TP2261-TR
TP2261-TR
    3PEAK(思瑞浦)
    SOT23-5
    36V、3.5MHz、15V/μs运算放大器
TP2261-TR 数据手册
TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Features Description ⚫ Supply Voltage: 3V to 36V The TP226X series amplifiers are newest high supply voltage ⚫ Low Supply Current: Maximum 1000μA per channel amplifiers with low offset, low power and stable high frequency ⚫ Differential Input Voltage Range to Supply Rail, can Work response. They incorporate 3PEAK’s proprietary and patented design techniques to achieve very good AC performance with as Comparator 3.5MHz bandwidth, 15V/μs slew rate and low distortion while ⚫ Input Rail to –VS, Rail to Rail Output ⚫ Fast Response: 3.5 MHz Bandwidth, 15V/μs Slew Rate, drawing only typical 700μA of quiescent current per amplifier. The input common-mode voltage range extends to V–, and the 100ns Overload Recovery ⚫ outputs swing rail-to-rail. The TP226X family can be used as Low Offset Voltage: plug-in replacements for many commercially available op-amps ±2mV Maximum at 25°C, to reduce power and improve input/output range and ±2.5mV Maximum at -40°C to 85°C performance. ±3mV Maximum at -40°C to 125°C The combination of features makes the TP226X ideal choices ⚫ Very Low THD+N: 0.0005% at Gain = 1, 1kHz ⚫ Excellent EMIRR: 60dB at 900MHz ⚫ 2KV HBM, 1KV CDM, 150mA Latch Up ⚫ –40°C to 125°C Operation Temperature Range for industrial control, motor control and portable audio amplification, sound ports, and other consumer audio. Applications ⚫ Sensor Interface ⚫ Motor Control ⚫ Industrial Control ⚫ Audio Pin Configuration Out 1 ﹣Vs 2 TP2261 TP2262 TP2264 5-Pin SOT23 8-Pin SOIC/TSSOP/MSOP 14-Pin SOIC/TSSOP -T Suffixes -S, -TS and -V Suffixes -S and -T Suffixes 8 ﹢Vs Out A 1 7 Out B ﹣In A 2 ﹢In A 3 ﹢Vs 4 TP2261 ﹢In B 5 8-Pin SOIC (-S Suffix) ﹣In B 6 Out B 7 3 + In ﹢Vs 5 4 Out A 1 ﹣In A 2 ﹢In A - In ﹣Vs A 3 6 B 4 5 ﹣In B ﹢In B B TP2262 8-Pin DFN 3*3, 2*2 (-F2 Suffix) NC 1 8 NC ﹣In 2 7 ﹢Vs Out A 1 8 ﹢In 3 6 Out ﹣In A 2 7 Out B ﹣Vs 4 5 NC ﹢In A 3 6 ﹣In B ﹣Vs 4 5 ﹢In B www.3peak.com A 1 / 18 14 Out D 13 ﹣In D 12 ﹢In D 11 ﹣Vs 10 ﹢In C 9 ﹣In C 8 Out C D C ﹢Vs The thermal pad of DFN package is recommended to be left float or connected to -Vs Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Table of Contents Features ........................................................................................................................................................................... 1 Applications ..................................................................................................................................................................... 1 Description....................................................................................................................................................................... 1 Pin Configuration ............................................................................................................................................................ 1 Table of Contents ............................................................................................................................................................ 2 Revision History .............................................................................................................................................................. 2 Order Information ............................................................................................................................................................ 3 Absolute Maximum Ratings Note 1 ................................................................................................................................... 4 ESD Rating ....................................................................................................................................................................... 4 Thermal Information ....................................................................................................................................................... 