Transient Voltage Suppressors
DO-214AB/SMC Package
5.0SMDJ Series
FEATURE
Peak Power Dissipation: 5000W
Fast response time. IR less than 2μA above 22V. Duty cycle: 0.01%
Excellent clamping capability, Low inductance, Bukt-in strain relief
Glass passivated junction
High Temperature soldering: 260°C, 10 seconds
Flammability Classification 94V-O.
UL/cUL safety approved: certification No: E223045
MAXIMUM RATINGS AND CHARACTERISTICS
Parameter
Symbol
Value
Unit
PPPM
Minimum 5000
Watts
IPPM
See Table
Amps
Steady State Power Dissipation at TL =75°C,Lead length .375” (9.5mm). (Fig. 5)
PM(AV)
6.5
Watts
Peak Forward Surge Current, 8.3ms Single Half Sine-wave Superimposed on Rated Load
IFSM
300
Amps
TJ , TSTG
-65 to +150
°C
Peak Pulse Power Dissipation on 10/1000μs waveform. (Note 1,Fig. 1)
Peak Pulse Current on 10/1000μs waveform. (Note 1,Fig. 3)
Operating junction and Storage Temperature Range.
Ratings at 25℃ ambient temperature unless otherwise specified.
1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25°Cper Fig. 2 .
2. Mounted on 8.0mm x 8.0mm Copper Pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minute maximum.
DIMENSIONS
SMC/DO-214AB (mm)
Item
Min.
Max.
L
6.60
7.11
D
5.59
6.22
D1
2.90
3.20
T
7.75
8.13
T1
0.76
1.52
d
0.203
s
2.06
2.62
t
0.152
0.305
SPECIFICATIONS
Part Number
Device
Marking
Code
Reverse
StandOff
Voltage
Breakdown
Voltage
Min.@IT
Breakdown
Voltage
Max.@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Uni-Polar
Bi-Polar
Uni
Bi
VRWM (V)
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
VC(V)
IPP(A)
IR (µA)
5.0SMDJ11A
5.0SMDJ11CA
5PEN
5BEN
11.0
12.20
13.50
10
18.2
275.00
800
5.0SMDJ12A
5.0SMDJ12CA
5PEP
5BEP
12.0
13.30
14.70
10
19.9
252.00
800
5.0SMDJ13A
5.0SMDJ13CA
5PEQ
5BEQ
13.0
14.40
15.90
10
21.5
233.00
500
5.0SMDJ14A
5.0SMDJ14CA
5PER
5BER
14.0
15.60
17.20
10
23.2
216.00
200
5.0SMDJ15A
5.0SMDJ15CA
5PES
5BES
15.0
16.70
18.50
1
24.4
205.00
100
5.0SMDJ16A
5.0SMDJ16CA
5PET
5BET
16.0
17.80
19.70
1
26.0
193.00
50
5.0SMDJ17A
5.0SMDJ17CA
5PEU
5BEU
17.0
18.90
20.90
1
27.6
181.00
5.0SMDJ18A
5.0SMDJ18CA
5PEV
5BEV
18.0
20.00
22.10
1
29.2
172.00
10
5.0SMDJ20A
5.0SMDJ20CA
5PEW
5BEW
20.0
22.20
24.50
1
32.4
155.00
5
Rev. 7c
5.0SMDJ Series
SPECIFICATIONS(CONTINUED)
Uni-Polar
Bi-Polar
Uni
Bi
Reverse
StandOff
Voltage
VRWM (V)
5.0SMDJ22A
5.0SMDJ22CA
5PEX
5BEX
22.0
24.40
26.90
1
35.5
141.00
5
5.0SMDJ24A
5.0SMDJ24CA
5PEZ
5BEZ
24.0
26.70
29.50
1
38.9
129.00
5
5.0SMDJ26A
5.0SMDJ26CA
5PFE
5BFE
26.0
28.90
31.90
1
42.1
119.00
5
5.0SMDJ28A
5.0SMDJ28CA
5PFG
5BFG
28.0
31.10
34.40
1
45.4
110.00
5
5.0SMDJ30A
5.0SMDJ30CA
5PFK
5BFK
30.0
33.30
36.80
1
48.4
103.00
5
5.0SMDJ33A
5.0SMDJ33CA
5PFM
5BFM
33.0
36.70
