ME6222
400mA , Ultralow Output Voltage 0.8V,
Adjustable ,High Speed LDO ME6222 Series
General Description
Features
The ME6222 series are highly accurate, low
Voltage Setting via External Resistor:0.8V~5.0V
noise, LDO Voltage Regulators .The output voltage
Maximum Output Current: 400mA
can be set via the external resistor.
Dropout Voltage:
On chip
125mV@ IOUT =100mA (Vout=3.3V)
trimming adjusts the reference/output voltage to
within ±2% accuracy. Internal protection features
Operating Voltage Range:2.8V~18V
consist of output current limiting, safe operating
Highly Accuracy:±2%
area compensation, and thermal shutdown. The
Standby Current: 45uA(TYP.)
current limiter’s feedback circuit also operates as a
Line Regulation: 30mV(TYP.)
short protect for the output current limiter and the
Temperature Stability≤0.5%
output pin. The CE function allows the output of
Thermal Shutdown Protection:165℃
regulator to be turned off, resulting in greatly
reduced power consumption. The ME6222 series
can operate with up to 18V input.
Package
Applications
Consumer and Industrial Equipment Point of Regulation
Switching Power Supply Post Regulation
Hard Drive Controllers
Battery Chargers
V02
www.microne.com.cn
● 5-pin SOT23-5
Page 1 of 9
ME6222
Typical Application Circuit
Fig.1
Fig.2
V02
VOUT=VFB=0.8V
VOUT=0.8X(R1+ R2)/R2
www.microne.com.cn
Page 2 of 9
ME6222
Selection Guide
ME 6222X X X G
Environment mark
Package:
M5-SOT23-5
Function
Product Type
Product Series
Microne
product series
ME6222CM5G
product description
VFB =0.8V,
the output voltage is adjustable
Pin Configuration
Pin Assignment
Pin Number
Pin Name
Functions
1
VIN
Power Input Voltage
2
VSS
Ground
3
CE
ON / OFF Control
4
FB
Feedback Voltage
5
VOUT
Output Voltage
SOT23-5
V02
www.microne.com.cn
Page 3 of 9
ME6222
Block Diagram
Absolute Maximum Ratings
Parameter
Symbol
Ratings
Units
Input Voltage
VIN
18
V
Output Current
IOUT
500
mA
Output Voltage
VOUT
Vss-0.3~8.0
V
CE Pin Voltage
VCE
Vss-0.3~VIN +0.3
V
FB Pin Voltage
VFB
Vss-0.3~VIN +0.3
V
PD
300
mW
Operating Temperature Range
TOPR
-40~+150
Storage Temperature Range
TSTG
-55~+150
Power Dissipation
SOT23-5
Lead Temperature
V02
260℃,4sec
www.microne.com.cn
Page 4 of 9
ME6222
Electrical Characteristics
(VIN= Vout+1,VCE=VIN ,VOUT=VFB, CIN=COUT=1uF,Ta=25OC,unless otherwise noted)
Parameter
Symbol
Conditions
Min.
Typ.
Max.
Units
VFB
IOUT=30mA,
784
800
816
mV
Output Voltage Range
VOUT(E)
(Note 2)
VIN= VOUT(T)+1V,VCE=VIN
Using test circuit 2
0.8
5.0
V
IOUTMAX
VIN= VOUT+1V(Note1)
400
550
mA
Load Regulation
∆VOUT
1mA≤IOUT≤100mA
4
10
mV
VDIF1
IOUT =100mA
125
140
mV
VDIF2
IOUT =200mA
250
270
mV
Supply Current
ISS
VIN= 3V, VCE=VIN
45
60
μA
Stand-by Current
ICEL
VIN= 3V,VCE=0V
μA
Line Regulation
(Note 1)
∆VOUT
IOUT =30mA
Vout+1V ≤VIN≤18V
4
15
mV
CE “High” Voltage
VCEH
RL=1.0KΩ
1.3
18
V
CE “Low” Voltage
VCEL
RL=1.0KΩ
V
CE “High”Current
ISH
VCE=7V
-0.1
0.1
μA
CE “Low” Current
ISL
VCE=0V
-0.1
0.1
μA
Short-circuit Current
ISHORT
VOUT=0V
70
mA
Thermal Shutdown
Protection
Tsd
IOUT=1mA,
165
Over Current Protection
Ilimit
600
mA
Feedback Voltage
Dropout Voltage (Note 3)
Note :
1. VOUT (T) :Output Voltage less than 0.8V, the input Voltage should be 2.8V at least, and the others fulfil the rule of
Vin=Vout+1.
2.VOUT (E) :Effective Output Voltage ( le. The output voltage when “VOUT (T)+1.0V”is provided at the Vin pin while
maintaining a certain IOUT value.)
3.VDIF:VIN1 –VOUT (E)’
VIN1 :The input voltage when VOUT(E)’ appears as input voltage is gradually decreased.
VOUT (E)’=A voltage equal to 98% of the output voltage whenever an amply stabilized IOUT {VOUT (T)+1.0V} is
input.
