FE1.1S-BQFN24B
FE1.1S-BQFN24B
    TERMINUS(汤铭科技)
    WQFN-24_4X4MM
    USB 2.0 4-端口集线器控制器
FE1.1S-BQFN24B 数据手册
USB 2.0 4-Port Hub Data Sheet Rev. B12.6E FE1.1s – Revision B USB 2.0 HIGH SPEED 4-PORT HUB CONTROLLER Data Sheet INTRODUCTION FEATURES The Terminus FE1.1s is an USB 2.0 High Speed 4-  Fully compliant with Universal Serial Bus port hub controller with special features to support Specification Revision 2.0 (USB 2.0); GSMA “Universal Charging Solution”, (UCS). It is □ Upstream Facing Port supports High- fully compliant to USB-IF “Universal Serial Bus Speed (480MHz) and Full-Speed Specification Revision 2.0” and “Battery Charging (12MHz) modes; Specification Revision 1.1/1.2”. □ Speed, Full-Speed, and Low-Speed The FE1.1s is a highly integrated, high quality, and (12MHz) modes; high performance solution for USB 2.0 4-port hub. With its tiny footprint and extremely low power  The high quality of FE1.1s is guaranteed by Design-  Integrated USB 2.0 Transceivers;  Integrated upstream 1.5KΩ pull-up, downstream 15KΩ pull-down, and serial For-Testing with comprehensive scan chains and Built-In-Self-Test modes which could exercise all High, Full, and Low Speed analog front end (AFE) components on the packaging and testing stages. FE1.1s could be optionally configured to support resistors;  Integrated 5V to 3.3V and 1.8V regulators;  Integrated Power-On-Reset with power failure detection circuit;  Charging Downstream Ports as defined by USB-IF Battery Charging Specification. With this feature  April 21, 2021 Integrated 12MHz-to-480MHz Phase Lock Loop (PLL);  Universal Charging Solution compliant battery based portable devices. Integrated 12MHz Oscillator with feedback resistor and crystal load capacitors; enabled, an USB hub could be easily transformed into a charging station – USB Charging Hub for Compliant with Universal Charging Solution, and USB Battery Charging Specification 1.1/1.2. consumption, it is the best choice for embedded application as well as standalone hub. 4 Downstream Facing Ports support High- Integrated Portable Device detection circuitry for UCS supporting;  Single Transaction Translator (Single TT) – Subject to Change Without Notice 1 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E □ One TT for all downstream ports; □ The TT could handle 64 periodic StartSplit transactions, 32 periodic CompleteSplit transactions, and 6 none-periodic transactions;  Ganged Power Control and Global OverCurrent Detection support;  EEPROM configured options – □ Vendor ID, Product ID, & Device Release Number; and □  Number of Downstream Ports; Automatic re-enumeration when hub switches from self-powered mode to bus-powered mode;  Board configured comprehensive Port Indicators support: □ Four Downstream Port Enabled indicator LED (Green, one for each port), plus one Active/Suspend indicator LED (Red); or □ One joint Downstream Port Enabled indicator LED (Green, one for all ports), plus one Active/Suspend indicator LED (Red); or □ One joint Downstream Port Enabled indicator LED (Green, one for all ports), plus one Charging Request/Portable Device Detection indicator LED (Blue);  Board configure support of portable device detection mechanism for Universal Charging Solution on all 4 downstream ports. April 21, 2021 Subject to Change Without Notice 2 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E ORDER INFORMATION P/N-Order Code Description Package Type Packing Minimum Order Quantity FE1.1s-BQFN24BT(Note1) 24-pin WQFN (II / III) Tape & Reel (4mm x 4mm) 3000 FE1.1s-BSOP28BCN 28-pin SSOP (10mm x 4mm) Tube 10000 Tape & Reel 15000 Tray 15000 FE1.1s-BSOP28BCNTR FE1.1s-BQFP48B 