BAV19W THRU BAV21W
Reverse Voltage 120-250 Volts
Forward Current - 0.2Ampere
FAST SWITHING DIODES
Features
SOD-123
for automatic insertion
For general purpose switching applications High
0.028(0.70)
0.071(1.80)
0.018(0.45)
0.055(1.40)
0.008(0.20)max.
Cathode bar
Fast switching speed
Surface mount package ideally suited
0.110(2.80)
0.098(2.50)
conductance
0.154 (3.90)
Absolute Maximum Ratings at 25 °C
PARAMETER
SYMBOLS
Peak repetitive peak reverse voltage
Working peak reverse voltage
DC Blocking voltage
0.006 (0.15)
0.026 (0.65)
0.014 (0.35)
0.0019 (0.05)
0.0087 (0.22)
9°
0.018 (0.45)
0.008 (0.2 )
Case: JEDEC SOD-123 molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.00056 ounce, 0.016 grams
Marking:BAV19W:A8, BAV20W:T2, BAV21W:T3
0° to
0.049 (1.25)
Mechanical Data
0.037(0.95)
0.138 (3.50)
Dimensions in inches and (millimeters)
BAV19W
BAV20W
BAV21W
120
200
250
71
106
141
UNITS
VRRM
VRWM
V
VR
RMS Reverse voltage
VR(RMS)
V
Forward continuous current
IFM
250
mA
Average rectified output current
IO
200
mA
Peak forward surge current @=1s
@=1ms
@=1us
Repetitive peak forward current
IFRM
1
3
9
625
IFSM
A
mA
Pd
500
mW
Thermal resistance junction to ambient
RΘJA
500
K/W
Storage temperature
TSTG
-55 to +150
C
Non-Repetitive peak reverse voltage
VRM
Power dissipation
120
250
200
V
Characteristics at Ta= 25 °C
PARAMETER
Max.
Unit
Conditions
VF1
1.0
V
IF=0.1A
VF2
1.25
V
IF=0.2A
0.1
uA
VR=120V
0.1
uA
VR=200V
0.1
uA
VR=250V
SYMBOLS
Min.
Typ.
Forward voltage
BAV19W
Reverse current
BAV20W
IR
BAV21W
Capacitance between terminals
CT
5
pF
VR=0V,f=1.0MHz
Reverse recovery time
trr
50
ns
Irr=0.1XIR,RL=100
IF=IR=10mA
http://www.microdiode.com
Rev:2025A4
Page :1
BAV19W THRU BAV21W
Typical Characterisitics
Forward
Characteristics
Reverse
1000
Characteristics
Pulsed
Pulsed
100
Ta=100℃
(nA)
100
REVERSE CURRENT IR
30
T=
a 2
5℃
T=
a 1
00
FORWARD CURRENT
IF
(mA)
400
10
10
Ta=25℃
1
3
1
0.2
0.4
0.6
0.8
FORWARD VOLTAGE
1.0
VF
1.2
0.1
1.4
60
REVERSE VOLTAGE
80
VR
100
120
125
150
(V)
Power Derating Curve
Capacitance Characteristics
1.4
(V)
600
Ta=25℃
500
PD
(mW)
6.0
4.5
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
3.0
1.5
0.0
400
300
200
100
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
100
Ta
The curve above is for reference only.
Rev:2025A4
Page :2
BAV19W THRU BAV21W
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-123
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
2.1
4.0
1.60
1.55
178.00
50.0
13.00
1.75
3.50
4.00
4.00
2.00
0.25
8.15
10.5
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
SOD-123
7"
3,000
4.0
45,000
190*190*190
178
400*400*220
180,000
APPROX.
GROSS WEIGHT
(kg)
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
3.2
0.126
D
2.0
0.079
E
4.4
0.173
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A4
Page :3
很抱歉,暂时无法提供与“BAV19W”相匹配的价格&库存,您可以联系我们找货
