5.0SMDJ SERIES
Transient Voltage Suppressors
Features
Uni-directional
◆5000W peak pulse power capability at 10/1000μs waveform,
Repetition rate (duty cycle):0.01%
◆For surface mounted applications to optimize board space
◆Low incremental surge impedance
◆Excellent clamping capability
◆Photo Glass and LPCVD process
◆Fast response time:typically less than 1ps from 0V to BV min.
◆Typical IR less than 2μA above 12V.
◆High Temperature soldering guaranteed: 260℃/40 seconds at terminals
◆Plastic package has underwriters laboratory flammability 94V-0
◆Meets MSL level 1, per J-STD-020.
◆Meet Halogen free and RoHS compliant
◆AEC-Q101 qualified available
◆Automotive product No.: base P/N-H
Bi-directional
Mechanical Data
◆Case: JEDEC DO-214AB
◆Polarity: Color band denotes positive end (cathode) except
bi-directional models
◆Weight:About 0.21g
Partnumber Coding System
5.0SMDJ XXX C A
5% VBR VOLTAGE TOLERANCE
BI-DIRECTIONAL
Blank:UNI-DIRECTIONAL
VRWM VOLTAGE
SERIES
Application
◆Power Supply: DC12V/24V、The DC48V of POE RJ45 etc.
◆Communication: RS485、 RS232 etc
Document Number:8060018
Revision:21-Apr-28
An hui Anmei Semiconductor Co.,Ltd.
www.amsemi.com.cn
~1~
5.0SMDJ SERIES
Maximum Ratings and Characteristics
Parameters at 25℃ ambient temperature unless otherwise Noted.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 5000
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
6.5
Watts
VF
4.0
V
IFSM
300
Amps
TJ,TSTG
-55 to +175
Steady state power dissipation at TA=50℃ (Fig.5)
Maximum Instantaneous Forward Voltage at 100A for
Unidirectional
Only
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 8.0mm×8.0mm copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
Dimensions (DO-214AB/SMC)
Millimeters
Symbol
Cathode Band
A C
I
B
H
D
F
E
G
Revision:21-Apr-28
J
K
J
Inches
Min.
Max.
Min.
Max.
A
2.90
3.20
0.114
0.126
B
6.60
7.11
0.260
0.280
C
5.59
6.22
0.220
0.245
D
2.06
2.62
0.079
0.103
E
0.76
1.52
0.030
0.060
F
0.203
0.008
G
7.75
8.130
0.305
0.320
H
0.152
0.305
0.006
0.012
I
3.30
0.129
J
2.40
0.094
K
4.20
0.165
www.amsemi.com.cn
~2~
5.0SMDJ SERIES
Electrical Characteristics
Part Number (Uni)
Part Number (Bi)
Marking
UNI
BI
Reverse Breakdown Voltage V
BR
Test
Stand off
(Volts) @ IT
Current IT
Voltage VR
(mA)
(Volts)
MIN
MAX
Maximum
Clamping
Voltage VC
@ Ipp (V)
Maximum
Peak Pulse
Current Ipp (A)
Maximum
Reverse
Leakage IR
@ VR (μA)
5.0SMDJ12A
5.0SMDJ12CA
5PEP
5BEP
12.0
13.30
14.70
10
19.9
252.00
800
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
13.0
14.40
15.90
10
21.5
233.00
500
5.0SMDJ14A
5.0SMDJ14CA
5PER
5BER
14.0
15.60
17.20
10
23.2
216.00
200
5.0SMDJ15A
5.0SMDJ15CA
5PES
5BES
15.0
16.70
18.50
1
24.4
205.00
100
5.0SMDJ16A
5.0SMDJ16CA
5PET
5BET
16.0
17.80
19.70
1
26.0
193.00
50
5.0SMDJ17A
5.0SMDJ17CA
5PEU
5BEU
17.0
18.90
20.90
1
27.6
181.00
5.0SMDJ18A