V02
www.microne.com.cn
Page 5 of 9
ME6222
Type Characteristics
(1)Output Voltage VS. Output Current
(VIN=VOUT+1V, VOUT=3.3V)
(2) Output Voltage VS. Temperature
(VIN=VOUT+1V , VOUT=3.3V, IOUT=10mA)
Output Current VS. Output Voltage
Output Voltage(V)
Output Volta ge VS. Te mpe ra ture
Output Voltage
3.35
3.32
3.29
3.26
V
CE=VIN=4.3V
Vce=Vin=4.3V
3.23
Vout=3.3V
3.2
200
300
400
500
600
3.35
3.30
3.25
3.20
3.15
3.10
3.05
3.00
-40
Output Current
Io= 10mA
IO=10mA
Vout=3.3V
Output Voltage(V)
600
400
200
VCE=VIN=4.3V
3.5
3
2.5
2
1mA
1.5
30mA
1
0.5
300
400
500
VCE=VIN
100mA
10
15
Input Volta ge (V)
Output current(mA)
(5) Quiescent Current VS. Input Voltage
Quiescent Current(uA)
60
50
40
30
VCE= VIN=3V
VFB=VOUT
10
10
15
Input Voltage(V)
V02
160
Output Volta ge VS. Input Volta ge
800
100
120
(4)Output Voltage VS. Input Voltage
(VOUT=3.3V)
Dropout Voltage VS. Output current
T e m p e r a t℃)
ure(
(3)Dropout Voltage VS. Output Current
(VIN=VOUT+1V,VOUT=3.3V)
Dropout Voltage(mV)
VCE=V
V IN
i n=4.3V
=4.3V
www.microne.com.cn
Page 6 of 9
ME6222
Applications Information
1. Setting the Output Voltage
ME6222 series output voltage can be set via a external resistor. AS the internal reference is 0.8V (Typical), the
external voltage can optionally set between 0.8V and 5.0V by connecting a extra resistor between the Vout and
VFB pins and a resistor between the VFB and VSS pins.
The output voltage is calculated as below:
VOUT=0.8x(1+R1/R2)
Table 1: Resistor selection for output voltage setting (e.g.)
VO (V)
R1 (KΩ)
R2 (KΩ)
1.2
50
100
1.8
125
100
2.5
215
100
3.0
275
100
3.3
315
100
3.6
350
100
5.0
525
100
Caution: The value of R2 is more than 100K in the best.
2. Input Bypass Capacitor
An input capacitor is recommended. A 1uFor more tantalum on the input is a suitable input bypassing for almost
all applications.
3. Output Capacitor
The output capacitor is critical in maintaining regulator stability, and must meet the required conditions for both
minimum amount of capacitance and ESR (Equivalent Series Resistance).The output capacitance required by
the ME6222 is 2.2µF or more, If a tantalum capacitor is used. Any increase of the output capacitance will merely
improve the loop stability and transient response. The ESR of the output capacitor should be less than 1Ω .
4. Load Regulation
The ME6222 regulates the voltage that appears between its output and adjust pins. In some cases, line
resistances can introduce errors to the voltage across the load. To obtain the best load regulation, a few
precautions are needed. Figure 1, shows a typical application. The Rt1 and Rt2 are the line resistances. It is
obvious that the VLOAD is less than the VOUT by the sum of the voltage drops along the line resistances. In this
case, the load regulation seen at the RLOAD would be degraded from the datasheet specification. To improve this ,
the load should be tied directly to the output terminal on the positive side and directly tied to the ground terminal
on the negative side.
Rt1
CE
VIN
VIN
VSS
Rt1 IL
VOUT
FB
R load
VOUT
Rt2
V02
Vload=VOUT-IL(Rt1+ Rt2)
Vload
www.microne.com.cn
Fig.1 Typical Application
Page 7 of 9
ME6222
Packaging Information
● Packaging Type: SOT23-5
DIM
V02
Millimeters
Inches
Min
Max
Min
Max
A
0.9
1.45
0.0354
0.0570
A1
A2
0.9
1.3
0.0354
0.0511
B
0.2
0.5
0.0078
0.0196
C
0.09
0.26
0.0035
0.0102
D
2.7
3.1
0.1062
0.1220
E
2.6
3.1
0.0866
0.1181
E1
1.50
1.80
0.0511
0.0708
e
0.95REF
0.0374REF
e1
1.90REF
0.0748REF
L
0.10
0.60
0.0039
0.0236
a0
00
300
00
300
www.microne.com.cn
Page 8 of 9
ME6222
The information described herein is subject to change without notice.
Nanjing Micro One Electronics Inc is not responsible for any problems caused by circuits or diagrams
described herein whose related industrial properties, patents, or other rights belong to third parties.
The application circuit examples explain typical applications of the products, and do not guarantee
the success of any specific mass-production design.
Use of the information described herein for other purposes and/or reproduction or copying without
the
express permission of Nanjing Micro One Electronics Inc is strictly prohibited.
The products described herein cannot be used as part of any device or equipment affecting the
human
body, such as exercise equipment, medical equipment, security systems, gas equipment, or any
apparatus installed in airplanes and other vehicles, without prior written permission of Nanjing Micro
One Electronics Inc.
Although Nanjing Micro One Electronics Inc exerts the greatest possible effort to ensure high quality
and reliability, the failure or malfunction of semiconductor products may occur. The user of these
products should therefore give thorough consideration to safety design, including redundancy,
fire-prevention measures, and malfunction prevention, to prevent any accidents, fires, or community
damage that may ensue.
V02
www.microne.com.cn
Page 9 of 9
很抱歉,暂时无法提供与“ME6222CM5G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.52704
- 100+0.42876
- 300+0.37973
- 3000+0.32854
- 6000+0.29906
- 9000+0.28437
- 国内价格
- 10+0.48312
- 100+0.39303
- 600+0.34808
- 1200+0.34286
- 3000+0.30116
- 国内价格
- 1+0.50490
- 200+0.32560
- 1500+0.28380
- 3000+0.25080
- 国内价格
- 1+0.39700
- 3000+0.30120
