MS51FB9AE-T
MS51FB9AE-T
    NUVOTON(新唐)
    TSSOP-20
    8位MCU单片机 2.4V~5.5V FLASH 16KB
MS51FB9AE-T 数据手册
MS51 1T 8051 8-bit Microcontroller NuMicro® Family MS51 Series Product Brief Nuvoton is providing this document only for reference purposes of NuMicro microcontroller based system design. Nuvoton assumes no responsibility for errors or omissions. All data and specifications are subject to change without notice. For additional information or questions, please contact: Nuvoton Technology Corporation. www.nuvoton.com Aug. 1st 2019 Page 1 of 25 Rev.2.00 MS51 SERIES PRODUCT BRIEF The information described in this document is the exclusive intellectual property of Nuvoton Technology Corporation and shall not be reproduced without permission from Nuvoton. MS51 1 GENERAL DESCRIPTION ® The NuMicro MS51 series is an embedded Flash type, 8-bit high performance 1T 8051-based microcontroller. The instruction set is fully compatible with the standard 80C51 and performance enhanced. The MS51 series contains up to 32 Kbytes main Flash called APROM, in which the contents of User Code reside. The Flash supports In-Application-Programming (IAP) function, which enables on-chip firmware updates. IAP also makes it possible to configure any block of User Code array to be used as non-volatile data storage, which is written by IAP and read by IAP or MOVC instruction. There is an additional Flash called LDROM, in which the Boot Code normally resides for carrying out In-SystemProgramming (ISP). The LDROM size is configurable with a maximum of 4 Kbytes. To facilitate programming and verification, the Flash allows to be programmed and read electronically by parallel Writer or In-Circuit-Programming (ICP). Once the code is confirmed, user can lock the code for security. The MS51 series provides rich peripherals including 256 Bytes of SRAM, up to 2 Kbytes of auxiliary RAM (XRAM), Up to 30 general purpose I/O, two 16-bit Timers/Counters 0/1, one 16-bit Timer2 with three-channel input capture module, one Watchdog Timer (WDT), one Self Wake-up Timer (WKT), one 16-bit auto-reload Timer3 for general purpose or baud rate generator, two UARTs with frame error 2 detection and automatic address recognition, one SPI, one I C, up to 12 enhanced PWM output channels, and one 12-bit ADC. The peripherals are equipped with 18 sources with 4-level-priority interrupts capability. The MS51 series is equipped with two clock sources and supports switching on-the-fly via software. The clock sources include internal clock inputs, 10 kHz internal oscillator, and one 24 MHz internal precise oscillator that is factory trimmed to ±1% at room temperature. MS51 series provides additional power monitoring detection such as power-on reset and 4-level brown-out detection, which stabilizes the power-on/off sequence for a high reliability system design. MS51 SERIES PRODUCT BRIEF The MS51 series microcontroller consumes very low power with two economic