5.0SMDJ36CA
5.0SMDJ36CA
    MERITEK
    SMC(DO-214AB)
    TVS 36V截止 86.1A峰值脉冲
5.0SMDJ36CA 数据手册
Transient Voltage Suppressors DO-214AB/SMC Package 5.0SMDJ Series FEATURE  Peak Power Dissipation: 5000W  Fast response time. IR less than 2μA above 22V. Duty cycle: 0.01%  Excellent clamping capability, Low inductance, Bukt-in strain relief  Glass passivated junction  High Temperature soldering: 260°C, 10 seconds  Flammability Classification 94V-O.  UL/cUL safety approved: certification No: E223045 MAXIMUM RATINGS AND CHARACTERISTICS Parameter Symbol Value Unit PPPM Minimum 5000 Watts IPPM See Table Amps Steady State Power Dissipation at TL =75°C,Lead length .375” (9.5mm). (Fig. 5) PM(AV) 6.5 Watts Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load IFSM 300 Amps TJ , TSTG -65 to +150 °C Peak Pulse Power Dissipation on 10/1000μs waveform. (Note 1,Fig. 1) Peak Pulse Current on 10/1000μs waveform. (Note 1,Fig. 3) Operating junction and Storage Temperature Range. Ratings at 25℃ ambient temperature unless otherwise specified. 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°Cper Fig. 2 . 2. Mounted on 8.0mm x 8.0mm Copper Pads to each terminal. 3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minute maximum. DIMENSIONS SMC/DO-214AB (mm) Item Min. Max. L 6.60 7.11 D 5.59 6.22 D1 2.90 3.20 T 7.75 8.13 T1 0.76 1.52 d - 0.203 s 2.06 2.62 t 0.152 0.305 SPECIFICATIONS Part Number Device Marking Code Reverse StandOff Voltage Breakdown Voltage Min.@IT Breakdown Voltage Max.@IT Test Current Maximum Clamping Voltage @IPP Peak Pulse Current Reverse Leakage @VRWM Uni-Polar Bi-Polar Uni Bi VRWM (V) VBR MIN.(V) VBR MAX.(V) IT(mA) VC(V) IPP(A) IR (µA) 5.0SMDJ11A 5.0SMDJ11CA 5PEN 5BEN 11.0 12.20 13.50 10 18.2 275.00 800 5.0SMDJ12A 5.0SMDJ12CA 5PEP 5BEP 12.0 13.30 14.70 10 19.9 252.00 800 5.0SMDJ13A 5.0SMDJ13CA 5PEQ 5BEQ 13.0 14.40 15.90 10 21.5 233.00 500 5.0SMDJ14A 5.0SMDJ14CA 5PER 5BER 14.0 15.60 17.20 10 23.2 216.00 200 5.0SMDJ15A 5.0SMDJ15CA 5PES 5BES 15.0 16.70 18.50 1 24.4 205.00 100 5.0SMDJ16A 5.0SMDJ16CA 5PET 5BET 16.0 17.80 19.70 1 26.0 193.00 50 5.0SMDJ17A 5.0SMDJ17CA 5PEU 5BEU 17.0 18.90 20.90 1 27.6 181.00 20 5.0SMDJ18A 5.0SMDJ18CA 5PEV 5BEV 18.0 20.00 22.10 1 29.2 172.00 10 5.0SMDJ20A 5.0SMDJ20CA 5PEW 5BEW 20.0 22.20 24.50 1 32.4 155.00 5 Rev. 7c Transient Voltage Suppressors DO-214AB/SMC Package 5.0SMDJ Series SPECIFICATIONS(CONTINUED) Uni-Polar Bi-Polar Uni Bi Reverse StandOff Voltage VRWM (V) 5.0SMDJ22A 5.0SMDJ22CA 5PEX 5BEX 22.0 24.40 26.90 1 35.5 141.00 5 5.0SMDJ24A 5.0SMDJ24CA 5PEZ 5BEZ 24.0 26.70 29.50 1 38.9 129.00 5 5.0SMDJ26A 5.0SMDJ26CA 5PFE 5BFE 26.0 28.90 31.90 1 42.1 119.00 5 5.0SMDJ28A 5.0SMDJ28CA 5PFG 5BFG 28.0 31.10 34.40 1 45.4 110.00 5 5.0SMDJ30A 5.0SMDJ30CA 5PFK 5BFK 30.0 33.30 36.80 1 48.4 103.00 5 5.0SMDJ33A 5.0SMDJ33CA 5PFM 5BFM 33.0 36.70 40.60 1 53.3 93.90 5 5.0SMDJ36A 5.0SMDJ36CA 5PFP 5BFP 36.0 40.00 