4 Electrical Characteristics ............................................................................................................................................... 5 Typical Performance Characteristics ............................................................................................................................ 7 Tape and Reel Information ........................................................................................................................................... 12 Package Outline Dimensions ....................................................................................................................................... 13 SOT23-5..................................................................................................................................................................................... 13 SOIC-8 ....................................................................................................................................................................................... 13 TSSOP-8 .................................................................................................................................................................................... 14 MSOP-8 ..................................................................................................................................................................................... 14 DFN8 2*2 ................................................................................................................................................................................... 15 DFN8 3*3 ................................................................................................................................................................................... 16 SOIC-14 ..................................................................................................................................................................................... 17 TSSOP-14 .................................................................................................................................................................................. 17 IMPORTANT NOTICE AND DISCLAIMER .................................................................................................................... 18 Revision History Date Revision Notes 2017/12/21 Rev.Pre Pre-Release Version 2018/9/9 Rev.0 Initial Version 2018/12/21 Rev.0.01 Add New Part Number: TP2262L1-TSR, TP2261L1-TR. Update mark information: Add “TP” before “226” on 8-Pin SOIC and 14-Pin SOIC Package. 2019/2/15 Rev.0.02 Add New Part Number: TP2262-F2R. Update Package Outline Dimensions. 2019/3/30 Rev.0.03 Update date code information. Update Package Outline Dimensions. 2019/5/30 Rev.0.04 Add Figure 29: Crosstalk vs. Frequency 2020/9/24 Rev.A Update the description of Absolute Maximum Ratings: “Maximum Junction Temperature” -> “Maximum Operating Junction Temperature” Add Part Number: TP2262-FR; Remove Part Number: TP2261L1-TR 2021/4/10 www.3peak.com Rev.A.1 Remove Part Number: TP2262L1-SR, TP2262L1-TSR, TP2264L1-TSR 2 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Order Information Order Number Operating Temperature Range Package Marking Information TP2261-SR -40 to 125°C 8-Pin SOIC TP2261-TR -40 to 125°C 5-Pin SOT23 TP2262-SR -40 to 125°C 8-Pin SOIC TP2262-FR -40 to 125°C 8-Pin DFN 2*2 TP2262-F2R -40 to 125°C 8-Pin DFN 3*3 TP2262-TSR -40 to 125°C 8-Pin TSSOP TP2262-VR -40 to 125°C 8-Pin MSOP TP2264-SR -40 to 125°C 14-Pin SOIC TP2264-TR -40 to 125°C 14-Pin TSSOP 2261 XXXX Note 1 226XX Note 1 TP2262 XXXX Note 1 226 XXXX Note 1 2262 XXXX Note 1 2262 XXXX Note 1 2262 XXXX Note 1 TP2264 XXXX Note 1 2264 XXXX Note 1 MSL Transport Media, Quantity 3 Tape and Reel, 4000 3 Tape and Reel, 3000 3 Tape and Reel, 4000 3 Tape and Reel, 3000 3 Tape and Reel, 4000 3 Tape and Reel, 3000 3 Tape and Reel, 3000 3 Tape and Reel, 2500 3 Tape and Reel, 3000 Note 1: “XX” or “XXXX” identify the manufacture site and date code information, “L” means MSL1 product. www.3peak.com 3 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Absolute Maximum Ratings Note 1 Parameters Rating Supply Voltage, (+VS)– (-VS) 40 V Input Voltage (-VS) – 0.3 to (+VS) + 0.3 Differential Input Voltage Input Current: +IN, –IN (+VS) - (-VS) ±10mA Note 2 Output Short-Circuit Duration Note 3 Infinite Maximum Junction Temperature 150°C Operating Temperature Range –40 to 125°C Storage Temperature Range –65 to 150°C Lead Temperature (Soldering, 10 sec) 260°C Note 1: Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. Note 2: The inputs are protected by ESD protection diodes to each power supply. If the input extends more than 300mV beyond the power supply, the input current should be limited to less than 10mA. Note 3: A heat sink may be required to keep the junction temperature below the absolute maximum. This depends on the power supply voltage and how many amplifiers are shorted. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. ESD Rating Symbol Parameter Condition Minimum Level Unit HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001 2 kV CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002 1 kV Thermal Information Package Type θJA θJC Unit 5-Pin SOT23 250 81 °C/W 8-Pin SOIC 158 43 °C/W 8-Pin TSSOP 191 44 °C/W 8-Pin DFN 3*3 120 50 °C/W 8-Pin MSOP 210 45 °C/W 14-Pin SOIC 120 36 °C/W 14-Pin TSSOP 180 35 °C/W www.3peak.com 4 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Electrical Characteristics All test condition is VS = 30V, TA = 25°C, RL = 10kΩ to VS/2, unless otherwise noted. Symbol Parameter TA Conditions Min Typ Max Unit 36 V 1500 μA 1700 μA 1300 μA 1500 μA 1000 μA 1200 uA 850 μA 1000 μA Power Supply VS Supply Voltage Range 3 IQ Quiescent Current per Amplifier VS = 30V, TP2261 1000 -40°C to 125°C VS = 5V, TP2261 850 -40°C to 125°C VS = 30V, TP2262/TP2264 700 -40°C to 125°C VS = 5V, TP2262/TP2264 600 -40°C to 125°C PSRR Power Supply Rejection Ratio VS = 3V to 36V 95 -40°C to 125°C 120 dB 90 dB Input Characteristics VOS Input Offset Voltage VS = 30V, VCM = 0V to 28V -2 2.5 mV -40°C to 125°C -3 3 mV -3 3 mV -4 4 mV 2 mV 3 mV VS = 5V, VCM = 2.5V -2 -40°C to 125°C IB Input Bias Current IOS Input Offset Current IIN Different Input Current 2 μV/°C 25 pA -40°C to 85°C 80 pA -40°C to 125°C 1000 pA 25 pA 10 nA 100 nA Differential Mode 5 pF Common Mode 2.5 pF 120 dB -40°C to 125°C VS = 36V, VID = 36V Av Input Capacitance Open-loop Voltage Gain 105 -40°C to 125°C VCMR Common-mode Input 0.1 -3 -40°C to 125°C CIN Voltage 100 dB (V-) (V+) Range CMRR Common Mode Rejection Ratio – V 1.5 VCM = 0V to 28V 105 -40°C to 125°C www.3peak.com mV -2.5 -40°C to 125°C Input Offset Voltage Drift 2 -40°C to 85°C VS = 30V, VCM = 28.5V VOS TC 0.1 5 / 18 100 130 dB dB Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Output Characteristics VOH Output Swing from Positive Rail RLOAD = 10kΩ to VS/2 200 -40°C to 125°C RLOAD = 2kΩ to VS/2 1.1 -40°C to 125°C VOL Output Swing from Negative Rail RLOAD = 10kΩ to VS/2 200 -40°C to 125°C RLOAD = 2kΩ to VS/2 0.8 -40°C to 125°C ISC Output Short-Circuit Current 25 32 300 mV 450 mV 1.4 V 2 V 300 mV 450 mV 1 V 1.6 V mA -40°C to 85°C 20 mA -40°C to 125°C 15 mA AC Specifications GBW Gain-Bandwidth Product SR Slew Rate G = 1, 10V step Open Loop tOR Overload Recovery tS Settling Time, 0.1% 9 G = -1, 10V step Settling Time, 0.01% 3.5 MHz 15 V/μs 15 V/μs -40°C to 85°C 7 V/μs -40°C to 125°C 6 V/μs 100 ns 0.8 μs 1 μs PM Phase Margin VS = 36V, RL=10K, CL=100pF 60 ° GM Gain Margin VS = 36V, RL=10K, CL=100pF 15 dB Noise Performance EN Input Voltage Noise f = 0.1Hz to 10Hz 1.7 μVRMS eN Input Voltage Noise Density f = 1kHz 30 nV/ √ Hz iN Input Current Noise f = 1kHz 2 fA/√Hz THD+N Total Harmonic Distortion and Noise f = 1kHz, G =1, RL = 10kΩ, VOUT 0.0005 % = 6VRMS www.3peak.com 6 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Typical Performance Characteristics 2 1.8 1.8 1.6 1.6 1.4 Quiesent Current(mA) Quiesent Current(mA) VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. 