Transient Voltage Suppressors
DO-214AB/SMC Package
1.5SMC Series
FEATURE
Peak Power Dissipation: 1500W
Fast response time. IR less than 1μA above 12V. Duty cycle: 0.01%
Excellent clamping capability, Low inductance
Glass passivated junction
High Temperature soldering: 260°C, 10 seconds
Flammability Classification 94V-O.
UL/cUL safety approved: certification No: E223045
MAXIMUM RATINGS AND CHARACTERISTICS
Parameter
Symbol
Value
Unit
PPPM
Minimum 1500
Watts
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75°C,Lead length .375” (9.5mm). (Fig. 5)
PM(AV)
6.5
Watts
Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load
IFSM
200
Amps
TJ , TSTG
-65 to +150
°C
Peak Pulse Power Dissipation on 10/1000μs waveform. (Note 1,Fig. 1)
Peak Pulse Current on 10/1000μs waveform. (Note 1,Fig. 3)
Operating junction and Storage Temperature Range.
Ratings at 25℃ ambient temperature unless otherwise specified.
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°Cper Fig. 2 .
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minute maximum.
DIMENSIONS
SMC/DO-214AB (mm)
Item
Min.
Max.
L
6.60
7.11
D
5.59
6.22
D1
2.90
3.20
T
7.75
8.13
T1
0.76
1.52
d
0.203
s
2.06
2.62
t
0.152
0.305
SPECIFICATIONS
Part Number
Device
Marking
Code
Reverse
StandOff
Voltage
Breakdown
Voltage
Min.@IT
Breakdown
Voltage
Max.@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Uni-Polar
Bi-Polar
Uni
Bi
VRWM (V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR (µA)
1.5SMC6.8A
1.5SMC6.8CA
6V8A
6V8C
5.8
6.45
7.14
10
10.5
144.8
1000
1.5SMC7.5A
1.5SMC7.5CA
7V5A
7V5C
6.4
7.13
7.88
10
11.3
134.5
500
1.5SMC8.2A
1.5SMC8.2CA
8V2A
8V2C
7.02
7.79
8.61
10
12.1
125.6
200
1.5SMC9.1A
1.5SMC9.1CA
9V1A
9V1C
7.78
8.65
9.50
1
13.4
113.4
50
1.5SMC10A
1.5SMC10CA
10A
10C
8.55
9.50
10.50
1
14.5
104.8
10
1.5SMC11A
1.5SMC11CA
11A
11C
9.40
10.50
11.60
1
15.6
97.4
5
1.5SMC12A
1.5SMC12CA
12A
12C
10.20
11.40
12.60
1
16.7
91.0
5
1.5SMC13A
1.5SMC13CA
13A
13C
11.10
12.40
13.70
1
18.2
83.5
1
1.5SMC15A
1.5SMC15CA
15A
15C
12.80
14.30
15.80
1
21.2
71.7
1
Rev. 7c
1.5SMC Series
SPECIFICATIONS(CONTINUED)
Part Number
Device
Marking
Code
Reverse
StandOff
Voltage
Breakdown
Voltage
Min.@IT
Breakdown
Voltage
Max.@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Uni-Polar
Bi-Polar
Uni
Bi
VRWM (V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR (µA)
1.5SMC16A
1.5SMC16CA
16A
16C
13.60
15.20
16.80
1
22.5
67.6
1
1.5SMC18A
1.5SMC18CA
18A
18C
15.30
17.10
18.90
1
25.2
60.3
1
1.5SMC20A
1.5SMC20CA
20A
20C
17.10
19.00
21.00
1
27.7
54.9
1
1.5SMC22A
1.5SMC22CA
22A
22C
18.80
20.90
23.10
1
30.6
49.7
1
1.5SMC24A
1.5SMC24CA
24A
24C
20.50
22.80
25.20
1
33.2
45.8
1
1.5SMC27A
1.5SMC27CA
27A
27C
23.10
25.70
28.40
1
37.5
40.5
1
1.5SMC30A
1.5SMC30CA
30A
30C
25.60
28.50
31.50
1
41.4
36.7
1
1.5SMC33A
1.5SMC33CA
33A
33C
28.20
31.40
34.70
1
45.7
33.3
1
1.5SMC36A
1.5SMC36CA
36A
36C
30.80
34.20
37.80
1
49.9
30.5
1
1.5SMC39A
1.5SMC39CA
39A
39C
33.30
37.10
41.00
1
53.9
28.2
1
1.5SMC43A
1.5SMC43CA
43A
43C
36.80
40.90
45.20
1
59.3
25.6
1
1.5SMC47A
1.5SMC47CA
47A
47C
40.20
44.70
