5.0SMDJ64CA/T7
5.0SMDJ64CA/T7
    AM(安美)
    SMC(DO-214AB)
    双向TVS 64V截止 峰值脉冲电流:48.6A@10/1000US
5.0SMDJ64CA/T7 数据手册
5.0SMDJ SERIES Transient Voltage Suppressors Features Uni-directional ◆5000W peak pulse power capability at 10/1000μs waveform, Repetition rate (duty cycle):0.01% ◆For surface mounted applications to optimize board space ◆Low incremental surge impedance ◆Excellent clamping capability ◆Photo Glass and LPCVD process ◆Fast response time:typically less than 1ps from 0V to BV min. ◆Typical IR less than 2μA above 12V. ◆High Temperature soldering guaranteed: 260℃/40 seconds at terminals ◆Plastic package has underwriters laboratory flammability 94V-0 ◆Meets MSL level 1, per J-STD-020. ◆Meet Halogen free and RoHS compliant ◆AEC-Q101 qualified available ◆Automotive product No.: base P/N-H Bi-directional Mechanical Data ◆Case: JEDEC DO-214AB ◆Polarity: Color band denotes positive end (cathode) except bi-directional models ◆Weight:About 0.21g Partnumber Coding System 5.0SMDJ XXX C A 5% VBR VOLTAGE TOLERANCE BI-DIRECTIONAL Blank:UNI-DIRECTIONAL VRWM VOLTAGE SERIES Application ◆Power Supply: DC12V/24V、The DC48V of POE RJ45 etc. ◆Communication: RS485、 RS232 etc Document Number:8060018 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~1~ 5.0SMDJ SERIES Maximum Ratings and Characteristics Parameters at 25℃ ambient temperature unless otherwise Noted. Rating Symbol Value Units Peak pulse power dissipation at 10/1000μs waveform (Note1, Note2, Fig.1) PPPM Minimum 5000 Watts Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3) IPPM See Table Amps PM(AV) 6.5 Watts VF 4.0 V IFSM 300 Amps TJ,TSTG -55 to +175 ℃ Steady state power dissipation at TA=50℃ (Fig.5) Maximum Instantaneous Forward Voltage at 100A for Unidirectional Only Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load, (JEDEC Method) (Note3, Fig.6) Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2. 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum. Dimensions (DO-214AB/SMC) Millimeters Symbol Cathode Band A C I B H D F E G Document Number:8060018 Revision:21-Apr-28 J K J Inches Min. Max. Min. Max. A 2.90 3.20 0.114 0.126 B 6.60 7.11 0.260 0.280 C 5.59 6.22 0.220 0.245 D 2.06 2.62 0.079 0.103 E 0.76 1.52 0.030 0.060 F - 0.203 - 0.008 G 7.75 8.130 0.305 0.320 H 0.152 0.305 0.006 0.012 I 3.30 - 0.129 - J 2.40 - 0.094 - K - 4.20 - 0.165 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~2~ 5.0SMDJ SERIES Electrical Characteristics Part Number (Uni) Part Number (Bi) Marking UNI BI Reverse Breakdown Voltage V BR Test Stand off (Volts) @ IT Current IT Voltage VR (mA) (Volts) MIN MAX Maximum Clamping Voltage VC @ Ipp (V) Maximum Peak Pulse Current Ipp (A) Maximum Reverse Leakage IR @ VR (μA) 5.0SMDJ12A 5.0SMDJ12CA 5PEP 5BEP 12.0 13.30 14.70 10 19.9 252.00 800 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 13.0 14.40 15.90 10 21.5 233.00 500 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14.0 15.60 17.20 10 23.2 216.00 200 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15.0 16.70 18.50 1 24.4 205.00 100 5.0SMDJ16A 5.0SMDJ16CA 5PET 5BET 16.0 17.80 19.70 1 26.0 193.00 50 5.0SMDJ17A 5.0SMDJ17CA 5PEU 5BEU 17.0 18.90 20.90 1 27.6 181.00 20 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18.0 20.00 22.10 1 29.2 172.00 10 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20.0 22.20 24.50 1 32.4 155.00 5 5.0SMDJ22A 5.0SMDJ22CA 5PEX 5BEX 22.0 24.40 26.90 1 35.5 141.00 5 5.0SMDJ24A 5.0SMDJ24CA 5PEZ 5BEZ 24.0 26.70 29.50 1 38.9 129.00 5 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26.0 28.90 31.90 1 42.1 119.00 5 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28.0 31.10 34.40 1 45.4 110.00 5 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30.0 