevent damage to the part when the temperature is higher than threshold. These parts are available in space-saving SOT23-6 package and DFN-8 package. Applications ⚫ Notebook and PC ⚫ Cell phone and PDAs ⚫ USB or other peripheral ports ⚫ Camera SOT23-6 Marking Information LP5308 Ordering and Package Information Part Number LP5308QVF F: Pb-Free Package Type: B6 : SOT23-6 QV : DFN-8 DFN-8 LP5308B6F Top Mark LPS LP5308 YWX LP5308 YWX Package Tape & Reel DFN-8 4K/REEL SOT23-6 3K/REEL Marking indication: Y: Production Year, W: Production week, X: Series Number LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 1 of 10 LP5308 Typical Application Circuitry Figure 1. Typical Application Circuitry Pin Configuration SOT23-6 (Top View) for LP5308B6F DFN-8 (Top View) for LP5308QVF Pin Description Pin Description GND Ground VIN Power supply and input of power switch VOUT Output of power switch ISET Over-current protection setting pin, connect a resistor to ground ENB Active-low device enable pin LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 2 of 10 LP5308 Functional Block Diagram Figure 2. Internal Block Diagram (LP5308) Absolute Maximum Ratings (Note 1) ⚫ VIN to GND ----------------------------------------------------------------------------------------------------------------- -0.3V to 36V ⚫ VOUT to GND ---------------------------------------------------------------------------------------------------------------- -0.3V to 7V ⚫ ENB to GND ------------------------------------------------------------------------------------------------------------------ -0.3V to 7V ⚫ ISET to GND ----------------------------------------------------------------------------------------------------------------- -0.3V to 7V ⚫ Maximum Junction Temperature (TA) ----------------------------------------------------------------------------------------- 150°C ⚫ Maximum Soldering Temperature (at leads, 10 seconds) ---------------------------------------------------------------- 260°C Note 1: Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, instead of functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specifications. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Thermal Information ⚫ Maximum Power Dissipation (SOT23-6, PD, TA VOVP_R to OUT voltage stop rising 30 ISHORT VIN = 5V, TA=25°C 5 A Output auto discharge RDIS VIN = 5V, VEN = 0V 3 kΩ Enable logic high voltage level VIH VIN = 2.4V to 6V Enable logic high voltage level VIL VIN = 2.4V to 6V Over current protection level OCP accuracy Over-Voltage Protection response time Short circuit protection level OCP qualification time Load switch turned on delay Output rising time IOCP A ACCOCP tOVP tOCP_QUAL tDON tR % VIN = 5V, TA = 25°C, qualification time from IOUT hits IOCP to switch turned off 50 1.4 ns V 0.4 V 150 μs VIN = 5V, ROUT = 100Ω, COUT = 22μF, time from enabled to VOUT = 0.5 VIN = 5V, ROUT = 100Ω, COUT = 22μF, time from VOUT = 0.1×VIN to 0.9×VIN VIN = 5V, ROUT = 500Ω, COUT = 0.1μF, time from disabled to VOUT = 0.9×VIN 10 ms 450 μs 10 μs Load switch turned off delay tOFF Thermal shutdown trigger TSD Temperature rising 150 °C Thermal shutdown release TSD_REL Temperature falling 130 °C Note 3. The parameter is guaranteed by design and characterization. LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 4 of 10 LP5308 Typical Timing Diagram Figure 3. Start-up and over current protection Typical Performance Characteristics Figure 4. Quiescent Current vs Temperature and VIN (CIN=COUT=1μF, VENB = 0V, no load) Figure 5. Shutdown Current vs VIN and Temperature (CIN=COUT=1μF, VENB = 5V, no load) Figure 6. On-resistance vs Temperature (VENB = 0V, ILOAD = 100mA) Figure 7. On-resistance vs Input Voltage (VENB = 0V, ILOAD = 100mA) LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 5 of 10 LP5308 Typical Operating Waveforms Figure 8. Start-up with enabled by ENB (VIN = 5V, CIN = COUT = 1μF, RLOAD = 10Ω) Figure 9. Disabled by ENB (VIN = 5V, CIN = COUT = 1μF, RLOAD = 10Ω) Figure 10. Over-Current Protection Response (ISET floating, VENB = 0V, 160µs debounce included) Figure 11. Short-Circuit Protection Response (ISET floating, VENB = 0V) Figure 12. Over-Voltage Protection Response (VIN normal ramp-up with 4V / 100ns, RLOAD = 100Ω) Figure 13. Over-Voltage Protection Response (VIN fast ramp-up with 25V / 100ns, RLOAD = 100Ω) LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 