1.5SMC30CA
1.5SMC30CA
    MERITEK
    SMC(DO-214AB)
    TVS 25.6V截止 36.7A峰值脉冲
1.5SMC30CA 数据手册
Transient Voltage Suppressors DO-214AB/SMC Package 1.5SMC Series FEATURE  Peak Power Dissipation: 1500W  Fast response time. IR less than 1μA above 12V. Duty cycle: 0.01%  Excellent clamping capability, Low inductance  Glass passivated junction  High Temperature soldering: 260°C, 10 seconds  Flammability Classification 94V-O.  UL/cUL safety approved: certification No: E223045 MAXIMUM RATINGS AND CHARACTERISTICS Parameter Symbol Value Unit PPPM Minimum 1500 Watts IPPM See Table Amps Steady State Power Dissipation at TL =75°C,Lead length .375” (9.5mm). (Fig. 5) PM(AV) 6.5 Watts Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load IFSM 200 Amps TJ , TSTG -65 to +150 °C Peak Pulse Power Dissipation on 10/1000μs waveform. (Note 1,Fig. 1) Peak Pulse Current on 10/1000μs waveform. (Note 1,Fig. 3) Operating junction and Storage Temperature Range. Ratings at 25℃ ambient temperature unless otherwise specified. 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°Cper Fig. 2 . 2. Mounted on 8.0mm×8.0mm copper pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minute maximum. DIMENSIONS SMC/DO-214AB (mm) Item Min. Max. L 6.60 7.11 D 5.59 6.22 D1 2.90 3.20 T 7.75 8.13 T1 0.76 1.52 d - 0.203 s 2.06 2.62 t 0.152 0.305 SPECIFICATIONS Part Number Device Marking Code Reverse StandOff Voltage Breakdown Voltage Min.@IT Breakdown Voltage Max.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Uni-Polar Bi-Polar Uni Bi VRWM (V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR (µA) 1.5SMC6.8A 1.5SMC6.8CA 6V8A 6V8C 5.8 6.45 7.14 10 10.5 144.8 1000 1.5SMC7.5A 1.5SMC7.5CA 7V5A 7V5C 6.4 7.13 7.88 10 11.3 134.5 500 1.5SMC8.2A 1.5SMC8.2CA 8V2A 8V2C 7.02 7.79 8.61 10 12.1 125.6 200 1.5SMC9.1A 1.5SMC9.1CA 9V1A 9V1C 7.78 8.65 9.50 1 13.4 113.4 50 1.5SMC10A 1.5SMC10CA 10A 10C 8.55 9.50 10.50 1 14.5 104.8 10 1.5SMC11A 1.5SMC11CA 11A 11C 9.40 10.50 11.60 1 15.6 97.4 5 1.5SMC12A 1.5SMC12CA 12A 12C 10.20 11.40 12.60 1 16.7 91.0 5 1.5SMC13A 1.5SMC13CA 13A 13C 11.10 12.40 13.70 1 18.2 83.5 1 1.5SMC15A 1.5SMC15CA 15A 15C 12.80 14.30 15.80 1 21.2 71.7 1 Rev. 7c Transient Voltage Suppressors DO-214AB/SMC Package 1.5SMC Series SPECIFICATIONS(CONTINUED) Part Number Device Marking Code Reverse StandOff Voltage Breakdown Voltage Min.@IT Breakdown Voltage Max.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Uni-Polar Bi-Polar Uni Bi VRWM (V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR (µA) 1.5SMC16A 1.5SMC16CA 16A 16C 13.60 15.20 16.80 1 22.5 67.6 1 1.5SMC18A 1.5SMC18CA 18A 18C 15.30 17.10 18.90 1 25.2 60.3 1 1.5SMC20A 1.5SMC20CA 20A 20C 17.10 19.00 21.00 1 27.7 54.9 1 1.5SMC22A 1.5SMC22CA 22A 22C 18.80 20.90 23.10 1 30.6 49.7 1 1.5SMC24A 1.5SMC24CA 24A 24C 20.50 22.80 25.20 1 33.2 45.8 1 1.5SMC27A 1.5SMC27CA 27A 27C 23.10 25.70 28.40 1 37.5 40.5 1 1.5SMC30A 1.5SMC30CA 30A 30C 25.60 28.50 31.50 1 41.4 36.7 1 1.5SMC33A 1.5SMC33CA 33A 33C 28.20 31.40 34.70 1 45.7 33.3 1 1.5SMC36A 1.5SMC36CA 36A 36C 30.80 34.20 37.80 1 49.9 30.5 1 1.5SMC39A 1.5SMC39CA 39A 39C 33.30 37.10 41.00 1 53.9 28.2 1 1.5SMC43A 1.5SMC43CA 43A 43C 36.80 40.90 45.20 