OR-6N137
OR-6N137
    ORIENT(奥伦德)
    DIP8_9.66X6.5MM
    6N137由高效的AlGaAs发光二极管和高速光学检测器组成。这种设计在光电耦合器的输入端和输出端之间提供了良好的交流和直流隔离。
OR-6N137 数据手册
Shenzhen Orient Technology Co ., Ltd ORPC-6N137 ORIENT Photocoupler Product Data Sheet Name: ORPC-6N137 Customer:_________________ Date: _________________ SHENZHEN ORIENT TECHNOLOGY CO.,LTD. Block A 3rd Floor No.4 Building,Tian’an Cyber Park,Huangge Rd,LongGang Dist,Shenzhen,GD TEL:0755-29681816 FAX:0755-29681200 www.orient-opto.com Copyright© 2018 Orient Tech Corporation.All rights Reserved 1 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 1、Features (1) 3.3v / 5V supply voltage (2) low power consumption (3) high speed: 15MBd(typical) (4) VCM=1000V, and the lowest common mode inhibition (CMR) is 10 kv/μs (5) when - 40 ℃ ~ + 85 ℃ temperature of ac and dc performance 2、Instructions 6N137 is made up of an efficient AlGaAs light-emitting diode and high-speed optical detector. This design provides good ac and dc isolation between the input and output ends of the photoelectric coupler. The output characteristic of the photodetector is a collector open circuit schottky clamp transistor. The total mode transient immunity should reach 10 kv/pa at 3.3 v. The photoelectric coupler operating temperature range: 40 ℃ ~ + 85 ℃. 3、Application Range • line receiver isolation •A/ D, D/A converted digital signal isolation • eliminate noise from the ground loop • switching power supply • alternative pulse transformers • motor control system • interface of microprocessor system, computer and peripheral equipment 4、Functional Diagram Truth table Input(LED)Enable Output 1.NC 5.GND 2.Anode 6.Output 3.Cathode 7.VE(Enable) 4.NC 8.Vcc ON H L OFF H H ON L H OFF L H ON NC L OFF NC H 0.1 capacitor F bypass capacitance needs to be connected between A Pin8 and Pin5 Copyright© 2018 Orient Tech Corporation.All rights Reserved 2 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 5、Absolute Maximum Ratings (Ta=25℃)*1 Parameter Input Output *2 Symbol Rated Value Unit Average Forward Input Current IF 20 mA Reverse Input Voltage VR 5 V Power Dissipation PI 40 mV Enable Input Voltage VE VCC+0.5 V Enable Input current IE 5 mA Output Collector Current IO 50 mA Output Collector Voltage VO 7 V Output Collector Power Dissipation PO 85 mW Supply Voltage VCC 7 V Insulation Voltage Viso 5000 Vrms Working Temperature Topr -40 ~ + 85 Storage Temperature Tstg -55~ + 125 Soldering Temperature Tsol 260 ℃ *1. Room temperature = 25 ℃. Exceeding the maximum absolute rating can permanently damage the device. Working long hours at the maximum absolute rating can affect reliability. *2. soldering time is 10 seconds. Copyright© 2018 Orient Tech Corporation.All rights Reserved 3 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 6、Recommended Operating Conditions Parameter Operating Temperature Supply Voltage Symbol Min Max Unit TA -40 85 ℃ 2.7 3.6 4.5 5.5 VCC V Low Level Input Current IFL 0 250 μA High Level Input Current IFH 5 15 mA Low Level Enable Voltage VEL 0 0.8 V High Level Enable Voltage VEH 2 VCC V Output Pull-up Resistor RL 330 4k Ω N — 5 TTL Loads Fan Out (at RL=1kΩ per channel) Copyright© 2018 Orient Tech Corporation.All rights Reserved 4 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 7、Opto-electronic Characteristics Parameter Symbol Condition Min Typ Max Unit VF IF= 10mA — 1.38 1.7 V ΔVF/ ΔT IF= 10mA — -1.5 — mV/℃ BVR IR = 10μA 5 — — V — 1.5 5 mA — 34 — pF — 3.8 10 