40.60
1
53.3
93.90
5
5.0SMDJ36A
5.0SMDJ36CA
5PFP
5BFP
36.0
40.00
44.20
1
58.1
86.10
5
5.0SMDJ40A
5.0SMDJ40CA
5PFR
5BFR
40.0
44.40
49.10
1
64.5
77.60
5
5.0SMDJ43A
5.0SMDJ43CA
5PFT
5BFT
43.0
47.80
52.80
1
69.4
72.10
5
5.0SMDJ45A
5.0SMDJ45CA
5PFV
5BFV
45.0
50.00
55.30
1
72.7
68.80
5
5.0SMDJ48A
5PFX
48.0
53.30
58.90
1
77.4
64.70
5
5.0SMDJ51A
5PFZ
51.0
56.70
62.70
1
82.4
60.70
5
5.0SMDJ54A
5RGE
54.0
60.00
66.30
1
87.1
57.50
5
5.0SMDJ58A
5PGG
58.0
64.40
71.20
1
93.6
53.50
5
5.0SMDJ60A
5PGK
60.0
66.70
73.70
1
96.8
51.70
5
5.0SMDJ64A
5PGM
64.0
71.10
78.60
1
103.0
48.60
5
5.0SMDJ70A
5PGP
70.0
77.80
86.00
1
113.0
44.30
5
5.0SMDJ75A
5PGR
75.0
83.30
92.10
1
121.0
41.40
5
5.0SMDJ78A
5PGT
78.0
86.70
95.80
1
126.0
39.70
5
5.0SMDJ85A
5PGV
85.0
94.40
104.00
1
137.0
36.50
5
5.0SMDJ90A
5PGX
90.0
100.00
111.00
1
146.0
34.30
5
5.0SMDJ100A
5PGZ
100.0
111.00
123.00
1
162.0
30.90
5
5.0SMDJ110A
5PHE
110.0
122.00
135.00
1
177.0
28.30
5
5.0SMDJ120A
5PHG
120.0
133.00
147.00
1
193.0
26.00
5
5.0SMDJ130A
5PHK
130.0
144.00
159.00
1
209.0
24.00
5
5.0SMDJ150A
5PHM
150.0
167.00
185.00
1
243.0
20.60
5
5.0SMDJ160A
5PHP
160.0
178.00
197.00
1
259.0
19.30
5
5.0SMDJ170A
5PHR
170.0
189.00
209.00
1
275.0
18.20
5
Device
Marking
Code
Part Number
Breakdown
Voltage
Min.@IT
Breakdown
Voltage
Max.@IT
Test
Current
VBR MIN.(V)
VBR MAX.(V)
IT(mA)
Maximum
Clamping
Voltage
@IPP
VC(V)
Peak
Pulse
Current
Reverse
Leakage
@VRWM
IPP(A)
IR (µA)
Rev. 7c
5.0SMDJ Series
RATING AND CHARACTERISTIC CURVES
Figure 1. Peak Pulse Power Rating Curve
Figure 3. Pulse Waveform
Figure 5. Steady Power Dissipation Derating Curve
Figure 2. Pulse Derating Curve
Figure 4. Tyoical Junctino Capacitance
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
Rev. 7c
5.0SMDJ Series
PACKAGING SPECIFICATION
Tape
Symbol
Dimension(mm)
W
16.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.5±0.10
D1
Φ1. 5±0.10
E
1.75±0.10
F
7.50±0.10
A0
6.27±0.10
B0
8.30±0.10
K0
3.15±0.15
T
0.30±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
20.0±2.0
Quantity
500PCS
Reel
Symbol
Dimension(mm)
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
20.0±2.0
Quantity
3000PCS
RECOMMENDED SOLDERING PROFILES
Reflow Condition
Pre
Heat
Temp. Min Ts(min)
150°C
Tempe. Max Ts(max)
200°C
Time (min. to max.) (ts)
60-180 seconds
Average ramp up rate (Liquidus
Temperature) (T A) to peak
3°C/second max.
Ts(max) to T A (Ramp-up rate)
3°C/second max.
Reflow
Temp. (T A) (Liquidus)
217°C
60-150 seconds
+/-0.5
Peak Temperature (T P)
Time within 5°C of actual peak
Temperature (tp)
Ramp-down Rate
260
Time 25°C to peak Temp. (TP)
8 minutes max.
°C
20-40 seconds
6°C/second max.
Rev. 7c
很抱歉,暂时无法提供与“5.0SMDJ100A”相匹配的价格&库存,您可以联系我们找货
