S5MB
S5MB
    DIOS(迪恩思)
    SMB(DO-214AA)
    整流二极管 1KV 5A SMB(DO-214AA)
S5MB 数据手册
S5AB THRU S5MB SURFACE MOUNT GENERAL RECTIFIER Reverse Voltage - 50 to 1000 Volts Forward Current -5.0 Amperes Features DO-214AA 0.155(3.94) 0.130(3.30) 0.087 (2.20) 0.071 (1.80) 0.180(4.57) 0.160(4.06) Mechanical Data 0.012(0.305) 0.006(0.152) 0.096(2.44) 0.084(2.13) 0.060(1.52) 0.030(0.76) The plastic package carries Underwriters Laboratory Flammability Classification 94V-0 For surface mounted applications Low reverse leakage Built-in strain relief,ideal for automated placement High forward surge current capability High temperature soldering guaranteed: 250 C/10 seconds at terminals Case: JEDEC DO-214AB molded plastic body Terminals: Solder plated, solderable per MIL-STD-750, Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight:0.09grams 0.008(0.203)MAX. 0.220(5.59) 0.200(5.08) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current at TL=75 C Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current TA=25 C at rated DC blocking voltage TA=100 C Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) Operating junction and storage temperature range SYMBOLS S5A S5B S5D S5G S5J S5K S5M UNITS VRRM VRMS VDC 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 VOLTS VOLTS VOLTS I(AV) 5.0 Amps IFSM 200.0 Amps VF 1.1 Volts IR 10.0 250.0 uA CJ RqJA TJ,TSTG 60.0 50.0 -65 to +175 pF C/W C Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas 1 S5AB THRU S5MB AVERAGE FORWARD RECTIFIED CURRENT, AMPERES FIG. 1- FORWARD CURRENT DERATING CURVE 4 3 Single Phase Half Wave 60Hz Resistive or inductive Load 2 1 0 0 25 50 FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT £PEAK FORWARD SURGE CURRENT, AMPERES 5.0 75 100 125 150 200 150 100 80 40 175 0 8.3ms SINGLE HALF SINE-WAVE (JEDEC Method) 1 10 AMBIENT TEMPERATURE, C FIG. 4-TYPICAL REVERSE CHARACTERISTICS FIG. 3-TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 1,000 10 1 TJ=25 C PULSE WIDTH=300 ms 1%DUTY CYCLE 0.1 0.01 0.6 0.8 1.0 1.2 1.4 1.5 INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES 20 100 TJ=150 C 10 TJ=100 C 1 0.1 TJ=25 C 0.01 INSTANTANEOUS FORWARD VOLEAGE, VOLTS 0 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% FIG. 6-TYPICAL TRANSIENT THERMAL IMPEDANCE TRANSIENT THERMAL IMPEDANCE, C/W FIG. 5-TYPICAL JUNCTION CAPACITANCE 400 200 JUNCTION CAPACITANCE, pF 100 NUMBER OF CYCLES AT 60 Hz 20 TJ=25 C 100 10 1 0.1 0.01 0.1 1 10 100 2 0.1 1.0 10 REVERSE VOLTAGE,VOLTS 100 t,PULSE DURATION,sec. 2
很抱歉,暂时无法提供与“S5MB”相匹配的价格&库存,您可以联系我们找货
S5MB
  • 20+0.12710
  • 200+0.11890
  • 500+0.11070
  • 1000+0.10250
  • 3000+0.09840
  • 6000+0.09266
库存:2715