28-pin SSOP USB 2.0 4-Port STT (10mm x 4mm) Hub Controller 48-pin LQFP (7mm x 7mm) FE1.1s-BQFP48BT(Note1) 48-pin LQFP (7mm x 7mm) Tray 2500 FE1.1s-BQFN24BV(Note2) 24-pin WQFN (III) (4mm x 4mm) Tape & Reel 3000 FE1.1s-BSOP28BJ 28-pin SSOP (10mm x 4mm) Tube 10000 Tape & Reel 15000 Tape & Reel 15000 Tube 10000 FE1.1s-BSOP28BJTR FE1.1s-BQFN24BJ FE1.1s-BSOP28BL FE1.1s-BSOP28BLTR FE1.1s-BQFN24BL FE1.1s-BSOP28BPTR FE1.1s-BQFN24B USB 2.0 4-Port STT 28-pin SSOP Hub Controller (10mm x 4mm) (Revision B10) 24-pin WQFN (4mm x 4mm) 28-pin SSOP (10mm x 4mm) USB 2.0 4-Port STT 28-pin SSOP Tape & Reel Hub Controller (10mm x 4mm) (Revision B12) 24-pin WQFN (II / III) Tape & Reel (4mm x 4mm) 28-pin SSOP Tape & Reel USB 2.0 4-Port STT (10mm x 4mm) Hub Controller 24-pin WQFN (II / III) Tape & Reel (Revision B16) (4mm x 4mm) 15000 15000 15000 15000 Note: 1. Product of order code BQFN24BT and BQFP48BT is final tested in Room Temperature, 85°C, and -40°C, respectively. 2. Product of order code BQFN24BV is AEC-Q100 Qualified and final tested in Room Temperature, 85°C, and -40°C, respectively. April 21, 2021 Subject to Change Without Notice 3 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E BLOCK DIAGRAM To Downstream Devices Downstream PHY #1 Downstream PHY #2 Downstream PHY #3 To Upstream Host/Hub Downstream PHY #4 Upstream PHY Routing Switch USB Multi-port Transceiver Macro Cell 3.3V & 1.8V Regulator 12MHz Crystal Over Current Detection Power Switch Control OSC POR PLL (x40) Serial Interface Engine Downstream Port Controllers Transaction Translator Full/Low-Speed Handler Data Recovery & Elastic Buffer Data Transmit Transaction Translator High-Speed Handler Unified Transaction Translator Buffer (2KB) Upstream Port Controller Hub Controller EEPROM, Hub Activity LED, Port Indicator LED, Charging Request LED, USB 2.0 Hub Controller Fig. 1: Block Diagram April 21, 2021 Subject to Change Without Notice 4 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE I 28-Pin SSOP (Body Size: 10mm x 4mm, Pitch: 0.64mm) PIN ASSIGNMENT VSS 1 28 NC XOUT 2 27 XIN 3 26 TESTJ OVCJ DM4 4 25 PWRJ DP4 5 24 LED2 DM3 6 23 LED1 DP3 7 FE1.1s 22 DRV DM2 8 (Rev. B) 21 VD33F DP2 9 20 VDD5 DM1 10 19 BUSJ DP1 11 18 VBUSM NC 12 17 XRSTJ NC 13 16 DPU REXT 14 15 DMU Fig. 2: 28-Pin SSOP Pin Assignment April 21, 2021 Subject to Change Without Notice 5 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE II / III 24-Pin WQFN (Body Size: 4mm x 4mm, Pitch: 0.5mm) BUSJ VBUSM XRSTJ DPU DMU REXT PIN ASSIGNMENT 18 VDD5 VD33F DRV LED1 LED2 PWRJ 13 19 12 FE1.1s (Rev. B) 25 VSS 24 6 OVCJ TESTJ XOUT XIN DM4 DP4 1 7 DP1 DM1 DP2 DM2 DP3 DM3 Fig. 3: 24-Pin WQFN Pin Assignment April 21, 2021 Subject to Change Without Notice 6 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE IV 48-Pin LQFP (Body Size: 7mm x 7mm) 48 NC NC VDD5 VD33F NC NC DRV LED1 LED2 NC NC PWRJ OVCJ PIN ASSIGNMENT 37 1 36 BUSJ NC VBUSM NC XRSTJ VSS TESTJ NC NC VSS DPU FE1.1s NC DMU (Rev. B) NC NC VD18 REXT VSS VD33 VREG18 XOUT 12 25 DM1 VSS DP2 DM2 VD33 DP3 DM3 VSS DP4 DM4 VD33 VS_A 24 13 DP1 XIN Fig. 4: 48-Pin LQFP Pin Assignment April 21, 2021 Subject to Change Without Notice 7 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PIN DESCRIPTION TABLE Pin Name Pin No. SSOP WQFN Type Function Note LQFP VSS 1 25 XOUT 2 3 11 OSC 12MHz Crystal Oscillator output. 1 XIN 3 4 12 OSC 12MHz Crystal Oscillator input/External 12MHz clock input. 