MSB40D THRU MSB40M
Voltage Range - 200 to 1000 Volts
Current - 4.0 Ampere
GLASS PASSIVATED SURFACE MOUNT BRIDGE RECTIFIERS
Features
UMSB
Glass Passivated Chip Junction
Reverse Voltage - 200 to 1000 V
.276(7.00)
.244(6.20)
.045(1.15)
.037(0.95)
(1)
(2)
.350(8.90)
.331(8.40)
.299(7.60)
.280(7.10)
.055(1.6)
.0315(1.0)
Forward Current- 4 A
High Surge Current Capability
.209(5.30)
.193(4.90)
Designed for Surface Mount Application
Mechanical Data
(3)
Top Viev
(4)
Bottom View
(1)
(2)
Case: JEDEC UMSB molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.00825 ounce, 0.234 grams
.012(0.29)
.070(0.17)
.122(3.10)
.003(0.08)
.002(0.04)
.059(1.5)
.051(1.3)
.114(2.90)
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Symbols
Marking Code
MSB40D
MSB40G
MSB40J
MSB40K
MSB40M
MDD
MB40D
MDD
MB40G
MDD
MB40J
MDD
MB40K
MDD
MB40M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Maximum Forward Voltage at 4.0 A
Maximum DC Reverse Current
@ T a =25 °C
at Rated DC Blocking Voltage
@ T a =125 °C
Typical Junction Capacitance per element
Typical Thermal Resistance(Note2)
Operating and Storage Temperature Range
I F(AV)
4
A
I FSM
95
A
VF
1.1
V
IR
5
100
μA
Cj
50
pF
RθJA
RθJC
RθJL
60
10
25
°C/W
T j , T stg
-55 ~ +150
°C
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. P.C.B. mounted with 4×1.5"×1.5"(3.81×3.81 cm)copper pad areas.
http://www.microdiode.com
Rev:2025A3
Page :1
MSB40D THRU MSB40M
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Average Rectified Output Current
Derating Curve
100
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
5.0
4.0
3.0
2.0
1.0
Resistive or Inductive Load
0.0
25
50
75
100
125
150
TJ=125°C
10
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Fig.4 Typical Junction Capacitance
Characteristics TJ=25°C
100
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
1.0
0.1
pulse with 300μ
s
1% duty cycle
0.01
00
0.5
1.0
1.5
TJ=25°C
10
1
2.0
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
100
Fig.6- Typical Transient Thermal Impedance
133
100
114
95
76
57
38
19
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
Number of Cycles
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
00
1.0
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2025A3
Page :2
MSB40D THRU MSB40M
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A3
Page :3
很抱歉,暂时无法提供与“MSB40D”相匹配的价格&库存,您可以联系我们找货