μA — 5.8 13 mA Input Forward voltage Temperature Coefficient OF Forward Voltage Reverse Voltage VE=2V,VCC=3.3V Input Threshold Current ITH VO=0.6V IOL (sinking) =13mA Input Capacitance CIN f = 1MHz, VF = 0V Detector VE= 0.5V, High Level Supply Current ICCH Low Level Supply Current ICCL High Level Enable Current IEH VCC= 3.3V,VE=2V — -0.19 -1.6 mA Low Level Enable Current IEL VCC= 3.3V,VE=0.5V — -0.41 -1.6 mA High Level Enable Voltage VEH 2 — — V Low Level Enable Voltage VEL — 0.8 V High Level Output Current IOH — 5 100 μA — 0.3 0.6 V VCC=3.3V,IF=0mA VE= 0.5V, VCC= 3.3V,IF=10mA VE=2V, VCC=3.3V, VO=3.2V,IF=250μA VE=2V, VCC=3.3V, Low Level Output Voltage VOL IF=5mA, IOL (sinking) = 13mA Recommended temperature range (TA= -40℃—+85℃,2.7V≤VCC≤3.6 V),IF= 7.5mA Unless otherwise stated. Typical valuesTA =25℃,VCC = 3.3 V. Copyright© 2018 Orient Tech Corporation.All rights Reserved 5 A0 Shenzhen Orient Technology Parameter Co ., Ltd ORPC-6N137 Symbol Condition Min Typ Max Unit VF IF= 10mA — 1.38 1.7 V ΔVF/ ΔT IF= 10mA — -1.5 — mV/℃ Reverse Voltage BVR IR = 10μA 5 — — V Input Threshold Current ITH — 1.35 5 mA Input Capacitance CIN — 34 — pF — 6.1 10 μA — 8.3 13 mA Input Forward voltage Temperature Coefficient OF Forward Voltage VCC=5.5V,VO=0.6V IOL>13mA f = 1MHz, VF = 0V Detector VE= 0.5V, High Level Supply Current ICCH Low Level Supply Current ICCL High Level Enable Current IEH VCC= 5.5V,VE=2V — -0.6 -1.6 mA Low Level Enable Current IEL VCC= 5.5V,VE=0.5V — -0.9 -1.6 mA High Level Enable Voltage VEH 2 — — V Low Level Enable Voltage VEL — 0.8 V High Level Output Current IOH — 0.9 100 μA — 0.3 0.6 V VCC=5.5V,IF=0mA VE= 0.5V, VCC= 5.5V,IF=10mA VE=2V, VCC=5.5V, VO=5.5V,IF=250μA VE=2V, VCC=5.5V, Low Level Output Voltage VOL IF=5mA, IOL (sinking) = 13mA Recommended temperature range(TA= -40℃—+85℃,4.5V≤VCC≤5.5V),IF= 7.5mA Unless otherwise stated. Typical values TA =25℃,VCC = 5.0V. Copyright© 2018 Orient Tech Corporation.All rights Reserved 6 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 8、Switching Characteristics Parameter Propagation delay time to output High level Propagation delay time to output Low level Pulse Width Distortion Output Rise Time (10 to 90%) Output Fall Time (90 to 10%) Propagation Delay Time of Enable from VEH to VEL Propagation Delay Time of Enable from VEL to VEH Symbol Condition Min Typ Max Unit tPLH 25 48 90 ns tPHL 25 35 75 ns — 13 — ns tr — 21 — ns tf — 6.6 — ns — 27 — ns — 9 — ns RL=350Ω |tPLH-tPHL| tELH tEHL CL=15pF RL=350Ω CL=15pF VEL=0V VEH=3V Recommended temperature range (TA= -40℃—+85℃,2.7V≤VCC≤3.6 V),IF= 7.5mA Unless otherwise stated. Typical values TA =25℃,VCC = 3.3 V。 Parameter Propagation delay time to output High level Propagation delay time to output Low level Pulse Width Distortion Symbol tPLH tPHL TA=25 ℃ RL=350 Ω CL=15pF |tPLH-tPHL| Output Rise Time (10 to 90%) tr Output Fall Time (90 to 10%) tf Propagation Delay Time of Condition tELH Copyright© 2018 Orient Tech Corporation.All rights Reserved RL=350Ω CL=15pF RL=350Ω 7 Min Typ Max Unit 25 40 75 — — 100 25 32 75 — — 100 — 8 — ns — 22 — ns — 6.9 — ns — 28 — ns ns ns A0 Shenzhen Orient Technology Enable from VEH to VEL Co ., Ltd ORPC-6N137 CL=15pF Propagation Delay Time of VEL=0V tEHL Enable from VEL to VEH VEH=3V — 12 — ns Recommended temperature range (TA= -40℃—+85℃,4.5V≤VCC≤5.5V),IF= 7.5mA Unless otherwise stated. Typical values TA =25℃,VCC = 5.0 V。 