B5817W THRU B5819W
Reverse Voltage 20-40 Volts
Forward Current - 1.0 Ampere
SCHOTTKY DIODES
Features
SOD-123
Fast switching speed
Surface mount package ideally suited
for automatic insertion
For general purpose switching applications High
0.028(0.70)
0.071(1.80)
0.018(0.45)
0.055(1.40)
0.008(0.20)max.
Cathode bar
0.110(2.80)
0.098(2.50)
conductance
0.154 (3.90)
Absolute Maximum Ratings at 25 °C
0.014 (0.35)
B5817W
B5818W
B5819W
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
14
21
28
V
Average rectified output current
I0
Continuous Forward Current
1
A
IFRM
1.5
A
I FSM
25
A
PD
500
mW
RθJA
160
°C /W
Operating Temperature Range
Tj
-55 ~ +125
°C
Storage Temperature Range
Tstg
-55 ~ +125
°C
Non-reptitive Peak Forward Surge Current
at 8.3ms
Power Dissipation
Typical Thermal Resistance
(1)
(1)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
Characteristics at Ta= 25 °C
Parameter
Reverse BreakdownVoltage at IR=1mA
Symbols
B5817W
V (BR)R
0.45
0.55
0.60
0.75
0.875
0.90
at 1A
Maximum Forward Voltage
Peak Reverse Current
VF
at 3A
at VR=20V Tj=25°C
Tj=100°C
Cj
Non-Repetitive peak reverse voltage
VRM
B5818W
B5819W
40
1.0
IR
Typical Junction Capacitance
http://www.microdiode.com
0.0019 (0.05)
0.0087 (0.22)
9°
0.026 (0.65)
Dimensions in inches and (millimeters)
Symbols
Parameter
0.018 (0.45)
0.006 (0.15)
0.008 (0.2 )
Case: JEDEC SOD-123 molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.00056 ounce, 0.016grams
Marking: B5817W:SJ, B5818W:SK, B5819W:SL
0° to
0.049 (1.25)
Mechanical Data
0.037(0.95)
0.138 (3.50)
Units
V
V
mA
10.0
pF
110
Rev:2025A4
40
V
Page :1
B5817W THRU B5819W
Typical Characterisitics
Forward
10
B5819W
Characteristics
Reverse
10
Pulsed
(mA)
a
a
T
=2
5℃
T
REVERSE CURRENT IR
=1
00
(A)
IF
FORWARD CURRENT
1
0.1
0.0
Characteristics
Pulsed
Ta=100℃
1
0.1
Ta=75℃
0.01
Ta=25℃
1E-3
0.4
0.8
1.2
FORWARD VOLTAGE
1.6
VF
2.0
1
(V)
10
REVERSE VOLTAGE
40
VR
(V)
Power Derating Curve
Capacitance Characteristics
600
375
(mW)
f=1MHz
PD
300
225
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
150
75
400
300
200
100
8
12
REVERSE VOLTAGE
16
VR
(V)
50
75
AMBIENT TEMPERATURE
100
Ta
125
The curve above is for reference only.
Rev:2025A4
Page :2
B5817W THRU B5819W
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-123
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
SOD-123
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
3.2
0.126
D
2.0
0.079
E
4.4
0.173
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“B5818W”相匹配的价格&库存,您可以联系我们找货