5.0SMDJ18CA
5PEV
5BEV
18.0
20.00
22.10
1
29.2
172.00
10
5.0SMDJ20A
5.0SMDJ20CA
5PEW
5BEW
20.0
22.20
24.50
1
32.4
155.00
5
5.0SMDJ22A
5.0SMDJ22CA
5PEX
5BEX
22.0
24.40
26.90
1
35.5
141.00
5
5.0SMDJ24A
5.0SMDJ24CA
5PEZ
5BEZ
24.0
26.70
29.50
1
38.9
129.00
5
5.0SMDJ26A
5.0SMDJ26CA
5PFE
5BFE
26.0
28.90
31.90
1
42.1
119.00
5
5.0SMDJ28A
5.0SMDJ28CA
5PFG
5BFG
28.0
31.10
34.40
1
45.4
110.00
5
5.0SMDJ30A
5.0SMDJ30CA
5PFK
5BFK
30.0
33.30
36.80
1
48.4
103.00
5
5.0SMDJ33A
5.0SMDJ33CA
5PFM
5BFM
33.0
36.70
40.60
1
53.3
93.90
5
5.0SMDJ36A
5.0SMDJ36CA
5PFP
5BFP
36.0
40.00
44.20
1
58.1
86.10
5
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
40.0
44.40
49.10
1
64.5
77.60
5
5.0SMDJ43A
5.0SMDJ43CA
5PFT
5BFT
43.0
47.80
52.80
1
69.4
72.10
5
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
45.0
50.00
55.30
1
72.7
68.80
5
5.0SMDJ48A
5.0SMDJ48CA
5PFX
5BFX
48.0
53.30
58.90
1
77.4
64.70
5
5.0SMDJ51A
5.0SMDJ51CA
5PFZ
5BFZ
51.0
56.70
62.70
1
82.4
60.70
5
5.0SMDJ54A
5.0SMDJ54CA
5RGE
5RGE
54.0
60.00
66.30
1
87.1
57.50
5
5.0SMDJ58A
5.0SMDJ58CA
5PGG
5BGG
58.0
64.40
71.20
1
93.6
53.50
5
5.0SMDJ60A
5.0SMDJ60CA
5PGK
5BGK
60.0
66.70
73.70
1
96.8
51.70
5
5.0SMDJ64A
5.0SMDJ64CA
5PGM
5BGM
64.0
71.10
78.60
1
103.0
48.60
5
5.0SMDJ70A
5.0SMDJ70CA
5PGP
5BGP
70.0
77.80
86.00
1
113.0
44.30
5
5.0SMDJ75A
5.0SMDJ75CA
5PGR
5BGR
75.0
83.30
92.10
1
121.0
41.40
5
5.0SMDJ78A
5.0SMDJ78CA
5PGT
5BGT
78.0
86.70
95.80
1
126.0
39.70
5
5.0SMDJ85A
5.0SMDJ85CA
5PGV
5BGV
85.0
94.40
104.00
1
137.0
36.50
5
5.0SMDJ90A
5.0SMDJ90CA
5PGX
5BGX
90.0
100.00
111.00
1
146.0
34.30
5
5.0SMDJ100A
5.0SMDJ100CA
5PGZ
5BGZ
100.0
111.00
123.00
1
162.0
30.90
5
5.0SMDJ110A
5.0SMDJ110CA
5PHE
5BHE
110.0
122.00
135.00
1
177.0
28.30
5
5.0SMDJ120A
5.0SMDJ120CA
5PHG
5BHG
120.0
133.00
147.00
1
193.0
26.00
5
5.0SMDJ130A
5.0SMDJ130CA
5PHK
5BHK
130.0
144.00
159.00
1
209.0
24.00
5
5.0SMDJ140A
5.0SMDJ140CA
5PHB
5BHB
140.0
155.00
171.00
1
226.8
22.20
5
5.0SMDJ150A
5.0SMDJ150CA
5PHM
5BHM
150.0
167.00
185.00
1
243.0
20.60
5
5.0SMDJ160A
5.0SMDJ160CA
5PHP
5BHP
160.0
178.00
197.00
1
259.0
19.30
5
5.0SMDJ170A
5.0SMDJ170CA
5PHR
5BHR
170.0
189.00
209.00
1
275.0
18.20
5
5.0SMDJ180A
5.0SMDJ180CA
5PKE
5BKE
180.0
200.20
220.00
1
291.6
17.10
5
5.0SMDJ190A
5.0SMDJ190CA
5PKG
5BKG
190.0
211.00
232.00
1
307.8
16.20
5
5.0SMDJ200A
5.0SMDJ200CA
5PKK
5BKK
200.0
224.00
247.00
1
324.0
15.40
5
5.0SMDJ220A
5.0SMDJ220CA
5PKM
5BKM
220.0
246.00
272.00
1
356.0
14.00
5
5.0SMDJ250A
5.0SMDJ250CA
5PKP
5BKP
250.0
279.00
309.00
1
405.0
12.30
5
5.0SMDJ300A
5.0SMDJ300CA
5PKR
5BKR
300.0
335.00
371.00
1
486.0
10.30
5
5.0SMDJ350A
5.0SMDJ350CA
5PKT
5BKT
350.0
391.00
432.00
1
567.0
8.80
5
5.0SMDJ400A
5.0SMDJ400CA
5PKV
5BKV
400.0
447.00
494.00
1
648.0
7.70
5
5.0SMDJ440A
5.0SMDJ440CA
5PKX
5BKX
440.0
492.00
543.00
1
713.0
7.00
5
Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double.