power modes to reduce power consumption - Idle and Power-down mode, which are software selectable. Idle mode turns off the CPU clock but allows continuing peripheral operation. Power-down mode stops the whole system clock for minimum power consumption. The system clock of the MS51 series can also be slowed down by software clock divider, which allows for a flexibility between execution performance and power consumption. Aug. 1st 2019 Page 2 of 25 Rev.2.00 MS51 2 FEATURES  Operating Characteristics – Voltage range: 2.4 V to 5.5 V – Temperature range: -40°C to +105°C     CPU – Fully static design 8-bit high performance 1T 8051-based CMOS microcontroller. – Instruction set fully compatible with MCS-51. – 4-priority-level interrupts capability. – Dual Data Pointers (DPTRs). Memories – Up to 32 Kbytes Flash – Configurable 4/3/2/1 Kbytes of LDROM, which provides flexibility to user developed Boot Code. – Up to 2 Kbytes SRAM – 256 Bytes on-chip RAM. – Flash Memory accumulated with pages of 128 Bytes each. – Built-in In-Application-Programmable (IAP). – Code lock for security. Clocks – 16 MHz high-speed internal oscillator trimmed to ±1% when VDD 5.0V, ±4% in all conditions. – 24 MHz high-speed internal oscillator trimmed ±1% when VDD 5.0V, ±4% in all conditions. – 10 kHz low-speed internal oscillator. – On-the-fly clock source switch via software. Peripherals Aug. 1st 2019      Page 3 of 25 Power management – Two power reduced modes: Idle and Powerdown mode. Power monitor – Brown-out detection (BOD) with low power mode available, 4-level selection, interrupt or reset options. – Power-on reset (POR). Strong ESD and EFT immunity – ESD HBM pass 8 kV – EFT ± 4.4 kV – Latch-up pass 150 mA 96-bit Unique ID (UID) 128-bit Unique Customer ID (UCID) 2-Byte (16-bit) PDID Rev.2.00 MS51 SERIES PRODUCT BRIEF – Standard interrupt pins ̅̅̅̅̅̅̅ and ̅̅̅̅̅̅̅. – Two 16-bit Timers/Counters 0 and 1 compatible with standard 8051. – One 16-bit Timer 2 with three-channel input capture module and 9 input pin can be selected. – One 16-bit auto-reload Timer 3, which can be the baud rate clock source of UARTs. – One 16-bit PWM counter interrupt for timer. – One programmable Watchdog Timer (WDT) clocked by dedicated 10 kHz internal source.  – One dedicated Self Wake-up Timer (WKT) for self-timed wake-up for power reduced modes. – Two full-duplex UART ports with frame error detection and automatic address recognition. TXD and RXD pins of UART0 exchangeable via software. – Three smart card ports support ISO7816-3 compliant T=0, T=1 and support full-duplex UART mode (32K Flash supported) – One SPI port with master and slave modes, up to 12 Mbps when system clock is 24 MHz. 2 – One I C bus with master and slave modes, up to 400 kbps data rate. – Up to six pairs, twelve channels of pulse width modulator (PWM) output, with different modes and Fault Brake function for motor control. – Eight channels of pin interrupt, shared