SMFJ5.0A - SMFJ170CA
Product specification
VOLTAGE RANGE: 8 .0 V
Features
POWER: 200Wa tts
Mechanical Data
For surface mounted applications
Low profile package
Low incremental surge resistance, excellent
clamping capability
200W peak pulse power capability with a10/1000 μs
wave from,repetition rate (dutycycle):0.01%
Case: JEDEC SOD- 123FL, molded plastic over
passivated chip
Polarity:
Color band denotes positiveend( cathode )
except for bidirectional
Mounting position: Any
Weight: 0.006 ounces, 0.02 gram
High temperature soldering guaranteed:
260 ℃/10 seconds, at terminals
Reference News
PACKAGE OUTLINE
PIN CONFIGURATION
SOD-123FL Unipolar
SOD-123FL Bipolar
Maximum Ratings TA = 25℃ unless otherwise specified
Symbol
Characteristic
Value
Unit
Maximum PPK Dissipation ( PW - 1 0 / 1 0 0 0 μ s)
P PK
200
W
Maximum PPK Dissipation @ Ta = 2 5 ℃ ( PW - 8 / 1 0 μ s) ( Note2 )
P PK
1000
W
PD
385
DC Power Dissipation @ Ta= 2 5 ℃
( Note 3 )
Derate above 2 5 ℃
W
4.0
mW/ ℃
Thermal Resistance, Junction to Ambient ( Note3 )
RӨ JA
325
℃ /W
Thermal Resistance, Junction to Lead ( Note 3 )
RӨ JL
26
℃ /W
TJ , TSTG
-55 to + 150
Operating Junction and Storage Temperature Range
Notes :
( 1 ) Non−repetitive current pulse at Ta = 25°C, per waveform of Fig. 2.
( 2 ) Non− repetitive current pulse at Ta = 2 5 ° C, per waveform of Fig. 5 .
( 3 ) Mounted with recommended minimum pad size , DC board FR4 .
Copyright© Msksemi Incorporated
www.msksemi.com
R everse
Marking
TYPE
(Uni)
(Bi)
SMFJ5.0A
SMFJ6.0A
SMFJ6.5A
SMFJ5.0CA
SMFJ6.0CA
SMFJ6.5CA
SMFJ7.0A
SMFJ7.5A
SMFJ8.0A
SMFJ8.5A
SMFJ9.0A
SMFJ10A
SMFJ11A
SMFJ12A
SMFJ13A
SMFJ14A
SMFJ15A
SMFJ16A
SMFJ17A
SMFJ18A
SMFJ20A
SMFJ22A
SMFJ24A
SMFJ26A
SMFJ28A
SMFJ30A
SMFJ33A
SMFJ36A
SMFJ40A
SMFJ43A
SMFJ45A
SMFJ48A
SMFJ51A
SMFJ54A
SMFJ58A
SMFJ60A
SMFJ64A
SMFJ7.0CA
SMFJ7.5CA
SMFJ8.0CA
SMFJ8.5CA
SMFJ9.0CA
SMFJ10CA
SMFJ11CA
SMFJ12CA
SMFJ13CA
SMFJ14CA
SMFJ15CA
SMFJ16CA
SMFJ17CA
SMFJ18CA
SMFJ20CA
SMFJ22CA
SMFJ24CA
SMFJ26CA
SMFJ28CA
SMFJ30CA
SMFJ33CA
SMFJ36CA
SMFJ40CA
SMFJ43CA
SMFJ45CA
SMFJ48CA
SMFJ51CA
SMFJ54CA
SMFJ58CA
SMFJ60CA
SMFJ64CA
SMFJ70A
SMFJ75A
SMFJ78A
SMFJ85A
SMFJ90A
SMFJ100A
SMFJ110A
SMFJ120A
SMFJ130A
SMFJ150A
SMFJ160A
SMFJ170A
SMFJ70CA
SMFJ75CA
SMFJ78CA
SMFJ85CA
SMFJ90CA
SMFJ100CA
SMFJ110CA
SMFJ120CA
SMFJ130CA
SMFJ150CA
SMFJ160CA
SMFJ170CA
(Uni)
(Bi)
KE
KG
KK
KM
KP
KR
KT
KV
KX
KZ
LE
LG
LK
LM
FE
FG
FK
FM
FP
FR
FT
FV
LP
LR
LT
LV
LX
LZ
ME
MG
MK
MM
MP
MR
MT
MV
MX
MZ
NE
NG
NK
NM
NP
NR
NT
NV
NX
NZ
PE
PG
PK
PM
PP
PR
FX
FZ
HE
HG
HK
HM
HP
HR
HT
HV
HX
HZ
JE
JG
JK
JM
JP
JR
JT
JV
JX
JZ
XE
XG
XK
XM
XP
XR
XT
XB
XX
XZ
TE
TG
TK
TM
TP
TR
Stand-Off
Voltag e
VRWM ( V)
Breakdown Br e akd o w n
Voltage
Voltage
Max.
