5.0SMDJ16AH – 5.0SMDJ100AH
Taiwan Semiconductor
5000W, 16V - 100V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
AEC-Q101 qualified
5000W peak pulse power capability at 10/1000μs waveform
Ideal for automated placement
Photo glass passivated junction
Excellent clamping capability
Fast response time: Typically less than 1.0ps
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
VBR
(uni-directional)
PPPSM
16 - 100
V
17.8 - 123
V
5000
W
TJ MAX
175
°C
Package
DO-214AB (SMC)
Configuration
Stacked die
APPLICATIONS
● I/O interface
● AC/DC power supply
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.300g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Non-repetitive peak impulse power dissipation with
(1)
10/1000us waveform
(2)
Steady state power dissipation at T L = 75°C
SYMBOL
VALUE
UNIT
PPK
5000
W
PD
6.25
W
Forward Voltage @ IF = 100A for Uni-directional only
VF
5
V
Junction temperature
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
SYMBOL
TYP
UNIT
Junction-to-lead thermal resistance
RӨJL
16
°C/W
Junction-to-ambient thermal resistance
RӨJA
61
°C/W
Junction-to-case thermal resistance
RӨJC
17
°C/W
(3)
Notes:
1. Non-repetitive current pulse per Fig.3 and derated above TA = 25°C Per Fig.1
2. Units mounted on PCB (16mm x 16mm Cu pad test board)
3. Pulse test with PW = 0.3ms
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: Units mounted on PCB (16mm x 16mm Cu pad test board)
1
Version: A2102
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Maximum
Breakdown
Working
Maximum
Maximum
Maximum
blocking
Test
standpeak
Temp.
Marking voltage
clamping
leakage
Part number
V
@I
BR
T
current
off
impulse
coefficient
code
voltage
current
(V)
IT
voltage
current
of VBR
VC@IPP
IIB@VWM
(Note 1)
(mA)
VWM
IPP
αV
BR@IT
(V)
(µA)
(V)
(A)
(mV/°C)
Uni
Uni
Min Max
(Note 1)
5.0SMDJ16AH
5PET
17.8 19.7
1
16
50
193
26.0
0.096
5.0SMDJ17AH
5PEU
18.9 20.9
1
17
27.6
0.097
5.0SMDJ18AH
5PEV
20.0 22.1
1
18
10
172
29.2
0.098
5.0SMDJ20AH
5PEW
22.2 24.5
1
155
32.4
0.099
5.0SMDJ22AH
5PEX
24.4 26.9
1
22
5
141
35.5
0.100
5.0SMDJ24AH
5PEZ
26.7 29.5
1
24
2
129
38.9
0.101
5.0SMDJ26AH
5PFE
28.9 31.9
1
26
2
119
42.1
0.101
5.0SMDJ28AH
5PFG
31.1 34.4
1
28
2
110
45.4
0.102
5.0SMDJ30AH
5PFK
33.3 36.8
1
30
2
103
48.4
0.103
5.0SMDJ33AH
5PFM
36.7 40.6
1
33
2
93.9
53.3
0.104
5.0SMDJ36AH
5PFP
40.0 44.2
1
36
2
86.1
58.1
0.104
5.0SMDJ40AH
5PFR
44.4 49.1
1
40
2
77.6
64.5
0.105
5.0SMDJ43AH
5PFT
47.8 52.8
1
43
2
72.1
69.4
0.105
5.0SMDJ45AH
5PFV
50.0 55.3
1
45
2
68.8
72.7
0.106
5.0SMDJ48AH
5PFX
53.3 58.9
1
48
2
64.7
77.4
0.106
5.0SMDJ51AH
5PFZ
56.7 62.7
1
51
2
60.7
82.4
0.107
5.0SMDJ54AH
5PGE
60.0 66.3
1
54
2
57.5
87.1
0.107
5.0SMDJ58AH
5PGG
64.4 71.2
1
58
2
53.5
93.6
0.107
5.0SMDJ60AH
5PGK
66.7 73.7
1
60
2
51.7
96.8
0.108
5.0SMDJ64AH
5PGM
71.1 78.6
1
64
2
48.6
103
0.108
5.0SMDJ70AH
5PGP
77.8 86.0
1
70
2
44.3
113
0.108
5.0SMDJ75AH
5PGR
83.3 92.1
1
75
2
41.4
121
0.108
5.0SMDJ78AH
5PGT
86.7 95.8
1
78
2
39.7
126
0.108
5.0SMDJ85AH
5PGV
94.4 104
1
85
2
36.5
137
0.110
5.0SMDJ90AH
5PGX
100
111
1
90
2
34.3
146
0.110
5.0SMDJ100AH
5PGZ
111
123
1
100
2
30.9
162
0.110
Note:
1. Pulse test with PW = 30ms
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
5.0SMDJxH
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 16V(5.0SMDJ16AH) to 100V(5.0SMDJ100AH)
2
Version: A2102
CHARACTERISTICS CURVES
Fig.1 Pulse Power or Current vs. Initial Junction
Fig.2 Power Derating Curve
100
6.5
6.0
PD - POWER DISSIPATION (W)
PEAK PULSE POWER (PPPM) OR CURRENT (IPP)
DERATING IN PERCENTAGE, %
Temperature
75
50
25
5.5
5.0
4.5
4.0
3.5
3.0
2.5
2.0
1.5
Heat sink
16mm x 16mm
Cu pad test board
1.0
0.5
0.0
50
75
100
125
150
25
50
75
100
125
150
175
LEAD TEMPERATURE (°C)
TJ - INITAL TEMPERATURE (°C)
Fig.3 Pulse Waveform
Fig.4 Typical Junction Capacitance
10000
100
5.0SMDJ16AH
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
Peak value
IPPM
120
Rise time tr=10μs to 100%
CAPACITANCE (pF)
IPPM, PEAK PULSE CURRENT (%)
140
80
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
40
5.0SMDJ51AH
1000
5.0SMDJ100AH
td
1
1.5
2
2.5
3
0.1
1
10
100
REVERSE VOLTAGE (V)
t, TIME (ms)
3
Version: A2102
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
4
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Version: A2102
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
5
Version: A2102
很抱歉,暂时无法提供与“5.0SMDJ16AH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+8.736983000+1.08306
