S2AF THRU S2MF
Reverse Voltage - 50 to 1000Volts
Forward Current - 20 Ampere
SURFACE MOUNT
GENERAL RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
Idea for printed circuit board
Open Junction chip
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed
0.146(3.70)
0.130(3.30)
250℃/10 seconds at terminals
0.047(1.20)
0.035(0.90)
Mechanical Data
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
Case: SMAF molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.0018 ounce, 0.064 grams
0.193(4.90)
0.173(4.40)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
S2AF
S2BF
S2DF
S2GF
S2JF
S2KF
S2MF
S2A
S2B
S2D
S2G
S2J
S2K
S2M
50
35
100
70
200
140
400
280
600
420
800
560
1000
700
V
V
50
100
200
400
600
800
1000
V
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=75℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
VRRM
VRMS
VDC
UNITS
I(AV)
2.0
A
IFSM
60
A
VF
1.10
5.0
50
V
IR
CJ
RJA
Operating junction and storage temperature range TJ,TSTG
30.0
50.0
-50 to +150
uA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
1
S2AF THRU S2MF
FIG. 1- FORWARD CURRENT DERATING CURVE
2.0
1.6
1.2
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
0.8
0.4
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
Typical Characterisitics
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
60
50
40
30
10
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
0.01
0.6
0.8
1.0
1.2
1.4
1.5
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MICROAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
0.1
1,000
100
TJ=100 C
1
0.1
TJ=25 C
0.01
60
80
100
200
TJ=25 C
10
TRANSIENT THERMAL IMPEDANCE,
C/W
PERCENT OF PEAK REVERSE VOLTAGE,%
FIG. 5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE, pF
TJ=150 C
10
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
100
100
NUMBER OF CYCLES AT 60 Hz
FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE
100
10
1
0.1
0.01
0.1
1
10
100
1
0.1
1.0
10
REVERSE VOLTAGE,VOLTS
100
t,PULSE DURATION,sec.
2
很抱歉,暂时无法提供与“S2MF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.04650
- 200+0.04350
- 500+0.04050
- 1000+0.03750
- 3000+0.03600
- 6000+0.03390
- 国内价格
- 20+0.15100
- 100+0.09380
- 800+0.06200
- 3000+0.04430
- 6000+0.04210
- 30000+0.03900