for all I/O ports, with variable configuration of edge/level detection. – One 12-bit ADC, supports up to 15 channels with 500 ksps converting rate – Up to 30 general purpose I/O pins and 1 input-only pin. All output pins have individual 2-level slew rate control. – Up to 20mA high current sink/source – Programmable pull-ups pull-lows MS51 3 BLOCK DIAGRAM Figure 3-1 NuMicro® MS51 Block Diagram MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 4 of 25 Rev.2.00 MS51 4 PARTS INFORMATION MS51 Series Naming Rule MS 51 F B 9 A E Core Line Package Flash SRAM Reserve Temperature 1T 8051 51: Base B: MSOP10 A: 8 KB 0: 2 KB (3x3 mm) B: 16 KB 1: 4 KB D: TSSOP14 C: 32 KB 2: 8/12 KB (4.4x5.0 mm) D: 64 KB 9: 1 KB E:-40°C ~ 105°C F: TSSOP20 (4.4x6.5 mm) E:TSSOP28 (4.4x9.7 mm) U: SOP28 (300 mil) O: SOP20 (300 mil) T: QFN33 (4x4 mm) P: LQFP32 (7x7 mm) L: LQFP48 MS51 SERIES PRODUCT BRIEF (7x7 mm) S: LQFP64 (7x7 mm) Aug. 1st 2019 Page 5 of 25 Rev.2.00 MS51 MS51 Series Selection Guide Package ADC(12-Bit) I2C SPI UART ISO-7816[2] PWM Timer/ I/O ISP ROM (KB) [1] SRAM (KB) Part Number Flash (KB) Connectivity 4* 8 4 5 2 1 5-ch MSOP10 MS51BA9AE 8 1 4* 12 4 5 2 1 1 7-ch TSSOP14 MS51DA9AE 8 1 [3] QFN20 4* 18 4 6 2 1 1 8-ch MS51XB9AE 16 1 [3] QFN20 4* 18 4 6 2 1 1 8-ch MS51XB9BE 16 1 4* 18 4 6 2 1 1 8-ch TSSOP20 MS51FB9AE 16 1 3 4* 18 4 10 2 1 1 10-ch TSSOP20 MS51FC0AE 32 2 3 4* 18 4 10 2 1 1 10-ch QFN20 MS51XC0BE 32 2 3 4* 26 4 12 2 1 1 15-ch TSSOP28 MS51EC0AE 32 2 3 4* 30 4 12 2 2 1 15-ch QFN33 MS51TC0AE 32 2 3 4* 30 4 12 2 2 1 15-ch LQFP32 MS51PC0AE 32 2 Note: 1. ISP ROM programmable 1K/2K/3K/4KB Flash for user program loader (LDROM) share from ARPOM. 2. ISO-7816 configurable as UART2. 3. Detailed package information please refer to Chapter 7 MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 6 of 25 Rev.2.00 MS51 5 PIN CONFIGURATION 5.1 MS51 Series Pin Diagram 5.1.1 MS51 Series LQFP32 Diagram MS51 SERIES PRODUCT BRIEF Figure 5-1 MS51 Series LQFP-32 -pin Diagram Aug. 1st 2019 Page 7 of 25 Rev.2.00 MS51 5.1.2 MS51 Series QFN33 Diagram MS51 SERIES PRODUCT BRIEF Figure 5-2 MS51 Series QFN-33 -pin Diagram Aug. 1st 2019 Page 8 of 25 Rev.2.00 MS51 5.1.3 MS51 Series TSSOP28 Diagram MS51 SERIES PRODUCT BRIEF Figure 5-3 MS51 Series TSSOP-28 -pin Diagram Aug. 1st 2019 Page 9 of 25 Rev.2.00 MS51 5.1.4 MS51FC0AE TSSOP20 Diagram MS51 SERIES PRODUCT BRIEF Figure 5-4 MS51 Series TSSOP-20 -pin Diagram Aug. 1st 2019 Page 10 of 25 Rev.2.00 MS51 5.1.5 MS51XC0BE QFN20 Diagram MS51 SERIES PRODUCT BRIEF Figure 5-5 MS51 Series QFN-20 -pin Diagram Aug. 1st 2019 Page 11 of 25 Rev.2.00 MS51 5.1.6 MS51 Series TSSOP20 Diagram PWM2/IC6/T0/AIN4/P0.5 1 20 P0.4/AIN5/STADC/PWM3/IC3 TXD/AIN3/P0.6 2 19 P0.3/PWM5/IC5/AIN6 RXD/AIN2/P0.7 3 18 P0.2/ICPCK/OCDCK/RXD_1/[SCL] RST/P2.0 4 17 P0.1/PWM4/IC4/MISO INT0/OSCIN/AIN1/P3.0 5 16 P0.0/PWM3/IC3/MOSI/T1 MS51FB9AE INT1/AIN0/P1.7 6 15 P1.0/PWM2/IC2/SPCLK GND 7 14 P1.1/PWM1/IC1/AIN7/CLO [SDA]/TXD_1/ICPDA/OCDDA/P1.6 8 13 P1.2/PWM0/IC0 VDD 9 12 P1.3/SCL/[STADC] 10 11 P1.4/SDA/FB/PWM1 PWM5/IC7/SS/P1.5 [ ] alternate function remapping , if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function. Figure 5-6 MS51 Series TSSOP-20 -pin Diagram MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 12 of 25 Rev.2.00 MS51 P0.1 / PWM0_CH4 / IC4 / SPI0_MISO P1.0 / PWM0_CH2 / IC2 / SPI0_CLK P0.0 / PWM0_CH3 / IC3 / SPI0_MOSI / T1 P0.1 / PWM0_CH4 / IC4 / SPI0_MISO MS51 Series QFN20 Pin Diagram P0.2 / ICPCK / OCDCK / UART1_RXD/[SCL] 5.1.7 15 14 13 12 11 PWM0_CH5 / IC5 / ADC_CH6 / P0.3 16 10 P1.2 / PWM0_CH0 / IC0 ADC_CH5 / STADC / PWM0_CH3 / IC3 / P0.4 17 9 P1.3 / I2C0_SCL / [STADC] PWM0_CH2 / IC6 / T0 / ADC_CH4 / P0.5 18 8 P1.4 / PWM0_CH1 / I2C0_SDA / PWM0_BRAKE UART0_TXD / ADC_CH3 / P0.6 19 7 P1.5 / PWM0_CH5 / IC7 / SPI0_SS UART0_RXD / ADC_CH2 / P0.7 20 6 VDD 2 3 4 5 INT0 / OSCIN / ADC_CH1 / P3.0 INT1 / ADC_CH0 / P1.7 VSS [SDA] / UART1_TXD / ICPDA / OCDDA / P1.6 MS51 SERIES PRODUCT BRIEF 1 nRESET / P2.0 MS51XB9BE [ ] alternate function remapping , if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function. Figure 5-7 MS51 Series QFN-20-pin Diagram Aug. 1st 2019 Page 13 of 25 Rev.2.00 MS51 P0.1 / PWM0_CH4 / IC4 / SPI0_MISO P1.0 / PWM0_CH2 / IC2 / SPI0_CLK P0.0 / PWM0_CH3 / IC3 / SPI0_MOSI / T1 P0.1 / PWM0_CH4 / IC4 / SPI0_MISO MS51 Series QFN20 Pin Diagram P0.2 / ICPCK / OCDCK / UART1_RXD/[SCL] 5.1.8 15 14 13 12 11 PWM0_CH5 / IC5 / ADC_CH6 / P0.3 16 10 P1.2 / PWM0_CH0 / IC0 ADC_CH5 / STADC / PWM0_CH3 / IC3 / P0.4 17 9 P1.3 / I2C0_SCL / [STADC] PWM0_CH2 / IC6 / T0 / ADC_CH4 / P0.5 18 8 P1.4 / PWM0_CH1 / I2C0_SDA / PWM0_BRAKE UART0_TXD / ADC_CH3 / P0.6 19 7 P1.5 / PWM0_CH5 / IC7 / SPI0_SS UART0_RXD / ADC_CH2 / P0.7 20 6 VDD 3 4 5 INT1/AIN0/P1.7 GND [SDA]/TXD_1/ICPDA/OCDDA/P1.6 2 INT0/OSCIN/AIN1/P3.0 MS51 SERIES PRODUCT BRIEF 1 RST/P2.0 MS51XB9BE [ ] alternate function remapping , if the same alternate function is shown twice, it indicates an exclusive choice not a duplication of the function. Figure 5-8 MS51 Series QFN-20-pin Diagram Aug. 1st 2019 Page 14 of 25 Rev.2.00 MS51 5.1.9 MS51 Series TSSOP14 Pin Diagram Figure 5-9 MS51 Series TSSOP-14-pin Diagram 5.1.10 MS51 Series MSOP10 Pin Diagram Figure 5-10 MS51 Series MSOP-10-pin Diagram MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 15 of 25 Rev.2.00 MS51 6 UTILITIES 6.1 Programmer and Debugger Nu-Link Basic full speed USB2.0 hardware debugger/programmer Nu-Link-Pro Advance hardware debugger/programmer with programming counter Nu-Link 2.0 Advance high speed USB2.0 hardware debugger/programmer with multi-functions Nu-Link-Gang Off-line hardware programmer supports up to four chips programming for mass-production ISP In system programming, a software programming tool support UART/USB ICP In Chip Programming, a software programming tool support Nu-Link programmer 6.2 Development Environment Programming IDE Keil C-51, IAR EW8051 