1.4 1.2 1 0.8 0.6 1.2 1 0.8 0.6 0.4 0.4 0.2 0.2 0 0 0 10 20 Supply Voltage(V) 30 40 -50 Figure 1. Quiescent Current vs. Supply Voltage, 2ch TP2262 50 Temperature(℃) 100 150 3 Vs = ±18V 2 input Offset Voltage(mV) 2 1 0 -1 -2 Vs = ±2.5V 1 0 -1 -2 -3 -3 -20 -10 0 10 20 -3 Common mode-Voltage(V) -2 -1 0 1 2 Common mode-Voltage(V) Figure 3. Offset Voltage vs. Common Mode Voltage Figure 4. Offset Voltage vs. Common Mode Voltage 3 3 Vs = 5V, Vcm = 2.5V Vs = 36V, Vcm = 18V 2 input Offset Voltage(mV) 2 input Offset Voltage(mV) 0 Figure 2. Quiescent Current vs. Temperature, 2ch TP2262 3 input Offset Voltage(mV) VS=±18V VS=±2.5V 1 0 -1 -2 1 0 -1 -2 -3 -3 -50 0 50 Temperaure(℃) 100 150 Figure 5. VOS vs. Temperature www.3peak.com -50 0 50 Temperaure(℃) 100 150 Figure 6. VOS vs. Temperature 7 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. 1400 Vs = 36V Blue: Vin+ = 36V, Vin- = 0V Red: Vin+ = 0V, Vin- = 36V 6000 5000 1200 Input Bias Current(pA) Input Current in Large Vdm(pA) 7000 4000 3000 2000 IB+ 1000 IB- 800 IOS 600 400 200 1000 0 0 -50 0 50 Temperature(℃) 100 -200 150 -50 0 Figure 7. Input Current in Large Vdm vs. Temperature 50 Temperature(℃) 100 150 Figure 8. IB vs. Temperature 120 120 100 PSRR+ PSRR- 80 80 CMRR(dB) PSRR+(dB) 100 60 60 40 40 20 20 0 0 10 100 1K 10K 100K 1M 10 100 1K Frequency(Hz) Figure 9. PSRR vs. Frequency 100K 1M Figure 10. CMRR vs. Frequency 140 140 120 120 100 100 CMRR(dB) PSRR(dB) 10K Frequency(Hz) 80 60 80 60 40 40 20 20 0 0 -50 0 50 Temperature(℃) 100 150 Figure 11. PSRR vs. Temperature www.3peak.com -50 0 50 Temperature(℃) 100 150 Figure 12. CMRR vs. Temperature 8 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. 100.00 90.00 80.00 EMIRR: dB 70.00 60.00 50.00 40.00 30.00 20.00 10.00 0.00 50 500 Frequency: MHz 5000 Figure 13. EMIRR+- vs. Frequency Figure 14. Open Loop Gain and Phase vs. Frequency 50 40 AV=1 AV=-1 AV=11 AV=100 Close Loop Gain(dB) 30 20 10 0 -10 -20 -30 -40 1 10 100 1K 10K Frequency(kHz) VS =±1.5V, VIN=100mVPP, RL=10K, CL=100pF, G=1 Figure 15. Close Loop Gain and Phase vs. Frequency Figure 16. Waveform under 3V Supply Voltage 0 Maximum Peak Output Voltage(V) Maximum Peak Output Voltage(V) 16 14 12 10 8 6 4 2 0 0.01 0.1 1 10 Load Resistance(kΩ) -2 -4 -6 -8 -10 -12 -14 -16 0.01 100 0.1 1 10 Load Resistance(kΩ) 100 Figure 17. Maximum Peak Output Voltage vs. Load Figure 18. Maximum Peak Output Voltage vs. Load Resistance Resistance www.3peak.com 9 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. 16 0 -2 14 -40℃ 25℃ 85℃ 125℃ 10 8 6 4 -6 -8 -10 -12 Vs = ±15V -14 2 -16 0 0 5 10 15 20 25 Output Current(mA) 30 0 35 Figure 19. Positive Output Voltage vs. Output Current 3 0 2.5 -0.5 -40℃ 25℃ 85℃ 125℃ 2 1.5 1 10 20 Output Current(mA) 30 40 Figure 20. Negative Output Voltage vs. Output Current Output Voltage(V) Output Voltage(V) Vs = ±15V -40℃ 25℃ 85℃ 125℃ -4 Output Voltage(V) Output Voltage(V) 12 Vs = ±2.5V -40℃ 25℃ 85℃ 125℃ -1 -1.5 -2 -2.5 0.5 Vs = ±2.5V -3 0 0 5 10 Output Current(mA) 15 20 0 5 10 15 Output Current(mA) 20 25 Figure 21. Positive Output Voltage vs. Output Current Figure 22. Negative Output Voltage vs. Output Current Voltage: 1V/div, Time: 200ns/div Voltage: 1V/div, Time: 200ns/div VS =5V, VIN = 2V, RL=Open, G=3 VS =5V, VIN = 2V, RL=Open, G=3 Figure 23. Positive Overload Recovery Figure 24. Negative Overload Recovery www.3peak.com 10 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps VS = ±15V, VCM = 0V, RL = 10kΩ, unless otherwise specified. Voltage: 20mV/div, Time: 100ns/div Voltage: 2V/div, Time: 1μs/div VS =±15V, RL=2K, CL=100pF, G=1 VS =±15V, RL=2K, CL=100pF, G=1 Figure 25. 100mV Signal Step Response Figure 26. 