TMI6050-18
TMI6050-18
    TMI(拓尔微)
    SOT23-5
    1.8V 600MA 5.5V
TMI6050-18 数据手册
TMI6050 TMI6050B 600mA, High PSRR, Fast Response LDO Regulators FEATURES GENERAL DESCRIPTION  2.5V to 5.5V Input Voltage Range  Up to 600mA output current (Typical) The TMI6050 is a 600mA, low-dropout (LDO) linear regulator with fast transient response and high PSRR. It offers high output accuracy, low dropout voltage and low quiescent current as well as fast start-up time. This regulator is based on a CMOS process. The TMI6050 is designed to work with low-ESR ceramic capacitors, reducing the amount of the PCB area necessary for power applications. Only a 1μF ceramic output capacitor can make the device stable over the whole load current range current (0mA to 600mA). The output of TMI6050 is adjustable, and the output can be set by an external resistor divider. When the FB pin is connected to an external resistor divider, its output can be adjusted from 0.8V to 5V. Other key features include over-current protection and thermal shutdown. The TMI6050 is packaged in SOT23-5 packages. with VIN-VOUT ≤ 1.8V@TA = 25°C  600mV @600mA Dropout Voltage  Excellent Transient Response  Stable with 1μF Ceramic Output Capacitor  60dB PSRR at 1kHz  Low 75μA Quiescent Current  Low Shutdown Current:
