SMDJ10AH – SMDJ100AH
Taiwan Semiconductor
3000W, 10V - 100V Surface Mount Transient Voltage Suppressor
FEATURES
KEY PARAMETERS
AEC-Q101 qualified
Ideal for automated placement
Glass passivated chip junction
Excellent clamping capability
Meets ISO 7637-2 (Pulse 1/2a/2b/3a/3b)
Fast response time: Typically less than 1.0ps
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VWM
10 - 100
V
VBR
11.1 - 123
V
PPK
3000
W
TJ MAX
175
°C
Package
DO-214AB (SMC)
Configuration
Single die
APPLICATIONS
● Immunization of sensitive devices in telecommunications,
consumer electronics, and industrial equipment from
electrostatic discharge (ESD) and transient voltages induced by
load switching and lightning.
MECHANICAL DATA
Case: DO-214AB (SMC)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: As marked
Weight: 0.290g (approximately)
DO-214AB (SMC)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
PPK
3000
W
PD
6.5
W
IFSM
300
A
VF
3.5 / 5.0
V
Junction temperature
TJ
-55 to +175
°C
Storage temperature
TSTG
-55 to +175
°C
Peak power dissipation at TA = 25°C, tp = 1ms
(1)
Steady state power dissipation at TA = 25°C
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load
(2)
Forward Voltage @ IF = 100A for Unidirectional only
Notes:
1. Non-repetitive current pulse per Fig.5 and derated above TA = 25°C per Fig.2
2. VF = 3.5V on SMDJ10AH - SMDJ90AH devices and VF = 5.0V on SMDJ100AH
Devices for bipolar applications
1. For bidirectional use CAH suffix for SMDJ10AH – SMDJ64AH
2. Electrical characteristics apply in both directions
1
Version: B2104
THERMAL PERFORMANCE
PARAMETER
SYMBOL
TYP
UNIT
Junction-to-ambient thermal resistance
RӨJA
75
°C/W
Junction-to-lead thermal resistance
RӨJL
15
°C/W
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
Part number
Uni
Bi
SMDJ10AH
SMDJ11AH
SMDJ12AH
SMDJ13AH
SMDJ14AH
SMDJ15AH
SMDJ16AH
SMDJ17AH
SMDJ18AH
SMDJ20AH
SMDJ22AH
SMDJ24AH
SMDJ26AH
SMDJ28AH
SMDJ30AH
SMDJ33AH
SMDJ36AH
SMDJ40AH
SMDJ43AH
SMDJ45AH
SMDJ48AH
SMDJ51AH
SMDJ54AH
SMDJ58AH
SMDJ60AH
SMDJ64AH
SMDJ70AH
SMDJ75AH
SMDJ78AH
SMDJ85AH
SMDJ90AH
SMDJ100AH
SMDJ10CAH
SMDJ11CAH
SMDJ12CAH
SMDJ13CAH
SMDJ14CAH
SMDJ15CAH
SMDJ16CAH
SMDJ17CAH
SMDJ18CAH
SMDJ20CAH
SMDJ22CAH
SMDJ24CAH
SMDJ26CAH
SMDJ28CAH
SMDJ30CAH
SMDJ33CAH
SMDJ36CAH
SMDJ40CAH
SMDJ43CAH
SMDJ45CAH
SMDJ48CAH
SMDJ51CAH
SMDJ54CAH
SMDJ58CAH
SMDJ60CAH
SMDJ64CAH
Marking
code
Breakdown
Test
voltage
current
VBR@IT
IT
(V)
(mA)
Uni
Bi
Min
Max
PDX
PDZ
PEE
PEG
PEK
PEM
PEP
PER
PET
PEV
PEX
PEZ
PFE
PFG
PFK
PFM
PFP
PFR
PFT
PFV
PFX
PFZ
PGE
PGG
PGK
PGM
PGP
PGR
PGT
PGV
PGX
PGZ
DDX
DDZ
DEE
DEG
DEK
DEM
DEP
DER
DET
DEV
DEX
DEZ
DFE
DFG
DFK
DFM
DFP
DFR
DFT
DFV
DFX
DFZ
DGE
DGG
DGK
DGM
11.1
12.2
13.3
14.4
15.6
16.7
17.8
18.9
20.0
22.2
24.4
26.7
28.9
31.1
33.3
36.7
40.0
44.4
47.8
50.0
53.3
56.7
60.0
64.4
66.7
71.1
77.8
83.3
86.7
94.4
100
111
12.3
13.5
14.7
15.9
17.2
18.5
19.7
