TJ-S5050UG3W5TLCRGBTW-A5 数据手册
TAIWAN TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
GUANGDONG TONGJIA OPTOELECTRONICS TECHNOLOGY CO., LTD
承 認 書
Specification For Approval
Customer: (客戶)
Description: (產品描述)
SMD5050燈珠RGBW正白
Part number:(產品型號) TJ-S5050UG3W5TLCRGBTW-A5
Date:
(日期)
Approved By: (客戶承認)
Prepared By:(我司承認)
Approval
核准
Check
Design
審核
製作
Sales
業務
Customer Service Hotline:400-676-8616
TEL:0769-8662 5999
0769-8200 2226
E-MIAL∶dg@togialed.com
FAX:0769-8200 2227
WEB:www.togi aled. c om
Outline Dimension:
φ 4.50
5
4
4
5
6
3
3
6
7
2
2
7
8
1
1
8
1.25
1.5
Polarity
Mark
4.08
3.0
5.0
0.6
5.5
0.6
R 5
4
G 6
3
B 7
W 8
2
1
PAD Lay Out PCB
6.4
3.2
0.56
ATTENTION
0.6
OBSERVE PRECAUTIONS
FOR HANDLING
ELECTROSTATIC
SENSITIVE DEVICES
Notes:
1.
All dimensions are in millimeters.
2.
Tolerance is ±0.2 unless otherwise noted.
3.
Specifications are subject to change without notice.
注意:此款灯珠由于支架灯杯原因在蓝光点亮时白光荧光粉部分会受到影响激发,非特定条件下不影响使用效果。
2/11
■Absolute Maximum Ratings (Ta = 25℃)
Items
Symbol
Absolute maximum Rating
Unit
Dissipation
PD
308
mW
Forward Current(DC)
IF
30
mA
Peak Forward Current
IFP
100
mA
Reverse Voltage
VR
5
V
Operation Temperature
Topr
﹣40~﹢85
Storage Temperature
Tstg
﹣40~﹢80
Lead Soldering Temperature
Tsol
Power
Max.260℃ for 5 sec Max.
(3min from the base of the epoxy bulb)
Pulse width≤
≤0.1msec duty≤
≤1/10
■Typical Electrical & Optical Characteristics(Ta=25°)
Items
Forward Voltage
Reverse Current
Dominant Wavelength
Color Temperature
Symbol
Condition
Min
Typ
Max
Unit
R
G
1.8
2.8
2.0
3.0
2.4
3.4
V
V
B
2.8
3.0
3.4
V
VF( IF =30mA)
W
2.8
3.0
3.4
V
IR
VR =5V
2
μA
R
620
630
nm
Λd(IF =20mA)
G
520
530
nm
IF =30mA
B
W
460
5500
400
470
7000
800
nm
K
mcd
VF ( IF =20mA)
R
Luminous Intensity
View Angle
Iv ( IF =20mA)
G
1200
2200
mcd
Iv(I F =30mA)
B
W
300
8
700
12
mcd
LM
2θ1/2
IF =20mA
120
Deg
3/11
Typical Electrical/Optical Characteristics Curves (R):
4/11
Typical Electrical/Optical Characteristics Curves (G):
5/11
Typical Electrical/Optical Characteristics Curves (B):
6/11
Typical Electrical/Optical Characteristics Curves (W):
7/11
Classification
Life Test
Environment
Test
Test Item
Standard
Test Method
Operating
Life Test
JIS7021:B4
MIL-STD-202:107D
MIL-STD-750:1026
High
Temperature
Storage
JIS7021:B10
MIL-STD-202:210A
MIL-STD-750:2031
Low
Temperature
Storage
JIS7021:B12
Temp
&Humidity
Test
Test
Conditions
Duration
Units
Tested
Number of
Damaged
TA=25℃±
5℃,IF=30mA
1000h
22
0/22
1000h
22
0/22
1000h
22
0/22
1000h
22
0/22
50
Cycles
22
0/22
50
Cycles
22
0/22
1 time
22
0/22
3time
22
0/22
TA=100℃±
5℃
TA=﹣55℃±
5℃
TA=85℃±
JIS7021:B11
MIL-STD-202:103D
5℃
RH=85﹪±
5℃RH
Thermal
Shock Test
JIS7021:B4
MIL-STD-202:107D
MIL-STD-750:1026
﹣10℃±5℃
← →100℃
±5℃
5min - 5min
﹣55℃~
Temperature
Cycling Test
JIS7021:A3
MIL-STD-202:107D
MIL-STD-750:1051
25℃~85
℃~25℃
3min -5min30min- 5min
Mechanical
Test
Resistance to
Soldering
Heat
JIS7021:A1
MIL-STD-202:210A
MIL-STD-750:2031
Lead Integrity
MIL-STD-750D
Method 2036.3
8/11
260±5℃,
10±1sec
Load 2.5N
0°~90°~0°
● Soldering :
1. Manual Soldering
The temperature of the iron tip should not be higher than 350℃and Soldering time to be within 3 seconds per
solder-pad.