Software Package Board Support Package(BSP), Sample Code, Development IDE NuTool Pin-View, NuTool-PinView, NuTool-ClockConfig 6.3 Development Board EVB NuMaker Part Number NT-MS51FB MS51XB9AE MS51FB9AE MS51XB9BE NT-MS51DA MS51DA9AE MS51BA9AE NK-MS51PC MS51FC0AE MS51XC0BE MS51EC0AE Feature Support Expand Connector, Arduino Uno Interface MS51 SERIES PRODUCT BRIEF MS51TC0AE MS51PC0AE Aug. 1st 2019 Page 16 of 25 Rev.2.00 MS51 7 PACKAGE DIMENSIONS 7.1 LQFP 32 (7x7x1.4 mm) for MS51PC0AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 17 of 25 Rev.2.00 MS51 7.2 QFN 33 (4x4x0.8 mm) for MS51TC0AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 18 of 25 Rev.2.00 MS51 7.3 TSSOP 28 (4.4x9.7x1.0 mm) for MS51EC0AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 19 of 25 Rev.2.00 MS51 7.4 TSSOP 20-Pin (4.4x6.5x0.9 mm) for MS51FB9AE & MS51FC0AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 20 of 25 Rev.2.00 MS51 7.5 QFN 20 (3.0x3.0 mm) for MS51XB9AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 21 of 25 Rev.2.00 MS51 7.6 QFN 20 (3.0x3.0 mm) for MS51XB9BE & MS51XC0BE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 22 of 25 Rev.2.00 MS51 7.7 TSSOP 14 (4.4x5.5 mm) for MS51DA9AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 23 of 25 Rev.2.00 MS51 7.8 MSOP 10 (3x3 mm) for MS51BA9AE MS51 SERIES PRODUCT BRIEF Aug. 1st 2019 Page 24 of 25 Rev.2.00 MS51 8 REVISION HISTORY Date Revision Description 2019.02.19 1.00 Initial version. 2019.06.24 1.01 Added Part number: MS51DA9AE & MS51 BA9AE 2019.08.01 2.00 Added Part number: MS51FC0AE MS51XC0BE MS51EC0AE MS51TC0AE MS51PC0AE Nuvoton Products are neither intended nor warranted for usage in systems or equipment, any malfunction or failure of which may cause loss of human life, bodily injury or severe property damage. Such applications are deemed, “Insecure Usage”. Insecure usage includes, but is not limited to: equipment for surgical implementation, atomic energy control instruments, airplane or spaceship instruments, the control or operation of dynamic, brake or safety systems designed for vehicular use, traffic signal instruments, all types of safety devices, and other applications intended to support or sustain life. All Insecure Usage shall be made at customer’s risk, and in the event that third parties lay claims to Nuvoton as a result of customer’s Insecure Usage, customer shall indemnify the damages and liabilities thus incurred by Nuvoton. Aug. 1st 2019 Page 25 of 25 Rev.2.00 MS51 SERIES PRODUCT BRIEF Important Notice
MS51FB9AE-T 价格&库存
很抱歉,暂时无法提供与“MS51FB9AE-T”相匹配的价格&库存,您可以联系我们找货
MS51FB9AE-T
  • 1+2.04820
库存:23
MS51FB9AE-T
    • 1+3.72680
    • 10+3.37590
    • 30+3.19440
    • 100+3.02500
    • 500+2.67410
    • 1000+2.62570
    库存:29670
    MS51FB9AE-T
    • 1+3.12400
    • 100+2.39800
    • 1250+2.09000
    • 2500+1.99100
    库存:1056
    MS51FB9AE-T
    • 1+3.99840
    • 10+3.31240
    • 30+2.96940
    • 100+2.62640
    库存:300