20.9
22.1
24.5
26.9
29.5
31.9
34.4
36.8
40.6
44.2
49.1
52.8
55.3
58.9
62.7
66.3
71.2
73.7
78.6
86.0
92.1
95.8
104
111
123
Working
stand-off
voltage
VWM
(V)
Maximum
Reverse
Leakage
IR@VWM
(µA)
10
11
12
13
14
15
16
17
18
24
26
28
30
33
36
40
43
45
48
51
54
58
60
64
70
75
78
85
90
100
5
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
Maximum
Maximum
peak impulse clamping
current
voltage
IPPM
VC@IPPM
(A)
(V)
176.5
164.8
150.8
139.5
129.3
123.0
115.4
108.7
102.7
92.6
84.5
77.1
71.3
66.1
62.0
56.3
51.6
46.5
43.2
41.3
38.8
36.4
34.4
32.1
31.0
29.1
26.5
24.8
23.8
21.9
20.5
18.5
17.0
18.2
19.9
21.5
23.2
24.4
26.0
27.6
29.2
32.4
35.5
38.9
42.1
45.4
48.4
53.3
58.1
64.5
69.4
72.7
77.4
82.4
87.1
93.6
96.8
103
113
121
126
137
146
162
ORDERING INFORMATION
ORDERING CODE(1)
PACKAGE
PACKING
SMDJxH
DO-214AB (SMC)
3,000 / Tape & Reel
Notes:
1. “x” defines voltage from 10V(SMDJ10AH) to 100V(SMDJ100AH)
“x” defines voltage from 10V(SMDJ10CAH) to 64V(SMDJ64CAH)
2
Version: B2104
CHARACTERISTICS CURVES
Fig.2 Pulse Derating Curve
PEAK PULSE POWER(PPP) OR CURRENT (IPP)
DERATING IN PERCENTAGE (%)
Fig.1 Peak Pulse Power Rating Curve
PPPM, PEAK PULSE POWER, KW
100
Non-repetitive
pulse waveform
shown in fig.5
10
1
0.1
0.001
0.01
0.1
1
100
75
50
25
25
50
75
100
125
150
175
tp, PULSE WIDTH, (ms)
TA, AMBIENT TEMPERATURE (°C)
Fig.3 Typical Junction Capacitance
Fig.4 Maximum Non-repetitive Forward Surge
Current
IFSM, PEAK FORWARD SURGE CURRENT (A)
10000
CJ, JUNCTION CAPACITANCE (pF)
125
VR=0
1000
100
VR-rated
stand-off voltage
f=1.0MHz
Vsig=50mVp-p
10
10
100
350
8.3ms single half sine wave
Unidirectional only
300
250
200
150
100
50
V(BR), BREAKDOWN VOLTAGE (V)
10
100
NUMBER OF CYCLES AT 60 Hz
3
Version: B2104
Fig.5 Clamping Power Pulse Waveform
120
IPPM, PEAK PULSE CURRENT (%)
110
Peak value
IPPM
100
Pulse width(td) is defined
as the point where the peak
current decays to 50% of IPPM
90
Rise time tr=10μs to 100% of IPPM
80
70
Half value-IPPM/2
10/1000μs, waveform
as defined by R.E.A.
60
50
40
30
td
10
1
1.5
2
2.5
3
3.5
4
4.5
5
t, TIME (ms)
4
Version: B2104
PACKAGE OUTLINE DIMENSIONS
DO-214AB (SMC)
SUGGESTED PAD LAYOUT
MARKING DIAGRAM
P/N
= Marking Code
G
= Green Compound
YW
= Date Code
F
= Factory Code
Cathode band for uni-directional products only
5
Version: B2104
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for
application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to any
intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for
such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale
and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability,
or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers
using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for
any damages resulting from such improper use or sale.
6
Version: B2104
很抱歉,暂时无法提供与“SMDJ20CAH”相匹配的价格&库存,您可以联系我们找货