2. Reflow Soldering
Preheating : 140℃~160℃±5℃,within 2 minutes.
Operation heating : 260℃(Max.) within 10 seconds.(Max)
Gradual Cooling (Avoid quenching).
10 SEC. MAX.
Temperature
260℃ MAX.
140~160℃
4℃ /SEC. MAX.
4℃ /SEC. MAX.
OVER 2 MIN.
Time
3. DIP soldering (Wave Soldering) :
Preheating : 120℃~150℃,within 120~180 sec.
Operation heating : 245℃±5℃ within 5 sec.260℃ (Max)
Temperature
Soldering heat Max. 260 ℃
245 ± 5℃ within 5 sec.
120~150℃
Preheat
120~180 sec.
Time
9/11
● Handling :
Care must be taken not to damage LED’s epoxy resin while exposing to high temperature or contact LED’s epoxy resin
with hard or sharp objects, such as metal hook, tweezer or sand blasting..
● Notes for designing:
Current limiting resistor must be used in the circuit to drive TOGIA LEDs within the rated figures and not to overload
TOGIA LEDs with instantaneous voltage at the turning ON and OFF cycles.
When using pulse driving, the average current must be within the rated figures. And the circuit should be designed to
avoid reverse voltage when turning off the TOGIA LEDs.
● Storage:
In order to avoid the absorption of moisture, it is recommended to solder TOGIA LEDs as soon as possible after
unpacking the sealed envelope.
If the envelope is still packed, to store it in the environment as following:
(1) Temperature : 5℃-30℃(41℉)Humidity : RH 60﹪Max.
(2) After this bag is opened, devices that will be applied to infrared reflow, vapor-phase reflow, or equivalent
soldering process must be:
a. Completed within 168 hours.
b. Stored at less than 30% RH.
(3) Devices require baking before mounting, if:
(2) a or (2) b is not met.
(4) If baking is required, devices must be baked under below conditions:
48 hours at 60℃±3℃.
● Package and Label of Products:
Package: Products are packed in one bag of 1000 pcs (one taping reel) and a label is attached to each bag.
10/11
● Tapping and packaging specifications(Units: mm)
Label Aluminum moisture-proof bag Desiccant Label
● Package Method unit: mm)
1 0 b a g /b o x
1000 pcs/ r e e l
225
B ar C ode L abel
270
280
215
130
A l u m i n u m F o i l B ag
480
6 b o x / c a r to n
290
410
11/11
TJ-S5050UG3W5TLCRGBTW-A5 价格&库存
很抱歉,暂时无法提供与“TJ-S5050UG3W5TLCRGBTW-A5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.94413
- 50+0.76684
- 150+0.67819
- 1000+0.55261
- 2000+0.49946
- 5000+0.47278
- 国内价格
- 5+0.85671
- 50+0.69583
- 200+0.61539
- 400+0.60616
- 1000+0.50144
