RMSB20B THRU RMSB20M
Voltage Range - 100 to 1000 Volts
Current - 2.0 Ampere
GLASS PASSIVATED SURFACE MOUNT BRIDGE RECTIFIERS
Features
UMSB
Glass Passivated Chip Junction
Reverse Voltage - 100 to 1000 V
.276(7.00)
.244(6.20)
.045(1.15)
.037(0.95)
(1)
.350(8.90)
.331(8.40)
.299(7.60)
.280(7.10)
.055(1.6)
.0315(1.0)
(2)
Forward Current- 2.0 A
Fast reverse recovery time
Designed for Surface Mount Application
.209(5.30)
.193(4.90)
(3)
Mechanical Data
Top Viev
(4)
Bottom View
(1)
(2)
.122(3.10)
.114(2.90)
.012(0.29)
.070(0.17)
.059(1.5)
.051(1.3)
Case: JEDEC UMSB molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.00825 ounce, 0.234 grams
.003(0.08)
.002(0.04)
(3)
(4)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Symbols
Marking Code
MDD
MDD
MDD
MDD
MDD
MDD
Units
RMSB20B RMSB20D RMSB20G RMSB20J RMSB20K RMSB20M
Maximum Repetitive Peak Reverse Voltage
V RRM
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
100
200
400
600
800
1000
V
I F(AV)
2
A
I FSM
50
A
VF
1.3
V
IR
5.0
200
μA
Typical Junction Capacitance (Note 1)
Cj
30
pF
Typical Thermal Resistance(Note2)
RθJA
RθJC
RθJL
60
15
25
°C/W
t rr
500
ns
T j , T stg
-55 ~ +150
°C
Maximum Average Forward Rectified Current
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
(JEDEC Method)
Maximum Forward Voltage at 2.0 A
Maximum DC Reverse Current
@ T a =25 °C
at Rated DC Blocking Voltage
@ T a =125 °C
Maximum Reverse Recovery Time (Note3)
Operating and Storage Temperature Range
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with4×1.5"×1.5"(3.81×3.81 cm)copper pad areas.
3. Measured with I = 0.5 A, I = 1 A, Irr = 0.25 A .
http://www.microdiode.com
Rev:2025A2
Page :1
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
4.0
3.0
2.0
1.0
Resistive or Inductive Load
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Rectified Output Current (A)
Fig.1 Average Rectified Output Current
Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
CaseTemperature (°C)
0.1
pulse with 300μs
1% duty cycle
Junction Capacitance (pF)
Instaneous Forward Current (A)
1.0
100
120
140
T J =25°C
10
1
0.5
1.0
1.5
2.0
2.5
0.1
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
10
Number of Cycles
100
Transient Thermal Impedance( °C /W)
60
1
1.0
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
80
100
Instaneous Forward Voltage (V)
10
60
Fig.4 Typical Junction Capacitance
T J =25°C
0.01
0.0
40
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Characteristics
10
Fig.6- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2025A2
Page :2
100
Suggested Pad Layout
Q1
1.0×1.4
39×55
P1
Q2
Dim
Min
P1
5.1
P2
7.1
Q1
1.8
Q2
1.3
P2
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A2
Page :3
很抱歉,暂时无法提供与“RMSB20J”相匹配的价格&库存,您可以联系我们找货
