SMDJ26CA
SMDJ26CA
    TAIWANSEMICONDUCTOR(台湾半导体)
    SMC(DO-214AB)
    TVS 26V截止 71.3A峰值脉冲
SMDJ26CA 数据手册
SMDJ10A – SMDJ100A Taiwan Semiconductor 3000W, 10V - 100V Surface Mount Transient Voltage Suppressor FEATURES ● ● ● ● ● ● ● ● KEY PARAMETERS Ideal for automated placement Glass passivated chip junction Excellent clamping capability Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b) Fast response time: Typically less than 1.0ps Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VWM 10 - 100 V VBR 11.1 - 123 V PPK 3000 W TJ MAX 175 °C Package DO-214AB (SMC) Configuration Single die APPLICATIONS ● Immunization of sensitive devices in telecommunications, consumer electronics, and industrial equipment from electrostatic discharge (ESD) and transient voltages induced by load switching and lightning. MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AB (SMC) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: As marked Weight: 0.290g (approximately) DO-214AB (SMC) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT PPK 3000 W PD 6.5 W IFSM 300 A VF 3.5 / 5.0 V Junction temperature TJ -55 to +175 °C Storage temperature TSTG -55 to +175 °C Peak power dissipation at TA = 25°C, tp = 1ms (1) Steady state power dissipation at TA = 25°C Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load (2) Forward Voltage @ IF = 100A for Unidirectional only Notes: 1. Non-repetitive current pulse per Fig.5 and derated above TA = 25°C per Fig.2 2. VF = 3.5V on SMDJ10A - SMDJ90A devices and VF = 5.0V on SMDJ100A Devices for bipolar applications 1. For bidirectional use CA suffix for SMDJ10A – SMDJ64A 2. Electrical characteristics apply in both directions 1 Version: I2104 SMDJ10A – SMDJ100A Taiwan Semiconductor THERMAL PERFORMANCE PARAMETER SYMBOL TYP UNIT Junction-to-ambient thermal resistance RӨJA 75 °C/W Junction-to-lead thermal resistance RӨJL 15 °C/W ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Part number Breakdown Test voltage Marking code current VBR@IT IT (V) (mA) Uni Bi Uni Bi Min Max SMDJ10A SMDJ11A SMDJ12A SMDJ13A SMDJ14A SMDJ15A SMDJ16A SMDJ17A SMDJ18A SMDJ20A SMDJ22A SMDJ24A SMDJ26A SMDJ28A SMDJ30A SMDJ33A SMDJ36A SMDJ40A SMDJ43A SMDJ45A SMDJ48A SMDJ51A SMDJ54A SMDJ58A SMDJ60A SMDJ64A SMDJ70A SMDJ75A SMDJ78A SMDJ85A SMDJ90A SMDJ100A SMDJ10CA SMDJ11CA SMDJ12CA SMDJ13CA SMDJ14CA SMDJ15CA SMDJ16CA SMDJ17CA SMDJ18CA SMDJ20CA SMDJ22CA SMDJ24CA SMDJ26CA SMDJ28CA SMDJ30CA SMDJ33CA SMDJ36CA SMDJ40CA SMDJ43CA SMDJ45CA SMDJ48CA SMDJ51CA SMDJ54CA SMDJ58CA SMDJ60CA SMDJ64CA PDX PDZ PEE PEG PEK PEM PEP PER PET PEV PEX PEZ PFE PFG PFK PFM PFP PFR PFT PFV PFX PFZ PGE PGG PGK PGM PGP PGR PGT PGV PGX PGZ DDX DDZ DEE DEG DEK DEM DEP DER DET DEV DEX DEZ DFE DFG DFK DFM DFP DFR DFT DFV DFX DFZ DGE DGG DGK DGM 11.1 12.2 13.3 14.4 15.6 16.7 17.8 18.9 20.0 22.2 24.4 26.7 28.9 31.1 33.3 36.7 40.0 44.4 47.8 50.0 53.3 56.7 60.0 64.4 66.7 71.1 77.8 83.3 86.7 94.4 100 111 12.3 13.5 14.7 15.9 17.2 18.5 19.7 20.9 22.1 24.5 26.9 29.5 31.9 34.4 36.8 