1 VD33 ─ ─ DM4 4 5 14 UTD The D- pin of the 4th Downstream Facing Port. DP4 5 6 15 UTD The D+ pin of the 4th Downstream Facing Port. DM3 6 7 17 UTD The D- pin of the 3rd Downstream Facing Port. DP3 7 8 18 UTD The D+ pin of the 3rd Downstream Facing Port. DM2 8 9 20 UTD The D- pin of the 2nd Downstream Facing Port. DP2 9 10 21 UTD The D+ pin of the 2nd Downstream Facing Port. DM1 10 11 23 UTD The D- pin of the 1st Downstream Facing Port. DP1 11 12 24 UTD The D+ pin of the 1st Downstream Facing Port. VS_A ─ ─ 25 P Analog Ground. VREG18 ─ ─ 26 P 1.8V power output from integrated 3.3V→1.8V regulator – a 10μF decoupling capacitor is required. NC 12 28 ─ ─ P These 2 pins were 1.8V power before Revision B. Though backward compatible, it is strongly recommended to be left as No-Connection in new designs. They could still be used in this version for testing internal 1.8V level. NC 13 ─ ─ P This pin was 3.3V power input before Revision B. It could be either left as No-Connection for new design or connected to pin 21 (VD33F) through the PCB board as backward compatible. NC ─ ─ 1,2,3,5, 7,8,29, 32,37, 40,41, 45,46 REXT 14 13 28 VD18 ─ ─ 9 April 21, 2021 6,10,16 P ,22,33 13,19, P 27 Ground (pin 25 of WQFN is the underbelly exposed pad) 3.3V Power No connection. External Bias Resistor A 2.7KΩ (± 1%) resistor should be connected to VSS to provide internal bias reference. P 1.8V Power Subject to Change Without Notice 8 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E DMU 15 14 30 UTU The D- pin of the Upstream Facing Port. DPU 16 15 31 UTU The D+ pin of the Upstream Facing Port. XRSTJ 17 16 34 I External Reset For normal applications, it should be pull-up to 3.3V. The internal Power-On-Reset circuit will take care of the reset operation during the chip power-up stage. In case there are system design needs to reset the chip other than powerup stage, it can be done by driving this input low for a minimum pulse of 10 µs. VBUSM 18 17 35 I Upstream Port Power (VBUS) Monitor This pin monitors the power state of VBUS from upstream facing port. High level indicates that the host is powered up and the hub should function normally. Low level indicates that the host is powered down, and the hub should be in power-down state. BUSJ 19 18 36 I Bus Power Sense This pin identify the primary power source of the hub. High level indicates the hub is Self-Powered and has enough strength to support High-Power devices on its downstream ports. Otherwise, it is Bus-Powered and each downstream ports are presumed to supply 100mA of power only. VDD5 20 19 38 P 5V Power Input This is the 5V power input for integrated 5V → 3.3V regulator. However, if external 3.3V source is used, this pin should be No-Connection. VD33F 21 20 39 P 3.3V output filter capacitor for embedded 5V → 3.3V regulator, or 3.3V input from external source. DRV/ CHRGEN 22 21 42 I/O24 LED Drive Control/Charging Hub Enable LED1/ EESCL 23 22 43 I/O8 LED Control 1/External EEPROM Clock Port 1 and Port 3 device connected indicator (LED) control; or, when LED2 is tied to high during power-onreset, it is the joint indicator for all ports. At the same time, it could also be used as the clock (SCL) of external EEPROM. LED2/ JLEDEN 24 23 44 I/O8 LED Control 2/Joint LED Indicator Enable Port 2 and Port 4 device connected indicator (LED) control. During power-on-reset, it is a configuration input for enabling Joint Port Indicator by tying to 3.3V. PWRJ 25 24 47 OD April 21, 2021 During power-on-reset, this pin is used as Charging Hub Enable. If it is tied to high, the battery charging function will be enabled. Otherwise, it is a normal hub and this pin functions as LED driving control pin. Power Enable This is an active low, open-drain output signal for Subject to Change Without Notice 9 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E controlling power to the downstream