49.40
1
64.8
23.5
1
1.5SMC51A
1.5SMC51CA
51A
51C
43.60
48.50
53.60
1
70.1
21.7
1
1.5SMC56A
1.5SMC56CA
56A
56C
47.80
53.20
58.80
1
77.0
19.7
1
1.5SMC62A
1.5SMC62CA
62A
62C
53.00
58.90
65.10
1
85.0
17.9
1
1.5SMC68A
1.5SMC68CA
68A
68C
58.10
64.60
71.40
1
92.0
16.5
1
1.5SMC75A
1.5SMC75CA
75A
75C
64.10
71.30
78.80
1
103.0
14.8
1
1.5SMC82A
1.5SMC82CA
82A
82C
70.10
77.90
86.10
1
113.0
13.5
1
1.5SMC91A
1.5SMC91CA
91A
91C
77.80
86.50
95.50
1
125.0
12.2
1
1.5SMC100A
1.5SMC100CA
68A
100C
85.50
95.00
105.00
1
137.0
11.1
1
1.5SMC110A
1.5SMC110CA
75A
110C
94.00
105.00
116.00
1
152.0
10.0
1
1.5SMC120A
1.5SMC120CA
120A
120C
102.00
114.00
126.00
1
165.0
9.2
1
1.5SMC130A
1.5SMC130CA
130A
130C
111.00
124.00
137.00
1
179.0
8.5
1
1.5SMC150A
1.5SMC150CA
150A
150C
128.00
143.00
158.00
1
207.0
7.3
1
1.5SMC160A
1.5SMC160CA
160A
160C
136.00
152.00
168.00
1
219.0
6.9
1
1.5SMC170A
1.5SMC170CA
170A
170C
145.00
162.00
179.00
1
234.0
6.5
1
1.5SMC180A
1.5SMC180CA
180A
180C
154.00
171.00
189.00
1
246.0
6.2
1
1.5SMC200A
1.5SMC200CA
200A
200C
171.00
190.00
210.00
1
274.0
5.5
1
1.5SMC220A
1.5SMC220CA
220A
220C
185.00
209.00
231.00
1
328.0
4.6
1
1.5SMC250A
1.5SMC250CA
250A
250C
214.00
237.00
263.00
1
344.0
4.4
1
1.5SMC300A
1.5SMC300CA
300A
300C
256.00
285.00
315.00
1
414.0
3.7
1
1.5SMC350A
1.5SMC350CA
350A
350C
300.00
332.00
368.00
1
482.0
3.2
1
1.5SMC400A
1.5SMC400CA
400A
400C
342.00
380.00
420.00
1
548.0
2.8
1
1.5SMC440A
1.5SMC440CA
440A
440C
376.00
418.00
462.00
1
602.0
2.5
1
1.5SMC480A
1.5SMC480CA
480A
480C
408.00
456.00
504.00
1
658.0
2.3
1
1.5SMC510A
1.5SMC510CA
510A
510C
434.00
485.00
535.00
1
698.0
2.1
1
1.5SMC530A
1.5SMC530CA
530A
530C
477.00
503.50
556.50
1
725.0
2.1
1
1.5SMC540A
1.5SMC540CA
540A
540C
486.00
513.00
567.00
1
740.0
2.0
1
1.5SMC550A
1.5SMC550CA
550A
550C
495.00
522.50
577.50
1
760.0
2.0
1
Rev. 7c
1.5SMC Series
RATING AND CHARACTERISTIC CURVES
Figure 1. Peak Pulse Power Rating Curve
Figure 3. Pulse Waveform
Figure 5. Steady Power Dissipation Derating Curve
Figure 2. Pulse Derating Curve
Figure 4. Tyoical Junctino Capacitance
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
Rev. 7c
1.5SMC Series
PACKAGING SPECIFICATION
Tape
Symbol
Dimension(mm)
W
16.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1. 5±0.10
E
1.75±0.10
F
7.50±0.10
A0
6.27±0.10
B0
8.30±0.10
K0
3.15±0.15
T
0.30±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
20.0±2.0
Quantity
500PCS
Reel
Symbol
Dimension(mm)
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity
3000PCS
RECOMMENDED SOLDERING PROFILES
Reflow Condition
Pre
Heat
Temp. Min Ts(min)
150°C
Tempe. Max Ts(max)
200°C
Time (min. to max.) (ts)
60-180 seconds
Average ramp up rate (Liquidus
Temperature) (T A) to peak
3°C/second max.
Ts(max) to T A (Ramp-up rate)
3°C/second max.
Reflow
Temp. (T A) (Liquidus)
217°C
60-150 seconds
+/-0.5
Peak Temperature (T P)
Time within 5°C of actual peak
Temperature (tp)
Ramp-down Rate
260
Time 25°C to peak Temp. (TP)
8 minutes max.
°C
20-40 seconds
6°C/second max.
Rev. 7c
很抱歉,暂时无法提供与“1.5SMC6.8A”相匹配的价格&库存,您可以联系我们找货
