SOD4001 THRU SOD4007
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL PURPOSE SILICON RECTIFIER
Features
SOD-123FL
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
0.079(2.00)
0.063(1.60)
0.046 (1.20)
0.031 (0.80)
0.118(3.00)
0.098(2.50)
High temperature soldering guaranteed:
250°C/10 seconds,0.375”(9.5mm) lead length, 5
0.052(1.35)
0.035(0.90)
lbs. (2.3kg) tension
0.012(0.30)
0.002(0.05)
0.039(1.00)
0.012(0.30)
0.158(4.00)
0.134(3.45)
Mechanical Data
Case: JEDEC 6OD-123FL molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.007 ounce, 0.02 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SOD4001 SOD4002 SOD4003 SOD4004 SOD4005 SOD4006 SOD4007
Parameter
UNITS
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
D1
D2
D3
D4
D5
D6
D7
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
1.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
1.1
V
Maximum DC reverse current
at rated DCblocking voltage
IR
5.0
50
uA
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
CJ
RJA
8
pF
90
℃/W
TJ
-55 to +150
TSTG
-55 to +150
Note: 1.Averaged over any 20ms period.
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted
http://www.microdiode.com
Rev:2025A4
Page :1
Typical Characterisitics
Fig.2 Typical Instaneous Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current (μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =15 0 °C
10
1.0
T J =25 °C
0.01
Junction Capacitance (pF)
C
2 5°
TJ =
TJ =
10
0°C
0°C
15
TJ =
Instaneous Forward Current (A)
0.2
0.9
60
100
80
Fig.4 Typical Junction Capacitance
0.5
0.8
40
percent of Rated Peak Reverse Voltage (%)
1.0
0.7
Fig.3 Typical Forward Characteristic
0.6
T J =75 °C
0.1
Case Temperature (°C)
0.1
0.5
T J =125 °C
1.0
1.1
100
T J=25°C
10
1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surge Current (A)
Fig.5 Maximum Non-Repetitive Peak
Forward Surae Current
35
30
25
10
05
00
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2025A4
Page :2
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SOD-123FL
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123FL
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.2
0.047
B
1.2
3.2
0.126
D
2
0.079
E
4.4
0.173
C
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“SOD4002”相匹配的价格&库存,您可以联系我们找货
