SMCJ5.0(A)H – SMCJ170(A)H
Taiwan Semiconductor
1500W, 5V - 170V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
AEC-Q101 qualified
Ideal for automated placement
Glass passivated junction
Excellent clamping capability
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Fast response time: Typically less than
1.0ps from 0 V to BV min
Typical IR less than 1μA above 10V
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
5 - 170
V
VBR
6.4 - 231
V
PPK
1500
W
TJ MAX
150
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
● Immunization of sensitive devices in telecommunications,
consumer electronics, and industrial equipment from
electrostatic discharge (ESD) and transient voltages induced by
load switching and lightning.
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.210g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PPK
1500
W
PD
5
W
IFSM
200
A
VF
3.5 / 5.0
V
Junction temperature
TJ
-55 to +150
°C
Storage temperature
TSTG
-55 to +150
°C
Peak power dissipation at TA = 25°C, tp = 1ms
(1)
Steady state power dissipation at T A = 25°C
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
(2)
Forward Voltage @ IF = 100A for Unidirectional only
Notes:
1. Non-repetitive current pulse per Fig.5 and derated above TA = 25°C per Fig.2
2. VF = 3.5V on SMCJ5.0H - SMCJ90H devices and VF = 5.0V on SMCJ100H - SMCJ170H devices
Devices for bipolar applications
1. For bidirectional use CH or CAH suffix for types SMCJ5.0H - types SMCJ170H
2. Electrical characteristics apply in both directions
1
Version: A2102
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
55
°C/W
Junction-to-case thermal resistance
RӨJC
10
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
SMCJ5.0H
SMCJ5.0AH
SMCJ6.0H
SMCJ6.0AH
SMCJ6.5H
SMCJ6.5AH
SMCJ7.0H
SMCJ7.0AH
SMCJ7.5H
SMCJ7.5AH
SMCJ8.0H
SMCJ8.0AH
SMCJ8.5H
SMCJ8.5AH
SMCJ9.0H
SMCJ9.0AH
SMCJ10H
SMCJ10AH
SMCJ11H
SMCJ11AH
SMCJ12H
SMCJ12AH
SMCJ13H
SMCJ13AH
SMCJ14H
SMCJ14AH
SMCJ15H
SMCJ15AH
SMCJ16H
SMCJ16AH
SMCJ17H
SMCJ17AH
SMCJ18H
SMCJ18AH
SMCJ20H
SMCJ20AH
SMCJ22H
SMCJ22AH
SMCJ24H
SMCJ24AH
SMCJ26H
SMCJ26AH
SMCJ28H
Marking
code
GDD
GDE
GDF
GDG
GDH
GDK
GDL
GDM
GDN
GDP
GDQ
GDR
GDS
GDT
GDU
GDV
GDW
GDX
GDY
GDZ
GED
GEE
GEF
GEG
GEH
GEK
GEL
GEM
GEN
GEP
GEQ
GER
GES
GET
GEU
GEV
GEW
GEX
GEY
GEZ
GFD
GFE
GFF
Breakdown voltage
VBR@IT
(V)
Min
6.4
6.4
6.67
6.67
7.22
7.22
7.78
7.78
8.33
8.33
8.89
8.89
9.44
9.44
10
10
11.1
11.1
12.2
12.2
13.3
13.3
14.4
14.4
15.6
15.6
16.7
16.7
17.8
17.8
18.9
18.9
22.2
24.4
24.4
26.7
26.7
28.9
28.9
31.1
Max
7.3
7
8.15
7.37
8.82
7.98
9.51
8.6
10.30
9.21
10.9
9.83
11.5
10.4
12.2
11.1
13.6
12.3
14.9
13.5
16.3
14.7
17.6
15.9
19.1
17.2
20.4
18.5
21.8
19.7
23.1
20.9
24.4
22.1
27.1
24.5
29.8
26.9
32.6
29.5
35.3
31.9
38
Test
current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
10
10
10
10
10
10
10
10
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
5
5
6
6
6.5
6.5
7
7
7.5
7.5
8
8
8.5
8.5
9
9
10
10
11
11
12
12
13
13
14
14
15
15
16
16
17
17
18
18
22
24
24
26
26
28
2
Maximum
Maximum
peak impulse
Reverse
current
Leakage
(Note 2)
(Note 3)
IPPM
IR@VWM (µA)
(A)
1000
1000
1000
1000
500
500
200
200
100
100
50
50
10
5
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
164
171
138
152
128
140
118
131
110
122
105
115
99
109
93
102
83
92
78
86
71
79
66
73
61
67
58
64
54
60
51
57
48
53
43
48
39
44
36
40
33
37
31
Maximum
clamping
voltage
(Note 2)
VC@IPPM
(V)
9.6
9.2
11.4
10.3
12.3
11.2
13.3
12.0
14.3
12.9
15.0
13.6
15.9
14.4
16.9
15.4
18.8
17.0
20.1
18.2
22.0
19.9
23.8
21.5
25.8
23.2
26.9
24.4
28.8
26.0
30.5
27.6
32.2
29.2
35.8
32.4
39.4
35.5
43.0
38.9
46.6
42.1
50.0
Version: A2102
Part number
SMCJ28AH
SMCJ30H
SMCJ30AH
SMCJ33H
SMCJ33AH
SMCJ36H
SMCJ36AH
SMCJ40H
SMCJ40AH
SMCJ43H
SMCJ43AH
