B5819WT
B5819WT
    DIOS(迪恩思)
    SOD-523
    肖特基二极管 40V 1A SOD-523
B5819WT 数据手册
B5819WT Schottky Diode Features SOD-523 ◇ Low Forward Voltage Drop ◇ SOD523 Micro SMD package ◇ RoHS compliant / Green EMC Anode Cathode ◇ Matte Tin (Sn) Lead finish       1 SL     2 ◇ Cathode Band / Device marking ◇ Surface Mount Package Ideally Suited for Automatic Insertion Marking : SL Maximum Ratings (Ta = 25 ℃) Symbol Parameter Value Units VRRM Repetitive Peak Reverse Voltage 40 V IF(AV) Average Forward Rectified Current 1 A IFSM Non-Repetitive Peak Forward Surge Current ( @t=8..3ms ) 6 A TJ Operating Junction Temperature 125 ℃ -50 to +125 ℃ TSTG Storage Temperature Range Electrical Characteristics (Ta) = 25 ℃) ( @t=8..3ms Symbol Max Units IF = 0.3A 0.5 V IF = 1A 0.68 V Reverse current VR= 40V 100 uA VBR Reverse breakdown voltage IR = 0.5mA CT Capacitance VR = 0V, f = 1MHz VF IR Parameter Forward Voltage Conditions Min 40 V 100 pF 1 2022/12/15 B5819WT Typical Electrical and Thermal Characteristics (Curves) 2 2022/12/15 B5819WT PACKAGE OUTLINE   SOD-523 Plastic surface mounted package; 2 leads ALL ROUND             A       C             HE D A       E bp                           UNIT mm   A bp C D E HE V 0.68 0.58 0.4 0.3 0.135 0.100 1.25 1.15 0.85 0.75 1.7 1.5 0.1 ∠   5 O 3 2022/12/15
B5819WT 价格&库存
很抱歉,暂时无法提供与“B5819WT”相匹配的价格&库存,您可以联系我们找货
B5819WT
  • 20+0.14400
  • 100+0.10770
  • 800+0.08350
  • 3000+0.06050
  • 6000+0.05760
  • 30000+0.05330
库存:295441
B5819WT
    • 20+0.06975
    • 200+0.06525
    • 500+0.06075
    • 1000+0.05625
    • 3000+0.05400
    • 6000+0.05085
    库存:4868