40.6 44.2 49.1 52.8 55.3 58.9 62.7 66.3 71.2 73.7 78.6 86.0 92.1 95.8 104 111 123 Working stand-off voltage VWM (V) Maximum Reverse Leakage IR@VWM (µA) 10 11 12 13 14 15 16 17 18 20 22 24 26 28 30 33 36 40 43 45 48 51 54 58 60 64 70 75 78 85 90 100 5 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 Maximum Maximum peak impulse clamping current voltage IPPM VC@IPPM (A) (V) 176.5 164.8 150.8 139.5 129.3 123.0 115.4 108.7 102.7 92.6 84.5 77.1 71.3 66.1 62.0 56.3 51.6 46.5 43.2 41.3 38.8 36.4 34.4 32.1 31.0 29.1 26.5 24.8 23.8 21.9 20.5 18.5 17.0 18.2 19.9 21.5 23.2 24.4 26.0 27.6 29.2 32.4 35.5 38.9 42.1 45.4 48.4 53.3 58.1 64.5 69.4 72.7 77.4 82.4 87.1 93.6 96.8 103 113 121 126 137 146 162 ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING SMDJx DO-214AB (SMC) 3,000 / Tape & Reel Notes: 1. “x” defines voltage from 10V(SMDJ10A) to 100V(SMDJ100A) “x” defines voltage from 10V(SMDJ10CA) to 64V(SMDJ64CA) 2 Version: I2104 SMDJ10A – SMDJ100A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Peak Pulse Power Rating Curve Fig.2 Pulse Derating Curve PEAK PULSE POWER(PPP) OR CURRENT (IPP) DERATING IN PERCENTAGE (%) PPPM, PEAK PULSE POWER (kW) 100 Non-repetitive pulse waveform shown in Fig.5 10 1 0.1 0.001 0.01 0.1 1 100 75 50 25 0 0 10 25 50 75 100 125 150 175 tp, PULSE WIDTH, (ms) TA, AMBIENT TEMPERATURE (°C) Fig.3 Typical Junction Capacitance Fig.4 Maximum Non-repetitive Forward Surge Current IFSM, PEAK FORWARD SURGE CURRENT (A) 10000 CJ, JUNCTION CAPACITANCE (pF) 125 VR=0 1000 100 VR-rated stand-off voltage f=1.0MHz Vsig=50mVp-p 10 10 100 350 8.3ms single half sine wave Unidirectional only 300 250 200 150 100 50 0 1 V(BR), BREAKDOWN VOLTAGE (V) 10 100 NUMBER OF CYCLES AT 60 Hz 3 Version: I2104 SMDJ10A – SMDJ100A Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.5 Clamping Power Pulse Waveform 120 IPPM, PEAK PULSE CURRENT (%) 110 Peak value IPPM 100 Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 90 Rise time tr=10μs to 100% of IPPM 80 70 Half value-IPPM/2 10/1000μs, waveform as defined by R.E.A. 60 50 40 30 20 td 10 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 t, TIME (ms) 4 Version: I2104 SMDJ10A – SMDJ100A Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AB (SMC) SUGGESTED PAD LAYOUT MARKING DIAGRAM P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Cathode band for uni-directional products only 5 Version: I2104 SMDJ10A – SMDJ100A Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: I2104
SMDJ26CA 价格&库存
很抱歉,暂时无法提供与“SMDJ26CA”相匹配的价格&库存,您可以联系我们找货
SMDJ26CA
  • 1+7.68885
  • 5+6.92841
  • 23+5.19631
  • 63+4.90903
  • 3000+4.75695
  • 6000+4.72315
SMDJ26CA
  • 1+8.645031+1.08028
  • 5+7.785955+0.97293
  • 25+6.8726225+0.85880
  • 100+6.17631100+0.77179
  • 500+5.76034500+0.71981
  • 3000+5.344373000+0.66783
  • 6000+5.145426000+0.64297
SMDJ26CA
    • 3000+2.220723000+0.27750
    • 6000+2.176316000+0.27195
    • 9000+2.166099000+0.27068
    • 12000+2.1318912000+0.26640
    • 15000+2.1217915000+0.26514
