深圳市御光视觉科技有限公司
SHENZHEN UCO VISION CO., LTD.
记录编号:072-220323
产 品 承 认 书
SPECIFICATIONS
品 名(Module Name)
: WDN01A-100
客户型号(Cust.P/N)
文档接受时间(Received)
DATE:2022 / 03 / 23
客 户 名 称
(Customer)
批
准
审
(Approved)
核
担
(Checked)
当
(In charge)
产品承认书 共 17 页
(These specifications are composed of 17 pages, including this title page.)
深圳市御光视觉科技有限公司
批
准
(Approved)
审
核
(Checked)
担
当
(In charge)
1
表单编号:QP-100-04-04-01
深圳市御光视觉科技有限公司
记录编号:072-220323
Revise History
Rev
Date
Description
Ver1.0
2022-03-23
First release
2
深圳市御光视觉科技有限公司
记录编号:072-220323
1. Scope
This approval sheet contains the general information of WDN01A-100 camera module
designed for SHENZHEN UCO VISION CO., LTD. It contains the key features of the module
as well as the information for the quality inspection and reliability test purposes.
2. Features
Back-illuminated and stacked CMOS image sensor “Exmor-RSTM”
Single Frame High Dynamic Range (HDR) with equivalent full pixels.
High signal to noise ratio (SNR).
Full resolution @30fps (Nornmal / HDR). 4K2K @30fps (Normal / HDR) 1080p
@60fps (Normal / HDR)
Output video format of RAW10/8, COMP8/6.
Pixel binning readout and H/V sub-sampling function.
Advanced Noise Reduction (Chroma noise reduction and luminance noise
reduction).
Independent flipping and mirroring.
CSI-2 serial data output (MIPI 2lane/4lane, Max. 1.2Gbps/lane, D-PHY spec.
ver. 1.1 compliant)
2-wire serial communication.
Two PLLs for independent clock generation for pixel control and data output
interface.
Advanced Noise Reduction.
Dynamic Defect Pixel Correction.
Zero shutter lag.
Power-on reset function
Dual sensor synchronization operation.
8K bit of OTP ROM for users.
Built-in temperature sensor
Applications
Cellular phones
Tablet PC
Others
3
深圳市御光视觉科技有限公司
记录编号:072-220323
3. General Description
3.1 Camera Module Specification
No.
1
2
3
4
Item
Sensor
Lens Size
Pixel array number
Power Supply
5
6
7
8
9
Sensor output formats
Sensor input clock frequency
Maximum frame rate
Sensor Pixel size
Image area
Specification
IMX214-0AQH5-C
1/3.06 inch
4208 (H) × 3120 (V)
Core = 1.0+0.15V/-0.1V;
Analog = 2.7+0.2V/-0.1V;
I/O = 1.8±0.1V
RAW10/8
6MHz - 27MHz
4208 (H)* 3120 (V) @30 frame/s
1.12μm (H) × 1.12μm (V)
Diagonal 5.867mm
3.2 Camera Lens Specification
No.
1
2
3
4
5
6
7
8
Item
Lens Size
Focal Length
F/NO.
Field of View Angle
Distortion
Image Quality
Focusing Range
IR Filter
Specification
1/3.06 inch
2.04
2.4±5%
124.8°(D)/101.9°(H)/82.1°(V)±3°
<12.1%
Center≥1900 LW/PH;Corner≥1400 LW/PH
0.52m - ∞ (AT=1.6m)
BG
4
深圳市御光视觉科技有限公司
记录编号:072-220323
4. Sensor Electrical Specification
4.1 Absolute Maximum Ratings
4.2 Application Conditions
5
深圳市御光视觉科技有限公司
记录编号:072-220323
4.2.1 Sensor DC Characteristics
4.2.2 Sensor AC Characteristics
Input specifications are shown below when square-wave signal is input directly into the external
pin INCK
6
深圳市御光视觉科技有限公司
记录编号:072-220323
7
深圳市御光视觉科技有限公司
记录编号:072-220323
After start operation, the oscillation frequency of PLL output transits from 0 Hz to target frequency
then gradually become stable. The duration for oscillation frequency becomes within 5 % of the target
frequency is defined as “settling time”.
8
深圳市御光视觉科技有限公司
记录编号:072-220323
9
深圳市御光视觉科技有限公司
记录编号:072-220323
4.2.3 Optical Characteristic
For more information of sensor please refer to the IMX214-0AQH5-C specification.
