DSF1A THRU DSF1J
Reverse Voltage - 50 to 600 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT SUPER FAST RECTIFIER
Features
SOD-123FL
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
0.079(2.00)
0.063(1.60)
0.046 (1.20)
0.031 (0.80)
0.118(3.00)
0.098(2.50)
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length,
0.052(1.35)
0.035(0.90)
5 lbs. (2.3kg) tension
0.012(0.30)
0.002(0.05)
0.039(1.00)
0.012(0.30)
Mechanical Data
0.158(4.00)
0.134(3.45)
Case: JEDEC 6OD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.0053 ounce, 0.015grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current at
TL(see fig.1)
DSF1A
DSF1B
DSF1C
DSF1D
DSF1E
DSF1G
DSF1J
E1A
E1B
E1C
E1D
E1E
E1G
E1J
50
35
50
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
600
420
600
SYMBOLS
VRRM
VRMS
VDC
UNITS
V
V
V
I(AV)
1.0
A
Peak forward surge current 8.3ms single half
sine-wave superimposed onrated load
(JEDEC Method)
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
Maximum DC reverse current TA=25℃
at rated DCblocking voltage TA=125℃
IR
5
100
CJ
trr
15
35
pF
Typical thermal resistance (NOTE 3)
RJA
85
℃/W
Operating junction temperature range
TJ
-55 to +150
-55 to +150
Typical junction capacitance (NOTE 1)
Maximum Reverse Recovery Time (NOTE 2)
Storage temperature range
TSTG
1
1.25
1.68
V
μA
ns
Note: 1.Measured with IF=0.5A, IR=1A, Irr=0.25A.
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.PCB mounted on 2.0*2.0" (5.0*5.0cm) coppeer pad area.
http://www.microdiode.com
Rev:2025A3
Page :1
DSF1A THRU DSF1J
Typical Characterisitics
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
t rr
10 ohm
Noninductive
50 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
300
1.2
1.0
I R - Reverse Current (μA)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
100
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
40
Case Temperature (°C)
T J =25°C
1.0
DSF1A~DSF1D
DSF1E/DSF1G
0.1
100
Fig.5 Typical Junction Capacitance
Junction Capacitance (pF)
Instaneous Forward Current (A)
Fig.4 Typical Forward Characteristics
10
80
60
% of PIV.VOLTS
DSF1J
0.01
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.001
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 m
mss Si
S i n g l e Ha
H a l f Si
S i n e Wa
Wa v e
( J E D E C Me
Method)
00
10
1
100
Number of Cycles
The curve above is for reference only.
Rev:2025A3
Page :2
DSF1A THRU DSF1J
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.2
0.047
B
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
C
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A3
Page :3
很抱歉,暂时无法提供与“DSF1C”相匹配的价格&库存,您可以联系我们找货