33.30 36.80 1 48.4 103.00 5 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33.0 36.70 40.60 1 53.3 93.90 5 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36.0 40.00 44.20 1 58.1 86.10 5 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40.0 44.40 49.10 1 64.5 77.60 5 5.0SMDJ43A 5.0SMDJ43CA 5PFT 5BFT 43.0 47.80 52.80 1 69.4 72.10 5 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 45.0 50.00 55.30 1 72.7 68.80 5 5.0SMDJ48A 5.0SMDJ48CA 5PFX 5BFX 48.0 53.30 58.90 1 77.4 64.70 5 5.0SMDJ51A 5.0SMDJ51CA 5PFZ 5BFZ 51.0 56.70 62.70 1 82.4 60.70 5 5.0SMDJ54A 5.0SMDJ54CA 5RGE 5RGE 54.0 60.00 66.30 1 87.1 57.50 5 5.0SMDJ58A 5.0SMDJ58CA 5PGG 5BGG 58.0 64.40 71.20 1 93.6 53.50 5 5.0SMDJ60A 5.0SMDJ60CA 5PGK 5BGK 60.0 66.70 73.70 1 96.8 51.70 5 5.0SMDJ64A 5.0SMDJ64CA 5PGM 5BGM 64.0 71.10 78.60 1 103.0 48.60 5 5.0SMDJ70A 5.0SMDJ70CA 5PGP 5BGP 70.0 77.80 86.00 1 113.0 44.30 5 5.0SMDJ75A 5.0SMDJ75CA 5PGR 5BGR 75.0 83.30 92.10 1 121.0 41.40 5 5.0SMDJ78A 5.0SMDJ78CA 5PGT 5BGT 78.0 86.70 95.80 1 126.0 39.70 5 5.0SMDJ85A 5.0SMDJ85CA 5PGV 5BGV 85.0 94.40 104.00 1 137.0 36.50 5 5.0SMDJ90A 5.0SMDJ90CA 5PGX 5BGX 90.0 100.00 111.00 1 146.0 34.30 5 5.0SMDJ100A 5.0SMDJ100CA 5PGZ 5BGZ 100.0 111.00 123.00 1 162.0 30.90 5 5.0SMDJ110A 5.0SMDJ110CA 5PHE 5BHE 110.0 122.00 135.00 1 177.0 28.30 5 5.0SMDJ120A 5.0SMDJ120CA 5PHG 5BHG 120.0 133.00 147.00 1 193.0 26.00 5 5.0SMDJ130A 5.0SMDJ130CA 5PHK 5BHK 130.0 144.00 159.00 1 209.0 24.00 5 5.0SMDJ140A 5.0SMDJ140CA 5PHB 5BHB 140.0 155.00 171.00 1 226.8 22.20 5 5.0SMDJ150A 5.0SMDJ150CA 5PHM 5BHM 150.0 167.00 185.00 1 243.0 20.60 5 5.0SMDJ160A 5.0SMDJ160CA 5PHP 5BHP 160.0 178.00 197.00 1 259.0 19.30 5 5.0SMDJ170A 5.0SMDJ170CA 5PHR 5BHR 170.0 189.00 209.00 1 275.0 18.20 5 5.0SMDJ180A 5.0SMDJ180CA 5PKE 5BKE 180.0 200.20 220.00 1 291.6 17.10 5 5.0SMDJ190A 5.0SMDJ190CA 5PKG 5BKG 190.0 211.00 232.00 1 307.8 16.20 5 5.0SMDJ200A 5.0SMDJ200CA 5PKK 5BKK 200.0 224.00 247.00 1 324.0 15.40 5 5.0SMDJ220A 5.0SMDJ220CA 5PKM 5BKM 220.0 246.00 272.00 1 356.0 14.00 5 5.0SMDJ250A 5.0SMDJ250CA 5PKP 5BKP 250.0 279.00 309.00 1 405.0 12.30 5 5.0SMDJ300A 5.0SMDJ300CA 5PKR 5BKR 300.0 335.00 371.00 1 486.0 10.30 5 5.0SMDJ350A 5.0SMDJ350CA 5PKT 5BKT 350.0 391.00 432.00 1 567.0 8.80 5 5.0SMDJ400A 5.0SMDJ400CA 5PKV 5BKV 400.0 447.00 494.00 1 648.0 7.70 5 5.0SMDJ440A 5.0SMDJ440CA 5PKX 5BKX 440.0 492.00 543.00 1 713.0 7.00 5 Notes: For bidirectional type having VRWM of 10V and less, the IR limit is double. Document Number:8060018 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~3~ 5.0SMDJ SERIES Ratings and Characteristic Curves(TA=25℃ unless otherwise noted) Figure 2. Pulse Derating Curve 100 Peak Pulse Power (PPP) or Current (IPP) Derating in Percentage % PPPM(KW) Figure 1. Peak Pulse Power Rating Curve 不重复脉冲波形见图 3 Non-Repetitive Pulse Waveform shown in Fige.3 TA=25℃ 10 1.0 100 75 50 25 0 0 0.31×0.31"(8.0×8.0mm) Copper Pad Areas 0.1 0 .1μs 1μs 25 50 75 100 125 150 175 TA-Ambient Temperature (℃) 10μs 100μs 1.0ms 10ms td(μs) Figure 3. Pulse Waveform 100000 TJ=25℃ Pulse Width(td) is defined as the point where the peak current decays to 50% of IPPM tr=10µs Bi-directional V=0V 10000 Peak Value IPPM 100 Uni-directional V=0V Cj (pF) IPPM - Peak Pulse Current, %IRSM 150 Figure 4. Typical Junction Capacitance Half Value IPPM (IPPM/2) 1000 Uni-direct ional @VR 100 50 10/1000µs Waveform as defined by R.E.A td 0 0 Bi-directional @VR 10 TJ=25℃ f=1.0MHz Vsig=50mVp-p 1 1.0 2.0 3.0 4.0 1 t-Time (ms) Figure 5. Steady State Power Dissipation DeratingCurve IFSM - Peak Forward Surve Current (A) PM(AV), Steady State Power Dissipation (W) 6 5 4 3 2 1 0 25 50 75 100 1000 125 150 175 300 270 240 210 180 150 120 90 60 30 0 1 TA-Ambient Temperature (℃) Document