44.20 1 58.1 86.10 5 5.0SMDJ40A 5.0SMDJ40CA 5PFR 5BFR 40.0 44.40 49.10 1 64.5 77.60 5 5.0SMDJ43A 5.0SMDJ43CA 5PFT 5BFT 43.0 47.80 52.80 1 69.4 72.10 5 5.0SMDJ45A 5.0SMDJ45CA 5PFV 5BFV 45.0 50.00 55.30 1 72.7 68.80 5 5.0SMDJ48A --- 5PFX --- 48.0 53.30 58.90 1 77.4 64.70 5 5.0SMDJ51A --- 5PFZ --- 51.0 56.70 62.70 1 82.4 60.70 5 5.0SMDJ54A --- 5RGE --- 54.0 60.00 66.30 1 87.1 57.50 5 5.0SMDJ58A --- 5PGG --- 58.0 64.40 71.20 1 93.6 53.50 5 5.0SMDJ60A --- 5PGK --- 60.0 66.70 73.70 1 96.8 51.70 5 5.0SMDJ64A --- 5PGM --- 64.0 71.10 78.60 1 103.0 48.60 5 5.0SMDJ70A --- 5PGP --- 70.0 77.80 86.00 1 113.0 44.30 5 5.0SMDJ75A --- 5PGR --- 75.0 83.30 92.10 1 121.0 41.40 5 5.0SMDJ78A --- 5PGT --- 78.0 86.70 95.80 1 126.0 39.70 5 5.0SMDJ85A --- 5PGV --- 85.0 94.40 104.00 1 137.0 36.50 5 5.0SMDJ90A --- 5PGX --- 90.0 100.00 111.00 1 146.0 34.30 5 5.0SMDJ100A --- 5PGZ --- 100.0 111.00 123.00 1 162.0 30.90 5 5.0SMDJ110A --- 5PHE --- 110.0 122.00 135.00 1 177.0 28.30 5 5.0SMDJ120A --- 5PHG --- 120.0 133.00 147.00 1 193.0 26.00 5 5.0SMDJ130A --- 5PHK --- 130.0 144.00 159.00 1 209.0 24.00 5 5.0SMDJ150A --- 5PHM --- 150.0 167.00 185.00 1 243.0 20.60 5 5.0SMDJ160A --- 5PHP --- 160.0 178.00 197.00 1 259.0 19.30 5 5.0SMDJ170A --- 5PHR --- 170.0 189.00 209.00 1 275.0 18.20 5 Device Marking Code Part Number Breakdown Voltage Min.@IT Breakdown Voltage Max.@IT Test Current VBR MIN.(V) VBR MAX.(V) IT(mA) Maximum Clamping Voltage @IPP VC(V) Peak Pulse Current Reverse Leakage @VRWM IPP(A) IR (µA) Rev. 7c Transient Voltage Suppressors DO-214AB/SMC Package 5.0SMDJ Series RATING AND CHARACTERISTIC CURVES Figure 1. Peak Pulse Power Rating Curve Figure 3. Pulse Waveform Figure 5. Steady Power Dissipation Derating Curve Figure 2. Pulse Derating Curve Figure 4. Tyoical Junctino Capacitance Figure 6. Maximum Non-Repetitive Forward Surge Current Uni-Directional Only Rev. 7c Transient Voltage Suppressors DO-214AB/SMC Package 5.0SMDJ Series PACKAGING SPECIFICATION Tape Symbol Dimension(mm) W 16.00±0.20 P0 4.00±0.10 P1 8.00±0.10 P2 2.00±0.10 D0 Φ1.5±0.10 D1 Φ1. 5±0.10 E 1.75±0.10 F 7.50±0.10 A0 6.27±0.10 B0 8.30±0.10 K0 3.15±0.15 T 0.30±0.05 D2 Φ178.0±2.0 D3 Φ50.0Min. D4 Φ13.0±0.5 W1 20.0±2.0 Quantity 500PCS Reel Symbol Dimension(mm) D5 Φ330.0±2.0 D6 Φ13.5±0.5 H 2.5±1.0 W2 20.0±2.0 Quantity 3000PCS RECOMMENDED SOLDERING PROFILES Reflow Condition Pre Heat Temp. Min Ts(min) 150°C Tempe. Max Ts(max) 200°C Time (min. to max.) (ts) 60-180 seconds Average ramp up rate (Liquidus Temperature) (T A) to peak 3°C/second max. Ts(max) to T A (Ramp-up rate) 3°C/second max. Reflow Temp. (T A) (Liquidus) Time (min. to max.) (ts) 217°C 60-150 seconds +/-0.5 Peak Temperature (T P) Time within 5°C of actual peak Temperature (tp) Ramp-down Rate 260 Time 25°C to peak Temp. (TP) 8 minutes max. °C 20-40 seconds 6°C/second max. Rev. 7c
5.0SMDJ36CA 价格&库存
很抱歉,暂时无法提供与“5.0SMDJ36CA”相匹配的价格&库存,您可以联系我们找货