SMCJ45H
SMCJ45AH
SMCJ48H
SMCJ48AH
SMCJ51H
SMCJ51AH
SMCJ54H
SMCJ54AH
SMCJ58H
SMCJ58AH
SMCJ60H
SMCJ60AH
SMCJ64H
SMCJ64AH
SMCJ70H
SMCJ70AH
SMCJ75H
SMCJ75AH
SMCJ78H
SMCJ78AH
SMCJ85H
SMCJ85AH
SMCJ90H
SMCJ90AH
SMCJ100H
SMCJ100AH
SMCJ110H
SMCJ110AH
SMCJ120H
SMCJ120AH
SMCJ130H
SMCJ130AH
SMCJ150H
SMCJ150AH
SMCJ160H
SMCJ160AH
SMCJ170H
SMCJ170AH
Marking
code
GFG
GFH
GFK
GFL
GFM
GFN
GFP
GFQ
GFR
GFS
GFT
GFU
GFV
GFW
GFX
GFY
GFZ
GGD
GGE
GGF
GGG
GGH
GGK
GGL
GGM
GGN
GGP
GGQ
GGR
GGS
GGT
GGU
GGV
GGW
GGX
GGY
GGZ
GHD
GHE
GHF
GHG
GHH
GHK
GHL
GHM
GHN
GHP
GHQ
GHR
Breakdown voltage
VBR@IT
(V)
Min
31.1
33.3
33.3
36.7
36.7
40
40
44.4
44.4
47.8
47.8
50
50
53.3
53.3
56.7
56.7
60
60
64.4
64.4
66.7
66.7
71.1
71.1
77.8
77.8
83.3
83.3
86.7
86.7
94.4
94.4
100
100
111
111
122
122
133
133
144
144
167
167
178
178
189
189
Max
34.4
40.7
36.8
44.9
40.6
48.9
44.2
54.3
49.1
58.4
52.8
61.1
55.3
65.1
58.9
69.3
62.7
73.3
66.3
78.7
71.2
81.5
73.7
86.9
78.6
95.1
86
102
92.1
106
95.8
115
104
122
111
136
123
149
135
163
147
176
159
204
185
218
197
231
209
Test
current
IT
(mA)
Working
stand-off
voltage
VWM
(V)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
28
30
30
33
33
36
36
40
40
43
43
45
45
48
48
51
51
54
54
58
58
60
60
64
64
70
70
75
75
78
78
85
85
90
90
100
100
110
110
120
120
130
130
150
150
160
160
170
170
Maximum
Maximum
peak impulse
Reverse
current
Leakage
(Note 2)
(Note 3)
IPPM
IR@VWM (µA)
(A)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
34
29
32
26
29
24
27
22
24
19
21
18
19
16
18
15
16
14
16
13.8
15
12.6
13.9
11.7
13
11.3
12.5
10.4
11.5
9.8
10.7
8.8
9.7
8
8.9
7.3
8.1
6.8
7.5
5.8
6.4
5.4
6
5.1
5.7
Maximum
clamping
voltage
(Note 2)
VC@IPPM
(V)
45.4
53.5
48.4
59.0
53.3
64.3
58.1
71.4
64.5
76.7
69.4
80.3
72.7
85.5
77.4
91.1
82.4
96.3
87.1
103
93.6
107
96.8
114
103
125
113
134
121
139
126
151
137
160
146
179
162
196
177
214
193
231
209
266
243
287
259
304
275
Notes:
1. VBR measure after IT applied for 30ms, IT = square wave pulse or equivalent
2. Surge current waveform per Fig.5 and derate per Fig.2
3. For bipolar types having VWM of 10V and under, the IR limit is doubled
4. All terms and symbols are consistent with ANSI/IEEE C62.35
3
Version: A2102
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SMCJxH
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 5V(SMCJ5.0H) to 170V(SMCJ170H)
4
Version: A2102
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
PEAK PULSE POWER (PPP) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER (kW)
100
NON-REPETITIVE
PULSE WAVEFORM
SHOWN in FIG.5
10
1
0.1
0.1
1
10
100
1000
125
100
75
50
25
Fig.3 Typical Junction Capacitance
IFSM, PEAK FORWARD SURGE CURRENT (A)
CJ, JUNCTION CAPACITANCE (pF)
UNIDIRECTIONAL
BIDRECTIONA
10000
VR=0
100
VR-rated
stand-off voltage
10
1
75
100
125
150
Fig.4 Maximum Non-repetitive Forward Surge
Current
100000
f=1.0MHz
Vsig=50mVp-p
50
TA, AMBIENT TEMPERATURE (°C)
tp, PULSE WIDTH (μs)
1000
25
10
1000
8.3ms single half sine wave
Unidirectional only
100
10
1
1
100
10
100
NUMBER OF CYCLES AT 60 Hz
V(BR), BREAKDOWN VOLTAGE (V)
5
Version: A2102
Fig.5 Clamping Power Pulse Waveform
120
IPPM, PEAK PULSE CURRENT (%)
110
Peak value
IPPM
100
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
90
Rise time tr=10μs to 100% of IPPM
80
70
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
50
40
30
td
10
1
1.5
2
2.5
3
3.5
4
4.5
5
t, TIME (ms)
6
Version: A2102
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
7
Version: A2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
8
Version: A2102
很抱歉,暂时无法提供与“SMCJ13AH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.772973000+0.21978
- 6000+1.755066000+0.21756
- 9000+1.737159000+0.21534
- 12000+1.7281912000+0.21423
- 15000+1.7013315000+0.21090