10
深圳市御光视觉科技有限公司
记录编号:072-220323
5. Camera Module Configuration Specification
11
深圳市御光视觉科技有限公司
记录编号:072-220323
6. Camera Module PIN Description
Pin Number Name
Pin type
Function/Description
Pin 1#
XCLK
I
System input clock
Pin 2#
DGND
GND
Digital GND
Pin 3#
MDP0
O
MIPI TX clock positive output
Pin 4#
MDN0
O
MIPI TX data negative output
Pin 5#
DGND
GND
Digital GND
Pin 6#
MDN1
O
Pin 7#
MDP1
O
Pin 8#
DGND
GND
Digital GND
Pin 9#
MCN
O
Pin 10#
MCP
O
Pin 11#
DGND
GND
Digital GND
Pin 12#
NC
Pin 13#
NC
Pin 14#
AVDD2.8V
POWER
Supply voltage(analog)
Pin 15#
AGND
GND
Analog GND
Pin 16#
DVDD1.0V
POWER
Supply voltage(digital)
Pin 17#
DOVDD1.8V
POWER
Supply voltage(interface)
Pin 18#
DGND
GND
Digital GND
Pin 19#
SIO_C
I/O
I2C PIN
Pin 20#
SIO_D
I/O
I2C PIN
Pin 21#
RESET
I
System clear (active low)
Pin 22#
NC
Pin 23#
DVDD1.0V
POWER
Pin 24#
DGND
GND
Digital GND
Pin 25#
MDP3
O
Pin 26#
MDN3
O
Pin 27#
DGND
GND
Digital GND
12
深圳市御光视觉科技有限公司
记录编号:072-220323
Pin 28#
MDN2
O
Pin 29#
MDP2
O
MIPI TX data positive output
Pin 30#
DGND
GND
Digital GND
13
深圳市御光视觉科技有限公司
记录编号:072-220323
7. Reliability Test
No.
Test Item
Constant Temperate
and Humidity Storage
Test
Test Conditions
Temperate:60±3℃;
Humidity:90±3%RH;
Test duration: 96H
2
High Temperate
Storage Test
Temperate:80±3℃;
Test duration:96H
3
Low Temperate
Storage Test
Temperate:-40±3℃;
Test duration: 96H
4
High and Low
Temperate Shock
Test
5
High Temperate
Function Test
6
Low Temperate
Function Test
7
Constant Temperate
and Humidity
Function Test
1
8
9
10
Vibration Test
Drop Test
ESD TEST
High Temp.:80 ± 3℃;
Low Temp.:-40 ± 3℃;
Each Place Time:30min;
Number of Cycles:30
Temperate:60±3℃;
Test Duration:24H;
Max Work Voltage
Temperate:-20±3℃;
Test Duration:24H;
Max Work Voltage
Temperate:55±3℃;
Humidity:85%RH;
Test Duration:24H;
Max Work Voltage
Frequency Range:10-55-10Hz;
Amplitude: 2mm;
Test All 3 Axes (X, Y, Z);
Duration 30min for Each Axis
Floor:Concrete;
Height:150cm;
Clamp Weight:100g;
Positions:6 Surface;
Each Surface Drop 3 Times
8KV Contact Discharge
12KV Air Discharge
10 Times for Second
Judge Standard
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
No image distort
and good color
rendition.
14
深圳市御光视觉科技有限公司
记录编号:072-220323
8. Packaging
8.1 Packaging Process
1. Every module is placed into a tray until all empty slots of a tray are
filled. Each tray contains no more than 70 modules.
2. Each tray uses an anti-static bag to prevent the module from moisture by
partially socking out the air from the stack.
3. A stack has 10 trays.
4. Insert three stacks into a outside box. Then attach the label onto the
outside box.
8.2 Labeling
8.2.1 External box label
8.2.2 Internal case label
15
深圳市御光视觉科技有限公司
记录编号:072-220323
8.3 Sketch Map of Packing Process
Module
1 tray
Outbox
Vacuumize
Spacer(x3)
1 set=10 tray
3 set
16
深圳市御光视觉科技有限公司
记录编号:072-220323
9. Precautions
9.1 Storage and Operating Conditions
To keep the product and packaging material in good condition, care must be taken to
control temperature and humidity in the storage area.
Recommended conditions:
Ambient temperature: 0~+40℃
Humidity: 30~70%RH
No rapid change on temperature and humidity.
The products listed in this catalog are not designed for use under the following
conditions. Storage and/or usage under following conditions is prohibited.
1. Exposure to corrosive gas such as chlorine, hydrogen sulfide, ammonia,
sulfur dioxide, nitrogen oxide, etc.
2. Exposure to direct sunlight.
3. Exposure to dust.
4. Exposure to excessive moisture or wet locations.
5. Exposure to salt water or sea breezes.
6. Exposure to strong static electricity or electromagnetic waves.
9.2 Transportation and Handling
1. Minimize any mechanical vibration or shock and avoid dropping of the product
during transportation or dropping the product that contains the substrate.
2. Since the application of static electricity or over voltage may cause defect in
the product or deterioration of its reliability, caution must be taken against
exposure to any static electricity generated by electrified items such as
workbenches, soldering irons, tools, carrying containers, etc.
3. Caution shall be taken to avoid overstress to the product.
- END -
17
很抱歉,暂时无法提供与“WDN01A”相匹配的价格&库存,您可以联系我们找货
