SMDJ10A – SMDJ100A
Taiwan Semiconductor
3000W, 10V - 100V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated chip junction
Excellent clamping capability
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Fast response time: Typically less than 1.0ps
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
10 - 100
V
VBR
11.1 - 123
V
PPK
3000
W
TJ MAX
175
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
● Immunization of sensitive devices in telecommunications,
consumer electronics, and industrial equipment from
electrostatic discharge (ESD) and transient voltages induced by
load switching and lightning.
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.290g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PPK
3000
W
PD
6.5
W
IFSM
300
A
VF
3.5 / 5.0
V
Junction temperature
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
Peak power dissipation at TA = 25°C, tp = 1ms
(1)
Steady state power dissipation at TA = 25°C
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
(2)
Forward Voltage @ IF = 100A for Unidirectional only
Notes:
1. Non-repetitive current pulse per Fig.5 and derated above TA = 25°C per Fig.2
2. VF = 3.5V on SMDJ10A - SMDJ90A devices and VF = 5.0V on SMDJ100A
Devices for bipolar applications
1. For bidirectional use CA suffix for SMDJ10A – SMDJ64A
2. Electrical characteristics apply in both directions
1
Version: I2104
SMDJ10A – SMDJ100A
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
Junction-to-lead thermal resistance
RӨJL
15
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
Breakdown
Test
voltage
Marking code
current
VBR@IT
IT
(V)
(mA)
Uni
Bi
Uni
Bi
Min
Max
SMDJ10A
SMDJ11A
SMDJ12A
SMDJ13A
SMDJ14A
SMDJ15A
SMDJ16A
SMDJ17A
SMDJ18A
SMDJ20A
SMDJ22A
SMDJ24A
SMDJ26A
SMDJ28A
SMDJ30A
SMDJ33A
SMDJ36A
SMDJ40A
SMDJ43A
SMDJ45A
SMDJ48A
SMDJ51A
SMDJ54A
SMDJ58A
SMDJ60A
SMDJ64A
SMDJ70A
SMDJ75A
SMDJ78A
SMDJ85A
SMDJ90A
SMDJ100A
SMDJ10CA
SMDJ11CA
SMDJ12CA
SMDJ13CA
SMDJ14CA
SMDJ15CA
SMDJ16CA
SMDJ17CA
SMDJ18CA
SMDJ20CA
SMDJ22CA
SMDJ24CA
SMDJ26CA
SMDJ28CA
SMDJ30CA
SMDJ33CA
SMDJ36CA
SMDJ40CA
SMDJ43CA
SMDJ45CA
SMDJ48CA
SMDJ51CA
SMDJ54CA
SMDJ58CA
SMDJ60CA
SMDJ64CA
PDX
PDZ
PEE
PEG
PEK
PEM
PEP
PER
PET
PEV
PEX
PEZ
PFE
PFG
PFK
PFM
PFP
PFR
PFT
PFV
PFX
PFZ
PGE
PGG
PGK
PGM
PGP
PGR
PGT
PGV
PGX
PGZ
DDX
DDZ
DEE
DEG
DEK
DEM
DEP
DER
DET
DEV
DEX
DEZ
DFE
DFG
DFK
DFM
DFP
DFR
DFT
DFV
DFX
DFZ
DGE
DGG
DGK
DGM
11.1
12.2
13.3
14.4
15.6
16.7
17.8
18.9
20.0
22.2
24.4
26.7
28.9
31.1
33.3
36.7
40.0
44.4
47.8
50.0
53.3
56.7
60.0
64.4
66.7
71.1
77.8
83.3
86.7
94.4
100
111
12.3
13.5
14.7
15.9
17.2
18.5
19.7
20.9
22.1
24.5
26.9
29.5
31.9
34.4
36.8
40.6
44.2
49.1
52.8
55.3
58.9
62.7
66.3
71.2
73.7
78.6
86.0
92.1
95.8
104
111
123
Working
stand-off
voltage
VWM
(V)
Maximum
Reverse
Leakage
IR@VWM
(µA)
10
11
12
13
14
15
16
17
18
24
26
28
30
33
36
40
43
45
48
51
54
58
60
64
70
75
78
85
90
100
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum
Maximum
peak impulse clamping
current
voltage
IPPM
VC@IPPM
(A)
(V)
176.5
164.8
150.8
139.5
129.3
123.0
115.4
108.7
102.7
92.6
84.5
77.1
71.3
66.1
62.0
56.3
51.6
46.5
43.2
41.3
38.8
36.4
34.4
32.1
31.0
29.1
26.5
24.8
23.8
21.9
20.5
18.5
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103
113
121
126
137
146
162
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SMDJx
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 10V(SMDJ10A) to 100V(SMDJ100A)
“x” defines voltage from 10V(SMDJ10CA) to 64V(SMDJ64CA)
2
Version: I2104
SMDJ10A – SMDJ100A
CHARACTERISTICS CURVES
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
PEAK PULSE POWER(PPP) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
PPPM, PEAK PULSE POWER (kW)
100
Non-repetitive
pulse waveform
shown in Fig.5
10
1
0.1
0.001
0.01
0.1
1
100
75
50
25
25
50
75
100
125
150
175
tp, PULSE WIDTH, (ms)
TA, AMBIENT TEMPERATURE (°C)
Fig.3 Typical Junction Capacitance
Fig.4 Maximum Non-repetitive Forward Surge
Current
IFSM, PEAK FORWARD SURGE CURRENT (A)
10000
CJ, JUNCTION CAPACITANCE (pF)
125
VR=0
1000
100
VR-rated
stand-off voltage
f=1.0MHz
Vsig=50mVp-p
10
10
100
350
8.3ms single half sine wave
Unidirectional only
300
250
200
150
100
50
V(BR), BREAKDOWN VOLTAGE (V)
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: I2104
SMDJ10A – SMDJ100A
Fig.5 Clamping Power Pulse Waveform
120
IPPM, PEAK PULSE CURRENT (%)
110
Peak value
IPPM
100
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
90
Rise time tr=10μs to 100% of IPPM
80
70
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
50
40
30
td
10
1
1.5
2
2.5
3
3.5
4
4.5
5
t, TIME (ms)
4
Version: I2104
SMDJ10A – SMDJ100A
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
5
Version: I2104
SMDJ10A – SMDJ100A
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for
application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
6
Version: I2104
很抱歉,暂时无法提供与“SMDJ43CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.72809
- 5+6.92980
- 23+5.18886
- 62+4.90012
- 3000+4.74725
- 6000+4.71328
- 国内价格 香港价格
- 1+8.299031+1.02830
- 5+7.441775+0.92208
- 25+6.5662725+0.81360
- 100+5.90052100+0.73111
- 500+5.50837500+0.68252
- 3000+5.107103000+0.63280
- 6000+5.070626000+0.62828
- 国内价格 香港价格
- 3000+2.239603000+0.27750
- 6000+2.194816000+0.27195
- 9000+2.184519000+0.27068
- 12000+2.1500212000+0.26640
- 15000+2.1398315000+0.26514
