BAV19WS THRU BAV21WS
Reverse Voltage 120-250 Volts Forward Current - 250mAmpere
FAST SWITHING DIODES
Features
SOD-323
For surface mounted applications
Cathode bar
Fast reverse recovery time
Ideal for automated placement
0.016(0.40)
0.057(1.45)
0.007(0.20)
0.043(1.10)
Lead free in comply with EU RoHS 2011/65/EU
directives
0.071(1.80)
0.063(1.40)
0.110 (2.80)
0.014 (0.35)
0.0019 (0.05)
0.024 (0.60)
0.0079 (0.20)
0.006 (0.15)
Dimensions in inches and (millimeters)
Absolute Maximum Ratings at 25 °C
SYMBOLS
9°
0.008 (0.2 )
0.016 (0.45)
0° to
0.043 (1.10)
Case: JEDEC SOD-323 molded plastic body
Terminals: Plated leads solderable per MIL-STD-750,
Method 2026
Polarity: Polarity symbols marked on case
Weight : 0.00019 ounce, 0.0548 grams
Marking:BAV19WS:A8, BAV20WS:T2, BAV21WS:T3
0.032 (0.80)
0.098 (2.50)
Mechanical Data
PARAMETER
0.008(0.20)max.
Glass Passivated Chip Junction
BAV19WS
BAV20WS
BAV21WS
UNITS
VRRM
Maximum Repetitive Peak Reverse Voltage
120
Maximum RMS voltage
VR(RMS)
100
200
250
150
200
V
V
Continuous Forward Current
IO
250
mA
Repetitive Peak Forward Current
IFM
625
mA
IFSM
1
3
9
A
Non-reptitive Peak forward surge current @=1s
@=1ms
@=1us
Total Power dissipation
Ptot
500
mW
Operating junction temperature
Tj
-55 to +150
C
TSTG
-55 to +150
C
Storage temperature
Characteristics at Ta= 25 °C
Parameter
Test conditions
Symbol
IR
Reverse current
VR=120V
BAV19WS
VR=200V
BAV20WS
VR=250V
BAV21WS
Min
Typ
Ta =25 °C
0.1
Ta =150 °C
100
Ta =25 °C
0.1
Ta =150 °C
100
Ta =25 °C
0.1
Ta =150 °C
100
IF 100mA
VF
Forward voltage
IF 200mA
Total capacitance
1
1.25
VR 0V,f 1MHz
Ctot
Reverse recovery time
http://www.microdiode.com
trr
Max
IF=0.5A IR =1A, Irr=0.25A , RL=100Ω
Rev:2025A3
Unit
uA
uA
V
5
pF
50
ns
Page :1
Typical Characterisitics
Forward
Characteristics
Reverse
1000
400
100
(nA)
REVERSE CURRENT IR
30
Ta
=2
5℃
Ta
=1
00
FORWARD CURRENT
Ta=100℃
100
IF
(mA)
300
Characteristics
10
30
Ta=25℃
10
3
1
3
0.3
1
0.2
0.4
0.6
0.8
FORWARD VOLTAGE
1.0
VF
1.2
0.1
1.4
60
REVERSE VOLTAGE
80
VR
100
120
125
150
(V)
Power Derating Curve
Capacitance Characteristics
7.5
(V)
300
250
PD
(mW)
6.0
4.5
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
Ta=25℃
f=1MHz
3.0
1.5
0.0
200
150
100
50
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
100
Ta
The curve above is for reference only.
Rev:2025A3
Page :2
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SOD-323
E
F
B
A
W
P
D2
T
D1
C
W1
D
1.46
2.90
1.25
1.50
330.00
50.00
178.00
54.40
13.00
1.75
3.50
4.00
4.00
2.00
0.06
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SOD-323
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
3,000
4.0
45,000
190*190*190
178
CARTON
SIZE
(m/m)
400*400*220
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
18 0,000
9.0
Suggested Pad Layout
Symbol
A
Unit (mm)
Unit (inch)
0.047
B
1.2
1.2
C
2.6
0.141
D
1.4
0.055
E
3.8
0.149
0.047
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A3
Page :3
很抱歉,暂时无法提供与“BAV20WS”相匹配的价格&库存,您可以联系我们找货