devices in Ganged Power Switching mode. It is enabled and disabled by the host hub driver to reduce the in-rush current or in response to Over-Current Detection. OVCJ 26 1 48 I Over Current Sense Active low input from external current monitor indicating over current condition for Global Over-Current Protection. TESTJ/ EESDA 27 2 4 OD- Test Mode Enable/External EEPROM Serial Data PU Active low, open drain signal with internal pull-up resistor. When tied to low during power-on-reset, the chip will be set in test mode. The test mode is for factory test only, for all applications, this pin should be either left as NoConnection or connected to the Serial Data/Address (SDA) pin of external 2-wire EEPROM. Type Abbreviation – I: Schmitt Trigger Input, 5V-Tolerant; I/O8: Input/Output (driving strength: 8mA); I/O24: Input/Output (driving strength: 24mA); OD: Output, Open Drain (sink current: 4mA); OD-PU: 3.3V Input/Output, Open Drain with Internal Pull-Up (sink current: 4mA); I-PU: 3.3V Input with Internal Pull-Up; UTD: USB Downstream Facing Port Transceiver (supporting High/Full/Low-Speed); UTU: USB Upstream Facing Port Transceiver (supporting High/Full-Speed); OSC: Crystal Oscillator (with integrated feedback resistor, and crystal load capacitor); P: Power/Ground. Note 1 – Crystal Requirements • Frequency accuracy: 12MHz ± 50ppm • Load capacitance: 16pF ~ 20pF • Equivalent Series Resistance: 50 Ω Max. April 21, 2021 Subject to Change Without Notice 10 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E APPLICATION ALTERNATIVES The FE1.1s can be configured through board design options in one of three modes – Individual Port Active Indicator mode, Joint Port Active Indicator mode, and USB Charging Hub mode. Each mode could incorporate an optional external serial EEPROM for customizing Vendor ID, Product ID, Device Release Number, and number of ports. The detailed layout of EEPROM contents is explained in the following section. All these options are implemented through four pins: DRV, LED1, LED2, and TEST. Individual Port Active Indicator Mode In this mode, as shown by Fig. 5, FE1.1s supports 5 LED indicators – one green LED for each downstream port, and one red LED for hub active/suspend indication. The green light turns on whenever a device is properly attached to its corresponding port, and turns off when the device is disconnected or failed, or the hub itself being suspended. The red light turns on when the hub is configured by the USB host, and turns off when it is detached or switched into suspend mode. All LED's are optional and could be safely omitted without any side effects. The external EEPROM is optionally hooked on TESTJ and LED1. TESTJ LED1 SDA SCL Green Green Green EEPROM Port 3 Indicator FE1.1s LED2 Port 1 Indicator A0 A1 A2 Green Port 2 Indicator Port 4 Indicator Red DRV Hub Active/Suspend Indicator Fig. 5: Individual Port Indicator Configuration April 21, 2021 Subject to Change Without Notice 11 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E Joint Port Active Indicator Mode The four downstream port indicators can be summarized into one single LED, as depicted in Fig. 6, by tying LED2 to 3.3V. In this mode, the Joint Port Indicator will turn on whenever there is at least one device attached to any of its downstream ports. The behavior of the Hub Active/Suspend Indicator and the external serial EEPROM are remained the same. Green 3.3V Joint Port Indicator TESTJ SDA SCL EEPROM LED1 A0 A1 A2 FE1.1s LED2 Red DRV Hub Active/Suspend Indicator Fig. 6: Joint Port Indicator Configuration USB Charging Hub Mode The major changes of FE1.1s Revision B from its predecessors