10V Signal Step Response 0.1 200 RL=10K, Vout = 3.5VRms RL=10K, Vout = 6VRms 0.01 THD+N(%) Equivalent Input Noise Voltage(nV/√Hz) 250 150 100 0.001 50 0 0.0001 10 100 1K Frequency(Hz) 10K 100K 10 100 1K Frequency(Hz) 10K VS =±15V, VCM=0V VS =±15V, VCM=0V, G=1 Figure 27. Voltage Noise Spectral Density vs. Frequency Figure 28. THD+N vs. Frequency 100K 0 Crosstalk(dB) -20 VIN=17.9Vpp -40 VIN=9Vpp -60 VIN=0.5Vpp -80 -100 -120 -140 -160 10 100 1K Frequency(Hz) 10K 100K VS =±15V, VCM=0V Figure 29. Crosstalk vs. Frequency www.3peak.com 11 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Tape and Reel Information Order Number Package D1 W1 A0 B0 K0 P0 W0 Pin1 Quadrant TP2261-TR 5-Pin SOT23 180.0 13.1 3.2 3.2 1.4 4.0 8.0 Q3 TP2261-SR 8-Pin SOIC 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 TP2262-SR 8-Pin SOIC 330.0 17.6 6.4 5.4 2.1 8.0 12.0 Q1 TP2262-VR 8-Pin MSOP 330.0 17.6 5.2 3.3 1.5 8.0 12.0 Q1 TP2262-TSR 8-Pin TSSOP 330.0 17.6 6.8 3.3 1.2 8.0 12.0 Q1 TP2262-FR 8-Pin DFN2*2 180.0 13.1 2.3 2.3 1.1 4.0 8.0 Q1 TP2262-F2R 8-Pin DFN3*3 330.0 17.6 3.35 3.35 1.13 8.0 12.0 Q1 TP2264-SR 14-Pin SOIC 330.0 21.6 6.5 9.0 2.1 8.0 16.0 Q1 TP2264-TR 14-Pin TSSOP 330.0 17.6 6.8 5.4 1.2 8.0 12.0 Q1 www.3peak.com 12 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps Package Outline Dimensions SOT23-5 SOIC-8 www.3peak.com 13 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps TSSOP-8 MSOP-8 www.3peak.com 14 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps DFN8 2*2 www.3peak.com 15 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps DFN8 3*3 www.3peak.com 16 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps SOIC-14 TSSOP-14 www.3peak.com 17 / 18 Rev.A.1 TP2261/ TP2262/ TP2264 36V, 3.5MHz, 15V/μs Op Amps IMPORTANT NOTICE AND DISCLAIMER Copyright© 3PEAK 2012-2023. All rights reserved. Trademarks. Any of the 思瑞浦 or 3PEAK trade names, trademarks, graphic marks, and domain names contained in this document /material are the property of 3PEAK. You may NOT reproduce, modify, publish, transmit or distribute any Trademark without the prior written consent of 3PEAK. Performance Information. Performance tests or performance range contained in this document/material are either results of design simulation or actual tests conducted under designated testing environment. Any variation in testing environment or simulation environment, including but not limited to testing method, testing process or testing temperature, may affect actual performance of the product. Disclaimer. 3PEAK provides technical and reliability data (including data sheets), design resources (including reference designs), application or other design recommendations, networking tools, security information and other resources "As Is". 3PEAK makes no warranty as to the absence of defects, and makes no warranties of any kind, express or implied, including without limitation, implied warranties as to merchantability, fitness for a particular purpose or non-infringement of any third-party’s intellectual property rights. Unless otherwise specified in writing, products supplied by 3PEAK are not designed to be used in any life-threatening scenarios, including critical medical applications, automotive safety-critical systems, aviation, aerospace, or any situations where failure could result in bodily harm, loss of life, or significant property damage. 3PEAK disclaims all liability for any such unauthorized use. www.3peak.com 18 / 18 Rev.A.1
TP2261-TR 价格&库存
很抱歉,暂时无法提供与“TP2261-TR”相匹配的价格&库存,您可以联系我们找货
TP2261-TR
  • 5+2.90520
  • 50+2.27880
  • 150+1.95480
  • 500+1.70640
  • 3000+1.51200
库存:5650
TP2261-TR
  • 1+0.91360
  • 10+0.67570
  • 100+0.57930
  • 1000+0.48270
库存:9000
TP2261-TR
    • 1+0.64240
    • 200+0.44220
    • 1500+0.40260
    • 3000+0.37620
    库存:4275
    TP2261-TR
    • 3000+2.464583000+0.30538
    库存:10725
    TP2261-TR
      • 558+0.41481
      库存:558
      TP2261-TR
      • 1+5.646661+0.69966
      • 10+3.9814810+0.49333
      • 25+3.5694625+0.44228
      • 100+3.11591100+0.38608
      • 250+2.89984250+0.35931
      • 500+2.76955500+0.34317
      • 1000+2.662491000+0.32990
      库存:10725
      TP2261-TR
        • 3000+0.62150
        库存:9000
        TP2261-TR
        • 1+2.10688
        • 30+2.03423
        • 100+1.88893
        • 500+1.74363
        • 1000+1.67098
        库存:50