Parameter Symbol Condition VCC=3.3V,VCM=1000V,RL=350Ω Logic High Common Mode Transient Immunity IF=0mA,TA=25℃ |CMH| VCC=5V,VCM=1000V,RL=350Ω IF=0mA,TA=25℃ VCC=3.3V,VCM=1000V,RL=350Ω Logic Low Common Mode Transient Immunity IF=10mA,TA=25℃ |CML| VCC=5V,VCM=1000V,RL=350Ω IF=10mA,TA=25℃ Parameter Input-Output Insulation Leakage Current Withstand Insulation Test Voltage Symbol Condition 45% RH,t=5s, II-O VISO VI-O = 3kV DC,TA =25 C Min 10 Typ Max 15 — Unit kV/μs 10 15 — 10 15 — kV/μs 10 15 — Min Typ Max Unit — — 1 μA — — VRMS — Ω RH ≤ 50%, t =1min,TA=25℃ 5000 Input-Output Resistance RI-O VI-O = 500V DC — 1012 Input-Output Capacitance CI-O f = 1MHz, TA = 25 C — 1 p Recommended temperature range (TA=40℃-85℃) Unless otherwise stated. Typical values TA =25℃. Copyright© 2018 Orient Tech Corporation.All rights Reserved 8 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 9、Naming Rule NOTE: (1)year Code: '08' means' 2008 ', '09' means' 2009 'and so on. (2) Week Code: 01 represents the first week, 02 represents the second week, and so on. (3)OR:Manufacturer name, representing manufacturer Shenzhen Orient Components Co., Ltd. (4) Type code: representing type 6N137. (5)Anode Copyright© 2018 Orient Tech Corporation.All rights Reserved 9 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 10、 Outer Dimension (1)OR-6N137 (2)OR-6N137M (3)OR-6N137S 11、Recommended Foot Print Patterns (Mount Pad) (unit:mm) Copyright© 2018 Orient Tech Corporation.All rights Reserved 10 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 12、Taping Dimensions (1)OR-6N137-TA (2)OR-6N137-TA1 type symbol Size: mm ( inches ) bandwidth W 16±0.3(0.63) pitch P0 4±0.1(0.15) F 7.5±0.1(0.295) P2 2±0.1(0.079) P1 12±0.1(0.472) pitch interval Encapsulation TA/TA1 type amount (pcs) Copyright© 2018 Orient Tech Corporation.All rights Reserved 1000 11 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 13、Temperature Profile Of Soldering (1)IR Reflow soldering (JEDEC-STD-020C compliant) Note: one solder backflow is recommended under the conditions described below in the temperature and time profile. Do not weld more than three times. Configuration items conditions Preheat - TSmin 150˚C - TSmax 200˚C - Time (min to Max(TS) 90±30 sec Soldering zone - temperature (TL) 217˚C - time(tL) 60~100 sec 260˚C Peak Temperature 3˚C / sec max. Ramp-up rate Drop rate (3˚C / sec max.) Copyright© 2018 Orient Tech Corporation.All rights Reserved 12 3~6˚C / sec A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 (2)Wave soldering (JEDEC22A111 compliant) One-time welding is recommended under the temperature condition. Temperature 260+0/-5˚C Time 10 sec Preheat temperature 5 to 140˚C 30 to 80 sec Preheat time (3)Hand soldering by soldering iron Single lead welding is allowed in each process and one-time welding is recommended. Temperature 380+0/-5˚C Time 3 sec max Copyright© 2018 Orient Tech Corporation.All rights Reserved 13 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 14、Switching time test circuit Copyright© 2018 Orient Tech Corporation.All rights Reserved 14 A0 Shenzhen Orient Technology Co ., Ltd ORPC-6N137 15、Characteristics Curve Copyright© 2018 Orient Tech Corporation.All rights Reserved 15 A0 Shenzhen Orient Technology Copyright© 2018 Orient Tech Corporation.All rights Reserved 16 Co ., Ltd ORPC-6N137 A0 Shenzhen Orient Technology Copyright© 2018 Orient Tech Corporation.All rights Reserved 17 Co ., Ltd ORPC-6N137 A0
OR-6N137 价格&库存
很抱歉,暂时无法提供与“OR-6N137”相匹配的价格&库存,您可以联系我们找货
