TPT487
3.0V to 5.5V RS-485 Transceivers
Description
Features
The TPT487 are IEC61000 ESD protected, 3.0V to 5.5V
Exceeds Requirements of EIA-485 Standard
Hot Plug Circuitry - Tx and Rx Outputs Remain Three-
powered transceivers that meet the RS-485 and RS-422
standards for balanced communication.
State During Power-up/Power-down
Transmitters in this family deliver exceptional differential output
Data Rate: 500 Kbps
Up to 256 Nodes on a Bus (1/8 unit load) at 500kbps
Full Fail-safe Receiver (Open, Short, Terminated)
Wide Supply Voltage 3V to 5.5V
on the network without using repeaters. Receiver (Rx) inputs
Bus-Pin Protection:
feature a “Full Fail-Safe” design, which ensures a logic high Rx
voltages into the RS-485 required 54Ω load. These 500kbps
devices have very low bus currents so they present a true “1/8
unit load” to the RS-485 bus. This allows up to 256 transceivers
±18 kV HBM ESD
output if Rx inputs are floating, shorted, or on a terminated but
±15 kV IEC61000-4-2 Contact Discharge
undriven bus.
±18 kV IEC61000-4-2 Air Discharge
TPT487 is designed for half-duplex RS485, and support SOP8,
–40°C to 125°C Operation Temperature Range
MSOP8 and DFN3X3-8L package, which is characterized from
–40°C to 125°C.
Applications
Motor Drives
Industrial Control
Communication Infrastructure
Device Table
Part
Duplex
Enable
Data Rate
Nodes
TPT487
Half
Yes
500Kbps
256
Simplified Schematic
TPT487 Block Diagram
TPT481, TPT487
www.3peakic.com.cn
TPT482, TPT488
1 / 12
TPT487 Network
TPT482A, TPT488A
Rev. A
TPT487
Revision History
Date
Revision
Notes
2019/1/14
Rev. Pre 0.1
Definition Version 0
2019/6/15
Rev. Pre 0.2
Update package information
2019/9/17
Rev. 0
Release version
2020/3/20
Rev. A
Update absolute rating
www.3peakic.com.cn
2 / 12
Rev. A
TPT487
Pin Configuration and Functions
Pin No.
Pin Name
I/O
Description
1
R
Digital output
Receiver Output.
2
/RE
Digital input
Receiver Output Enable.
3
DE
Digital input
Driver Output Enable.
4
D
Digital input
Driver Input.
5
GND
Ground
Ground.
6
A
Bus input/output
Noninverting Receiver Input A and Noninverting Driver Output A.
7
B
Bus input/output
Inverting Receiver Input B and Inverted Driver Output B.
8
VCC
Power
Power Supply.
Order Information
Model
Name
Order Number
TPT487
TPT487L1-SO1R
8-Pin SOP
MSL1
Tape and Reel
4,000
T487
TPT487
TPT487-VS1R
8-Pin MSOP
MSL3
Tape and Reel
3,000
T487
TPT487
TPT487L1-DF6R
8-Pin DFN3X3
MSL1
Tape and Reel
4,000
T487
www.3peakic.com.cn
MSL
Level
Package
3 / 12
Transport Media,
Quantity
Marking
Information
Rev. A
TPT487
Functional Table
Driver Function Table
Input
Enable
Outputs
Outputs
Description
D
DE
A
B
H
H
H
L
Actively drives bus High
L
H
L
H
Actively drives bus Low
X
L
Z
Z
Driver disabled
Z
Z
Driver disabled by default
H
L
Actively drives bus High by default
Input
Input
Output
A-B
/RE
R
>-50mV
L
H
Receive valid bus High
-200mV
很抱歉,暂时无法提供与“TPT487L1-SO1R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+7.601581+0.94189
- 10+5.4547510+0.67588
- 25+4.9159025+0.60911
- 100+4.31890100+0.53514
- 250+4.03369250+0.49980
- 500+3.86184500+0.47851
- 1000+3.720471000+0.46099
- 国内价格
- 5+5.30280
- 50+4.11480
- 150+3.51000
- 500+3.07800
- 2500+2.72160
- 4000+2.54880
- 国内价格
- 1+0.65250
- 30+0.63000
- 100+0.58500
- 500+0.54000
- 1000+0.51750
- 国内价格
- 5+5.48640
- 50+4.23360
- 150+3.69360
- 500+3.02400