are the new capabilities to support GSMA “Universal Charging Solution” and USB-IF “Battery Charging Specification Revision 1.1/1.2”. With the charging support enabled, the FE1.1s will be ready to respond to the charging requests from portable devices no matter whether it is not connected to the host, the host being April 21, 2021 Subject to Change Without Notice 12 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E powered down, in normal operation, or in suspend. In other words, as long as the hub itself is adequately powered, the charging function is independent to the status of the upstream port or the host controller. Thus make it a full function USB Charging Hub. Fig. 7 illustrates how the FE1.1s being configured as USB Charging Hub mode by tying the DRV pin to 3.3V. Green 3.3V Joint Port Indicator TESTJ SDA SCL EEPROM LED1 A0 A1 A2 FE1.1s DRV Blue LED2 Charging Request Indicator Fig. 7: USB Charging Hub In this mode, the LED1 is the Joint Port Indicator which turns on whenever there are at least one device connected to any of its downstream ports. And it turns off when all devices has been disconnected, or itself is switched into suspend mode. The LED2 will be the Charging Request Indicator which turns on when Charging Request is detected on any of its downstream ports, or charging request handshake has been completed successfully. The connect/disconnect status of the portable devices is detected through standard USB procedure. April 21, 2021 Subject to Change Without Notice 13 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E That is, for Full/Low Speed devices, both D+ and D- of the corresponding downstream port been detected as Single Ended Zero (SE0) for more than 2.5 μs. For High Speed, through the detection of removal of termination of D+ and D-. The status of power source for charging is indicated by BUSJ. When BUSJ is low, the hub is Bus Powered, and presumably has been provided 500mA only, which is barely enough to sustain the normal USB function of the hub plus 4 more Low Power Device (100mA). In this case, Charging is certainly not allowed. When BUSJ is high, the hub is Self Powered, and presumably has its own power source and has enough power for portable devices to charge. An optional external Serial EEPROM could still be hooked on LED1 and TESTJ to provide alternate Product ID, Vendor ID, Device Release Number, and number of downstream ports – if the system designer would like some number less than 4. April 21, 2021 Subject to Change Without Notice 14 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E EEPROM CONTENTS Address Contents Note 0x00 0x40 Constant, low byte of check code. 0x01 0x1A Constant, high byte of check code. 0x02 Vendor ID (Low) Low byte of Vendor ID, idVendor field of Standard Device Descriptor. 0x03 Vendor ID (High) High byte of Vendor ID. 0x04 Product ID (Low) Low byte of Product ID, idProduct field of Standard Device Descriptor. 0x05 Product ID (High) High Byte of Product ID. 0x06 Device Release (Low) Low byte of Device Release Number, must be Binary Coded Decimal, bcdDevice field of Standard Device Descriptor. 0x07 Device Release (High) High byte of Device Release Number, must be Binary Coded Decimal. 