IXFK94N50P2
http://www.osen.net.cn
500V N-CHANNEL MOSFET
Features:
Fast switching speed
开关速度快
High input impedance and low level drive
高输入阻抗和低电平驱动
Avalanche energy tested
雪崩能量测试
Improved dv/dt capability,high ruggedness
提高 dv/dt 能力,高耐用性
TO-264
Applications
High efficiency switch mode power supplies
高效率开关电源
Power factor correction
功率因数校正
Electronic lamp ballast
电子整流器
Publication Order Number:[IXFK94N50P2]
21.2.10
@OSEN*Rev
1
IXFK94N50P2
Absolute Maximum Ratings (Tc=25°C)
Symbol
VDSS
VGS
ID
IDM
PD
Tj
Parameters
Ratings
Unit
500
V
±30
V
漏极持续电流
94
A
Drain Current-Single Plused(Note 1)
漏极单次脉冲电流
240
A
1300
W
150
Drain-Source Voltage
漏源电压
Gate-Source Voltage-Continuous
栅源电压
Drain Current-Continuous(Note 2)
Power Dissipation (Note 2)
功率损耗
Max.Operating junction temperature
最大结温
Electrical characteristics (Tc=25°C unless otherwise noted)
Symbo
Parameters
l
Min
Typ
Max
Units
Conditions
500
V
3
5
V
VDS=VGS,ID=250uA
60
mΩ
VGS=10V,ID=47A
±100
nA
VGS=±30V,VDS=0
10
μA
VDS=500V,VGS=0
75
S
VDS=10V,ID=47A
Static Characteristics
Drain-Source Breakdown
BVDSS
VoltageCurrent (Note 1)
漏极击穿电压
VGS(th)
RDS(on)
IGSS
IDSS
gfs
Gate Threshold Voltage
栅极开启电压
Drain-Source On-Resistance
漏源导通电阻
Gate-Body Leakage Current
栅极漏电流
Zero Gate Voltage Drain Current
零栅极电压漏极电流
Forward Transconductance
正向跨导
21.2.10
ID=250uA,VGS=0V,
TJ=25°C
@OSEN*Rev
2
IXFK94N50P2
Switching Characteristics
Td(on)
Tr
Td(off)
Tf
Qg
Qgs
Qgd
Turn-On Delay Time
开启延迟时间
Rise Time
上升时间
Turn-Off Delay Time
关闭延迟时间
Fall Time
下降时间
Total Gate Charge
栅极总电荷
Gate-Source Charge
栅源极电荷
Gate-Drain Charge
栅漏极电荷
35
ns
15
ns
VDS=250V,
ID=47A,
75
ns
15
ns
230
nC
RG=1Ω(Note 2)
VDS=250V,
65
nC
80
nC
14
pF
VGS=10V,
ID=47A(Note 2)
Dynamic Characteristics
Ciss
Coss
Crss
IS
VSD
Rth(j-c)
Input Capacitance
输入电容
Output Capacitance
输出电容
Reverse Transfer Capacitance
反向传输电容
Continuous Drain-Source Diode
Forward Current(Note 2)
二极管导通正向持续电流
Diode Forward On-Voltage
二极管正向导通电压
Thermal Resistance, Junction to Case
结到外壳的热阻
VDS=25V,VGS=0,
1390
pF
33
pF
94
A
1.4
V
0.10
℃/W
f=1MHz
IS=94A,VGS=0
Note 1: Repetitive Rating : Pulse width limited by maximum junction temperature
Note 2: Pulse test: PW
很抱歉,暂时无法提供与“IXFK94N50P2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+42.62500
- 10+38.50000
- 50+35.20000
- 150+33.00000
- 300+31.62500