Number:8060018 Revision:21-Apr-28 100 Figure 6. Maximum Non-Repetitive Forward Surge Current 7 0 10 VBR-Reverse Breakdown Voltage (V) An hui Anmei Semiconductor Co.,Ltd. 10 Number of Cycles at 60Hz 100 www.amsemi.com.cn ~4~ 5.0SMDJ SERIES ReflowSoldering Parameters tP TP Critical Zone TL to TP Ramp-up Temperature TL tL TS max Ramp-down TS min tS Preheat 25℃ t 25℃ to Peak Time (t) Reflow Condition Pre heat Lead-free Assembly -Temperature Min (TS min) 150℃ -Temperature Max (TS max) 200℃ -Time (min to max) ( tS) 60-180 seconds Average ramp-up rate (TL to TP) 3℃/second max. TS max to TL -Ramp-up Rate 3℃/second max. Reflow -Temperature (TL) (Liquidus) 217℃ -Time (min to max) (tS) 60-150 seconds Peak Temperature (TP) 260(+0/-5)℃ Time within 5℃ of actual Peak Temperature (tP) 20-40 seconds Ramp-down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max. Do not exceed 280℃ Reliability Standards Terminal strength MIL-STD-750 Method 2036 Mechanical shock JESD22-B104 Vibration JESD22-B103 High Temp. Storage JESD22-A103 High Temp Reverse Bias JESD22-A108 Temperature Cycling JESD22-A104 High Temp High humidityReverse Bias JESD22-A101 Resistance to solder heat JESD22-B106 Document Number:8060018 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~5~ 5.0SMDJ SERIES Packaging Part number Compnent Package Quantity Packaging Option 5.0SMDJxxxXX 5.0SMDJxxxXX-T7 DO-214AB DO-214AB 3000 500 Tape & Reel-16mm tape/13″ reel Tape & Reel-16mm tape/7″ reel Packaging Specification EIA STD RS-481 EIA STD RS-481 Tape and Reel Specification Document Number:8060018 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~6~ 5.0SMDJ SERIES IMPORTANT NOTICE AND DISCLAIMER AM RESERVES THE RIGHT TO MAKE CHANGES TO ALL PRODUCT, PRODUCT SPECIFICATIONS AND DATA WITHOUT NOTICE TO IMPROVE RELIABILITY, FUNCTION OR DESIGN OR OTHERWISE. CUSTOMERS SHOULD OBTAIN AND CONFIRM THE LATEST PRODUCT INFORMATION AND SPECIFICATIONS BEFORE FINAL DESIGN PURCHASE OR USE. AM disclaim any and all liability for any errors, inaccuracies or incompleteness contained in any datasheet or in any other disclosure relating to any product. All information are provided as-is, even it has qualified by the AEC-Q101 which satisfy industrial application requirement, except as expressly stated in this data sheet is applied for automotive grade, AM make no warranties, representation or guarantee, whether express, implied or statutory, including, without limitation, regarding any merchantability, satisfactory quality, or fitness for a particular purpose with respect to AM. AM does not assume any liability or compensation for any application assistance or customer product design, and make no warranty or accept any liability with products, which are purchased or used for any unintended or unauthorized application. Except as expressly indicated in writing, AM products are not designed for use in medical, life-saving, or lifesustaining applications or for any other application in which the failure of the AM product could result in personal injury or death. Customers using or selling AM products not expressly indicated for use in such applications do so at their own risk. Please contact authorized AM personnel to obtain written terms and conditions regarding products designed for such applications. No license, express or implied, by estoppel or otherwise, to any intellectual property rights is granted by this document or by any conduct of AM. Product names and markings noted herein may be trademarks of their respective owners. Document Number:8060018 Revision:21-Apr-28 An hui Anmei Semiconductor Co.,Ltd. www.amsemi.com.cn ~7 ~
5.0SMDJ64CA/T7 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ64CA/T7”相匹配的价格&库存,您可以联系我们找货
