FFC2B35-42-T
FFC2B35-42-T
    GCT
    SMD,P=0.5mm,卧贴
    FPC/FFC连接器 P=0.5mm 42Pin 翻盖式 卧贴
FFC2B35-42-T 数据手册
Dimensions No. of Contacts H * 54 *6 *7 *8 *9 * 10 * 11 * 12 * 13 * 14 * 15 * 16 * 17 * 18 * 19 * 20 * 21 * 22 * 23 24 * 25 * 26 * 27 * 28 * 29 * 30 31 * 32 * 33 * 34 * 35 * 36 * 37 * 38 * 39 * 40 41 * 42 * 43 1.30 B±0.05 1.00 0.50±0.05 1.50 0.30±0.05 A±0. 20 2.20 G 1.80 0.71 0.50±0.05 2.0 Recommended PCB Layout General Tolerance ±0.05 Solder Area Component Outline 92 . ef °r (B+1)±0.05 B±0.03 0.50±0.03 0.30±0.03 0.50±0.08 3.00±0.30 4.35 ref. E 6.76 2.20 1.00 0.20±0.03 1.01 4.5 ref. B±0.10 0.81 ref. D±0.10 F 0.30±0.03 D 6.00±0.50 Reinforcing Layer 0.10 44 * 45 * 46 47 C±0.05 48 49 * 50 51 * 52 * 53 54 * 55 * 56 57 58 59 60 C Specification: B Material: Housing: LCP, UL 94V-0, Natural Actuator: LCP, UL 94V-0, Black Contact: Phosphor Bronze Fitting Nail: Brass Plating: Contact: See Ordering Grid Fitting Nail: Matte Tin Mechanical & Environmental Durability: 30 Cycles Operating Temperature: -40°C to +85°C Solder Profile: Peak Temp 260°C (+0/-5°C) max. (5 seconds) A 1 Electrical: Voltage Rating (Max.): 50V AC/DC Current Rating (Max.): 0.4A AC/DC (60 contacts powered) 0.5A AC/DC (40 contacts powered) Dielectric Strength: 250V AC for 1 minute Insulation Resistance: 50 MΩ Min. Contact Resistance: Initial: 30 mΩ Max. Final: 50 mΩ Max. 2 3 4 Recommended FFC/FPC Dimensions Ordering Grid FFC2B35 XX No. of Contacts 04 - 60 (see dimension table) X Request Samples and Quotation Halogen Free Contact Plating G = Gold Flash over all (Standard) T = Tin Plating over all * Product Description FFC/FPC 0.5mm Pitch Side Entry, Bottom Contact, SMT, Height=2.0mm, Front Flip By Detail Revision Date 5 CC Drawing Release A3 25/04/23 Tolerances (Except as Noted) Length Angle X.X ± 0. 20 X.XX ± 0.10 X.° ± 1° Units: Metric (mm) C 3rd Angle Projection 6 B C D 1.50 2.60 3.50 2.00 3.10 4.00 2.50 3.60 4.50 3.00 4.10 5.00 3.50 4.60 5.50 4.00 5.10 6.00 4.50 5.60 6.50 5.00 6.10 7.00 5.50 6.60 7.50 6.00 7.10 8.00 6.50 7.60 8.50 7.00 8.10 9.00 7.50 8.60 9.50 8.00 9.10 10.00 8.50 9.60 10.50 9.00 10.10 11.00 9.50 10.60 11.50 10.00 11.10 12.00 10.50 11.60 12.50 11.00 12.10 13.00 11.50 12.60 13.50 12.00 13.10 14.00 12.50 13.60 14.50 13.00 14.10 15.00 13.50 14.60 15.50 14.00 15.10 16.00 14.50 15.60 16.50 15.00 16.10 17.00 15.50 16.60 17.50 16.00 17.10 18.00 16.50 17.60 18.50 17.00 18.10 19.00 17.50 18.60 19.50 18.00 19.10 20.00 18.50 19.60 20.50 19.00 20.10 21.00 19.50 20.60 21.50 20.00 21.10 22.00 20.50 21.60 22.50 21.00 22.10 23.00 21.50 22.60 23.50 22.00 23.10 24.00 22.50 23.60 24.50 23.00 24.10 25.00 23.50 24.60 25.50 24.00 25.10 26.00 24.50 25.60 26.50 25.00 26.10 27.00 25.50 26.60 27.50 26.00 27.10 28.00 26.50 27.60 28.50 27.00 28.10 29.00 27.50 28.60 29.50 28.00 29.10 30.00 28.50 29.60 30.50 29.00 30.10 31.00 29.50 30.60 31.50 * FFC2B35 11th June 2021 6.4 6.9 7.4 7.9 8.4 8.9 9.4 9.9 10.4 10.9 11.4 11.9 12.4 12.9 13.4 13.9 14.4 14.9 15.4 15.9 16.4 16.9 17.4 17.9 18.4 18.9 19.4 19.9 20.4 20.9 21.4 21.9 22.4 22.9 23.4 23.9 24.4 24.9 25.4 25.9 26.4 26.9 27.4 27.9 28.4 28.9 29.4 29.9 30.4 30.9 31.4 31.9 32.4 32.9 33.4 33.9 34.4 = Tooled Parts Please contact GCT for non-tooled parts Part Number Drawing Date A 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 1/2 Direction of Unreeling H Cover Tape Reel Peeling angle: 165°~180° Peeling strength: 0.3 ~ 0.9 N 165° ~180 ° Ø13 G Vacuum Bag Desiccant Ø330 Carrier Tape Void filler F W+4 Label Green Product Label Empty 36pcs E Empty 36pcs 2000pcs 12.0±0.1 4.0±0.1 2.0±0.1 Ø1.50+0.1 -0 C 1.75±0.10 S±0.1 W±0.3 D 300 Green Product Label Direction of Unreeling B 36 0 Label A No. of Contacts 4 ~ 19 20~ 31 32 ~ 49,51 50, 52 ~ 60 1 W S 24 32 44 56 N/A 28.4 40.4 52.4 0 36 Pcs/Reel Reel/Carton Pcs/Carton 2000 2000 2000 2000 2 10 8 6 4 20000 16000 12000 8000 3 Part Number Product Description FFC2B35 FFC/FPC 0.5mm Pitch Side Entry, Bottom Contact, SMT, Height=2.0mm, Front Flip Drawing Date 11th June 2021 By Detail 4 Revision Date 5 CC Drawing Release A3 25/04/23 Tolerances (Except as Noted) Length Angle - - Units: Metric (mm) C 3rd Angle Projection 6 7 This drawing is confidential and copyright of Global Connector Technology, Ltd (GCT). This drawing must not be copied or disclosed without written consent. E & OE www.gct.co Not to Scale Drawn By CC 8 Sheet No. 2/2
FFC2B35-42-T 价格&库存
很抱歉,暂时无法提供与“FFC2B35-42-T”相匹配的价格&库存,您可以联系我们找货
FFC2B35-42-T
    • 1+5.41080
    • 200+2.16000
    • 500+2.08440
    • 1000+2.05200