@ IT
Min. @IT
VBR
MIN(
5.0
6.0
6.5
6.40
6.67
7.22
7.0
7.5
8.0
8.5
9.0
10
11
12
13
14
15
16
17
18
24
26
28
30
33
36
40
43
45
48
51
54
58
60
64
70
75
78
85
90
100
110
120
130
150
160
170
V)
VBR
MAX (
V)
Test
Current
IT (mA)
M axi m u m
Reverse C l a m p i n g
Leakage V o l t a g e
@ IPP
@ VRWM
VC(V)
IR(uA)
Peak
IPP ( A )
10
10
10
400
400
250
9.2
10.3
11.2
7.78
8.33
8.89
9.44
10.0
11.1
12.2
13.3
14.4
15.6
16.7
7.00
7.37
7.98
8.60
9.21
9.83
10.4
11.1
12.3
13.5
14.7
15.9
17.2
18.5
10
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
100
50
25
10
5.0
2.5
2.5
2.5
1.0
1.0
1.0
12.0
12.9
13.6
14.4
15.4
17.0
18.2
19.9
21.5
23.2
24.4
21.7
19.4
17.9
16.7
15.5
14.7
13.9
13.0
11.8
11.0
10. 1
9.3
8.6
8.2
17.8
18.9
20.0
22.2
24.4
26.7
28.9
31. 1
33.3
36.7
40.0
44.4
47.8
50.0
53.3
56.7
60.0
64.4
66.7
71. 1
77.8
83.3
86.7
94.4
100
111
122
133
144
167
178
189
19.7
20.9
22. 1
24.5
26.9
29.5
31.9
34.4
36.8
40.6
44.2
49. 1
52.8
55.3
58.9
62.7
66.3
71.2
73.7
78.6
86.0
92. 1
95.8
104
111
123
135
147
159
185
197
209
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103
113
121
126
137
146
162
177
193
209
243
259
275
7.7
7.2
6.8
6.2
5.6
5.1
4..8
4.4
4.1
3.8
3.4
3.1
2.9
2.8
2.6
2.4
2.3
2.1
1.8
1.7
1.5
1.4
1.4
1.3
1.2
1.1
1.0
0.9
0.8
0.7
0.7
0.6
www.msksemi.com
P PPM ,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
10
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
1.0
0.1
0.01
0.1
PEAK PULSE POWER(PPP)OR CURRENT(Ipp)
DERATINGIN PERCENTAGE%
Fig.2 Forward Current Derating Curve
100
80
60
40
10
100
1000
25
10000
T A =25°C
100
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
I FSM ,PEAK FORWARD SURGE CURRENT,
AMPERES
I ppm ,Peak Pulse Current (%)
Fig.3 Pulse Waveform
t f =10usec
75
100
125
150
175
T A ,AMBIENT TEMPERATURE,°C
td,PULSE WIDTH ,us
120
50
Fig.4 Maximum Non-Repetitive Peak
Forward Surge Current
30
25
10
05
T J =T J max
8.3ms Single Half Sinepwav e
JEDEC Method
1.0
T,TIME,ms
3.0
4.0
1
10
100
Number of Cycles at 60Hz
www.msksemi.com
1.8± 0.3
0.95 ±0.25
PACKAGEMECHANICALDATA
1.15±0.25
0.05-0.30
2.75 ±0.25
0.6±0.3
3.7 ±0.30
Dimensions in millimeters
Suggested Pad Layout
2.85
Note:
1.4
1.Controlling dimension:in millimeters.
2.General tolerance:±0.05mm.
3.The pad layout is for reference purposes only.
1.2
REELSPECIFICATION
P/N
SMFJ5.0A-SMFJ170CA
PKG
QTY
SOD- 123FL
3000
www.msksemi.com
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not
handle applications that require extremely high levels of reliability, such as life-support
have specifications
that can
systems, aircraft's control systems, or
other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with
your MSKSEMI Semiconductor representative
nearest
you before using any MSKSEMI Semiconductor products described
or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that
exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in
products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the
performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To
verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test
devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor
products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could
endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing
equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are
not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained
herein are controlled under any of applicable local export control laws and regulations, such products must not be exported
without obtaining the export license from theauthorities
concerned
in accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior
written permission of MSKSEMI Semiconductor.
Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume
production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or
implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties.
Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI
Semiconductor productthat you intend to use.
www.msksemi.com