6 of 10 LP5308 Function Description General Description Over-Current Protection LP5308 is a OVP power switch integrated OCP feature to protect systems and loads which can be damaged or disrupted by the application of high currents. The devices all contain a 135mΩ N-channel MOSFET and a controller capable of working over a wide input operating range of 3V to 36V. The controller protects against system malfunctions through over-current protection, undervoltage lockout and thermal shutdown. The OCP is adjustable from 0.2A to 2.5A through an external resistor. The OCP feature ensures that the device will disconnect output from input when current through the switch exceed a setting value. The current at which the parts will limit is adjustable through the selection of an external resistor connected to ISET. Once the switch is turned off, unless by disabled through ENB pin, it will not conduct again until 1.3s later. The hiccup behavior will continue as long as the heavy loading condition exist. Over-Voltage Protection Enable Control The ENB pin controls the state of the switch. When ENB is pulled low or floating more than 10ms de-bounce time, the load switch is turned on. Activating ENB continuously holds the switch in the on state so long as there is no fault. An under-voltage, over-voltage condition on VIN or a junction temperature in excess of 150°C overrides the ENB control to turn off the switch. The LP5308 does not turn off in response to an over current condition until the current exceed threshold longer than qualification time 150µs, as long as ENB is active and the thermal shutdown or VIN voltage not in proper range. The enable pin ENB’s control voltage and VIN pin have independent recommended operating ranges. The ENB pin voltage can be driven by a voltage level higher than the input voltage. There is internal pull-down resistor on ENB pin. Leave the pin floating will active the device as well. The LP5308 has Over-Voltage protection to prevent high voltage on VIN passing through to VOUT. Once the voltage on input exceeds the OVP threshold, the power FET will be turned off immediately. When VIN drop back below OVP release level, the switch will be turned on again after a 10ms de-bounce time. Under-Voltage Lockout The under-voltage lockout turns-off the switch if the input voltage drops below the under-voltage lockout threshold. With the ENB pin active, the input voltage rising above the under-voltage lockout threshold more than 10ms will cause a controlled turn-on of the switch which limits current over-shoots. Thermal Shutdown The thermal shutdown protects the device from internally or externally generated excessive temperatures. During an over temperature condition, the switch is turned off. The switch automatically turns on again if the temperature drops below the threshold temperature more than 1.3s. LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 7 of 10 LP5308 Application Information The LP5308 OCP is set with an external resistor connected between ISET pin and GND. This resistor is selected using the following equation: 25𝐾 𝑅SET = (1) I OCP Where, RSET, united as kΩ, is the resistor connected to ISET. IOCP is the expected current limit value in mA. Resistor tolerance of 1% or less is recommended. The relationship between RSET and IOCP could also be found as below diagram: 2.2 IOCP [A] 1.7 1.2 0.7 0.2 10 20 30 40 50 60 70 80 90 100 RSET [KΩ] Figure 4. OCP trigger level vs resistor on ISET pin LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 8 of 10 LP5308 Package Information SOT23-6 A D B C A1 b 1.00 2.60 e H 0.95 L 0.5 Recommended Land Pattern SYMBOL A A1 B b C D e H L MIN 0.889 0.000 1.397 0.28 2.591 2.692 0.080 0.300 MILLIMETER NOM 1.100 0.050 1.600 0.35 2.800 2.920 0.95BSC 0.152 0.450 MAX 1.295 0.152 1.803 0.559 3.000 3.120 0.254 0.610 LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 9 of 10 LP5308 DFN-8 D1 L E E1 F D b e BOTTOM VIEW TOP VIEW 2.50 0.75 0.6 A1 C A 1.65 0.25 Recommended Land Pattern SIDE VIEW SYMBOL A A1 b c D D1 E E1 e L F 0.50 MIN 0.70 0.00 0.18 1.90 1.10 1.90 0.60 0.25 0.25 Dimensions In Millimeters NOM 0.75 0.02 0.25 0.20 REF 2.00 1.30 2.00 0.75 0.50 BSC 0.35 0.30 MAX 0.80 0.05 0.30 2.10 1.65 2.10 0.85 0.40 0.35 LP5308 Rev0.7 Jan-2022 www.lowpowersemi.com Email: marketing@lowpowersemi.com Page 10 of 10