1 59.3 25.6 1 1.5SMC47A 1.5SMC47CA 47A 47C 40.20 44.70 49.40 1 64.8 23.5 1 1.5SMC51A 1.5SMC51CA 51A 51C 43.60 48.50 53.60 1 70.1 21.7 1 1.5SMC56A 1.5SMC56CA 56A 56C 47.80 53.20 58.80 1 77.0 19.7 1 1.5SMC62A 1.5SMC62CA 62A 62C 53.00 58.90 65.10 1 85.0 17.9 1 1.5SMC68A 1.5SMC68CA 68A 68C 58.10 64.60 71.40 1 92.0 16.5 1 1.5SMC75A 1.5SMC75CA 75A 75C 64.10 71.30 78.80 1 103.0 14.8 1 1.5SMC82A 1.5SMC82CA 82A 82C 70.10 77.90 86.10 1 113.0 13.5 1 1.5SMC91A 1.5SMC91CA 91A 91C 77.80 86.50 95.50 1 125.0 12.2 1 1.5SMC100A 1.5SMC100CA 68A 100C 85.50 95.00 105.00 1 137.0 11.1 1 1.5SMC110A 1.5SMC110CA 75A 110C 94.00 105.00 116.00 1 152.0 10.0 1 1.5SMC120A 1.5SMC120CA 120A 120C 102.00 114.00 126.00 1 165.0 9.2 1 1.5SMC130A 1.5SMC130CA 130A 130C 111.00 124.00 137.00 1 179.0 8.5 1 1.5SMC150A 1.5SMC150CA 150A 150C 128.00 143.00 158.00 1 207.0 7.3 1 1.5SMC160A 1.5SMC160CA 160A 160C 136.00 152.00 168.00 1 219.0 6.9 1 1.5SMC170A 1.5SMC170CA 170A 170C 145.00 162.00 179.00 1 234.0 6.5 1 1.5SMC180A 1.5SMC180CA 180A 180C 154.00 171.00 189.00 1 246.0 6.2 1 1.5SMC200A 1.5SMC200CA 200A 200C 171.00 190.00 210.00 1 274.0 5.5 1 1.5SMC220A 1.5SMC220CA 220A 220C 185.00 209.00 231.00 1 328.0 4.6 1 1.5SMC250A 1.5SMC250CA 250A 250C 214.00 237.00 263.00 1 344.0 4.4 1 1.5SMC300A 1.5SMC300CA 300A 300C 256.00 285.00 315.00 1 414.0 3.7 1 1.5SMC350A 1.5SMC350CA 350A 350C 300.00 332.00 368.00 1 482.0 3.2 1 1.5SMC400A 1.5SMC400CA 400A 400C 342.00 380.00 420.00 1 548.0 2.8 1 1.5SMC440A 1.5SMC440CA 440A 440C 376.00 418.00 462.00 1 602.0 2.5 1 1.5SMC480A 1.5SMC480CA 480A 480C 408.00 456.00 504.00 1 658.0 2.3 1 1.5SMC510A 1.5SMC510CA 510A 510C 434.00 485.00 535.00 1 698.0 2.1 1 1.5SMC530A 1.5SMC530CA 530A 530C 477.00 503.50 556.50 1 725.0 2.1 1 1.5SMC540A 1.5SMC540CA 540A 540C 486.00 513.00 567.00 1 740.0 2.0 1 1.5SMC550A 1.5SMC550CA 550A 550C 495.00 522.50 577.50 1 760.0 2.0 1 Rev. 7c Transient Voltage Suppressors DO-214AB/SMC Package 1.5SMC Series RATING AND CHARACTERISTIC CURVES Figure 1. Peak Pulse Power Rating Curve Figure 3. Pulse Waveform Figure 5. Steady Power Dissipation Derating Curve Figure 2. Pulse Derating Curve Figure 4. Tyoical Junctino Capacitance Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Rev. 7c Transient Voltage Suppressors DO-214AB/SMC Package 1.5SMC Series PACKAGING SPECIFICATION Tape Symbol Dimension(mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1. 5±0.10 E 1.75±0.10 F 7.50±0.10 A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 Quantity 500PCS Reel Symbol Dimension(mm) D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity 3000PCS RECOMMENDED SOLDERING PROFILES Reflow Condition Pre Heat Temp. Min Ts(min) 150°C Tempe. Max Ts(max) 200°C Time (min. to max.) (ts) 60-180 seconds Average ramp up rate (Liquidus Temperature) (T A) to peak 3°C/second max. Ts(max) to T A (Ramp-up rate) 3°C/second max. Reflow Temp. (T A) (Liquidus) Time (min. to max.) (ts) 217°C 60-150 seconds +/-0.5 Peak Temperature (T P) Time within 5°C of actual peak Temperature (tp) Ramp-down Rate 260 Time 25°C to peak Temp. (TP) 8 minutes max. °C 20-40 seconds 6°C/second max. Rev. 7c
1.5SMC30CA 价格&库存
很抱歉,暂时无法提供与“1.5SMC30CA”相匹配的价格&库存,您可以联系我们找货