Revision:21-Apr-28
www.amsemi.com.cn
~3~
5.0SMDJ SERIES
Ratings and Characteristic Curves(TA=25℃ unless otherwise noted)
Figure 2. Pulse Derating Curve
100
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
PPPM(KW)
Figure 1. Peak Pulse Power Rating Curve
不重复脉冲波形见图 3
Non-Repetitive Pulse
Waveform shown in Fige.3
TA=25℃
10
1.0
100
75
50
25
0.31×0.31"(8.0×8.0mm)
Copper Pad Areas
0.1
0 .1μs
1μs
25
50
75
100
125
150
175
TA-Ambient Temperature (℃)
10μs
100μs
1.0ms
10ms
td(μs)
Figure 3. Pulse Waveform
100000
TJ=25℃
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
tr=10µs
Bi-directional V=0V
10000
Peak Value IPPM
100
Uni-directional V=0V
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
150
Figure 4. Typical Junction Capacitance
Half Value IPPM (IPPM/2)
1000
Uni-direct ional @VR
100
50
10/1000µs Waveform
as defined by R.E.A
td
Bi-directional @VR
10
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
1.0
2.0
3.0
4.0
1
t-Time (ms)
Figure 5. Steady State Power Dissipation
DeratingCurve
IFSM - Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
6
5
4
3
2
1
50
75
100
1000
125
150
175
300
270
240
210
180
150
120
90
60
30
Revision:21-Apr-28
100
Figure 6. Maximum Non-Repetitive Forward
Surge Current
7
VBR-Reverse Breakdown Voltage (V)
10
Number of Cycles at 60Hz
100
www.amsemi.com.cn
~4~
5.0SMDJ SERIES
ReflowSoldering Parameters
tP
TP
Critical Zone
TL to TP
Ramp-up
Temperature
TL
tL
TS max
Ramp-down
TS min
tS
Preheat
25℃
t 25℃ to Peak
Time (t)
Reflow Condition
Pre heat
Lead-free Assembly
-Temperature Min (TS min)
150℃
-Temperature Max (TS max)
200℃
-Time (min to max) ( tS)
60-180 seconds
Average ramp-up rate (TL to TP)
3℃/second max.
TS max to TL -Ramp-up Rate
3℃/second max.
Reflow
-Temperature (TL) (Liquidus)
217℃
-Time (min to max) (tS)
60-150 seconds
Peak Temperature (TP)
260(+0/-5)℃
Time within 5℃ of actual Peak Temperature (tP)
20-40 seconds
Ramp-down Rate
6℃/second max.
Time 25℃ to Peak Temperature
8 minutes max.
Do not exceed
280℃
Reliability
Standards
Terminal strength
MIL-STD-750 Method 2036
Mechanical shock
JESD22-B104
Vibration
JESD22-B103
High Temp. Storage
JESD22-A103
High Temp Reverse Bias
JESD22-A108
Temperature Cycling
JESD22-A104
High Temp High humidityReverse Bias
JESD22-A101
Resistance to solder heat
JESD22-B106
Revision:21-Apr-28
www.amsemi.com.cn
~5~
5.0SMDJ SERIES
Packaging
Part number
Compnent
Package
Quantity
Packaging
Option
5.0SMDJxxxXX
5.0SMDJxxxXX-T7
DO-214AB
DO-214AB
3000
500
Tape & Reel-16mm tape/13″ reel
Tape & Reel-16mm tape/7″ reel
Packaging
Specification
EIA STD RS-481
EIA STD RS-481
Tape and Reel Specification
Revision:21-Apr-28
www.amsemi.com.cn
~6~
5.0SMDJ SERIES
IMPORTANT NOTICE AND DISCLAIMER
AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA
WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD
OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN
PURCHASE OR USE.
AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or
in any other disclosure relating to any product.
All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application
requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no
warranties, representation or guarantee, whether express, implied or statutory, including, without limitation,
regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM.
AM does not assume any liability or compensation for any application assistance or customer product design,
and make no warranty or accept any liability with products, which are purchased or used for any unintended
or unauthorized application.
Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or
lifesustaining applications or for any other application in which the failure of the AM product could result in
personal injury or death. Customers using or selling AM products not expressly indicated for use in such
applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and
conditions regarding products designed for such applications.
No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this
document or by any conduct of AM. Product names and markings noted herein may be trademarks of their
respective owners.
Revision:21-Apr-28
www.amsemi.com.cn
~7 ~
很抱歉,暂时无法提供与“5.0SMDJ48CA/T7”相匹配的价格&库存,您可以联系我们找货