0x08 ~ 0x19 Filling 0x1A Port Number 0x1B ~ 0x1E Filling 0x1F Check Sum All 0x00. Number of Downstream Ports, bNbrPorts field of Hub Descriptor. All 0x00. The 8-bit sum of all value from 0x00 to 0x1E. The first two bytes are the check code from the existence of EEPROM, their value must be 0x1A40. Any other value would cause the EEPROM loading mechanism of FE1.1s to conclude that the contents of this EEPROM is unusable, and use the default value instead. The last byte, 0x1F, is a checksum made up of the sum of all value from 0x00 to 0x1E. The number must match to render the contents of the EEPROM usable. Otherwise, the loading mechanism of FE1.1s would discard the value from EEPROM and use default value instead. April 21, 2021 Subject to Change Without Notice 15 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS Parameter Symbol Min. Max. Unit Storage Temperature TS -55 +150 °C Power Supply Voltage VDD5 VD33 -0.5 -0.5 +6.0 +4.0 V -2000 +2000 V ESD Machine Mode -200 +200 V ESD Charged Device Mode -500 +500 V Latch Up -200 +200 mA ESD Human Body Mode Recommended Operating Ranges Parameter Symbol Operating Temperature TA Operating Voltage VDD5 VD33 LOW level voltage of digital input VIL HIGH level voltage of digital input Min. Typ. Max. 70 °C 5.5 3.6 V -0.3 0.8 V VIH 2.0 5.5 V Threshold voltage of digital input VTH 1.45 1.58 1.74 V Low-to-High level of Schmitt-trigger input VT+ 1.44 1.5 1.56 V High-to-Low level of Schmitt-trigger input VT- 0.89 0.94 0.99 V LOW level voltage of digital output VOL 0.4 V HIGH level voltage of digital output VOH XIN input capacitance Cin Internal Pull-Up Resistor Range RPU April 21, 2021 0 Unit 4.5 3.0 5.0 3.3 2.4 V 32 39 Subject to Change Without Notice 65 ρF 116 KΩ 16 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E EXTENDED OPERATING RANGES Product with order code of BQFN24BT, BQFP48BT and BQFN24BV is Final Tested (FT) at Room Temperature, 85°C, and -40°C. Parameter Operating temperature April 21, 2021 Symbol TA Subject to Change Without Notice Min. Typ. Max. -40 25 85 Unit °C 17 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E POWER CONSUMPTION ABSOLUTE MAXIMUM RATINGS Symbol Condition Active Host Typical Unit Devices I_suspend Suspend 800 μA I_suspend_cm Suspend in Charging Mode 1300 μA High-Speed 4 x High-Speed 84 mA High-Speed 4 x Full-Speed 41 mA Full-Speed 4 x Full-Speed 28 mA High-Speed 3 x High-Speed 73 mA High-Speed 3 x Full-Speed 41 mA Full-Speed 3 x Full-Speed 28 mA High-Speed 2 x High-Speed 62 mA High-Speed 2 x Full-Speed 41 mA Full-Speed 2 x Full-Speed 28 mA High-Speed 1 x High-Speed 51 mA High-Speed 1 x Full-Speed 41 mA Full-Speed 1 x Full-Speed 28 mA High-Speed None 40 mA Full-Speed None 28 mA Icc 4 3 2 1 No Active Note: The power consumption is measured when the bus is in IDLE state – there is no activities other than the Start-Of-Frame (SOF) and INTERRUPT-IN packets for the hub itself on the bus. The peak power consumption varies depending upon the system configuration, type of operations, and over-all bus utilization. April 21, 2021 Subject to Change Without Notice 18 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE I 28-pin SSOP (Body Size: 10x4 mm, Pitch: 0.64mm) April 21, 2021 Subject to Change Without Notice 19 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE II 24-pin WQFN (II) (Body Size: 4x4 mm, Pitch: 0.5mm, Exposed Pad: 2.7x2.7mm) April 21, 2021 Subject to Change Without Notice 20 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE III 24-pin WQFN (III) (Body Size: 4x4 mm, Pitch: 0.5mm, Exposed Pad: 2.5x2.5mm) April 21, 2021 Subject to Change Without Notice 21 USB 2.0 4-Port Hub Data Sheet Rev. B12.6E PACKAGE IV 48-pin LQFP (Body Size: 7x7 mm) Terminus Technology Inc. 5F., No. 9, Ln. 130, Sec. 3, Minsheng E. Rd. Songshan District, Taipei City 105 TAIWAN, R.O.C. www.terminus-tech.com April 21, 2021 Subject to Change Without Notice 22
FE1.1S-BQFN24B 价格&库存
很抱歉,暂时无法提供与“FE1.1S-BQFN24B”相匹配的价格&库存,您可以联系我们找货
FE1.1S-BQFN24B
  • 1+5.51430
  • 10+4.35600
  • 600+2.77200
  • 1200+2.74428
  • 3000+2.68939
库存:2227
